 Old 02-24-2011, 08:43 PM   #1
zx2man's Avatar
Posts: 1,356   (View Stats)
Hi David,
Thanks for the inquiry and sorry for the late reply. The ext WG housing is essentially the same housing but with some mods done at casting. The A/R is the same, but the external wastegate port is significantly larger than the internal wastegate port on the internally gated housing. If you already own a V44 (larger MVR size flange) and you want to be able to bolt up to the MVS flange we put on the new housing, we could make you an adapter to step from one size to the other but you would end up with two v-band clamps on that one joint.
This is my response from ATP turbo.
I also asked him how I could run a 44mm mv-r on the mvs=38mm flange.
So anyways, yes A/R is the same size. Hope this helps.
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
JBARONE SHIFTERPLATE
COBB RSB
KONIG WHEELS/HANKOOK TIRES
zx2man is offline   Reply With Quote
The Following 3 Users Say Thank You to zx2man For This Useful Post:
EwMPS (02-25-2011), triplejumper18 (02-24-2011), wette460 (03-07-2011)
4" maf housing cageyvet MazdaSpeed 3/6 - Big Turbo Builds 63 02-05-2011 11:10 PM
ATP fail housing vs. T3 .82 A/R housing BrianZX10R MazdaSpeed 3/6 - Big Turbo Builds 23 12-08-2010 04:34 PM
big maf housing mason MazdaSpeed 3/6 - Turbo Induction 2 11-21-2010 08:11 AM
.64 or .82 turbine housing? Jarods7920 MazdaSpeed 3/6 - Turbo Induction 12 05-02-2009 09:43 AM
DIY Intake / MAF Housing CaptainKRM Mazdaspeed3/6 General Discussion 40 01-29-2009 01:11 AM
Page generated in 0.23844 seconds with 21 queries
