  • 1 Post By SarcasticOne
  • 1 Post By rfinkle2
 Old 01-02-2013, 02:24 PM   #1
shawn.'s Avatar
Posts: 541   (View Stats)
shawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the world
Groaned at 22 Times in 16 Posts
Default Adjusting preload IWG
So I'm wondering how to go about adjusting the preload on my ATP GTX3071r without taking the turbo off of the car. I can only make 17psi with my MBC cranked all the way up so I was informed I need to preload the IWG arm...
I loosened the nut but am not positive how to tighten/shorten the arm. Also will I need to take the wastegate off of the turbo to get the arm to turn? If so is it just attached by the two bolts?
Thanks
ATP GTX3071r// Cobb 3 Port EBCS // 3 Bar MAP // Cobb Accessport Freek Tuned // E85 Mix // JBR 3.5" Intake/TIP // Treadstone TR8C FMIC // Autotech HPFP Internals // Ported IM //C-pe Catted Downpipe // TRZ RMM // Corksport CBE // ISC Coilovers // EBC Slotted Rotors--Redstuff Pads // TWM shifter bushings // Dashhawk v2 // 6000k HIDs
Built engine--Manley H Beam Rods--Wiseco Pistons
shawn. is offline   Reply With Quote
 Old 01-02-2013, 06:04 PM   #2
shawn.'s Avatar
Ok so do I need to disconnect the wg arm from the actual wastegate part? And then screw the part into the arm and then reconnect? If so how do I disconnect that wg arm or what? Still can't really figure it out after lookin at it and messin around with it a little.
I really don't wanna take out my turbo again lol
 Old 01-02-2013, 06:19 PM   #3
atvfreek's Avatar
Posts: 7,787   (View Stats)
There is a c-clip you have to pop off. Check this out for a better idea.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 4 Users Say Thank You to atvfreek For This Useful Post:
dantes5823 (01-06-2013), Fizzyb (07-14-2013), impossible (05-10-2014), shawn. (01-02-2013)
 Old 01-02-2013, 06:24 PM   #4
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Wastegate Preload Setting - YouTube
Aussies have their C-clips pop off mid WOT pull
atvfreek likes this.
The Following User Says Thank You to SarcasticOne For This Useful Post:
atvfreek (01-02-2013)
 Old 01-06-2013, 12:01 AM   #5
Matrix311's Avatar
Posts: 2,133   (View Stats)
If you still need help with the preload let me know. I messed with the pre load on my gtx3071r a lot and it can easily be adjusted on the car. No need to pull the turbo. You will want to tighten it. Just pm me if you need extra help.
The Following 2 Users Say Thank You to Matrix311 For This Useful Post:
atvfreek (01-06-2013), shawn. (01-07-2013)
 Old 01-07-2013, 02:00 PM   #6
shawn.'s Avatar
thanks man i figured it out with that video justin posted, really isn't very hard at all.
The Following User Says Thank You to shawn. For This Useful Post:
atvfreek (01-07-2013)
 Old 08-05-2013, 08:57 AM   #7
bhamitgeek's Avatar
Posts: 362   (View Stats)
bhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the world
I thought these kits already came preloaded to the desired preload that u requested on the form? am I thinking of something else?
bhamitgeek is offline   Reply With Quote
The Following User Says Thank You to bhamitgeek For This Useful Post:
rfinkle2 (08-05-2013)
 Old 08-05-2013, 09:02 AM   #8
You are thinking that ATP gives a shit. I wish this was the case as well.
I suppose it can be argued that they are looked over before they are shipped, but it is always a good idea to hook the turbo up to a compressor and gauge and make sure the preload is close to where you want it...
Much easier to adjust out of the car and well worth the testing before dropping it in.
bhamitgeek likes this.
bhamitgeek (08-05-2013), BigRedSpecial (08-05-2013)
Adjusting WG spring preload on turbo? p057 MazdaSpeed 3/6 - Turbo Induction 10 10-30-2012 05:55 PM
Adjusting boost ATR? zx2man MazdaSpeed 3/6 - ECU Computer Tuning 13 08-04-2010 02:29 PM
Adjusting headlights dizwhoadayjohn Appearance - WHITE 1 03-03-2010 03:46 PM
Adjusting the E-Brake? xl1200r 2010 MS3 - Suspension & Brakes 3 12-13-2009 01:26 PM
Adjusting the Fogs dizwhoadayjohn MazdaSpeed 3 - How-To's 5 07-05-2009 02:57 AM
Page generated in 0.29619 seconds with 25 queries
