 Old 12-23-2010, 10:09 PM   #1
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
Default 3071 and a strang studder
So this problem just started on me. When i go to boost the car sarts to studder and its like brrrrrrrrrrrrrrrr and your rolling the "r"s on the top of your mouth. Im leaning towards maybe spark plugs. It drives great as long as im not loading the car. Im running the Grimspeed 3 port set up and cobbs new stage 2 map.
I have also been toying wih the idea of putting a mbc in for the GS. My friend has a new turboxs mbc in the box. ideas there?
06 Speed6 GT- Sold
 Old 12-23-2010, 10:11 PM   #2
spoolin00's Avatar
Posts: 497   (View Stats)
spoolin00 is the leader of the worldspoolin00 is the leader of the worldspoolin00 is the leader of the worldspoolin00 is the leader of the worldspoolin00 is the leader of the worldspoolin00 is the leader of the worldspoolin00 is the leader of the worldspoolin00 is the leader of the worldspoolin00 is the leader of the worldspoolin00 is the leader of the worldspoolin00 is the leader of the world
I cant roll my r's...so I'm having trouble diagnosing the problem.
Good luck though.
-2006 BCM Speed6
--SRI
I'm hoping this turbo is big enough to bring sea level to me.
spoolin00 is offline   Reply With Quote
The Following 4 Users Say Thank You to spoolin00 For This Useful Post:
FreeFlyFreak (12-24-2010), predapio (12-28-2010), wankular (12-28-2010), xcoldricex (12-28-2010)
 Old 12-23-2010, 10:14 PM   #3
bcmurphy87's Avatar
i just ment its a hella of a studder like its holding back lol
06 Speed6 GT- Sold
 Old 12-23-2010, 10:22 PM   #4
bmylez's Avatar
Posts: 3,197   (View Stats)
Sure, check the plugs. If they look good, test the coils.
 Old 12-23-2010, 11:46 PM   #5
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
its not compressor surge right?
post some logs man so we can take a look......
easy (12-24-2010), MS3-a(sore)ASS-rex (12-23-2010)
 Old 12-23-2010, 11:54 PM   #6
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Logs please...
NATOR PA
 Old 12-23-2010, 11:58 PM   #7
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
how do you test coils ??
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 12-24-2010, 12:02 AM   #8
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
I stick mine in my butthole.
The Following 9 Users Say Thank You to madvillain For This Useful Post:
easy (12-24-2010), FreeFlyFreak (12-24-2010), rigor (12-24-2010), spiker98 (01-27-2011), spnkr21 (01-27-2011), spoolin00 (12-25-2010), turd burglar (12-25-2010), wankular (12-28-2010), xcoldricex (12-28-2010)
 Old 12-24-2010, 12:19 AM   #9
bmylez's Avatar
Give them to your friend and try them out on his car
 Old 12-24-2010, 05:50 AM   #10
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
is it richer due to the cold weather? that will cause a missfire...
logs
at 104000 2 bent rods
tuned by nishan
 Old 12-24-2010, 09:15 AM   #11
bcmurphy87's Avatar
Ok thanks ill get some logs this morning
06 Speed6 GT- Sold
 Old 12-24-2010, 10:46 AM   #12
bcmurphy87's Avatar
ok i have two logs the first seems to have not turned off lol. But now its not studdering its just over boosting lol.
06 Speed6 GT- Sold
 Old 12-24-2010, 11:19 AM   #13
bmylez's Avatar
S&G Tool Aid 23950 COIL ON PLUG IGNITION SPARK CHECKER
Just in case you actually wanted to test your COPs.
 Old 12-24-2010, 01:26 PM   #14
acidbbg's Avatar
Posts: 208   (View Stats)
acidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud ofacidbbg has much to be proud of
Based on you logs and what you posted...
Your probably hitting fuel cut. Do you have upgraded cdfp?
Your di fuel pressure looks like $hit.
You should be holding 16-1800psi but you can see from the attachment, your di fuel pressure drops to ~500psi.
Time to give CPE or KMD a call for Cam Driven Fuel Pump internals.
I recommend you stay away from WOT for time being.
All content created by this user is for entertainment purposes only.
Mods: Wouldn't you like to know
acidbbg is offline   Reply With Quote
 Old 12-24-2010, 08:21 PM   #15
bcmurphy87's Avatar
Well what would make the boost over boost so hard. The boost needle wants to shoot up to like 25. I know it cost to play but those internals are steep lol.
06 Speed6 GT- Sold
 Old 12-24-2010, 09:13 PM   #16
acidbbg's Avatar
$400 for internals is allot cheaper than $6k+ for a new motor.
If you can't afford upgraded CDFP internals, I would suggest you work on lowering boost down ASAP so that you don't grenade the motor before you get the cdfp internals installed.
What are u using to control boost? MBC/EBC?
Check out the link below...It maybe helpful.
MY ATR Journey...
 Old 12-24-2010, 09:41 PM   #17
bcmurphy87's Avatar
I can afford the internals just have to wait till after chirstmas. Im running AP stage 2 map w/ a Grimspeed in 3 port mode, i lowered the duty cycle by 30%. Im thinking im going to switch to the my Turboxs mbc until i get a protune and the internals. Also the 3071 is set up with the IWG.
06 Speed6 GT- Sold
 Old 12-24-2010, 09:57 PM   #18
m4tic's Avatar
Posts: 4,928   (View Stats)
why the fuck dont you have a fuel pump upgrade with a big turbo
all bad
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
The Following 4 Users Say Thank You to m4tic For This Useful Post:
Danish (01-27-2011), MPSdriver (12-27-2010), rigor (12-27-2010), the_caruch (12-27-2010)
 Old 12-24-2010, 10:01 PM   #19
bcmurphy87's Avatar
Well funny story i was happy with my pg k04 then i had a 3071 fall into my lap. So wasnt really planned
06 Speed6 GT- Sold
 Old 12-24-2010, 10:07 PM   #20
m4tic's Avatar
sorry i didnt mean to be cross....
umm please get that fixed
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 12-25-2010, 08:11 PM   #21
bcmurphy87's Avatar
I cant find the KMD internals for the mazda pump any ideas? Hard to search from the blackberry
06 Speed6 GT- Sold
 Old 12-25-2010, 08:21 PM   #22
bmylez's Avatar
Here's PTP: Protege Garage - PTP Fuel Pump Internals Kit - 2.3 DISI
The Following User Says NO Thank You to bmylez For This Un-useful Post:
turd burglar (12-26-2010)
 Old 12-25-2010, 08:33 PM   #23
acidbbg's Avatar
Here's the link for KMD's site:
KMD Tuning - KMD V2.1 FSI Fuel Pump Kit w/ Armoloy Coating
They are listed for audi/vw's but they will work 100% on the speed3/6 & cx-7 cdfp.
p.s. I would be cautious when purchasing any products with the name ptp.
 Old 12-25-2010, 08:38 PM   #24
bcmurphy87's Avatar
im all for kmd, no need for ptp. thanks gents
06 Speed6 GT- Sold
 Old 12-26-2010, 11:21 AM   #25
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
jesus man, looking at that last log wtf wtf wtf
seriously hear me out, if you dont get a) fuel pump upgrade and b) an actual solid tune ....you are gonna grenade your motor man....
i see low fuel pressure, inconsistent AFR, inconsistent boost, 6 point of KR, super high loads for a stock bottom end...... do what you want but I am telling you, if u keep driving that car as is I guaranteee that you will have shrapnel real soon.
rigor (12-27-2010), spnkr21 (01-27-2011)
 Old 12-26-2010, 09:51 PM   #26
bcmurphy87's Avatar
Im confused right now. Im buying the KMD internals first thing in the morning but i dont understand why im seeing shit tons of knock at random times. Here are a few more logs of me not boosting but getting random knock. Im just using a ots stage 2 map. I did reduce the wgdc by 50%. It wasn't doing this when it was warm, could the cold really be ruining my life this much?
File Type: csv datalog11.csv (812 Bytes, 5 views)
06 Speed6 GT- Sold
 Old 12-26-2010, 10:15 PM   #27
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
what are u running? AP and mbc, ebc or just oem bc?
that part throttle KR is it within the first 15 min of the car warming up ??
u gotta be careful because if that is real knock u are playing with fire.
rigor (12-27-2010)
 Old 12-26-2010, 10:24 PM   #28
bcmurphy87's Avatar
KMDS ON THE WAY, hope this helps
Lenny those logs are from cruising down the interstate in 6th gear. im running a Cobb stage 2 map. and for boost im using the grimspeed in 3 port mode.
06 Speed6 GT- Sold
Last edited by bcmurphy87; 12-26-2010 at 10:24 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-26-2010, 10:33 PM   #29
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
ok but is that like within the first 15 minutes of driving and shit??? cuz usually around 3k we all get phantom KR... which I wouldnt worry about.... do me a favor ....next time u log that... leave the foot on the gas at the same position and does it go 6.0, 5.5, 4.9, 3.7, etc etc etc until it hits 0????
cuz thats what pretty much all ap cars do when its warming up. mine though doesnt do it anymore ever since i swapped the 3071 in there
 Old 12-26-2010, 10:35 PM   #30
acidbbg's Avatar
What octane do you have available in your location?
Stupid question, but are you using the correct octane map?
What spark plugs are you running? OEM? What are they gapped at?
Based on your mods, I would recommend running 1 step colder plugs.
Or at least that's what recommend by Cobb.
Not sure on the gap..but I am sure you can find if you search.
IMHO, what's happening is that the colder weather is causing your OEM CDFP pump to work harder than it was during the warmer temps (spring/summer). Which is causing it to fail.
I have seen this many times on the forums. Add the leaner a/f and you have your knock and potential for ZoomZoom Boom.
 Old 12-26-2010, 10:40 PM   #31
bcmurphy87's Avatar
No those maps were from cruising for over 30mins. Im running 93 octane with denso step 2 colder.
I usally see .3, .7, 1.3, 5.4, 7.1 the highest i have saw 8.1. It normally climbs so i left off.
06 Speed6 GT- Sold
 Old 12-26-2010, 11:28 PM   #32
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
if its out of boost... check for leaks and if u have none its the AP... its phantom KR... i wouldnt worry about it unless u are in boost and higher loads....
u dont hear pinging i assume?
 Old 12-26-2010, 11:48 PM   #33
bcmurphy87's Avatar
no i dont hear pinging but you guys have me scared to death now. It just stumbles a lot. I hope its just the fuel
06 Speed6 GT- Sold
 Old 12-26-2010, 11:53 PM   #34
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
after u put the kmd s if it persits change maps
 Old 12-27-2010, 01:25 AM   #35
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
I'm wondering if the combination of cold weather and TWO step colder plugs is causing the problem...
rigor (12-27-2010)
 Old 12-27-2010, 01:35 AM   #36
hnda etr's Avatar
Groans: 90
From here:
http://www.ngksparkplugs.com/tech_su...k_plugs/p2.asp
If the selected spark plug heat range is too cold, the spark plug may begin to foul when the engine speed is low or when operating in cold conditions with rich air-fuel mixtures. In some cases, the insulator nose can usually be cleaned by operating the engine at higher speeds in order to reach the self-cleaning temperature. If the spark plug has completely fouled, and the engine will not operate correctly, the spark plug may need to be cleaned / replaced and the fouling cause identified.
rigor (12-27-2010)
 Old 12-27-2010, 06:06 AM   #37
rigor's Avatar
Groans: 40
the fuel pump, you will feel a difference! and it will run smoother, no more wot till you get them!
spring stretch, 1 step colder..
if your missing it will show as kr..
the pump may clear up the kr...
good luck!
tuned by nishan
 Old 12-27-2010, 08:35 AM   #38
bcmurphy87's Avatar
Thanks guys, i got the hint ill order a new set of one step colder
06 Speed6 GT- Sold
 Old 12-27-2010, 01:37 PM   #39
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
fuck step colder plugs.... use meth/water to control combustion temps and run the stockers
stockers > densos
nutsac76 (12-28-2010), spnkr21 (01-27-2011)
 Old 12-28-2010, 11:08 AM   #40
bcmurphy87's Avatar
I need KMD internals and there out of stock. any where else i can order them? Im not buying anything with PTP's name on it or associated with it.
KMD Tuning Fuel Pump Kit w/ Armology Coating; VW & Audi - eBay (item 120654882083 end time Dec-31-10 13:55:00 PST)
Are these the same ones for our vehicle?
06 Speed6 GT- Sold
Last edited by bcmurphy87; 12-28-2010 at 11:08 AM. Reason: MSF Database - Automerged Doublepost
3071 HOW TO: MSP6COP MazdaSpeed 6 - How-To's 59 08-22-2011 02:37 AM
3" catback for 3071 setup? zx2man MazdaSpeed 3/6 - Turbo Induction 1 05-30-2010 07:03 PM
altitude and my 3071 djuosnteisn MazdaSpeed 3/6 - Turbo Induction 0 08-13-2009 01:22 PM
3071 with stock mani logs djuosnteisn MazdaSpeed 3/6 - Turbo Induction 25 07-04-2009 04:26 PM
Page generated in 0.62491 seconds with 31 queries
