![]() Join Date: Apr 2010 Location: Salt lake city, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 389
Groans: 30
(Thread Starter) | Not Ranked : 0 score Thought id document this since i have been taking pictures... First off big thanks to Mark from SU for the hookup, Driver311 for the porting help, and Lenny for answering questions and posting his turbo build thread. Im using the ATP GT3071r as most of you know this IS an IWG setup. This is the newer "revised" version of the iwg, meaning it has a bit of porting and a larger flap. Here are some pictures of the turbo BEFORE porting. IWG housing (BEFORE PORTING) IWG housing (AFTER ADDITIONAL PORTING) Install will be next weekend, I will update thread with more pictures as it progresses.
__________________ 08.5 MS3- : ATP GT3071r: cp-e XL intake: cp-e big inlet: cp-e rmm 75 Duro: cp-e e-flex motor mounts : cp-e catted down pipe: cp-e cbe,: cp-e FMIC, cp-e HPFP: cp-e safe seals : DNP Manifold: COBB AP: COBB RSB: DO stg 2 meth kit ,: SURE TIG's, : KW V2 coilovers: Konig Milligram 18x8.5 +35, Hankook ventus evo's 235/40/18, Saitek adj endlinks :HKS BPV: TWM STS: 465whp 468 wtq Best e.t 11.9 Best trap 123mph |
| The Following 14 Users Say Thank You to 801MS3 For This Useful Post: | 08.5MS3 (05-10-2011), AJ713 (04-29-2011), Alpha (05-10-2011), AZSPEED3 (05-25-2011), dizzin9 (04-28-2011), dougefresh_ (05-13-2011), Fobio (05-02-2011), madvillain (05-15-2011), manelscout4life (04-28-2011), Mistersix (07-19-2014), PunjabiPlaya (04-29-2011), Scribbles (04-28-2011), spnkr21 (05-15-2011), TurboDreams (05-09-2011) |
![]() Join Date: Dec 2010 Location: TX
| Not Ranked : 0 score Kewl. Should be awesome. Also, I really like how your car looks.
__________________ 2007 CTS-V - Trying to sell 2009 CTS-V - Not getting a cam. Ever. |
| The Following User Says Thank You to bmylez For This Useful Post: | 801MS3 (05-01-2011) |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1904 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
| Not Ranked : 0 score Get that badboy fired up. I wanna see another 400whp ms3 roaming the streets. LOL
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp |
![]() Join Date: Mar 2010 Location: Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 778
| Not Ranked : 0 score Looks good, hopefull that will be enough porting, if it isnt, then youll have to go ewg, cause you did all you can basicly=youll be fine. Your car looks pure sex, so having a 3071 in there to back up the looks will be a good thing...Nice nice. Anthony.......My steedspeed mani will be @ my doorstep next week, then I can slap turbo in and drive down to get tuned by Timmy...another 3071 ms3 will on the loose in the Pacific Northwest
__________________ 2009 MS3 COBB AP COBB INTAKE COBB/TURBOXS TBE DNP TURBO MANIFOLD CXRACING FMIC TURBOSMART BPV JBARONE RMM TURBOSMART BPV JBARONE SHIFTERPLATE COBB RSB KONIG WHEELS/HANKOOK TIRES TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO* |
| The Following User Says Thank You to zx2man For This Useful Post: | 801MS3 (05-01-2011) |
![]() Join Date: Jun 2010 Location: West Jordan, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 91
Groans: 32
Groaned at 27 Times in 12 Posts
| Not Ranked : 0 score Not looking forward to the install on this. after doing mine i wanted to die. good thing its all bolt up and not fabricating or welding or dealing with all the shit i had too deal with. im thinking we can do this in > 6 hours.
__________________ CP-E INTAKE W/ AMSOIL FILTER, CP-E INLET, TURBOSMART BOV, DENSO ITV22, AWR RMM, STREET-UNIT TMM & PMM, STEEDSPEED MANI CERAMIC COATED, T3 GT3076, TIAL EWG, CUSTOM V-BAND DOWNPIPE, UR CATTED TESTPIPE, TURBO XS CATBACK EXHAUST, COBB FMIC, CP-E FUEL PUMP, DASHHAWK+CP-E MOUNT, JBARONE SSP, COBB ACCESSPORT STAGE 2 SF 91 FMIC. SELF TUNED WITH 400HP/375TQ @ 21 PSI ON 100 OCTANE. |
![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
| Not Ranked : 0 score and then we have the battle? pearl vs 801?
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 |
| Not Ranked : 0 score So is it in?????
Groans: 30
(Thread Starter) | Not Ranked : 0 score Not till next weekend.. Still need to pick up some coolant and hope that the random silicone hose pieces i have will work for the hot pipe to turbo. And crossing my fingers on the stock hard coolant line "bending" far enough to re-use.
![]() Join Date: Nov 2010 Location: St. Louis missouri
Rep Power: 1310 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groans: 134
We didn't do this on my 2871 and trying to tighten the hard coolant line bolt and bend it while on the turbo was a super pita once mounted to the mani. | |
| The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post: | 801MS3 (05-03-2011) |
Groans: 30
(Thread Starter) | Not Ranked : 0 score Just finishing everything up.. crossing my fingers none of the lines leak.
| The Following 5 Users Say Thank You to 801MS3 For This Useful Post: | 08.5MS3 (05-10-2011), Alpha (05-10-2011), Docnox (05-12-2011), madvillain (05-15-2011), Manny3 (05-25-2011) |
| Not Ranked : 0 score DONE! starts and no leaks at idle. 801 needs to get his slave cylinder in the mail like NAOW
Groans: 32
Sent from my SGH-T959V using Tapatalk
__________________ CP-E INTAKE W/ AMSOIL FILTER, CP-E INLET, TURBOSMART BOV, DENSO ITV22, AWR RMM, STREET-UNIT TMM & PMM, STEEDSPEED MANI CERAMIC COATED, T3 GT3076, TIAL EWG, CUSTOM V-BAND DOWNPIPE, UR CATTED TESTPIPE, TURBO XS CATBACK EXHAUST, COBB FMIC, CP-E FUEL PUMP, DASHHAWK+CP-E MOUNT, JBARONE SSP, COBB ACCESSPORT STAGE 2 SF 91 FMIC. SELF TUNED WITH 400HP/375TQ @ 21 PSI ON 100 OCTANE. | |
anyways 801 should check back in soon. we drove the car last night
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 | |
| The Following User Says Thank You to snailD For This Useful Post: | wette460 (05-12-2011) |
Groans: 30
(Thread Starter) | Not Ranked : 0 score Coolant leak was a false alarm... Just waiting for my parts from silicone intakes then its go time..
| The Following 8 Users Say Thank You to 801MS3 For This Useful Post: | BigjohnB20 (05-13-2011), Ckmazdaspeed3 (05-13-2011), dougefresh_ (05-13-2011), madvillain (05-15-2011), Manny3 (05-25-2011), snailD (05-12-2011), Speed3eak (05-13-2011), wette460 (05-25-2011) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,452
Groans: 82
Well, let's just say that'll be the bolt-on turbo I might go after. Driver311 has made 395 whp on a bolt-on 3071 IIRC, so I feel like one of those, if the IWG works out, would be almost exactly what I'm looking for in a turbo. Really streetable, only slight turbo lag, and minimal modification/fab work. | |
![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
| Not Ranked : 0 score Nice. Good luck w/ install. I hope it all goes smoothly!! Take a lot of pics if you can
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to dougefresh_ For This Useful Post: | 801MS3 (05-14-2011) |
| Not Ranked : 0 score Hopefully you can come up soon and we can finish up your setup and throw it on the dyno. That way we have two cars similar setups on the same dyno to see how they compare. I really like your car bro. There is only maybe 2-3 cars on this website Id call my own. YOurs is at the top of the list for sure. Nice fucking car man. Now lets rock the rollers with that bitch.
| The Following User Says Thank You to driver311 For This Useful Post: | 801MS3 (05-14-2011) |
Groans: 78
| Not Ranked : 0 score Congrats on the new setup, I know that's a damn good feeling! Enjoy that shit!
| The Following User Says Thank You to madvillain For This Useful Post: | 801MS3 (05-15-2011) |
Groans: 30
(Thread Starter) | Not Ranked : 0 score Went out and ripped the car around for a bit tonight.. MBC was all the way down car holds (13-14) pretty steady off iwg spring. So from the initial test drive it looks like the porting is working to control the boost in the lower psi range! More updates as i turn up the boost and try out new maps and whatnot. Also i forgot to take a picture but i did modify the stock coolant inlet line (the one you are supposed to "bend" bending didn't seem like it was going to work so i cut off all but about an inch of the straight after the banjo and picked up some high temp hose and ran that instead. I'll take some pictures of that also.
| The Following 2 Users Say Thank You to 801MS3 For This Useful Post: | dougefresh_ (05-15-2011), Speed3eak (05-15-2011) |
| Not Ranked : 0 score Right the fuck on man! Good shit. Gives some solid hope to those that don't want the hassle of ewg. Good work!!
| The Following User Says Thank You to dougefresh_ For This Useful Post: | 801MS3 (05-15-2011) |
Groans: 30
(Thread Starter) | Not Ranked : 0 score Yea the point of this thread was to encourage those like me who are (currently) not interested in a full ewg setup and want the simplicity of the IWG. I really hope this setup works out and does what it's supposed to do and others can use the porting as a blue print to run a kick ass IWG direct bolt on setup.. Shit.. Driver311's car is all the motivation they need, but a little backup couldn't hurt.
| The Following 3 Users Say Thank You to 801MS3 For This Useful Post: |
![]() Join Date: Dec 2008 Location: ky
| Not Ranked : 0 score I used the ATP 3071r with external waste gate housing it was a very simple install and with the dump pipe it sounds amazing... |
| The Following User Says Thank You to JoeSpeed6 For This Useful Post: | jracer (08-12-2011) |
| Not Ranked : 0 score Nice. Looking forward to more results, and I'm sure many others are too. Good stuff.
![]() | | #24 | ![]() |
Groans: 30
(Thread Starter) | Not Ranked : 0 score Went out again tonight and gave it hell, went wot for the first time.. turned the boost up to 15-16, feels pretty good for being on a very mild tune and 15 psi. Took some logs that ill post up later. Also ill throw up pictures of my gnarly coupler setup. Now for more tuning and more boost!
| The Following 5 Users Say Thank You to 801MS3 For This Useful Post: | dougefresh_ (05-17-2011), Manny3 (05-25-2011), mayer (05-18-2011), snailD (05-17-2011), Speed3eak (05-18-2011) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score so no creep then? =)
![]() | | #26 | ![]() |
Groans: 30
(Thread Starter) | Not Ranked : 0 score Not so far on 15psi.. Cp-e 2.25" to 2" reducer that came with FMIC The turbo inducer is about 2 1/2" shorter than the ko4 so i am in need of a longer reducer.. however as far as i could find there aren't any longer than 3" (the one i already have from cp-e) So i bought a 2.25" joiner and another 3" section of 2.25" silicone and 2 more t clamps.. All together it's a tiny bit long but it gets the job done.. I also drilled into the cp-e coupler for a boost source. Heres what this frankenCoupler looks like.
| The Following User Says Thank You to 801MS3 For This Useful Post: | dougefresh_ (05-18-2011) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score [IMG] FAIL
![]() | | #28 | ![]() |
Groans: 30
(Thread Starter) | Not Ranked : 0 score Works for me DummyD Of course i can cut it.. lol.. but with the clamps and the length of the joiner, it kind of has to be the length it currently is.
![]() | | #29 | ![]() |
| Not Ranked : 0 score If the coupler is too long...you know you can cut silicone couplers, right? haha Looks good.
![]() | | #30 | ![]() |
| Not Ranked : 0 score Cut the joiner? I have a 2" exhaust pipe that I roughed up with sand paper and the coupler hasn't slipped running 21psi.
![]() | | #31 | ![]() |
| Not Ranked : 0 score I went through something similar w/ my cpe fmic. The couplers it comes w/ are ghetto and really thin. I was looking for longer than 3" and all I found was 2.25" x 12"... so I could make 3 4" ones. But I said the hell with it, and just ordered new, thicker ply ones from vortex (they're almost 2x as thick as the cpe ones). Your frankencoupler looks fine.. maybe trim it like Brian said.
![]() | | #32 | ![]() |
![]() | | #33 | ![]() |
![]() Join Date: Dec 2009 Location: layton, UT
| Not Ranked : 0 score nice austin.. u went BT.... i will be runnin a 3076r after i get back from this deployment... i need to start getting a build list together of all the odds and ends becuz will be running the tr10 custom FMIC so all my piping will be custom. might run the hotpipe under the motor if i can figure it out and not scrape it off on bumps lol... did u use stock mani? or stock mani position atleast? hit me up dude
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
![]() | | #34 | ![]() |
Groans: 30
(Thread Starter) | Not Ranked : 0 score Brief update.. Did some logs tonight.. Just want to say that if you are considering going IWG but are worried about creep/spike... DONT BE! This porting as far as i can tell completely fixes those issues. My boost is VERY stable right now no spike or creep at almost 17psi... For those who care enough to open a csv file i have attached a 3rd and 4th gear log. This is still on a pretty baseline tune.
![]() | | #35 | ![]() |
![]() Join Date: Jan 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,186
| Not Ranked : 0 score Setup is holding boost really nice man! What is your target psi for the tune?
__________________ T3 GTX 3076R .82 a/r, ATP wide-mouth turbo inlet, CPE FMIC, 3.25" MAF custom intake, HKS BPV, Steedspeed T3 Exh. mani, CPE High Output Fuel Pump, Streetunit MM, CP-E side mounts, Mazdaspeed CBE, v-band custom DP, TiAL 38mm EWG, DO stg 2 meth 75/25 w/ do7, 3.5 bar MAP, Cobb AP, TWM solid shifter base bushings, BC racing 32 way adj. coilovers, Mazdaspeed camber links, 18" Bronze Enkei wheels |
![]() | | #36 | ![]() |
Groans: 30
(Thread Starter) | Not Ranked : 0 score Going to get it locked in at 18psi tonight and then get the tune dialed in.. Again this is just a "street" map.
![]() | | #37 | ![]() |
| Not Ranked : 0 score What fuel pump are you running? Are you tuning yourself? So far so good
![]() | | #38 | ![]() |
![]() Join Date: Feb 2009 Location: Salt Lake City, Utah
Rep Power: 427 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 626
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Cant wait to go for a ride.
__________________ 417whp 428tq 12.037@117.2mph |
![]() | | #39 | ![]() |
Groans: 30
(Thread Starter) | Not Ranked : 0 score Anytime man.. cp-e pump... Driver311 and i have been messing with the tune.. planning on getting some more msf help to fine tune it. Got it locked at about 18.5 tonight, saw 315 g/s. need to go down about a click to get to 18.. Ill post more logs if anyone wants to see them.
![]() | | #40 | ![]() |
| Not Ranked : 0 score Nice nice...how much different does you car feel now?
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/801ms3-s-gt3071r-project-79206/ | ||||
| ? View topic - One quick mps | This thread | Refback | 04-18-2013 05:39 AM | |
| ?????? ???? ????? ?????? ? ??????????. - Opel Performance Center Club Russia - ???????? 50 | This thread | Refback | 01-15-2012 02:56 AM | |
| ??????? ?????, ?????? ??????, ????? ? ????????... - Opel Performance Center Club Russia - ???????? 1054 | This thread | Refback | 11-05-2011 04:30 PM | |
| GT3071r AP Maps | MS6_Wolf | Cobb ATR Support | 15 | 07-19-2011 04:54 PM |
| GT3071R Question | manofhonor24 | MazdaSpeed 3/6 - Turbo Induction | 20 | 10-01-2009 01:33 PM |
| GT3071r project... heres the goods | phailerider | MazdaSpeed 3/6 - Turbo Induction | 189 | 04-01-2008 09:25 PM |
