 Old 04-03-2014, 10:19 AM   #1
scapone4's Avatar
Posts: 179   (View Stats)
scapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud ofscapone4 has much to be proud of
Default Stage 2 SRI Installed
Just got done installing the JBR stage 2 and flashed the Stratified OTS. Install wasn't too bad with mediocre mechanic skills.
Question: It is very audible which I like. I so feel as if it has a very slight whistling noise to it. I haven't gone WOT yet with fear I have a leak somewhere. Is this very slight whistling normal?
scapone4 is offline   Reply With Quote
 Old 04-03-2014, 10:26 AM   #2
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
It's probably normal noise. Your just not used to actually hearing the turbo spool.
Put about 30 miles on that flash and go rip a WOT log or 2 and post em up in the tuning section. We'll be able to see if it's a leak or not.
scapone4 (04-03-2014)
 Old 04-03-2014, 10:27 AM   #3
scapone4's Avatar
Will do. Thanks orange you're the man
The Following User Says Thank You to scapone4 For This Useful Post:
Agent_Orange (04-03-2014)
 Old 04-03-2014, 12:56 PM   #4
Chief_Wiggum's Avatar
Posts: 419   (View Stats)
I get what I'd call a 'whistle' from air being sucked through the filter...totally normal (and awesome).
 Old 04-03-2014, 03:10 PM   #5
XerocX's Avatar
Posts: 1,093   (View Stats)
XerocX is the leader of the worldXerocX is the leader of the worldXerocX is the leader of the worldXerocX is the leader of the worldXerocX is the leader of the worldXerocX is the leader of the worldXerocX is the leader of the worldXerocX is the leader of the worldXerocX is the leader of the worldXerocX is the leader of the worldXerocX is the leader of the world
Hmmm, the JBR Power Path Stage II Intake or the Wide path 3" intake. I'm still on the Ko4 though.
2009 CWP MS3
COBB Accessport, COBB Adjustable STS, JBR Dog bone, JBR RSB, JBR SSB, CS 3", PG FMIC, Autotech internals, HKS SSQV, CNT Catless DP + CBE, H&R Springs, CPE tow plate,
XerocX is offline   Reply With Quote
 Old 04-04-2014, 06:26 AM   #6
scapone4's Avatar
Just did my first log. Third gear, road was little wet, traction control off. ANy info would be appreciated. Thanks
 Old 04-05-2014, 04:00 PM   #7
frequencysurfer's Avatar
Posts: 232   (View Stats)
frequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the worldfrequencysurfer is the leader of the world
Uh, did you bury the pedal at ~2300 rpm? Don't got WOT until right around 3k RPM. Otherwise, I think it looks ok to my untrained eye...
Last edited by frequencysurfer; 04-05-2014 at 04:01 PM. Reason: MSF Database - Automerged Doublepost
frequencysurfer is offline   Reply With Quote
BNR STAGE 3 INSTALLED... beno72 2010 MS3 - Big Turbo Builds 44 03-25-2015 06:09 PM
Snow stage 2 meth kit installed Mikey MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 16 04-02-2014 09:31 PM
New Southbend Clutch Stage 3 to be installed! Matrix311 MazdaSpeed 3 - Engine, Transmission & Driveline 36 09-03-2013 11:58 AM
Installed HPFP and loaded stage 2 log kritz 2010 MS3 - ECU Computer Tuning 4 09-20-2011 12:26 PM
Devils Own Stage 2 Meth Installed aaronc7 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 59 03-10-2009 03:06 PM
Page generated in 0.27785 seconds with 25 queries
