Like Tree3Likes
  • 1 Post By JBR
  • 1 Post By flyhigh
  • 1 Post By MSP6
 Old 12-28-2016, 10:34 AM   #1
Exclamation Who's tired of broken yellow zink sway bar brackets?
Who wants inexpensive high quality replacement bracket and bushing kits that will never rust or break and carry a lifetime warranty? Look no further!! JBR now has our own line of replacement sway bar bushings and brackets for most all aftermarket front and rear sway bars. We also stock replacements for many OEM sway bars too!!
Did we mention these are warrantied for life and guaranteed never to rust or break??!!
If this wasn't already pretty awesome, these are now the standard bushings and brackets included with EVERY JBR sway bar kit. We know how tired everyone is having to replace broken sway bar brackets every year. NO MORE!!
Details:
No more cheap, rusted and broken yellow zinc coated sway bar brackets. JBR Sway Bar Bushings and Bracket kits are the toughest in the industry!
First, they're laser cut out of .180" thick stainless stainless steel which will never rust. This is nearly twice as thick as the typical bracket. They're then die formed using our own proprietary tooling that guarantees a perfect fit every time.
After forming, each bracket is then tapped to accept a grease fitting making maintenance simple and easy.
Included with every pair of JBR brackets are a set of 90a durometer bushings available in the most common OEM and aftermarket sizes.
Once you have these installed, you'll never need to replace your sway bar brackets or bushings again.
Available Applications:
  • 2013+ Ford Focus ST OEM Rear
  • 2004-2009 Mazdaspeed 3 OEM Front & Rear
  • 2010-2013 Mazdaspeed 3 OEM Front
  • 2010-2013 Mazdaspeed 3 OEM Rear
  • 2004-2009 Mazda 3 OEM Front & Rear
  • 2010-2013 Mazda 3 OEM Front
  • 2010-2013 Mazda 3 OEM Rear
  • 2014+ Mazda 3 OEM Front
  • 2014+ Mazda 3 OEM Rear
  • 2006-2014 Mazda 5 OEM Front & Rear
  • 2013+ Mazda CX-5 OEM Front
  • 2013+ Mazda CX-5 OEM Rear
  • 2014+ Mazda 6 OEM Front
  • 2014+ Mazda 6 OEM Rear
  • 1.250" (32mm) Aftermarket Rear Sway Bars
  • 1.125" (28.5mm) Aftermarket Rear Sway Bars
Don't see your application? Contact us, we probably have it.
Features:
  • Designed and manufactured in the USA
  • Stainless steel die formed construction
  • 90 durometer bushings
The JBR Tru-Torsion Sway Bar Bracket Kit Includes:
  • 2 Stainless sway bar brackets with grease fittings
  • 2 New 90 durometer polyurethane bushings
  • Lifetime warranty
ryguy 3 likes this.
Code Monkey (12-28-2016), mazdaspeedmyk (12-30-2016), redneck4Christ (12-29-2016), [R]usty (12-28-2016)
 Old 12-28-2016, 10:54 AM   #2
[R]usty's Avatar
Posts: 2,204   (View Stats)
Good price point. Will get these if my prothane brackets break.
2010 Mazdaspeed3 w/tech
kolosok17 (12-28-2016)
 Old 12-28-2016, 11:33 AM   #3
kolosok17's Avatar
Posts: 1,104   (View Stats)
kolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the world
Groans: 47
Nice! Ditto on what Rusty said. The sway bar has been squeaking lately, perhaps I should have a look down there.
2012 CWP Non-Tech MS3
JBR SSB, Mazda Rear Bumper Guards, JBR Mud Flaps, JBR 88a RMM, Mazda All-Weather Floor Mats,
COBB AP V2B, JBR RSB with Tru-Torsion brackets, Autotech Internals, CorkSport SRI+TIP, JBR Stage 2 OCC,
Mazda Rear Cargo Tray, Stratified S-OTS+ Stage 1 Map, NATOR NorCal Sticker
kolosok17 is offline   Reply With Quote
 Old 12-29-2016, 01:23 PM   #4
flyhigh's Avatar
Posts: 218   (View Stats)
flyhigh has a reputation beyond reputeflyhigh has a reputation beyond reputeflyhigh has a reputation beyond reputeflyhigh has a reputation beyond reputeflyhigh has a reputation beyond reputeflyhigh has a reputation beyond reputeflyhigh has a reputation beyond reputeflyhigh has a reputation beyond reputeflyhigh has a reputation beyond reputeflyhigh has a reputation beyond reputeflyhigh has a reputation beyond repute
Thanks for making these standard with new purchases.
JBR likes this.
12' black mica w/tech: BNR S4 V2; CM STG 2 WMI; DAMOND TB SPACER; GUARDIAN ANGEL V3; KOZMIC OCC; CP-E SAFE SEALS; DAMOND EGR DELETE; WHITEWIDOW INTAKE GASKET; Cobb AP V3 CP-E Xcel XL SRI; CP-E 4" TIP; CP-E Catted DP; CP-E Cat-back exhaust; CP-E TMIC; Cobb BPV; JBR EBCS; Cobb RMM; CorkSport HPFP internals; JBR turbo hoses; NGK (6510) LTR7IX-11 Iridium IX Spark Plugs; JBR short shifter; JBR Small battery tray; Optima 51r Battery
Rice--CorkSport interior lights and carbon fiber hood scoop
ETH/METH tune by Stratified in progress
flyhigh is offline   Reply With Quote
The Following User Says Thank You to flyhigh For This Useful Post:
JBR (12-29-2016)
 Old 12-30-2016, 11:34 AM   #5
MSP6's Avatar
Posts: 1,246   (View Stats)
Are you shitting my face right now...I just replaced the bushing/brackets Front and rear like a month ago..Doh! Looks good, will buy in future when my knuckles have healed from the last go around.
JBR likes this.
 Old 08-26-2018, 09:35 PM   #6
kolosok17's Avatar
Groans: 47
What size should I order for:
Rear Sway Bar Kit - Black
Item# MS3RSB-BLK
The 1.125"/28.5mm ones?
 Old 08-27-2018, 08:01 AM   #7
Item# MS3RSB-BLK
No, our rear sway bar is 1.25"/32mm as indicated in the drop down.
 Old 08-27-2018, 09:37 AM   #8
kolosok17's Avatar
Groans: 47
Thanks, Jamie! Going to put in an order. The original ones finally failed.
New Product Release - JBR Tru-Torsion Billet Sway Bar Brackets and Bushings JBR JAMES BARONE RACING 87 01-24-2015 05:35 PM
JBR Rear Sway, Brackets, MOOG End-Link Fitment Issue Teal JAMES BARONE RACING 9 09-23-2014 06:39 PM
How many MS6's are tired of broken axles? 2nr MazdaSpeed 3 - Engine, Transmission & Driveline 13 10-25-2008 07:29 AM
Page generated in 0.28802 seconds with 25 queries
