Like Tree8Likes
 Old 08-09-2012, 12:51 PM   #41
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
Originally Posted by spnkr21 View Post
If I was you I'd put heat sleeves on all your coolant lines. After awhile the heat bakes the lines and they get really hard and brittle. Too bad I saw this thread after you got fluids flowing lol. But, it's def a must that will save headache down the road.
Yea I've been thinking about that. I'm slightly pissed that I didn't just use the same hose as the oil drain. Will definitely have to do something. Any suggestions for heat sleeves?
Originally Posted by mayer View Post
I also got the 7psi one and it was welded just like yours, which it just stupid. ATP had to send a new actuator complete with bracket and all. I think a new one complete with bracket is like 140 bucks or something from ATP...
Edit: Checked and it's 145$...
Actuator and matching bracket used on Mazdaspeed kit : atpturbo.com
Fuckers. Who would even want that light of a spring? Too bad I bought it second hand...
'08 CWP MS3 w/ T3 3071r
 Old 08-09-2012, 02:04 PM   #42
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
Yeah dei I think? Fuckin auto zone should have it, cut to fit. You probably only need 6-10" on each line, just enough to protect it from the turbo heat.
2012 WRX HB w/mudflaps yo!
NJSPEED3 (08-09-2012)
 Old 08-10-2012, 02:59 PM   #43
rabble rabble
802MS3's Avatar
Groans: 221
amazon has 36" of the DEI velco wrap for $30. The non velcro is only $14 for the same length. I also have heat reflective tape, but that would prob just make a mess.
 Old 08-10-2012, 03:43 PM   #44
spnkr21's Avatar
Groans: 105
Velcro you wouldn't have to undo everything...
 Old 08-11-2012, 01:53 PM   #45
rabble rabble
802MS3's Avatar
Groans: 221
preloaded the wastegate arm as much as possible and now I spike to 18, and flucuate between 16-18. blah.
I will get a log after this rain is done.
 Old 08-14-2012, 07:05 PM   #46
rabble rabble
802MS3's Avatar
Groans: 221
some shitty logs
https://docs.google.com/spreadsheet/...lhuSk1FcDhLOWc
https://docs.google.com/spreadsheet/...Fo0UFh6QXhKbUE
how come no one uses google docs?
covered the coolant lines today with some dei velcro heat wrap.
86AmishMs3 (08-15-2012), rfinkle2 (09-11-2012)
 Old 08-15-2012, 02:21 AM   #47
spnkr21's Avatar
Groans: 105
Smart
 Old 08-15-2012, 02:24 AM   #48
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
cut the arm shorter to increase effective preload. Looking pretty decent. Just need more boost and timing, ethanol would help too to get there.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 08-15-2012, 05:58 AM   #49
rabble rabble
802MS3's Avatar
Groans: 221
damn Tim posting at 420AM?? you got your AM and PM mixed up man!
no eth in VT, NH, or ME think meth in the tank might be interesting though.
superskater found me a 14psi actuator with braket, so I'll prob install that next week sometime.
spnkr21 (09-10-2012)
 Old 09-09-2012, 08:03 PM   #50
rabble rabble
802MS3's Avatar
Groans: 221
New bracket and 14psi WGA installed. Gonna have to lessen the preload a bit, spiking at 20, settling at 15 by redline with MBC cranked all the way down.
Now on the list is a new downpipe. slowly but surely...
The Following 4 Users Say Thank You to 802MS3 For This Useful Post:
86AmishMs3 (09-09-2012), atvfreek (09-09-2012), lilred (09-09-2012), rfinkle2 (09-11-2012)
 Old 09-09-2012, 08:27 PM   #51
atvfreek's Avatar
Posts: 7,787   (View Stats)
Think she will be ready for the PA dyno day?
Freekn tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
Last edited by 802MS3; 09-09-2012 at 09:22 PM. Reason: edit button =/= quote button
Don06speed6 (09-09-2012)
 Old 09-09-2012, 09:24 PM   #52
rabble rabble
802MS3's Avatar
Groans: 221
I'll at least have the spike worked out by then with the MBC. Plan is to have a reverse taper to 22 or whenever I run out of fuel on 93, but I need to do some learning on those boost control tables
 Old 09-11-2012, 03:48 AM   #53
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Reverse taper FTW.
802MS3 (09-11-2012)
 Old 09-16-2012, 10:26 PM   #54
MazdaSpeedSix's Avatar
Posts: 88   (View Stats)
MazdaSpeedSix is a name known to allMazdaSpeedSix is a name known to allMazdaSpeedSix is a name known to allMazdaSpeedSix is a name known to allMazdaSpeedSix is a name known to allMazdaSpeedSix is a name known to all
awesome setup! straight up tits!
MazdaSpeedSix is offline   Reply With Quote
 Old 10-07-2012, 08:19 PM   #55
rabble rabble
802MS3's Avatar
Groans: 221
zoom zoomin @20psi and 48 degree weather
https://docs.google.com/spreadsheet/...HpsemxFNGN3MVE
https://docs.google.com/spreadsheet/...kxqbmtYWHdjTkE
https://docs.google.com/spreadsheet/...VVVQ0hsYzltTUE
86AmishMs3 (10-15-2012)
 Old 10-15-2012, 03:34 PM   #56
rabble rabble
802MS3's Avatar
Groans: 221
results from PA dyno day, 355/333. 350 was my goal, so I'm happy. she pulls hard to redline. OTS timing still. reverse taper from 17psi@4000rpm to 21psi by redline. the boost curve was done by @atvfreek in 4 revisions cause hes the man...
I'll post some logs later.
86AmishMs3 (10-15-2012), atvfreek (10-15-2012), charlesfist (10-15-2012), rfinkle2 (10-15-2012)
 Old 10-15-2012, 03:44 PM   #57
atvfreek's Avatar
The curves look great, and that should keep your clutch happy until you can get something stronger! Pretty stoked we were able to hit over 350 on just pump gas and OTS timing. That turbo has a lot of potential!
Freekn tappin
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
802MS3 (10-15-2012), rfinkle2 (10-15-2012)
 Old 10-15-2012, 03:55 PM   #58
QFT.
 Old 10-15-2012, 04:36 PM   #59
atvfreek's Avatar
QFT.
Please remind me of QFT? sorry for being slow. Lol
Freekn tappin
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 10-15-2012, 05:44 PM   #60
rabble rabble
802MS3's Avatar
Groans: 221
quoted for truth yo!
atvfreek likes this.
 Old 10-15-2012, 06:09 PM   #61
rabble rabble
802MS3's Avatar
Groans: 221
Justin you have a link to a 3bar MAP I can buy? I want to stretch that boost out mooooore.
psychophyr (10-15-2012)
 Old 10-15-2012, 06:38 PM   #62
atvfreek's Avatar
Here you go sir, map sensor and PNP harness
Home » Shop » Sensors » Pressure Sensors » Bosch 3 Bar TMap Map Sensor with IAT
Mazdaspeed MAP Harness - Bitwise Motorsports
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 4 Users Say Thank You to atvfreek For This Useful Post:
86AmishMs3 (10-15-2012), MattJackson86 (10-21-2012), psychophyr (10-15-2012), rfinkle2 (10-16-2012)
 Old 10-15-2012, 08:07 PM   #63
rabble rabble
802MS3's Avatar
Groans: 221
damn that dude must make a nice chunk of change on that harness
 Old 10-15-2012, 08:20 PM   #64
atvfreek's Avatar
You can buy just the Bosch pigtail for around 30, but would have to splice it in. The PNP harness is pretty nice though
Freekn tappin
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
86AmishMs3 (10-15-2012), rfinkle2 (10-16-2012)
 Old 10-17-2012, 09:23 PM   #65
rabble rabble
802MS3's Avatar
Groans: 221
Two logs from our quick ebcs tuning session in PA
don't make fun of my timing
https://docs.google.com/spreadsheet/...lE&hl=en#gid=0
https://docs.google.com/spreadsheet/...UE&hl=en#gid=0
 Old 03-19-2013, 04:32 PM   #66
rabble rabble
802MS3's Avatar
Groans: 221
I haz to install:
76mm PnP throttle body
3bar MAP sensor
Guardian Angel
Vibrant vacuum block
Koyorad alum. radiator
but it just snowed a foot and I haz no garage.
Must stop buying car parts and save for house...
atvfreek (03-19-2013), DSIT995 (03-19-2013)
 Old 03-21-2013, 02:39 PM   #67
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Default Re: 3071r build
you gonna run it down at mnm?
 Old 03-21-2013, 03:20 PM   #68
rabble rabble
802MS3's Avatar
Groans: 221
fuck yea...won't be able to launch hard though I think, the clutch was slipping when I was on the MBC @~20psi. But I'll definitely give it a shot. If I was thinking forward, I'd give up all of those attempts to break 14.0 on the stock turbo, lol. I counted my slips the other day, and there was over 50 of them lol. Best was a 13.5@106.95 on a cool october afternoon in canada country. only was able to do it once
NJSPEED3 (03-22-2013)
 Old 04-17-2014, 08:59 PM   #69
rabble rabble
802MS3's Avatar
Groans: 221
Car sat in storage for the winter. Haven't changed much. Mounts, speakers, amp, Mazdaspeed catback.
oil, new plugs a couple weeks ago. Put in a gallon of E85 and bumped timing up a few degrees.
Was cold tonight. Heres a log. Gonna try to go out tomorrow night and play some more.
https://docs.google.com/spreadsheets...rYxqj-fPRiAHis
 Old 02-12-2015, 07:07 AM   #70
rabble rabble
802MS3's Avatar
Groans: 221
new manifold and matching stainless T3-vband turbine housing going on soon with the same 3071r.
865ms3 likes this.
fivefingerdeathpunch (02-26-2015), WetzMS3 (02-12-2015)
 Old 02-12-2015, 07:20 AM   #71
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Looks good! I'm trying to figure out if it's worth going from the mazda flanged hot side to a different one. I'll be interested in the outcome.
 Old 02-12-2015, 07:37 AM   #72
rabble rabble
802MS3's Avatar
Groans: 221
yeah the idea is that it *should* give me some more headroom. I don't have pump e85 anywhere near me, and I've been holding back on a meth setup. efficiency is what I'm striving for.
jdmage_mx5 (02-12-2015)
 Old 02-12-2015, 08:03 AM   #73
865ms3's Avatar
Posts: 2,602   (View Stats)
what manifold is that? looks VERY similar to the one i just picked up.
edit: JK...a lot different. carry on.
Brent
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
 Old 02-12-2015, 08:25 AM   #74
rabble rabble
802MS3's Avatar
Groans: 221
I picked it up last year from the original owner. its a top-mount, not really sure who made it. john russel maybe? It needs to be cleaned up a bit on the inside, and gonna get it ceramic coated.
865ms3 likes this.
 Old 08-17-2017, 10:24 AM   #75
rabble rabble
802MS3's Avatar
Groans: 221
Bumping my old thread because I feel like I should contribute something to this forum that is dead af.
I still have the car, and I am still running the 3071r. That stupid-ass top mount manifold didn't fit worth a shit, so I put the plans on the back burner for another year. I ended up buying the FJ Performance manifold, and still used the ebay T3-in/vband-out stainless knock-off Tial housing that @Tomas; has vouched for.
I bought the HTP hotside undermount kit to use since the FJ requires the turbo to point down. I also asked HTP if they could fab up a custom cold-side for me for my CP-e core, even with a custom BOV flange (using the Turbosmart Race Port valve, sounds amazing), and they came through for a good price.
I worked with a buddy of mine to fab up a fully custom downpipe and wastegate setup. Everything we used for the fab is from Vibrant and is 3" v-band. The downpipe is in two pieces, and I used one of those baller Vibrant GESi high-flow cats. I also put the vband flanges on the cat piece, and have a straight through piece for when I feel like saying fuckoff and spitting fire around town with the 2-step. I am running the old-school 3" Mazdaspeed OEM upgrade catback.
The only issue I've had with this setup is that after a few thousand miles, the bolts that old the turbine housing to the CHRA completely backed out. I ended up needing to pull the turbo to fix them, and to make sure it wouldn't happen again, I used drilled head bolts, and tied them together with safety wire.
I am the original owner of this car. 80k miles, 9 years old this summer, and it barely burns any oil. I still fucking love this car, and I still love working on it and surprising the shit out people. Mazda made a winner here kids, this car is still strong, has no issues, and I don't want to give this thing up.
My MAF is calibrated, I run 13° of timing up top, and my logs consistently say 400 g/s of airflow.
I said I would never do it, but I think I'm just gonna drop a meth kit with a fat nozzle and say fuck it, see how far this 3071r will go. over the winter I might rebuild the motor and send the turbo off to FP to turn it into an HTA.
JSmith (08-17-2017), Shwaykid (08-17-2017)
 Old 08-17-2017, 03:15 PM   #76
EwMPS's Avatar
Posts: 140   (View Stats)
EwMPS has a reputation beyond reputeEwMPS has a reputation beyond reputeEwMPS has a reputation beyond reputeEwMPS has a reputation beyond reputeEwMPS has a reputation beyond reputeEwMPS has a reputation beyond reputeEwMPS has a reputation beyond reputeEwMPS has a reputation beyond reputeEwMPS has a reputation beyond reputeEwMPS has a reputation beyond reputeEwMPS has a reputation beyond repute
Epic work!
EwMPS is offline   Reply With Quote
APT 3071R ANMSPD3 MazdaSpeed 3/6 - Big Turbo Builds 47 04-16-2014 11:51 AM
Swedish BT-Build (3071R) mayer MazdaSpeed 3/6 - Big Turbo Builds 82 04-20-2012 07:54 PM
Burn813's 3071r Build burn813 MazdaSpeed 3/6 - Big Turbo Builds 60 06-29-2011 10:31 AM
Page generated in 0.54212 seconds with 31 queries
