Like Tree5Likes
 Old 11-03-2010, 11:59 PM   #1
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
Default ATP 3071r swap how to , lenny gets BT fever too
alright guys.... i got a big cup of suck it up in hand and time to do the nasty.
ill try to add as much as i can ....its a bit demoralizing typing all this shit up and linking pics... but i keep telling myself that it may help others... so here we go.
got a great deal from SU Mark on this brand new ATP 3071r iwg
the kit comes with AN oil return line.... quicktap boost source nipple for tapping silicone coupler.... AN rear coolant line that leads into a rubber hose for oem installation and a 2.5 silicone coupler.
to go with this turbo i decided to buy this slug looking piece from cpe... (big inlet)
now lets take a look at the hotside and see what ATP has improved vs the older ATP turbos...(mainly the wg)
heres the flapper open (notice the pivot arm is right up to the end of the wg hole, on older models the hole is smaller and u can tell by looking at the pivot arm in reference with the hole)
heres the machining done to it.... it goes deeper and doesnt end at a wall on the half moon rather a transition like the end of a shovel
if i were to remove material I would perhaps take some from where my finger is blocking to better blend the transition from the exhaust manifold gases flowing into the turbine and side tracking out the wastegate when needed
a more aggressive material removal
thats it for the first post.... ill keep adding as i troll my photbucket
comment or not if u want...doesnt matter people can follow it either way
:: Gusto :: likes this.
The Following 33 Users Say Thank You to rodrigo For This Useful Post:
3mazdaspeed (12-23-2010), 801MS3 (11-12-2010), :: Gusto :: (04-04-2011), Aetherfury (11-04-2010), alien_sporez (03-23-2011), ANMSPD3 (01-20-2011), bioevolve (11-04-2010), Broxer (10-07-2011), Cataphract_40 (01-19-2011), Dano (11-09-2010), djuosnteisn (05-11-2011), Docnox (11-04-2010), dougefresh_ (11-16-2010), Fobio (01-23-2011), gtarman77787 (11-12-2010), i8urgti (11-16-2010), JacksonMS30 (11-10-2010), jracer (01-19-2011), Juyoung (01-13-2013), knarfies (05-11-2011), mayer (07-08-2011), MS3-a(sore)ASS-rex (11-09-2010), Ms3_Miami (12-24-2011), mtnrunner (11-04-2010), onelove221 (09-01-2011), PaPaSpeed (11-04-2010), Post pwned (05-02-2011), redboat (11-27-2013), robry (10-18-2012), Shin Gouki (12-12-2010), SIXual Panda (11-04-2010), spoolin00 (01-31-2011), triplejumper18 (03-29-2011)
 Old 11-04-2010, 12:06 AM   #2
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
1st post
so no big dick fever?
The Following User Says Thank You to dooderek For This Useful Post:
dougefresh_ (03-19-2011)
The Following User Says NO Thank You to dooderek For This Un-useful Post:
 Old 11-04-2010, 12:24 AM   #3
mtnrunner's Avatar
Posts: 864   (View Stats)
mtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the world
thanks lenny, your right that its going to help people in the future. especially with all the controversy on the iwg atp turbos. a write up like this could put a lot of things to rest.
Murdered out 2007 speed3 GT with navi.
mtnrunner is offline   Reply With Quote
The Following User Says Thank You to mtnrunner For This Useful Post:
 Old 11-04-2010, 12:38 AM   #4
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
ok next on the list is boost control..... from what i have seen no one with a BT can control boost with oem bc... so I went ahead and bought a hallman pro rx mbc... it comes with a soft fine tuning spring up to 5lbs fine tuning over wg spring pressure.... and a stiffer less fine tuning spring to crank it up to the sky...
heres the hardware... in cobb blue (sort of)
ok... so here is a shot of the wga... and its adjustable rod... (i believe this turbo comes with a 12-14lbs wg spring.) i set it to the lower end... because if i adjust too much preload the flapper will bind if it ever needs to be extended to 90 degrees from being shut.\
here is also a shot of the rear coolant line provided by ATP....
and this is how it will be routed once in car....the rear one goes over the turbo
now one thing we discussed in length is supporting the turbo from underneath. stock the turbo has only 2 solid support anchors... the ex manifold....(top) and the turbo bracket (bottom) .... the dp doesnt really support it since it is only helt to the body by the hangers holding the exhaust pipes.
so....
i ordered some thermo tech header wrap....
i also bought from siliconeintakes.com a 90 degree reducer from 2.50 to 2.0 and also a metal insert and finally a straight coupler....
all this will be used because the snout of the turbo (3071r) is actually shorter than the ko4...and the regular coupler i use with my cobb fmic kit simply wont reach.
heres the hardware i bought.....
put together to show u how much longer it can reach
so back to the bracket....
i bought a second bracket to fuck with......
so first thing ill do is notch that section i used a marker on.... this will give me a way to wrap the header wrap around the edge where the bracket will contact the turbo... and provide both support and NOT transmit vibrations....
ill wrap it around here once or two times around....
i also bought some high heat ties....to be able to secure the wrap nicely so it doesnt walk around on me
so now for the front coolant line that requires u to bend the oem one to clear the larger compressor.... i had bought a banjo and high temp hose to use instead....
wasnt very happy to see how close the hose comes to the turbine housing....
so we ll get back to solving this in a bit.
now back to the other thing we have to modify on the turbo bracket....
the 3071r has a much larger turbine housing than the ko4.... so the bracket will interfere with the fit unless it sits lower.....
one way i was considering was to bend it to accommodate.... but instead it was suggested to me i slot drill the holes that go towards the block on the bracket so i can adjust the height of it at will.
and heres a pic of the proposed slotting... marked with a marker.
now that we r done with that...lets finish up that front coolant line....
bought a banjo with 6 -an fitting.... 2ft steel braided hose with one end 90 degree -6an fitting and one with a straight -6am fitting..female both.
also as a last touch i bought a -6an fitting to add to the line...and the other end with a barbed ending to attach to oem hose.
heres all 3 lines now attached to the turbo...(only one being re used is the oem oil feed line from the top)
anyways.... feel free to ask questions and discuss.... i know we have been talking about this for a while.....but im doing this really for the guys that one day might be encouraged by these pics and words.
this was easier than i thought lol
Originally Posted by dooderek View Post
1st post
nah....came close though ...almost had a cock in my mouth....but then the microwave beeped and i lost track of time afterwards...
oh well
im hoping to help squash this controversy.... i think its trial and error and if those few of us going atp... can make our cars reliable, powerful and consistently run the same.... then it might open up options for guys that dont want to go ewg and all out shit.
TWOptSL0W likes this.
Last edited by rodrigo; 11-07-2010 at 02:36 PM. Reason: MSF Database - Automerged Doublepost
The Following 31 Users Say Thank You to rodrigo For This Useful Post:
801MS3 (11-09-2010), 802MS3 (11-04-2010), Addikted To Boost (11-14-2010), Aetherfury (11-04-2010), alien_sporez (03-23-2011), bioevolve (11-04-2010), Cataphract_40 (01-19-2011), cld12pk2go (11-09-2010), Dash08 (11-07-2010), djuosnteisn (05-11-2011), Docnox (11-04-2010), dougefresh_ (11-16-2010), EwMPS (11-09-2010), ganque (12-15-2010), gtarman77787 (11-12-2010), i8urgti (11-16-2010), JacksonMS30 (11-10-2010), jracer (11-04-2010), mayer (07-08-2011), mazda.speed3 (11-04-2010), memin (03-06-2011), MPSdriver (11-04-2010), MS3-a(sore)ASS-rex (11-09-2010), NJSPEED3 (11-07-2010), onelove221 (09-01-2011), PaPaSpeed (11-04-2010), Phoenix Speed3 (06-11-2011), Post pwned (05-02-2011), robry (10-18-2012), SIXual Panda (11-04-2010), thehead (02-18-2012)
 Old 11-04-2010, 01:14 AM   #5
2zz mr-s
dooderek's Avatar
Groans: 239
damn nega got some hair on your hands. oh becareful with em steel zip ties, sliced my hand once real good
 Old 11-04-2010, 01:18 AM   #6
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
uhhhhh..... yeah dude. were i come from men have hair. on their... chest, balls, hands ....then when u start getting closer to 40 you hair on top of your head suddenly migrates to your asshole....
how do u yanks roll here????
and ive handled header ties before....i pull with vise grips neggaramus....i aint stupid
but ty for the heads up
ms3blackmica likes this.
ms3blackmica (12-05-2012), NRSpeed (11-04-2010)
 Old 11-04-2010, 01:22 AM   #7
mtnrunner's Avatar
i agree that it is trial and error. massive improvements have been made to the wastegate design already and if its not perfect now you can try your porting that you talked about. driver311 and you are both great examples of how to get this turbo setup properly for a close to plug and play option.
 Old 11-04-2010, 01:27 AM   #8
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
i am actually not porting anything.... anthony (driver311) had parts that caused him to outflow what mine will be able to do...
he had a big maf...creep
no cat ...creep
older style 3071r.....creep
eventually he corrected his issues and does creep....but im not worried about creep myself....i mean all out...sure ewg, t3 housing the whole 9 yards....
but for a plug and play deal....i doubt there is anything better than atp... as long as u realize u wont win any dyno contests.....
the price is the ONLY issue i see....cuz these fuckers sure like to charge
 Old 11-04-2010, 07:08 AM   #9
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
ground hogs day!
at 104000 2 bent rods
tuned by nishan
 Old 11-04-2010, 08:03 AM   #10
WOT @1k RPM!
NRSpeed's Avatar
Posts: 1,570   (View Stats)
NRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the world
Groans: 47
Groaned at 50 Times in 33 Posts
It is unfortunate that the original thread was lost. There was some good learning in there.
Got a day set for install yet?
MazdaSPEED3 2009 - Mica Black
http://www.mazdaspeedforum.org/forum/forum/f8/setting-avatar-new-users-other-noobs-43712/
http://www.mazdaspeedforum.org/forum/forum/f8/uploading-adding-images-your-post-43704/
No BB URL code = sux
NRSpeed is offline   Reply With Quote
 Old 11-04-2010, 08:08 AM   #11
SIXual Panda's Avatar
Posts: 2,363   (View Stats)
Groans: 56
in before install. should be kickass lenny!
I envy your ass raping.
 Old 11-04-2010, 09:08 AM   #12
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
nah waitin on philly to have a date of his shit...december sometime
 Old 11-04-2010, 09:10 AM   #13
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
in before blown motor
The Following 3 Users Say Thank You to aaronc7 For This Useful Post:
BrianZX10R (11-09-2010), gtarman77787 (11-12-2010), Huligan (11-07-2010)
 Old 11-04-2010, 12:17 PM   #14
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
go make your turbo miata thread.... so i can post the same for u.... likelihood will be about the same.....
NRSpeed (11-10-2010)
 Old 11-07-2010, 02:37 PM   #15
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
edit********88 i erroneously put i bought a 90 degree reducer/coupler 2.75 to 2.5... it was 2.5 to 2.0 actually
 Old 11-07-2010, 08:17 PM   #16
bro2's Avatar
Posts: 384   (View Stats)
bro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the worldbro2 is the leader of the world
I <3 lenny for this...no homo that is...i have about 1 more year of school left then i will have $$$ to do this same thing
2010 Mica black ms3 ~ cobb AP ~ cp-e nano/ AEM dryflow ~ TRZ rmm ~ 35% tint all around with 15% strip on top ~ 6k hid ~ nokya hyper yellow fogs ~ cp-e towplate
bro2 is offline   Reply With Quote
The Following User Says Thank You to bro2 For This Useful Post:
rodrigo (11-07-2010)
 Old 11-07-2010, 11:08 PM   #17
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
i dont mind gay love... are u near so cal???
 Old 11-07-2010, 11:21 PM   #18
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
thats until he wakes up in the morning with sticky ass cheeks
 Old 11-07-2010, 11:30 PM   #19
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
gerry u disappoint me man... i thought u drew up your avatar...but i saw it black pointing the other way on someone else.....
how could u
 Old 11-09-2010, 11:04 AM   #20
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
If it were me, I would spend 20 minutes with an air grinder and enlarge/smooth the entrance into the flapper with a special focus on open up the radius so the entrance isn't a 90° from the normal exhaust flow.
We know that it is marginal with respect to having creep in its current state and it is a shit-ton easier to massage it now than it is to pull it later...
 Old 11-09-2010, 11:21 AM   #21
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Lenny, another good write up man!
FWIW I just remembered this from my install.
you will likely need to cut the oil return line. Mine was like 2" too long and there was no way to route it to connect back to the block. If you have ever tried to cut steel braided line without the proper tool...well it sucks!
I duct taped the fuck out of mine where I was going to make the cut, and hacked away with a brand new hack saw blade and it actually turned out good. The hard part is getting the SS line back into the fitting and screwed back down.
rubbersoul1989 likes this.
zx2man (11-09-2010)
 Old 11-09-2010, 01:47 PM   #22
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
thanks for the heads up..... no way to swap ends to make it work better???
ill check with the others see if they had the same issues because no one else has mentioned this....
zx2man (11-09-2010)
 Old 11-09-2010, 02:40 PM   #23
Trail of Fail
Dano's Avatar
well I do over look simple things sometimes but i don't think so.
you have to come off the turbo with the straight connector and use the 45* or whatever it is to get you to the block. if I tied mine up like a pretzel maybe. Go try to flex that hose...it doesn't move much.
Like this:
(oh and notice my "modified" OEM water outlet
oh and my ghetto bracket:
 Old 11-09-2010, 02:44 PM   #24
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
i guess ill find out when i try it..... but seems the curvature of the hose plus being able to swivel the 45 degree end wouldnt present an issue....
hmmmmm
i pmed gsrtypo1 he had the 3071 atp kit..ill see if he says he had to modify it...
could be a case of "u fail" dano....lol
NRSpeed (11-10-2010), zx2man (11-09-2010)
 Old 11-09-2010, 02:51 PM   #25
Trail of Fail
Dano's Avatar
It certainly could be a "u fail" case but I absolutely did NOT want to have to cut that hose and spent over an hour trying to figure out a way around it.
I'll be interested to know if you have to cut yours...ur I mean if Philly has to cut it.
zx2man (11-09-2010)
 Old 11-09-2010, 03:04 PM   #26
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
philly does the grunt work....detailed work that requires accuracy is always done by me
FreeFlyFreak (11-09-2010)
 Old 11-09-2010, 03:07 PM   #27
Trail of Fail
Dano's Avatar
O I C
 Old 11-09-2010, 03:25 PM   #28
801MS3's Avatar
Posts: 453   (View Stats)
801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world
Groans: 30
Hell yea Lenny, exited to see how it all works out.. Ive got a IWG 3071 in the works also... Could you provide links to the extra parts you had/wanted to buy to help when others are ready.
For a bolt on that comes with lines, at a glance it seems like there are a lot of line modification that needs to be done.
Good luck man
08.5 MS3- : ATP GT3071r: cp-e XL intake: cp-e big inlet: cp-e rmm 75 Duro: cp-e e-flex motor mounts : cp-e catted down pipe: cp-e cbe,: cp-e FMIC, cp-e HPFP: cp-e safe seals : DNP Manifold: COBB AP: COBB RSB: DO stg 2 meth kit ,: SURE TIG's, : KW V2 coilovers: Konig Milligram 18x8.5 +35, Hankook ventus evo's 235/40/18, Saitek adj endlinks :HKS BPV: TWM STS:
465whp 468 wtq Best e.t 11.9 Best trap 123mph
801MS3 is offline   Reply With Quote
The Following User Says Thank You to 801MS3 For This Useful Post:
 Old 11-09-2010, 03:27 PM   #29
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
will do....when i get home ill get the part #s and shit from ATP and such where i bought the goodies.
 Old 11-09-2010, 06:45 PM   #30
zx2man's Avatar
Posts: 1,356   (View Stats)
Lenny has does a excellent job on this write up so far, and has helped me via pm's...Ill be keeping close eye on how the oil return line fits, if I got to cut it, not gonna fuck around, either get right cutting tool, or take it to machine shop and have them cut it to size. Im really trying to avoid anything ghettoland. As for bracket...think Lennys wrap job will work, Im gonna try what Lex said, and fabricate a bracket for my Cobb Dp to bolt to the stock dp mount location. Good shit guys..keep it up
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
JBARONE SHIFTERPLATE
COBB RSB
KONIG WHEELS/HANKOOK TIRES
zx2man is offline   Reply With Quote
The Following User Says Thank You to zx2man For This Useful Post:
rodrigo (11-09-2010)
 Old 11-09-2010, 06:52 PM   #31
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
Like this:
oh shit dano..i see steedpseed???
 Old 11-09-2010, 06:59 PM   #32
Trail of Fail
Dano's Avatar
you have a keen eye there lenny..
I told you i'd snap some pics when I did the swap and those are just a couple.
I'll put a thread together soon with all the pics.
teasers
Hallman Pro EVO in the foreground
The Following 5 Users Say Thank You to Dano For This Useful Post:
4G63 (06-04-2011), djuosnteisn (11-16-2010), Docnox (11-21-2010), madvillain (11-11-2010), rodrigo (11-09-2010)
 Old 11-09-2010, 07:07 PM   #33
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
wow..so much room!!!
 Old 11-09-2010, 07:32 PM   #34
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
my guess is that lenny is most pissed about not having a v-band clamp downpipe.
2008 STi
Intake
Turboback
AP
 Old 11-09-2010, 07:52 PM   #35
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
fuck that dane........... fuck that v clamp so hard man... i still have nightmares about holding that shit for 12 hrs stright while u and philly try to make the shit go in.....
fuck that whole car man...that car should have been dumped in tj long ago
on the other hand...it was alexanders favorite speed to hit my driveway hahahahahah
danesti (11-09-2010)
 Old 11-09-2010, 08:26 PM   #36
danesti's Avatar
Groans: 137
haha you were not a happy camper that night.
I thought your were going drop kick my cat after you came back from the fail test drive (fuel pump internals or something?)
and i really dont know how i was able to put that shit on by myself then have the hardest time ever with you and philly. fuck.
tell alexander he has good taste.
may have been a pile of shit but it looked pretty good.
2008 STi
Intake
Turboback
AP
 Old 11-09-2010, 08:34 PM   #37
Trail of Fail
Dano's Avatar
yeah looks like a giant hole in the back of the bay...I gotta think of something to put back there LOL.
yea it needz a EWG sitting pretty right on top...
 Old 11-09-2010, 10:38 PM   #38
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
man im getting excited.... 6 puck clutch in 2 weeks...and BT in about a month or so....
hope my shit dont blow up....if it holds ill be a happy camper
djuosnteisn (11-16-2010), dougefresh_ (03-19-2011)
 Old 11-09-2010, 10:41 PM   #39
aaronc7's Avatar
Groans: 370
whoa whoa... why are you posting in your BT thread, shouldn't you be moving threads?? you made the thread... what happened to leading by example???
 Old 11-09-2010, 10:43 PM   #40
Dan, looking forward to impressions and some flow numbers with this manifold!
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/atp-3071r-swap-how-lenny-gets-bt-63559/
Boost Tapering Suggestions (GT3071R - Stock Block) This thread Refback 06-15-2011 04:10 AM
Turbo upgrade? This thread Refback 03-31-2011 01:44 PM
Turboaufladung » Internes Wastegate This thread Refback 01-31-2011 11:05 AM
APT 3071R ANMSPD3 MazdaSpeed 3/6 - Big Turbo Builds 47 04-16-2014 11:51 AM
Toyota exec tries to cool plug-in fever Haltech Automotive News 0 06-12-2008 07:20 AM
Toyota exec tries to cool plug-in fever Haltech Automotive News 0 06-11-2008 05:50 PM
Page generated in 0.61238 seconds with 35 queries
