Like Tree4Likes
  • 1 Post By kolosok17
  • 1 Post By Agent_Orange
  • 1 Post By JBR
  • 1 Post By alphasaur
 Old 01-17-2014, 10:53 PM   #1
kolosok17's Avatar
Posts: 1,104   (View Stats)
kolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the world
Groans: 47
Default Stage 2 OCC is empty - should I be worried?
I installed the JBR Stage 2 OCC on Christmas Eve by following the v2 instructions for the check valve positioning. Today, I checked it after 950 miles of driving mostly highway miles and absolutely nothing came out of the catch can. I have 17550 miles on the car. I searched around and saw that some folks had issues with other catch cans draining when the weather is cold, but I am in CA and it was 70 degrees today. Should I be worried?
Btw, the catch can feels like an extremely high quality product, just like all the other JBR stuff I have installed!
cciepunk likes this.
2012 CWP Non-Tech MS3
JBR SSB, Mazda Rear Bumper Guards, JBR Mud Flaps, JBR 88a RMM, Mazda All-Weather Floor Mats,
COBB AP V2B, JBR RSB with Tru-Torsion brackets, Autotech Internals, CorkSport SRI+TIP, JBR Stage 2 OCC,
Mazda Rear Cargo Tray, Stratified S-OTS+ Stage 1 Map, NATOR NorCal Sticker
kolosok17 is offline   Reply With Quote
 Old 01-18-2014, 10:26 AM   #2
timmcc02's Avatar
Posts: 253   (View Stats)
Groaned at 9 Times in 3 Posts
I have the same question as I've now driven about 4k miles with it installed and have had no oil drain out when I opened it up. Is the routing correct on the instructions? I also have stage 2 with check valve
 Old 01-18-2014, 07:28 PM   #3
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Your both in Cali and are experiencing little to no accumulation/drainage. Coincidence? I think not. If the ambient air temp. never falls to or below the dew point temp. condensation will not take place. This coupled with how a car is driven affects the accumulation you'll see. Lots of short trips with the oil not rising to full operating temp. will encourage condensation. The opposite is true if the car's oil regularly sees full op temp.
Just glanced at the weather out there for the past month or so. Your average lows were around the 45 degree area, while the dew points were in the mid to low 30's. So it's not even coming close to condensation.
JBR likes this.
The Following 5 Users Say Thank You to Agent_Orange For This Useful Post:
alphasaur (01-19-2014), JBR (01-19-2014), JeffroMS3 (02-22-2014), JgamB (01-18-2014), kolosok17 (01-18-2014)
 Old 01-19-2014, 07:18 AM   #4
This could not have been said any better. No oil is not a bad thing either. confirm the installation, fix it if necessary and enjoy.
Thanks,
Jamie
Agent_Orange likes this.
Agent_Orange (01-19-2014), econman (01-19-2014), kolosok17 (01-19-2014)
 Old 01-19-2014, 09:12 PM   #5
alphasaur's Avatar
Posts: 2,847   (View Stats)
Groans: 235
Bill fucking nye the science guy over here
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/lol nator.
The Following 2 Users Say Thank You to alphasaur For This Useful Post:
Agent_Orange (01-19-2014), thehead (02-22-2014)
 Old 01-18-2014, 10:28 AM   #6
JgamB's Avatar
Posts: 2,566   (View Stats)
The arrow is pointing toward your throttle body on the check valve? Double check, I've seen a dry catch can due to backward installation.
The one I recently helped drain needed a love tap to get the flow started, but once it did it let loose about 1oz of condensation that was pretty clear, and then about 2oz of yellow snot came out at progressively faster drainage rates. That was from 3k miles or less afaik.
The Following 3 Users Say Thank You to JgamB For This Useful Post:
chaser27 (01-19-2014), Easter Bunny (01-18-2014), kolosok17 (01-18-2014)
 Old 01-18-2014, 11:34 AM   #7
kolosok17's Avatar
Groans: 47
Yup, the arrow is pointing toward the intake side of where the original PCV hose was, just like the instructions state. I'll try the tap method.
 Old 01-18-2014, 05:55 PM   #8
kolosok17's Avatar
Groans: 47
Tried draining after driving around for a bit to get everything warmed up. Nothing came out, not even after tapping. My next oil change is in over 1k miles, so I'll try again then. If nothing drains out, I gotta buy me some ramps.
 Old 01-18-2014, 05:57 PM   #9
jseams's Avatar
Posts: 1,414   (View Stats)
jseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the world
I have a pair of rhino ramps I can give you... however, be warned. They can be tricky to use as I accidentally shot them under my car once.
... or you can borrow my race ramps, which are much easier to use. I even have the extensions if you decide to drop your car a bit.
CRMetallic 2019 Mercedes C43 AMG
SOLD MNBlue 2012 S4 Prestige... a few mods
SOLD IB 2015 3.8 Gencoupe Ultimate
BLOWED UP DIB 2014 Mustang 5.0... a few mods
SOLD - LS 2012 MS3
Cobb AP//SF//CAB
Autotech HPFP
Corksport TMIC//BPV//TIP//BTbs
JBR 88a RMM
Sure M3 TP
OBX CBE
Tanabe NF210's
ADVAN RG-D 18x8 +38
Freektuned 50/50 E85
jseams is offline   Reply With Quote
 Old 01-18-2014, 06:03 PM   #10
kolosok17's Avatar
Groans: 47
Yeah I'm a bit scared to use the rhinos after reading some reviews about them. Would love to borrow the race ramps maybe late February. I ain't dropping my car - too lazy to care about hitting curbs when parking.
Which length of race ramps do you have? I might buy some for long term stuff. Would these be the appropriate size?
Race Ramps RR-56-2 56" Race Ramp - 2 Piece : Amazon.com : AutomotiveRace Ramps RR-56-2 56" Race Ramp - 2 Piece : Amazon.com : Automotive
I also own these:
Race Ramps RR-WC Rubber Wheel Chock - Set of 4 : Amazon.com : AutomotiveRace Ramps RR-WC Rubber Wheel Chock - Set of 4 : Amazon.com : Automotive
Edit: Why do things cost so much money? Now you have me really wanting a new tmic, race pipe, and tune...
 Old 01-18-2014, 06:11 PM   #11
jseams's Avatar
@kolosok17, I have the Race Ramps RR-XT-2 67-Inch XT 2-Piece Race Ramps and the Race Ramps RR-EX-14 67" Xtenders.
Race Ramps RR-XT-2 67-Inch XT 2-Piece Race Ramp : Amazon.com : AutomotiveRace Ramps RR-XT-2 67-Inch XT 2-Piece Race Ramp : Amazon.com : Automotive
Amazon.com: Race Ramps RR-EX-14 67" Xtender: AutomotiveAmazon.com: Race Ramps RR-EX-14 67" Xtender: Automotive
You are welcome to borrow them any time you need them.
SOLD - LS 2012 MS3
Cobb AP//SF//CAB
Autotech HPFP
JBR 88a RMM
Sure M3 TP
OBX CBE
Tanabe NF210's
ADVAN RG-D 18x8 +38
The Following 2 Users Say Thank You to jseams For This Useful Post:
kolosok17 (01-18-2014), sidekick (01-19-2014)
 Old 01-18-2014, 06:12 PM   #12
kolosok17's Avatar
Groans: 47
Bah, you have issues getting on the 67" one without the extender? Jesus.
The Following User Says Thank You to kolosok17 For This Useful Post:
jseams (01-18-2014)
 Old 01-18-2014, 06:25 PM   #13
Hush's Avatar
Posts: 520   (View Stats)
Hush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the world
Groans: 156
If you are not sure if your OCC is plumbed right, you can check it by turning the car on, and while it is idling, open the OCC valve, put your finger over the OCC drain opening. It should suck your finger.
-2012 CWP MS3 -
- COBB AP V2b - Autotech HPFP Internals - JBR 3.0 WP - CP-E TMIC - UR TP - NGK ILTR6A-8G # 3787 plugs - EGR delete - Bosch 3-bar TMap - DO WMI 50/50
- JBR RMM 88a - JBR PMM 70a + JBR TMM 70a - JBR OCC S2 - JBR SSP - JBR SSB - JBR RSB -
- Block8head single defrost pod - VDO Vision Boost Gauge - Maisonvi Custom Stainless Steel Ball Shift Knob -
- Self Tuning 91 octane of fail with 50/50 WMI of win -
Hush is offline   Reply With Quote
The Following 5 Users Say Thank You to Hush For This Useful Post:
5doorsoffury (01-19-2014), Agent_Orange (01-18-2014), ItsNox (02-10-2014), kolosok17 (01-18-2014), SeeMeGovan (01-18-2014)
 Old 01-19-2014, 08:10 AM   #14
Hanzodurrr's Avatar
Posts: 240   (View Stats)
Hanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the worldHanzodurrr is the leader of the world
Just takes time depending on driving/weather conditions. I didn't get much of anything until I put around 15k miles and 3 seasons on my OCC. Then I got like 10oz of nasty.
JBR Wrinkly Black Dong//CX FMIC w/Wrinkle black piping//PPT Tune//Autotech HPFP//Corksport Springs//TWM Full Replacement//JBR 88tmm 88rmm 80pmm//JBR OCC//JBR EGR delete//JBR TIG//GFB 100% Rice to Air//TB bypass// Kozmic Vband DP//CP-E ExMani//PTE 5558//Stoptech Power Slots all around//Stoptech SS lines//EBC Yellows//
BLEW UP AUG 2014
Aug 2015 SP63 Long Block coming soon!!!
Hanzodurrr is offline   Reply With Quote
The Following 2 Users Say Thank You to Hanzodurrr For This Useful Post:
kolosok17 (01-19-2014), LatinKraze (01-19-2014)
 Old 01-19-2014, 11:19 AM   #15
kolosok17's Avatar
Groans: 47
Just checked for suction from the drain with the engine on and yup - it's there. If the check valve is facing the wrong way, what could happen? I don't think it is but will verify.
 Old 01-19-2014, 12:02 PM   #16
LatinKraze's Avatar
Posts: 804   (View Stats)
Took about 6k miles (two oil changes) to see anything in my JBR OCC. Don't worry about it
2016 CX-5 GT AWD
The Following User Says Thank You to LatinKraze For This Useful Post:
 Old 01-19-2014, 02:49 PM   #17
ear28's Avatar
Posts: 203   (View Stats)
ear28 is the leader of the worldear28 is the leader of the worldear28 is the leader of the worldear28 is the leader of the worldear28 is the leader of the worldear28 is the leader of the worldear28 is the leader of the worldear28 is the leader of the worldear28 is the leader of the worldear28 is the leader of the worldear28 is the leader of the world
OP, also make sure there is no sag in the lines to and fro the OCC. That's what helped me.
2014 Tundra CM TSS
Sold 2012 LSM MS3
ear28 is offline   Reply With Quote
The Following 2 Users Say Thank You to ear28 For This Useful Post:
Agent_Orange (01-19-2014), kolosok17 (01-19-2014)
 Old 01-19-2014, 03:13 PM   #18
kolosok17's Avatar
Groans: 47
I think there's some sag, but very little. I used the full length of the provided hose. I'm going to wait a couple thousand more miles and if nothing is in the can, I'll try shortening the lines to reduce sag to 0. Thanks!
 Old 01-19-2014, 04:10 PM   #19
If you used the full length of the hoses there's definitely some sagging.
 Old 01-19-2014, 04:12 PM   #20
timmcc02's Avatar
I still have some sag and I took off way more that the instructions recommended. Next time I get under it I'm gonna recheck the valve and cut some hose off
 Old 01-19-2014, 04:36 PM   #21
We include a fair amount of extra hose for various configurations.
 Old 01-19-2014, 09:06 PM   #22
kolosok17's Avatar
Groans: 47
Hmm, it seemed to be a fairly smooth curve when I routed it. I'll make sure to check again. How much would you estimate I would need to cut off for a genpu? Is there an easy way to test against sagging?
 Old 01-25-2014, 09:01 AM   #23
timmcc02's Avatar
So i checked finally and found I installed the check valve backwards like a retard. switched it back around. Would this cause any drivability issues? car running rich?
 Old 01-27-2014, 02:08 PM   #24
JgamB's Avatar
Not sure I'd recommend a PCV delete like that but I know someone that ran his for almost 30k miles backward to no ill effect, compression test was 190 across the board on a 65K mile motor.
He expected to have to re-tune for the added metered air, but it wasn't significant at all, and once the check valve was corrected it was confirmed nothing had gummed up in the lines off the block and it drained fine.
One anecdotal situation might not be the norm, just watch your fuel trims.
ItsNox (02-10-2014)
 Old 01-27-2014, 12:52 PM   #25
swsmailman's Avatar
Posts: 1,118   (View Stats)
I have one of these that will be installed this weekend at the same time I do an oil change. Going to have to double check the instructions and so forth.
I will say I have some rhino ramps, used them last night and they suck just on concrete, I fixed the problem and made it even better by using a large piece of carpeting to go under both of them at the same time. Was so much easier, plus was nice and comfy and not cold while I was under the car checking the RSB installation.
2013 Liquid Silver MazdaSpeed
kolosok17 (01-27-2014)
 Old 01-27-2014, 03:22 PM   #26
timmcc02's Avatar
Ya my fuel trims adjusted slightly after switching it around but nothing crazy
 Old 01-27-2014, 10:46 PM   #27
gmoney542's Avatar
Posts: 236   (View Stats)
gmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the worldgmoney542 is the leader of the world
I checked my catch can for the first time the other day after ~400 miles and nothing came out. I rechecked everything and it was all good. I guess I'll just wait and recheck it when I change the oil.
2009 CWP Mazdaspeed3
- COBB AP V3 - Richtune - 50/50 E85 - Autotech HPFP Internals - CNT Catless Downpipe - HTP 3" Intake - NGK One Step Colder Plugs -
- Kozmic Motorsports EGR Deletes - JBR 88 RMM/TMM/PMM - JBR Shifter Bushings - JBR TIG + Coolant Bypass - JBR OCC -
- JBR RSB - GroundControl Coilovers - CorkSport Camber Plates - CorkSport Rear Camber Arms - CorkSport Rear Toe Arms -
- WhiteLine Front Endlinks - WhiteLine Bumpsteer Kit - WhiteLine Poly LCA Bushings - AWR Rear Endlinks -
- 18x8 Mazdaspeed MS-01S - Nitto NT05 245/40/18 -
gmoney542 is offline   Reply With Quote
 Old 01-28-2014, 08:26 AM   #28
Could be frozen too.
 Old 02-22-2014, 10:22 AM   #29
kolosok17's Avatar
Groans: 47
Chicken soup, anyone?
Finally, a drain after 1500 miles.
Oil Catch Can Empty Monkey_3 MazdaSpeed 3 - Engine, Transmission & Driveline 14 05-05-2013 12:38 PM
Empty OCC? wdautrem MazdaSpeed 3/6 - Turbo Induction 5 04-30-2012 01:43 PM
Need advice with empty package from KMD dpolseno41 Mazdaspeed3/6 General Discussion 8 03-30-2012 07:46 PM
empty tube E.M.S. MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 04-27-2010 12:47 PM
A cartoonist's take on empty showrooms Haltech Automotive News 1 02-23-2009 01:59 PM
Page generated in 0.58253 seconds with 32 queries
