Like Tree118Likes
 Old 10-08-2013, 11:41 AM   #41
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
What wastegate should I run? Rob is a busy guy and hasn't replied back yet on which to get. Was gonna order percisions 46mm gate and 4-port.
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
The Following User Says Thank You to mazdafreak For This Useful Post:
Speed.mazda.3 (11-07-2018)
 Old 10-08-2013, 11:44 AM   #42
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
I have a tial MVR (44mm) and really like it.
mazdafreak (10-08-2013)
 Old 10-08-2013, 12:17 PM   #43
mazdafreak's Avatar
Groans: 124
Rob said he wants to run a large gate w/ low spring, idk if that means 44 or 46mm gate.
713whp/569wtq!
 Old 10-08-2013, 12:39 PM   #44
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Well if you go with an external wastegate, then there is no real way to compare this build to a stock turbo.
Pickles Tune in progress
The Following 7 Users Say Thank You to himurax13 For This Useful Post:
btstarcher (10-08-2013), chuckms6 (10-19-2013), Easter Bunny (10-08-2013), Elvisrosales88 (10-25-2013), lilred (10-08-2013), memin (10-08-2013), phate (10-08-2013)
 Old 10-08-2013, 12:55 PM   #45
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
Originally Posted by mazdafreak View Post
Well we/or u kno that my car was done at 332whp. I don't see any k04 ever going over 340whp, unless happy dyno.
All I'm looking at is if I can make over what I did last yr with billet wheel, ewg will just hopefully help up top like u said. Results should give a good idea what turbo is capable of. Just trying to get it all done before all this cold weather moves in!
I just don't kno what wastegate @rfinkle2; wants me to run, since he doesnt like messaging me back through email haha , so I can order all those parts
Had 2 NATOR AZ locals pull 340 something in feb on the dyno with the k04. 1 with meth (speed3), other with 100%E85 (speed6). I can pull the dyno sheets, there somewhere here on MSF.
I myself only put down 338/377 on 3gallons of E85 and no meth at the time .
I am very interested in your results from this.. I will be building my block next year and debating CR as I type this. But I'll end up with some stupid big turbo I'm sure lol.
 Old 10-08-2013, 03:52 PM   #46
Voltwings's Avatar
Posts: 3,713   (View Stats)
44 and 46 both use the same flange, so thats really just up to whatever flange you put on there... may as well go 46 if you ask me, i dont think theres such a thing as "too big" with wastegates.
mazdafreak likes this.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 10-08-2013, 06:06 PM   #47
mazdafreak's Avatar
Groans: 124
Well we'll get an idea on what the turbo is capable of making either way.
Sweet thanks, I was planning on going 46mm once I went bt next yr, so thanks for making my mind up! Was looking at precisions 46mm gate.
713whp/569wtq!
 Old 10-08-2013, 06:22 PM   #48
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Not really. If you make over that 330hp with the new setup, can you say with any certainty that x% of that came from the ewg and y% of that came from the wheel? Nope, not at all. If we had anyone else running an ewg K04, we might be able to make some educated guesses, but we simply don't.
-06 MS6
-Corn fed 07 MS3 - Sold
Chuthor (10-08-2013), mazdafreak (10-08-2013)
 Old 10-08-2013, 06:23 PM   #49
Chuthor's Avatar
Posts: 435   (View Stats)
Chuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the world
Science!
Sent from my XT1060 using Tapatalk 4
2012 CWP w/ Tech; Damond Motorsports RMM; AT Internals; CS Stage II Intake; Cobb DP; Phate Tuned; KW V1 Coilovers; Damond SSP; DM OCC
Chuthor is offline   Reply With Quote
The Following 2 Users Say Thank You to Chuthor For This Useful Post:
phate (10-08-2013), Speed_j23 (10-09-2013)
 Old 10-08-2013, 06:27 PM   #50
Eth Fiend
phate's Avatar
I suppose, if you had a motivated tuner, that you could have both gates hooked up, but have tunes with one of them locked so they couldn't operate anymore...then we really could say that yes, the new wheel is doing x% with the internal gate, and with the ewg it is doing y% more.
-06 MS6
The Following 5 Users Say Thank You to phate For This Useful Post:
Easter Bunny (10-08-2013), El_Diablo (10-09-2013), mazdafreak (10-08-2013), redboat (04-08-2014), SLOWHATCH (10-15-2013)
 Old 10-08-2013, 07:18 PM   #51
mazdafreak's Avatar
Groans: 124
How would u keep the gate closed? Well I may get the cpe manifold. Or I can just make my racebuilt one ewg, and use a block off plate. Then I can tune with and without ewg if rob is willing to do that or clint? Haha.
Dumb question, how does a 4-port get hooked up?? With/without ewg.
713whp/569wtq!
 Old 10-08-2013, 07:44 PM   #52
if your gate is to big you loose all your resolution for controlling boost at low WGDC values. This would be more prevalent on a smaller turbo as well......
no one needs a gate bigger then a 38mm unless your running something like 8lbs on a 35R or bigger
The Following 5 Users Say Thank You to superskaterxes For This Useful Post:
06Speed6 (10-08-2013), Easter Bunny (10-10-2013), El_Diablo (10-09-2013), mazdafreak (10-08-2013), Voltwings (10-08-2013)
 Old 10-08-2013, 07:53 PM   #53
mazdafreak's Avatar
Groans: 124
Well i hope rob can chime in soon and lmk what gate to run, but this was the last email i got from him the other day.
"I'm very tempted to say that we should try a large gate, with a very low spring... Maybe even consider a 4 port solenoid with a low crack pressure ... something like 5 psi in the gate... the 4 port will handle the remainder.
—That is just my first thought considering our primary focus is creep on the high CR engine."
713whp/569wtq!
 Old 10-08-2013, 09:45 PM   #54
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Ill be running a 38mm gate and I am looking at 600+hp after everything is done. For the 4cyl crowd, the 44mm gates are for people running 700+hp.
Big wastegates are for big v8 people that wanna run a huge turbo with low boost. They have to vent most of the exhaust flow through the wastegate, hence the need for huge wastegates.
For our engine, its like trying to modulate the water level of a kiddy pool with the flood gates on the Hoover Dam.
2006 Mazdaspeed 6
The Following 10 Users Say Thank You to 06Speed6 For This Useful Post:
09Speed3Z (10-25-2013), btld_ls1 (11-29-2013), chuckms6 (10-19-2013), Easter Bunny (10-10-2013), El_Diablo (10-09-2013), mazdafreak (10-08-2013), ms3rick (10-19-2013), redboat (04-08-2014), rfinkle2 (10-10-2013), superskaterxes (10-09-2013)
 Old 10-08-2013, 11:29 PM   #55
Voltwings's Avatar
AHH, the guy who built my engine has done a ton of turbo builds and said i wanted a 46mm wastegate so i said ok.
Past:
-Sold-
-Sold-
Current:
Easter Bunny (10-10-2013), Speed_j23 (10-09-2013)
 Old 10-09-2013, 03:22 AM   #56
SparkySparks's Avatar
Posts: 1,314   (View Stats)
Maybe that was part of the reason why your daily driving suffered?
On Order:
Coming Soon:
DIY Projects:
The Following 4 Users Say Thank You to SparkySparks For This Useful Post:
Easter Bunny (10-10-2013), El_Diablo (10-09-2013), himurax13 (10-10-2013), Voltwings (10-09-2013)
 Old 10-09-2013, 09:23 AM   #57
Voltwings's Avatar
my daily driving suffered because i had a giant turbo that lagged more than i wanted it too. it drove perfectly smooth, just slow haha.
Past:
-Sold-
-Sold-
Current:
Koke382 (10-19-2013)
 Old 10-09-2013, 10:23 AM   #58
I was thinking more from the loss or resolution in addition to the large turbo made daily driving not so fun.
On Order:
Coming Soon:
DIY Projects:
 Old 10-09-2013, 10:32 AM   #59
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
I just sold my JGS wastegate but they're awesome and have a very fast response time due to being a piston actuated wastegate. The 40mm gate would be plenty for anyone on here but it would still allow for fine tuning. They'll fit on 36-40mm flanges while being way more compact than a similarly sized Tial.
 Old 10-09-2013, 11:18 AM   #60
Voltwings's Avatar
Maybe, I had the same gate on my 3071, but I suppose its been so long now its really hard to say.
Past:
-Sold-
-Sold-
Current:
 Old 10-09-2013, 12:06 PM   #61
mazdafreak's Avatar
Groans: 124
Going with a 44mm wastegate with a 5psi spring
713whp/569wtq!
The Following 2 Users Say Thank You to mazdafreak For This Useful Post:
Easter Bunny (10-17-2013), rfinkle2 (10-10-2013)
 Old 10-09-2013, 01:01 PM   #62
speeding3's Avatar
Posts: 118   (View Stats)
speeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond reputespeeding3 has a reputation beyond repute
Groaned at 17 Times in 8 Posts
I looked all I over the web for that compressor wheel I can find anything lol. do you possibly have a link to the site or company u purchased from. I saw in the pics you had a ebay package checked ther as well no luck thanks bro
speeding3 is offline   Reply With Quote
 Old 10-09-2013, 01:20 PM   #63
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
he purchased it from turbolabs usa. You can see their return address on the packaging.
EDIT: He also says he bought the wheel from Turbolabs in a post on the first page......
here is where they talk about the k04 services they offer:
ko3 ko4 ko6 Turbo upgrade for audi, Volkswagen, sky, mazda 3, cobalt | Proudly doing turbo upgrades for mitsubishi, audi, BMW, Volkswagen, Buick, lawnmowers and more!
The Following 4 Users Say Thank You to 2.0t03speed For This Useful Post:
mazdafreak (10-09-2013), redboat (04-08-2014), rfinkle2 (10-10-2013), SLOWHATCH (10-15-2013)
 Old 10-10-2013, 04:54 PM   #64
mazdafreak's Avatar
Groans: 124
Just got my dual MD oil catch can installed.......Ordered my 44mm wastegate, Mac 4-port ebcs.
Just rly waiting on the turbo. Taking a lil longer than expected on it. Had usps crack the housing during shipping. Which is shitty.
713whp/569wtq!
 Old 10-10-2013, 06:08 PM   #65
man you still have enough space for the coupler/clamp to get a good seal.
The Following User Says Thank You to 2.0t03speed For This Useful Post:
 Old 10-10-2013, 06:28 PM   #66
mazdafreak's Avatar
Groans: 124
Yes I kno, he is still gonna machine it. But I filed a complaint through usps.
But the wheel turbo gave me, the backing plate was cut flat for some reasom, so now the guy needs to make a custom made spacer to fit onto wheel.
713whp/569wtq!
Mazdazilla6 (10-10-2013)
 Old 10-11-2013, 07:25 AM   #67
got pictures of what you are talking about?
 Old 10-15-2013, 05:00 PM   #68
mazdafreak's Avatar
Groans: 124
Sry dont have an pics, i can try and pull a pic up from google or something.....Basically the backs of the turbo wheels have a lil hump in them to space them out when on the turbo rod, but this one was cut flat, so they guy had to make a spacer to space it enough or wheel would sit to much inward and not close enought the the comp housing.
EDIT--
@2.0t03speed; I updated post so you know what im talking about lol
See how the turbo wheel has a spacing on the table, doesnt sit flat on table, its like a cone shape that comes outwards. Mine was flat so had to have a exact size spacer to fit.
Heres another pic, see bottom of wheel that cone like shape volcano on bottom....Mine wheel came without that, so guy needed to make a spacer that exact size to space it enough on the turbo shaft.
I talked to my machine guy and turbo will be done tomorrow and shipped out!
Also my wastegate and 4-port ebcs came in and a filter for my dual occ setup for the vented can.
2.0t03speed likes this.
713whp/569wtq!
The Following 5 Users Say Thank You to mazdafreak For This Useful Post:
2.0t03speed (10-15-2013), BigRedSpecial (10-16-2013), dsb_chicago (10-19-2013), El_Diablo (10-15-2013), Voltwings (10-15-2013)
 Old 10-15-2013, 06:05 PM   #69
Posts: 2,237   (View Stats)
humm your not Lucky with that turbo, looks like they copied the front of the Wheel correctly but forget the back or maybe it was for another turbo brand with a different back housing ?
Hope it won't cost you that much for the spacer.
 Old 10-15-2013, 06:17 PM   #70
mazdafreak's Avatar
Groans: 124
For some reason the wheels turbolab has the backs were all cut flat. Spacer was like $50, no big deal.
Its all good. Everything will be done tomorrow. Next is get runner welded onto my manifold for a wastegate and I'm set to install everything.
713whp/569wtq!
 Old 10-15-2013, 09:11 PM   #71
i would be pissed. i wonder what they do when they upgrade peoples turbos for them
 Old 10-15-2013, 10:03 PM   #72
mazdafreak's Avatar
Groans: 124
This is what turbolab wrote me after finding out.
"no its not. Its very common to use a spacer with the pte and garrett turbos because some many wheels vary with 2.5 and 5mm super backs. tell him to use the old thrust collar as a spacer it will work perfectly"
That spacer has to be exact, unless somehow thurst collar spaces it enough but sounds rigged and not safe.
I wasn't gonna go through the hassle of returning and trying to get the right one. I said fuck it and had him make a spacer.
713whp/569wtq!
 Old 10-15-2013, 10:13 PM   #73
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
Fuck yo couch
The Following User Says Thank You to forcedinduktion For This Useful Post:
mazdafreak (10-15-2013)
 Old 10-15-2013, 10:23 PM   #74
mazdafreak's Avatar
Groans: 124
Originally Posted by forcedinduktion View Post
Fuck yo couch
Ill fuck u on ur couch
713whp/569wtq!
skiptowncat (10-15-2013)
 Old 10-17-2013, 06:44 PM   #75
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Hmmmm... So I happen to have a good low mileage k04 hanging around. Turbolab said they would rebuild the k04, convert to the 50x61mm and rebalance the rotating assembly for $350...
That is just cheap enough to make me want to try it and see how it turns out. I am inquiring about their turn around times and a few other things. Unfortunately, my search on 'turbolab' hasn't really yielded a lot of information to give me any sort of real world confidence in them.
MINI H1 6.0 - CAR LED TAILS
The Following 5 Users Say Thank You to dale_gribble For This Useful Post:
btstarcher (10-17-2013), El_Diablo (10-17-2013), mazdafreak (10-17-2013), redboat (04-08-2014), speed23 (10-17-2013)
 Old 10-17-2013, 07:48 PM   #76
mazdafreak's Avatar
Groans: 124
That's why I didn't go with them. No info and super sketchy when I called them. They didn't even say like who os was, not turbolab or anything. And sounded like they were at a party....I hung up cause I thought I dialed the wrong number.
I have the 50x65mm wheel from them but went with my own turbo guy that i trusted....I should have results soon enough tho!
713whp/569wtq!
 Old 10-18-2013, 04:11 PM   #77
The turbolab guy has been emailing me back from his iphone, so it's just a guy with a shop I gather. His communications haven't been the best, but he is responsive. He sent me a pic of a Mazdaspeed k04 he just reworked; I attached it here.
I am still gathering some information but for $350 it is almost worth a shot. Sounds like a few week turnaround and he has wheels in stock.
The Following 6 Users Say Thank You to dale_gribble For This Useful Post:
blackms3_71 (10-18-2013), dsb_chicago (10-19-2013), Easter Bunny (10-18-2013), El_Diablo (10-18-2013), mazdafreak (10-18-2013), redboat (04-08-2014)
 Old 10-18-2013, 04:16 PM   #78
Here's the guy's facebook page-
https://www.facebook.com/TurboLabAmerica
Youtube video channel.
 Old 10-18-2013, 06:05 PM   #79
maisonvi's Avatar
Groans: 75
Yeah it just seems like a guy who works out of a small shop. He is a nice guy and helpful, but not the fastest with stuff. It is good enough for me though, and his work seems quality.
I have a chain of 55 emails back and fourth with him. So he is super patient as well.
Sent from my XT907 using Tapatalk 2
The Following 3 Users Say Thank You to maisonvi For This Useful Post:
dale_gribble (10-18-2013), El_Diablo (10-18-2013), mazdafreak (10-18-2013)
 Old 10-18-2013, 06:24 PM   #80
was that your turbo he took a picture of?
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/billet-k04-comp-wheel-upgrade-155583/
Mps 3 and cx7 question - Page 3 This thread Refback 08-18-2014 06:27 AM
Custom Billet Wheel Spacers hnda etr MazdaSpeed 3/6 - Wheels & Tires 9 01-10-2011 11:45 PM
Extreme wheel Upgrade DIY ... Feels faster ;-) jamesthebikeguy MazdaSpeed 3/6 - Wheels & Tires 15 07-28-2009 01:37 PM
Billet compressor wheel upgrade for the stock turbo!!!! ptperformance Mazdaspeed3/6 General Discussion 52 05-13-2009 05:20 PM
endlink upgrade needed w/ ASB upgrade? red07 MazdaSpeed 3/6 - Suspension & Brakes 12 11-26-2008 01:34 AM
Page generated in 0.60240 seconds with 36 queries
