  • 1 Post By StayBroke
 Old 06-09-2013, 06:55 PM   #1
ESA
ESA's Avatar
Posts: 120   (View Stats)
ESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond repute
Default Big turbo's speed6 with Corksport divorced DP
How many speed 6 are out there running big turbo with a Corksport divorced DP?
Have you had any Issues with It because of the divorced DP?
Thanks.
[B]06 Speed6
Prosport Boost,Oil Tem.,Oil Press Gauge/Corksport DP/Corksport Catless RP/ITV22/Autotech Internals/Cobb AP/Corksport SRI (Stage 2)/JBR RMM/TWM stage2/CPE Safe Seal.
GT3071 EWG Kit on stand by.... Waiting for more funds for suporting mod...
ESA is offline   Reply With Quote
 Old 06-09-2013, 07:11 PM   #2
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
I dunno about the speed6, but the ATP wastegate flapper most definitely does not work with the MS3 corksport downpipe. It doesn't fit inside of the divorced section so its unable to open fully.
'08 CWP MS3 w/ T3 3071r
helmetface (06-09-2013), rfinkle2 (06-14-2013)
 Old 06-09-2013, 07:30 PM   #3
ESA
ESA's Avatar
Thanks for the response 802MS3.
I already have the CS DP (First purchase with little knowledge of the platform and future plans with the car).
The question Is because I'm planning on going big (GT30) and want to know what problems will I face with this DP.
Will I have to change the CS DP or can I avoid spending more money on another DP and just go EWG GT30.
I hope some of the MS6 guys can comment on this.
Thanks anyway.
[B]06 Speed6
 Old 06-10-2013, 01:06 PM   #4
Nuch3412's Avatar
Posts: 14   (View Stats)
Nuch3412 is a jewel in the roughNuch3412 is a jewel in the roughNuch3412 is a jewel in the rough
I just purchased a GT3076 about a week ago from import image and they told me that my CS DP would not bolt about properly. Had to go with a whole with a complete bolt on turbo kit with a DP. That's my experience in the matter. Don't know to much but every little bit helps.
Nuch3412 is offline   Reply With Quote
 Old 06-10-2013, 01:15 PM   #5
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
It will bolt up if it is a mazda hotside flange, but if you got a standard 3076, then it probably won't work. I would personally choose a different DP though, because the CS downpipe is optimized for the stock turbo.
@CorkSport;
 Old 06-10-2013, 01:45 PM   #6
StayBroke's Avatar
Posts: 2,075   (View Stats)
You could just sell the dp, then buy a ebay v band dp.
ciezczak1 likes this.
The Following User Says Thank You to StayBroke For This Useful Post:
SLOWHATCH (06-10-2013)
 Old 06-10-2013, 02:07 PM   #7
ESA
ESA's Avatar
I'll probably end up doing that but I want to se If I can avoid that and use It with a EWG If possible (Still researching).
If I sell It I'll be shipping from Dom. Rep. because here I have not seen another speed 6 yet.
[B]06 Speed6
 Old 06-10-2013, 02:19 PM   #8
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
@CorkSport;
This makes me a sad panda as I had plans to go BT as well. Hopefully Corksport pops in and clarifies.
2012 Velocity Red Mica
 Old 06-10-2013, 02:23 PM   #9
KusteLokal's Avatar
Posts: 2,664   (View Stats)
KusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the world
Groans: 124
@CorkSport; @kritz;
Sent from GalaxyS3
1995 Miata 1.8
2006 MS6 Sold
KusteLokal is offline   Reply With Quote
 Old 06-10-2013, 02:31 PM   #10
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
Even if it does "work" with BT, even if going EWG, it's still a restriction IMO. I would sell it and get something else. Definitely a great DP for stock frame turbos though. Curious if it works with the GTX2867.
The Following User Says Thank You to SLOWHATCH For This Useful Post:
breakfstincluded (01-11-2014)
 Old 06-10-2013, 02:38 PM   #11
Police - Grammarhead
Vansquish's Avatar
If you're looking to sell, I could be interested!
 Old 06-10-2013, 02:51 PM   #12
CorkSport's Avatar
Posts: 3,416   (View Stats)
The flapper design with the ATP versions we have seen the door hits the divider due to the different design they used. The downpipe does bolt up which means you would have to do some work to get the clearance needed to run it.
-Derrick
WWW.CORKSPORT.COM
breakfstincluded (01-11-2014), rfinkle2 (06-14-2013)
 Old 06-10-2013, 02:52 PM   #13
jomc111's Avatar
Posts: 585   (View Stats)
jomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the worldjomc111 is the leader of the world
I have it on my3 running the 3076 I have never seen any signs that the flapper is hitting the pipe when I have had it off but I do get creep above 22psi
2012 Cadillac CTS-V
2014 focus st
2010 Taurus sho- sold
2009 speed 3 gt cwp -was once a monster -sold
jomc111 is offline   Reply With Quote
 Old 06-10-2013, 03:05 PM   #14
turbo toshi's Avatar
Posts: 149   (View Stats)
turbo toshi is the leader of the worldturbo toshi is the leader of the worldturbo toshi is the leader of the worldturbo toshi is the leader of the worldturbo toshi is the leader of the worldturbo toshi is the leader of the worldturbo toshi is the leader of the worldturbo toshi is the leader of the worldturbo toshi is the leader of the worldturbo toshi is the leader of the worldturbo toshi is the leader of the world
Not sure if im beating a dead horse but I just put my 3076 on last night with the CS divorced DP and I had not issues BUT im running EWG so no flapper in the way
GT30R | Tial 38mm wastegate | HTP 3.5" intake | Corksport DP | BC Coilovers | JBR Camber Arms |JBR Trillogy Mounts | JBR OCC | Turbosmart Dual Port | Treadstone TR11 FMIC | Autotech HPFP Internals | NGK 2 stage colder plugs | Custom Straight Pipe | EVO X wheels
TUNED BY LEX
BROLO IS THE MOTTO BRO Movement
turbo toshi is offline   Reply With Quote
 Old 06-10-2013, 03:34 PM   #15
Dimenus's Avatar
Groans: 33
I'm very curious of this as well. I would run this or a BNR.
 Old 06-10-2013, 04:02 PM   #16
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
Who cares if you can't control the boost, run ALL OF IT!!!
rigor (06-10-2013)
 Old 06-10-2013, 04:08 PM   #17
sidekick's Avatar
Groans: 47
Don't buy the ebay DP unless you want to deal with cracks.
 Old 06-10-2013, 04:25 PM   #18
StayBroke's Avatar
Had one on my 3 and now the 6....no problems
sent to you from me
Corksport Downpipe speed6 boosted_speed6 MazdaSpeed 3/6 - Turbo Induction 2 04-03-2011 11:11 PM
Page generated in 0.36451 seconds with 32 queries
