 Old 01-19-2011, 10:05 AM   #41
Docnox's Avatar
Posts: 1,435   (View Stats)
Docnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the world
Groans: 35
Originally Posted by Speedie6 View Post
The Cobb tuner says he's actually against meth. In his view, to get power from meth, you have to tune for meth. But if you tune for meth and your meth runs out, you fry your motor. You can get failsafe systems, but, he didn't think he trusted them enough to risk a motor on it.
IF your meth runs out is the key, just pay attention to it and your golden. Get a big 2.5gallon tank if you're that worried about running out. When you're that heavily modded you have to pay attention to everything anyway, it's not gonna kill you to check your meth tank and make sure it's not bone before you go out on a tear.
'06 Speed 6
Black Mica
Mazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe,
3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp
Altered Customs fmic, Autotech fp internals
Cobb AP, Stage 2+ 93 tweaked
Centric blanks, EBC red pads
Lotek center gauge pod: AEM wideband, Autometer boost and volts
Tints, blacked emblems, spec-v front lip, Shark fin
Redline MT-90, ITV-22s, Matt Damond OCC
13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap)
DO Meth kit waiting on install
Docnox is offline   Reply With Quote
 Old 01-19-2011, 10:05 AM   #42
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
fill up meth once a week.
carry a gallon of distilled water in the car and use it if you ever run out. should be fine.
 Old 01-19-2011, 10:33 AM   #43
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
fuuuuuuuuuuuuuck i would shoot myself having to check that once a week. lol... so not worth it.
it's fun to do bad things
 Old 01-19-2011, 10:36 AM   #44
Speedie6's Avatar
Posts: 1,838   (View Stats)
I actually had a meth kit. I had to, at least temporarily, disconnect it. I had a TMIC and the tank was in the wheel well and the pump was near the shifter. When I got the FMIC, the pipes ran where the tank and pump were. So, I disconnected it for the moment. I may hook it back up, and put a 2.5 gallon tank in the trunk.
I'm not 100% sold on Calvin (the tuner's) position. But, I understand it. He also said that the regulation of meth systems aren't as robust as the car's regular fuel system. You can have a full tank, but get some crap in it and clog the nozzle. Of course, a failsafe system is supposed to monitor flow. He just didn't feel sufficiently confident in it.
 Old 01-19-2011, 04:29 PM   #45
bmylez's Avatar
Posts: 3,197   (View Stats)
It's a little annoying, but the benefits far outweigh the downside of checking it. I am, however, considering a 2.5gal tank...
2007 CTS-V - Trying to sell
 Old 01-20-2011, 02:02 AM   #46
spiker98's Avatar
Posts: 427   (View Stats)
spiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the world
Get yourself a xcel xl maf housing/ standback by cp-e and sell you ap.. no wonder you can't make 400 whp.
2006 LP MS6 sport-
Garret GT30, Carillo rods, ARP mainstuds, CP custom forged pistons, Custom Downpipe, Creative Performance exhaust manifold, MAP intake manifold, Tial 38mm external wastegate, Cp-e Nviscid BT inlet pipe, Cp-e XL Xcel intake, Cp-e standback, Cp-e fuel cut fix/ Maf/ full throttle flash, Custom screamer pipe, Cp-e FMIC Blacked out, HKS SSQV blackout edition, KMD v2 fuel pump internals, BSD kit, Oil baffle, SU stiff diff brace, TWM stage 2 short shifter, BC coilovers, AWR endlinks font/ rear, SPC balljoints, SURE Juggernaut, Car-led tail lights, Cp-e center gauge pod, Prosport premium boost/ Air fuel/ Oil pressure gauges. All the little shit that goes with that. In coordination with Ginger performance and DDMworks.
spiker98 is offline   Reply With Quote
The Following User Says Thank You to spiker98 For This Useful Post:
rigor (01-20-2011)
 Old 01-20-2011, 03:05 AM   #47
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
How much power you making with all you CPE stuff ??
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 01-20-2011, 03:20 AM   #48
spiker98's Avatar
Nothing yet. Stay tuned, should be done in a few more weeks...
I love a good redhead...
2006 LP MS6 sport-
rigor (01-20-2011)
 Old 01-20-2011, 08:30 AM   #49
Speedie6's Avatar
Well, I will go ahead and get the bigger MAF. I've got the CPE BT turbo inlet pipe. Which is only 3". And I already had the ATP 3" MAF, so, I figured that would be "good enough". Perhaps not. I quess I will go ahead and upgrade to a 3.25" MAF.
But, question is, is the CPE turbo inlet good enough? Its only 3"?
As far as the AP, they've also broken the "top limit", so, I don't see it being an advantage to switch to the Standback.
The Following User Says Thank You to Speedie6 For This Useful Post:
jack_hammer (01-20-2011)
 Old 01-20-2011, 10:05 AM   #50
BigjohnB20's Avatar
Posts: 779   (View Stats)
Dude do you even have your car back yet? I am sure the people over at cobb know what they are doing and are very competent tuners, but I would get your car back, drive some, take some logs, etc before you go start buying new parts based on random recommendations from the forum.
Just my 0.02
The Following 2 Users Say Thank You to BigjohnB20 For This Useful Post:
Click Here (01-20-2011), veselini (01-28-2011)
 Old 01-20-2011, 10:12 AM   #51
Speedie6's Avatar
Just my 0.02
Well, that's a fair enough recomendation. A bigger MAF sounds like it might be in the cards, but, I'm not going to buy anything at the moment.
I'm going to pick up my car probably Saturday. Gotta fly to Dallas.
 Old 01-20-2011, 12:07 PM   #52
Click Here's Avatar
Posts: 202   (View Stats)
Click Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the world
I'm not sure I follow why you think you need a larger MAF? If it's not pegging the voltage then why do you feel that it needs to be replaced?
And as far as the 3" inlet goes...that should be fine. There's no reason to run anything larger at your power level IMO.
And to echo what BigjohnB20 said, your tuner is going to give you the best advice in how to proceed. I see many of the suggestions here as blind guesses at best. Review the logs, talk to the tuner, and decide where the next restriction is.
Good luck!
Click Here is offline   Reply With Quote
 Old 01-20-2011, 12:57 PM   #53
spiker98's Avatar
Here's what was said to me from Jake at Cp-e. And this was a LONG time ago but I believe its still relevant. The way the 3in ATP MAF scales to the ECU does not work correctly. You can do the math and make it work but it just takes a lot more time in tuning. Cause you have to adjust for the difference. But he told me the Cp-e 3.25 scales correctly... I ran the ATP 3in MAF on my car for a little over a year untuned....before I blew..(not saying that's the reason)
2006 LP MS6 sport-
 Old 01-20-2011, 01:25 PM   #54
Speedie6's Avatar
Well, I'm not a tuner, but, this doesn't make sense to me. I would figure that the 3" would require 'x' amount of scaling from stock and the 3.25" would require 'y' scaling from stock. But neither is stock and so both would need compensation. At least that is what I would think.
Well, I hear that Cagey is pegging his 3.25" and he's supposedly at around 550 WHP. So, I was guestimating that maybe 3" would be getting closed to pegged at 400 WHP. I don't know the exact numbers, I was just guestimating.
But, bottom line is, I'll see what Calvin recommends to go forward.
 Old 01-20-2011, 09:16 PM   #55
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
i definitely think it is a must to hit 400, cause you will max it out right @ or just beyond 400hp, bad hp to have your maf freak out imo
but if you get the cpe 3.5 maf take the alan screws out, and smear some ultragray silicone on the piece, and reassemble it.
is ruff cut, metal on metal! and it leaks
at 104000 2 bent rods
tuned by nishan
 Old 01-21-2011, 04:53 AM   #56
Speedie6's Avatar
Well, I suspect you are right, but, I will wait until I see what my tuner recommends.
Well that sucks, considering how expensive it is! I was thinking that if/when I get one, to look at the Treadstone because 1. its cheaper and 2. it has an air straightener. Though I'm not certain of the ID. I heard someone say it is also 3.25", but, I'm not sure of that. It looks from the pic to just be a hunk of 3.5" tube, which would put the ID at (I think) 3.37". Not certain.
 Old 01-21-2011, 07:32 AM   #57
rigor's Avatar
Groans: 40
ya i know i thought their was an o-ring or something, but nagatory gost rider! i ended up welding mine, i found the leak during a boost leak test!
and it leaked bad!
may not matter that close to were your drawing in air, but i don't want to find out either....
tuned by nishan
 Old 01-25-2011, 11:24 PM   #58
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
djuosnteisn
 Old 01-26-2011, 12:08 AM   #59
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
kingpin
 Old 01-26-2011, 07:09 AM   #60
rigor's Avatar
Groans: 40
tuned by nishan
 Old 01-27-2011, 12:15 PM   #61
bcmurphy87's Avatar
So whats happening, we think the only hold back is the 3 maf housing?
06 Speed6 GT- Sold
 Old 01-27-2011, 03:16 PM   #62
Speedie6's Avatar
Well, I STILL haven't got my car back from Cobb. They recommended I get an air/oil separator:
Crawford Performance
And its taking them TWO WEEKS to install the damn thing. My car has been there about 6 weeks! Some of the issues haven't been their fault, and there was also Christmas/New Years. But, it still seems absurd.
I hope (I better!) get my car back Saturday. At that point, I'll talk with their tuner as to what recommendations are going forward.
 Old 01-28-2011, 12:58 PM   #63
X-Man's Avatar
Posts: 103   (View Stats)
X-Man is the leader of the worldX-Man is the leader of the worldX-Man is the leader of the worldX-Man is the leader of the worldX-Man is the leader of the worldX-Man is the leader of the worldX-Man is the leader of the worldX-Man is the leader of the worldX-Man is the leader of the worldX-Man is the leader of the worldX-Man is the leader of the world
Get an aquamist system (i have one) If you run out of fluid it changes maps. If a nozzle is clogged, it changes maps... If you want to switch the wi of, it changes maps...
And dont run it on meth, water... Meth is more of an octane booster, and you dont need that. Run it on water to avoid knock. And a cpe fuel pump.
But thats just me...
X-Man is offline   Reply With Quote
 Old 01-28-2011, 01:29 PM   #64
turd burglar's Avatar
Posts: 1,895   (View Stats)
Groans: 39
cobb takes forever with alot of stuff, its ridiculous
 Old 01-28-2011, 02:22 PM   #65
Speedie6's Avatar
God dammit. I just talked to Cobb. And, they said they didn't have enough hose to install that can, so they had to order it so it won't be done until like Tuesday.
This week, I wasn't too busy at work and could have flown any day to pick it up. Next week I have a customer acceptance testing so I won't be free. So, probably won't be able to get it for yet another week. Dammit. They've been working on the can for 2 weeks and just now deciding they need more hose?
 Old 01-28-2011, 02:34 PM   #66
Groans: 39
they had mine for 6 months maing...
The Following User Says Thank You to turd burglar For This Useful Post:
wette460 (03-29-2011)
 Old 01-28-2011, 10:01 PM   #67
rigor's Avatar
Groans: 40
took me an hr to put in my cc????????
tuned by nishan
 Old 01-29-2011, 08:36 AM   #68
Speedie6's Avatar
Well, there is a bit of complication that could add a day or two to the equation...
The full story is, based on bad recommendation from PTP, and what I thought I understood that a couple of people have done (though I may have misunderstood what they were doing) was to remove the stock PCV assembly and replace it with a blocking plate, and add a second tap to the valve cover on the passenger side. Cobb indicated that wasn't cutting it, they were seeing elevated pressure in the crankcase.
So, Cobb's recommendation was to utilize the PTP aluminum blocking plate I had to have two fittings, one out, one back in from the AOS. And, while they were at it, weld off the EGR and PCV connections on the intake manifold. So, no possible way for oil to get into the IM anymore.
But, they said that modifying the PTP plate was more involved than they anticipated in order to make sure the out was out and the in would drain back to the pan. They said they built a little box and welded it onto the blocking plate.
So, the project was more involved than a simple catch can install. But, still, two weeks to do that seems on the long side to me. And it was annoying that they had it all done and then said, oh, shit, we need more hose.
 Old 01-29-2011, 08:42 AM   #69
rigor's Avatar
Groans: 40
huh i think their is no better place to draw the pvc from then the stock location, this way you get the gas vapor before it settles in the oil
i hope their not charging you for all that time
hopefully soon you will have your car!
i get about a 12 oz of str8 gas out of my cc every oil change
it was half that on stock turbo,, but my tune was real fat, so maybe now that it is leaned out more, it will go back to 6 oz
tuned by nishan
 Old 01-29-2011, 08:52 AM   #70
Speedie6's Avatar
Well, basically, Cobb is agreeing with you. The tap into the PTP plate is basically using the stock location. The reasoning (apparently faulty) by PTP was that there (supposedly) is a lot of oil slosh in the stock location, causing the stock PCV to get oil fouled and putting more oil into the intake manifold. So, the theory was, that by tapping just off the valve cover, most heavier-than-air fluid would fall downward before going through the taps. Not all of course, just, in theory, better than the stock location.
But, the taps off the valve cover just don't keep pressure from building in the crankcase. So, turned out to be a bad plan. They gave me a quote for how much to isntall the can. Kinda pricey, but, fixed cost, so, its not costing me extra for them taking 2 weeks to do it.
rigor (02-05-2011)
 Old 01-31-2011, 08:14 PM   #71
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
+1 on the 3.25" cpe maf - I dont generally rep cpe stuff either, but it is the only one ide use.
-1 on the meth - port injection bandaids arent needed for di.
+1 on the Cobb pcv fix - it sounds good to me.
+1 on the Bosch 3.0 bar map idea... oh wait no one mentioned that one.
+1 on ARP main and head studs...
2006 Mazdaspeed 6
 Old 01-31-2011, 10:27 PM   #72
Speedie6's Avatar
Still no car yet. They should be done any day, but, travel to Dallas is kinda bad this week with the Superbowl. And, I'm busy at work. So, I don't know when I'll get the damn thing.
Well, I got the head studs, I forgot to put it on the list. I'll add it. But, I didn't even know that ARP made main studs, so, I don't think I have them. Unless Cobb used them and I don't remember.
Why the CPE one over Treadstone? The Treadstone one does look more basic, just a hunk of 3.5" pipe and a MAF mount. But, it does have an air straightener.
Never heard of this. I googled it and found JumpingJackson's thread. I'll ask Cobb what they have to say.
 Old 02-01-2011, 06:30 PM   #73
Speeeeeed
06Speed6's Avatar
ARP makes both head and main studs, you can look at them side by side and there is almost no difference between them.
The CPE maf because it measures the incoming air more accurately than anything else I have seen. I saw someone mention something about the multiplier in the ECU, but thats a pile. Its about accurate measurements, that is all.
2006 Mazdaspeed 6
 Old 02-01-2011, 06:33 PM   #74
Speedie6's Avatar
Yeah, after your post, I googled the main studs and found it. But, I don't think I got those. Cobb didn't suggest them, to my recollection anyway. Would've been good I'm sure, but I didn't know it.
I figured the multiplier info was bogus. I'll see what Cobb recommends for MAF.
Thanks for responding.
 Old 02-03-2011, 07:52 AM   #75
senor blanco ms3's Avatar
Posts: 1,353   (View Stats)
senor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the world
This is a perfect example of jumping before looking.
2008.5 Crystal White Pearl MS3
A lot of mods
Check out my big turbo build!
senor blanco ms3 is offline   Reply With Quote
The Following User Says NO Thank You to senor blanco ms3 For This Un-useful Post:
turd burglar (02-04-2011)
 Old 02-03-2011, 09:14 AM   #76
Speedie6's Avatar
There was a very extensive thread that was lost in the MSF crash, where I asked for parts recommendations. Jake of CPE, SSinstaller and others gave lots of good advice in that thread. Quite a lot of thought and time went into this project that you are not seeing in this thread.
06Speed6 (02-05-2011)
 Old 02-05-2011, 02:03 PM   #77
Speeeeeed
06Speed6's Avatar
+1 I remember that thread.
2006 Mazdaspeed 6
Speedie6 (02-05-2011)
 Old 02-05-2011, 02:06 PM   #78
Speedie6's Avatar
Thanks, and I think you also participated. Too bad that went goodbye.
rigor (02-05-2011)
 Old 02-08-2011, 10:52 PM   #79
Speedie6's Avatar
Well, I *FINALLY* got my car back today. I flew to Dallas this afternoon and drove home this evening. Just got in about an hour ago.
First thing, I *definitely* notice the increased lag over the stock turbo. Boost doesn't really kick in until 3k RPM or so. I'm glad I didn't get anything more laggy.
So, here is what Calvin, my tuner had to say:
* In short, he thinks the turbo is giving pretty much all its got. He doesn't think there is a lot of room for improvement with my current 3071.
* I'm at 360 HP/380 TQ. The manager said that was basically 400 on a dynajet, they have a Mustang.
* There are at least some possible options, like meth, which as I said, he's not a fan of. And he could make a tune for 100 octane race fuel. But, I'm not going to run that so, no bother. He didn't mention NOS, but, I'm not going to do that either.
* He likes Forced Performance turbos. I had never heard of them until after I bought my turbo. In my earlier thread that is now gone where I was asking for recommendations, nobody mentioned them. The theory with Forced Performance is that they have a proprietary wheel that is supposed to spool as well as a 3071 but have more like 3076 topend. Or thereabouts, in theory. I probably should have got that but I didn't know.
* He also likes twin-scroll, which is also something I never heard of until after I bought my turbo.
* He contradicted what the shop manager told me. The shop manager told me that it was running out of gas at the top end. Calvin said, no, fuel is fine. I probably *would* start to run out of gas and need a bigger fuel pump in the tank if I went to higher power levels. But, at the current level, I have enough fuel. I don't know why the manager told me otherwise.
* They did go with the Bosch 3-bar like 06speed6 mentioned. I had never heard of it, but they did it.
* He said my MAF still has some headroom so, no immediate need for anything else other than the ATP MAF I have.
So, maybe someday I'll upgrade to a Forced Performance turbo and twin-scroll. But, I've sent enough on this car, so, probably, I'll call it pretty much done for the foreseeable future.
I'll post some pics this weekend. Too tired now.
The Following 2 Users Say Thank You to Speedie6 For This Useful Post:
jack_hammer (02-10-2011), wette460 (03-29-2011)
 Old 02-08-2011, 11:06 PM   #80
BrianB6's Avatar
Posts: 400   (View Stats)
360HP and 380TQ is strong for a MS6 on that dyno.
I think you are the highest MS6 on that dyno ever.
Be happy and enjoy the car for a bit.
Forced Performance is the shit. They are local to the DFW area and big in the Mitsu and Subie world. Just say "FP red" or "FP green" and they will know what you are talking about.
BTW as a reference check out Cobb foums>Plano and check the dyno vids to compare your car.
2016 - WRX -Cobb AP - Perrin Shift Stop - Perrin Trans Mount - Whiteline Positive Shift Bushings
2006 - MS6 - Dead RIP
WOT missing kabobulate MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 07-09-2010 10:01 PM
can you tell me what is missing? HaigDaniel 2010 MS3 - Troubleshoot/Diagnostics 5 05-06-2010 01:41 PM
Page generated in 0.62794 seconds with 37 queries
