 Old 06-10-2016, 08:20 PM   #1
D1Sano's Avatar
Posts: 7   (View Stats)
D1Sano has a spectacular aura aboutD1Sano has a spectacular aura about
Default ATP GTX3076R EWG fittment issues
Well I ran into an issue getting the EWG to clear the downpipe so I ordered the 90 degree adapter which ideally would work but I clocked by turbo to utilize the under mount piping.
Excuse my ignorance but from a performance aspect would it be stupid to have a pipe fabbed to bring the waste gate to where im holding it in picture 1? I would obviously have a support bracket welded to hold the weight. Again, please excuse my ignorance I just don't want to give up my under mounted piping if i don't have to!
Thanks for the input.
2008.5 CWP MS3
2008.5 True Red MS3
2007 True Red MS3
2007 Cosmic Blue MS3
D1Sano is offline   Reply With Quote
 Old 06-11-2016, 01:24 AM   #2
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
You could have a EWG elbow fabbed onto the manifold but it won't likely fit well with how low cyl #1 runner is. I say scrap this and get a Cp-e LTR and Kozmic dump tube or FJ performance's stock location turbo manifold if you can afford to switch.
 Old 06-11-2016, 06:21 AM   #3
Vader's Avatar
Posts: 1,651   (View Stats)
Vader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the world
Groans: 45
Fabing an adapter pipe should be fine. And cheaper than a 800 - 1k manifold.
Have one made, run it, and if you have issues, only then consider dropping more money.
I have the same on a GTX3071, but with the 90 elbow. Never had a single issue.
Originally Posted by mikelevi View Post
...When you have 600 lbs of faggot in your car, you are much slower than someone with 10 lbs of dick.
Vader is offline   Reply With Quote
 Old 10-20-2016, 09:27 PM   #4
impossible's Avatar
Groans: 30
I have same dp and turbo and gate placement as OP, decided to go with a used ATP dp which seems like one of the few turbos that work flawless with the gate being directly on the hotside
 Old 10-21-2016, 08:16 AM   #5
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
I can confirm the metal catted ultimate racing v2 dp fits with that turbo.
 Old 10-21-2016, 08:42 AM   #6
broda's Avatar
Posts: 375   (View Stats)
+1 Fits with the same DP on a HTA3576. I'll have the DP for sale eventually but definitely not in time to help you out OP.
MS3 GTX3076r EWG JCMS07 MazdaSpeed 3/6 - Big Turbo Builds 32 10-09-2016 09:21 PM
GOING BT- GTX3076R JB11SPEED3 2010 MS3 - Big Turbo Builds 4 09-29-2015 12:29 PM
GTX3076r brandonbaldy 2010 MS3 - Big Turbo Builds 13 06-13-2014 12:28 PM
XcelXL fittment BlckMs3 MazdaSpeed 3/6 - Turbo Induction 4 12-11-2012 10:29 PM
fittment question Hamilton69 2010 MS3 - Wheels & Tires 13 06-01-2011 11:08 PM
Page generated in 0.25474 seconds with 25 queries
