![]() | | #41 | ![]() |
![]() Join Date: Apr 2009 Location: Bethpage, New York
Rep Power: 4481 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,850
Groans: 778
| Not Ranked : 0 score 56k on motor stock block GT35R ATP fail for now--T3 soon 44mm Tial ewg---14 lb spring Medievil Manifold, resurfaced cpe 4 inch TIP PnP Intake mani--vcts delete ATP DP CP-E cai BSD front and rear MM FMIC SB egr delete TT-rear diff bushing inserts EDIT:more nonsense... hks bov, turbo XS and greddy--switch when i want MAXXXbore 63MM TB Turbosmart in cabin MBC soon getting a PTP HPFP and injector seals some of these things are on the car now others are waiting for the nice weather to come around for the install I plan to make as much AWHP as I can with the ATP fail hotside on the 35r until I reach 100k on the motor then I will build bottom up and go from there with the SB hopefully making upwards of 500AWHP....if thats even possible by the time I build my motor. as of now I'm in the stock block boat with many other as I have faith in my motor. a couple things in my list I don't even have yet like the SB but I'll have these things ready by the time I install my 35r and rape brians anus. i'll make a thread when I do the instal
__________________ 2003 SilverStone Grey Honduh S2000 ![]() ![]() Last edited by SpeedSixxx; 03-10-2010 at 08:32 AM. |
| The Following User Says Thank You to SpeedSixxx For This Useful Post: | madvillain (03-10-2010) |
![]() | | #42 | ![]() |
| Banned ![]() ![]() Join Date: Jul 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 126
| Not Ranked : 0 score Greddy EBC solenoid is dead. Going to try and pick up a mbc tomorrow and drop the car off. Even if he starts tuning it again tomorrow I doubt it'll be finished b/c tuning with the AP is pretty time intensive. I'll wait until I see the end results of the tuning but I'm expecting good results. |
| The Following User Says Thank You to cageyvet For This Useful Post: | SpeedSixxx (03-09-2010) |
![]() | | #43 | ![]() |
Groans: 778
i hate ebc..they fail all the time , aside from being fail
__________________ 2003 SilverStone Grey Honduh S2000 ![]() ![]() | |
![]() | | #44 | ![]() |
| Not Ranked : 0 score That's the second greddy profec b spec II that I've owned where the boost control solenoid died. Its a bad ass EBC when it works but the boost control solenoids have a reputation for failing. |
![]() | | #45 | ![]() |
![]() Join Date: Mar 2008 Location: STL, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,984
| Not Ranked : 0 score My progress so far: IC disconected Intake removed Inlet removed EBC removed Top heat sheild removed Turbo studs removed DP disconnected 3/10 manifold nuts removed Things left to do: Finish removing manifold Drain oil and change filter Disconnect oil/water lines Remove stock turbo Replace alternator and 'big-3' wires Install new oil/water lines Install new turbo w/open element filter Reconnect DP Test fit new manifold for fitment/clearence (once received) Ceramic coat the manifold Install manifold Wire up EGT gauge Install breather filter on valve cover Install EWG Reconnect IC Refill oil Go get dump pipe made Wash car Claybar & wax Log Tune Log Tune Log Tune Log Log Log Then shortly in the future: Procure PTP S2 FP Install said FP with the dual walbro in-tank set up Change out 0.5 bar spring for 1.0 bar spring in EWG Log Tune Log Tune Log Tune Log Log Log |
| The Following 5 Users Say Thank You to ATE BALLER For This Useful Post: | 802MS3 (03-09-2010), Fagwagon (03-10-2010), kilik2 (03-09-2010), madvillain (03-09-2010), SpeedSixxx (03-10-2010) |
![]() | | #46 | ![]() |
Rep Power: 3168 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score thats an awesome list ATE, hopefully the new wife isn't giving you too much heat about all the work
![]() | | #47 | ![]() |
| Not Ranked : 0 score lol, not a problem. Who do you think bought me the turbo |
![]() | | #48 | ![]() |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
Groans: 105
| Not Ranked : 0 score I'll give an update on my ride. I have built motor and pnp head. My welder ordered the piping last week for ewg setup. Once that is done I can put the 3071 on and start tuning for 400+hp. I'm running the car now with stock turbo and it is screaming for mercy. Spiking to 20 psi on stock tune.
__________________ 2012 WRX HB w/mudflaps yo! |
![]() | | #49 | ![]() |
![]() Join Date: May 2009
Rep Power: 215 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 68
| Not Ranked : 0 score sorry im hiding
__________________ 07 speed3, vivid has my car under house arrest 03 miata, top down |
| The Following 4 Users Say Thank You to conso For This Useful Post: |
![]() | | #50 | ![]() |
Groans: 78
(Thread Starter) | Not Ranked : 0 score The day has finally come. I've just received images of my kit, the one off the shop car, and will begin its transit over to the lovely state of Arizona tomorrow morning on a Fedex truck. I HOPE to see it by the weekend, as Fedex delivers on Saturday, but I won't hold my breath.
| The Following User Says Thank You to madvillain For This Useful Post: | KeysMS3 (03-10-2010) |
![]() | | #51 | ![]() |
![]() | | #52 | ![]() |
Groans: 78
(Thread Starter) | Not Ranked : 0 score I chose to take it, and got a lot of money back. its better than waiting for god knows how much longer for the production kit, and I know the shit fits. Since the latest mid march date can no longer be met, i threw in the towel on it.
![]() | | #53 | ![]() |
![]() Join Date: Jul 2009 Location: Elk Grove, Ca
Rep Power: 147 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score You seem like a cool guy so I wish you luck on it. I wouldn't expect anything wonderful off of a shop car though. |
![]() | | #54 | ![]() |
| Not Ranked : 0 score ^ failure has spoken. |
| The Following 2 Users Say Thank You to Lex For This Useful Post: | madvillain (03-11-2010), MarkyMark (03-11-2010) |
![]() | | #55 | ![]() |
![]() Join Date: Mar 2010 Location: Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 778
| Not Ranked : 0 score madvillain is cool beans so I wish him luck as well "HOPEFULLY" everything turns out alright |
| The Following User Says Thank You to zx2man For This Useful Post: | madvillain (03-11-2010) |
![]() | | #56 | ![]() |
![]() Join Date: Dec 2009 Location: Fontucky, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,096
Groans: 1,364
Groaned at 589 Times in 386 Posts
| The Following User Says Thank You to felt For This Useful Post: | mpsanger6 (03-15-2010) |
![]() | | #57 | ![]() |
Groans: 78
(Thread Starter) | Not Ranked : 0 score I am by no means hanging on RR's nuts like many think, nor have I been this whole time. I simply want to share my experience with them, which has for the most part been positive, and for those who are on the edge to keep all the options open. Although I've had a good experience, the situation is obviously not ideal. I will not share any of the pictures until I have the kit in my hand, but I can genuinely say that the kit looks great. There are a few things that still need to be worked out with Brice, but I am pleased to be on the home stretch, I just want everything to be over. For those thinking that I'm getting bent over and fucked by getting the used kit, I am not. The price at which I'm purchasing it is more than fair, and the difference of money was back into my bank account within a day. Those who speak of RR as if they're sipping margaritas down on the beach in Mexico, are those who have never once spoken to them. Would I make the same choices as they have thus far? Hell no. But, its not my company. Anyways, everything is on a fedex truck and en route. Fingers are crossed that it will reach me on Saturday
| The Following 2 Users Say Thank You to madvillain For This Useful Post: | KeysMS3 (03-11-2010), SpeedSixxx (03-11-2010) |
![]() | | #58 | ![]() |
Groans: 1,364
| Not Ranked : 0 score |
| The Following User Says Thank You to felt For This Useful Post: | madvillain (03-11-2010) |
![]() | | #59 | ![]() |
![]() Join Date: Aug 2009 Location: Kingwood, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,102
Groans: 50
| Not Ranked : 0 score Good luck man!!! Keep us posted. A lot of people had a lot of hopes and dreams riding on this kit, so let's pray that it is actually legit. I'm pullin for ya bud. |
| The Following User Says Thank You to banditscout For This Useful Post: | madvillain (03-11-2010) |
![]() | | #60 | ![]() |
| Not Ranked : 0 score They did some more tuning on the car today, things went by alot faster and the car would be done except for an unforseen error on my part. My tial 44mm ewg has a small blue spring and can only hold 14lbs. of boost with the mbc. My tuner said I need to run a large yellow with the small blue. The first tuning session i had on monday he was working on tuning out the KR i was seeing. Today, he continued doing that and on the first run @ 12 psi the car dynoed 279whp but it was runnning lean and hit boost cut. He added some fuel and adjusted the boost cut and the car made 288 whp @ 12 psi, afr at the sniffer @ the end of the exhaust was 12.11.12.20. KR was at 0 so he decided to up the boost on the MBC. First, run with the mbc turned up, boost spike ups to 20psi immediately and he lets off so the mbc can be turned down. Looking at the dyno graph from that run, 20+ psi is in the turbo's efficiency range b/c there was a dramatic shift of the graph to the left and the slope of the graph was very steep. He dials down the mbc, boost ends up holding 14psi @ the next run and the car made 308whp. He told me to he'd try to finish tuning the car later this week after I get another wastegate spring, but he said the car should definetly make 400. The highest KR i see now is .35 and my afr's are in the low 11's @ WOT. My car is being tuned by Huy Tran (inline racing). |
| The Following 5 Users Say Thank You to cageyvet For This Useful Post: | -cj- (03-13-2010), 06Speed6 (03-14-2010), Fagwagon (03-14-2010), kilik2 (03-14-2010), madvillain (03-13-2010) |
![]() | | #61 | ![]() |
Groans: 78
(Thread Starter) | Not Ranked : 0 score cagey- sorry if i missed it, but what kind of dyno are these numbers on? congrats on the progress
| The Following User Says Thank You to madvillain For This Useful Post: | cageyvet (03-13-2010) |
![]() | | #62 | ![]() |
![]() | | #63 | ![]() |
| Not Ranked : 0 score My progress as of now: stock manifold removed stock alternator removed stock turbo removed greddy e-01 removed stock oil lines removed began test fitting turbo broke my finger Things still to do: modify new/old oil drain lines find missing water line place all new oil/water lines mount new turbo install iragge alternator run all 'big-5' wires per iragge's instructions install fresh serpentine belt recharge and install battery test fit ptp manifold when received wire egt gauge and sensor ceramic coat ptp manifold install ptp manifold with ewg construct dump pipe for ewg |
![]() | | #64 | ![]() |
![]() Join Date: Sep 2009 Location: CREVE COUER, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 263
Groans: 75
| Not Ranked : 0 score lol how did you break your finger? |
![]() | | #65 | ![]() |
| Not Ranked : 0 score haha, I was trying to break loose the bolt holding the turbo to the bracket undernieth it, and when it finally went, so did my fist right into a bulge in the firewall. It's not really broken I don't think, but more my knuckle is all fucked up, swollen, and throbbing. |
![]() | | #66 | ![]() |
![]() Join Date: Mar 2008 Location: orange county
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,807
Groans: 137
| Not Ranked : 0 score ATE- might i suggest some medication like the one in your avatar. should solve some issues.
__________________ 2008 STi Intake Turboback AP |
![]() | | #67 | ![]() |
![]() Join Date: Jun 2008 Location: Atlanta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 98
| Not Ranked : 0 score Well it will be awhile before my Turbo setup gets installed and running since the motor is STILL blown. Still on the fence somewhat concerning whether to build the block I got or buy a running low mileage motor and keep that one stock. But I am now leaning towards building this block as I really want to see what my setup will make as no one else has run this yet. Exh mani : custom one off T3 top mount Ceramic coated Turbo : Turbonetics T3/T4 hybrid 50 trim with a .63 A/R hot side ceramic coated BCS : Perrin ECBS EWG : Tial 38mm w/ 14 lb. spring. DP : Custom one off ceramic coated down to the flex joint Screamer pipe is a custom one off that is also ceramic coated and is VTA I was gonna sell my stuff (and still may) but was only interested selling it all together and not piece meal as I wanted to see what it would do. But since I mocked it up on my motor thats on my engine stand the damn thing is just to damn sexy looking and I know I'd be kicking myself if it put up good numbers. So what the hell is another $5 K when you consider what I've got in the car already right???
__________________ I BUSTED SOCKS CHERRY AND IT WAS GOOOOD![]() I'VE BEEN PLAYING DUMB FOR SO LONG ITS NOT A GAME ANYMORE IF IT WAS WORTH THE TIME IT TOOK YOU TO GET EVEN THAN WHY DIDNT YOU TAKE A LITTLE MORE AND GET AHEAD? |
| The Following 8 Users Say Thank You to SneakyP86 For This Useful Post: | 802MS3 (03-14-2010), danesti (03-14-2010), Docnox (03-15-2010), kilik2 (03-14-2010), madvillain (03-14-2010), SpeedSixxx (03-14-2010), spnkr21 (03-14-2010), superskaterxes (03-15-2010) |
![]() | | #68 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 944
Groans: 127
Groaned at 40 Times in 31 Posts
| Not Ranked : 0 score ATE it might be broken get that shit looked at. I split my knuckle in half and just told everyone that its cool, and I kept playing basketball. The next day I looked like I had a grapefruit with fingers. |
![]() | | #69 | ![]() |
Groans: 75
| Not Ranked : 0 score Still left to do....pretty much everything lol. This weekend im going to try and at least get the PTP internals installed if that goes well i will be taking the mani/dp/turbo off and mocking up the holset onto the medival mani to figure out what position im going to have to weld the new t3 flange on, if it goes well i might even have time to chop off the stock flange and tack up the t3 so i can bring it to someone who knows what they are doing with a welder lol. |
![]() | | #70 | ![]() |
| Not Ranked : 0 score meh, I'll be alright, lol. The worst part is having to type at work. Plenty of herbal suppliments should keep the pain at bay til it's healed. Every one of my fingers had been broke at least once before I was even in highschool. Gotta love little-league football! |
![]() | | #71 | ![]() |
![]() Join Date: Nov 2008 Location: pensacola FL
Rep Power: 580 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 213
Groans: 32
shit you might be done b4 me. FML!!!
__________________ 2008.5 Mazdaspeed 3 Built Engine- CP Pistons 9.5:1/Pauter Rods -- Holset Big Turbo-- DNP Manifold w/ewg -- Tial 44mm EWG -- STRATIFIED EBCS CP-E Catback Exhaust -- Custon Downpipe-- CUSTOM 3.25 MAF-- CP-E 4 inch Turbo Inlet, custom Proto-type Injector Seals COBB AP CUSTOM TUNE-- COBB FMIC Fuel Pump Internals -- Devils Own Meth Kit #7 -- Spin-on Oil Filter -- 3 Step Colder Plugs -- TWM Short Shift Custom Center Gauge Pod -- Custom 1 Of A Kind MS3 Gauges -- Halo Lights -- Front Lip -- Emblem Less Grill -- Rice Gen1&2 Hood Hybrid 513whp MS3<-- for now (sold)1993 RX7 FD build in progress!!!!!! | |
| The Following User Says Thank You to austin102085 For This Useful Post: | Fagwagon (03-16-2010) |
![]() | | #72 | ![]() |
Groans: 75
![]() | | #73 | ![]() |
![]() Join Date: May 2009 Location: N Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 523
Groans: 77
| Not Ranked : 0 score just got done putting my 3071, manifold, ewg, ebc, and half of the fmic back. i am excited to finish up tomorrow!
__________________ 2008.5 MAZDASPEED3 GT TRUE RED ***GONE*** ![]() 2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19 |
| The Following User Says Thank You to dizzin9 For This Useful Post: | madvillain (03-17-2010) |
![]() | | #74 | ![]() |
| Not Ranked : 0 score Drove over some incomplete construction on a pothole, couldn't change lanes and did some nice damage to my fmic. On a good note, I installed a (large green & small yellow) ewg springs along with the stock boost control solenoid. I would recommend using the stock solenoid over a mbc b/c it has eliminated the boost spike i was seeing from running a larger wastegate and is consistent. |
![]() | | #75 | ![]() |
Groans: 78
(Thread Starter) | Not Ranked : 0 score Bump.. anyone else make any progress? I iz stuck until I get back in town and have my ECU from Cp-e. |
![]() | | #76 | ![]() |
Groans: 105
| Not Ranked : 0 score Was running 15psi and started dialing afr. Car was running great! Then the turbine inlet broke. Bummer.
![]() | | #77 | ![]() |
Groans: 32
| Not Ranked : 0 score i got my car back. its running good. just feels like it has less power then my reworked k04 on the ap. im useing the sb now with out any of the flashes. (holset h1c at 15psi ewg spring. )
![]() | | #78 | ![]() |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
| Not Ranked : 0 score Damn i hope DCR makes good thats bullshizel |
![]() | | #79 | ![]() |
Groans: 105
| Not Ranked : 0 score Well I'm not even going to try and call them. I'm just gonna bring it to the welder and have him put a nice bead on it.
![]() | | #80 | ![]() |
Groans: 78
| MazdaSpeed 2.3L DISI Turbo Blown Engine Resource Thread | JimmyMac | MazdaSpeed 3 - Engine, Transmission & Driveline | 1441 | 06-25-2019 06:11 PM |
| Big turbo chicken thread | phailerider | MazdaSpeed 3/6 - Turbo Induction | 111 | 07-01-2010 06:18 AM |
| Corb's Thread of Progress | corbs | Appearance - WHITE | 98 | 09-17-2009 05:19 PM |
| Mazdaspeed 2.3L DISI Turbo Blown Engine Resource Thread | Kennosuke | MazdaSpeed 6 - Engine, Transmission & Driveline | 1 | 04-27-2009 01:26 AM |
