Like Tree53Likes
 Old 05-02-2016, 02:58 PM   #121
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Originally Posted by ryguy 3 View Post
You didn't read did you? He's talking about CS injector seals and going from the S3 - S4.
Guess not.
2007 Mazdaspeed3 GT
 Old 05-03-2016, 06:36 AM   #122
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Why would you upgrade from an S3 to a CS anyway man? That's a sidegrade, not an upgrade.
Hope the S4 works for you. I'm probably going the opposite direction (smaller) after having the S3 honestly but I can understand the appeal of big turbo power especially for how cheap the S4 is. It's an amazing value.
Going with the BNR S4 for the turbo, going with CS for the injector seals.
 Old 05-12-2016, 08:46 AM   #123
iamareios's Avatar
Posts: 79   (View Stats)
iamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to behold
22psi on the S4 sure feels good!
allo80 and blackms3_71 like this.
(PD tuned) 397hp/358tq 91/100% meth
BNR S4, XS v3 manifold, CNT dp, OBX cbe, JBR ebcs, AUTOTECH hpfp, PnP/vtcs del. manifold, SU TMIC, HTP 3.5" intake, Synapse DV, D10 100% meth kit, Damond OCC VTA, AFR failsafe, Bilstein b8's/Cobb springs, stuff
iamareios is offline   Reply With Quote
 Old 07-10-2016, 11:39 PM   #124
StevenW's Avatar
Posts: 268   (View Stats)
StevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the worldStevenW is the leader of the world
Groaned at 8 Times in 7 Posts
Originally Posted by Chef_boi_r_u_dum View Post
S3 for me.
My decision was made based on not wanting to max the stock block/internals, not wanting to use aux fueling/meth and not wanting to buy a new intake.
Old thread bump, but what intake did you run? RPM's website says the s3 inlet is 2.36 while the k04 is 2.16. Will I be able to stretch a silicone JBR intake for the k04 onto the s3?
StevenW is offline   Reply With Quote
 Old 07-11-2016, 11:24 AM   #125
Yes.
StevenW (07-11-2016)
 Old 10-14-2016, 09:50 AM   #126
Lex2007's Avatar
Posts: 574   (View Stats)
Been driving on an almost complete 91 tune S4 for sometime now and can say hands down the S4 is superior to the S3... I remember when the S3 was claimed as the best turbo for daily driving and stock block <<< that can't be said anymore.. The off/on boost delivery is perfect with smoother and stronger power... The best part? the power band is widened up to perfection... It has a strong hit (maybe not as fast as the s3) but the continues chugging of the turbo all the way to redline just has a different, kick ass feel now... inherents a good side effect; the feel of taller gearing. WIN
Even though I really want to start my meth tune... it's at a real good place with just 91 so no big deal.
Your comment caught my attention. Thanks for posting this. Im trying to decide between Corksport drop in turbo, or BNR3 or BNR4 on stock everything accept for a CAI and HPFP internals. Everyone is complimentary of the 3 turbos but without being able to make a comparison between them. You did.
I dont care about the $200 price difference between stage 3 and 4 and I dont plan to rebuild the motor. I need a reliable DD and I need a replacement on my leaking ko4 with 113k miles on it, and soon.
allo80 likes this.
 Old 10-14-2016, 09:55 AM   #127
tmillner's Avatar
Posts: 621   (View Stats)
Not sure where the cs spoils at but the s4 spoils at 3500. You will get better response with s3 and if you arent going to build block can get close to maxing block out with s3 and better response. Just something to think about
Sent from my SM-N930P using Tapatalk
 Old 10-14-2016, 10:09 AM   #128
Lex2007's Avatar
Its tough to make these decisions without the benefit of driving cars with the different turbos.
Someone claims the CS creeps boost very easily.
Who knows!?
 Old 10-14-2016, 10:12 AM   #129
tmillner's Avatar
Come 2 savannah ga you can drive my s4 ms3.
 Old 10-14-2016, 10:21 AM   #130
Lex2007's Avatar
you driven an s3 equipped car?
Sometimes I wonder if its even worth it...its just gonna spin tires in 1st and 2nd, then Im gonna need high-vibration motor mounts, then the clutch is gonna take a shit, then injectors will leak. But I digress....
EDGE Autosports, please make a RWD conversion kit!
 Old 10-14-2016, 11:48 AM   #131
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
If everything is stock except for the HPFP and CAI (so not even exhaust) then I'd go for the S3 because it will have more grunt down low. Of course you need to carefully tune the response and load up to 3500rpm but that's another story. Without an exhaust you will push back a lot of heat into the turbine wheel and not that you will not make the expected power but you may also damage it prematurely.
As for the CS and S4 turbos they flow more up top while sacrificing about 200-300rpm in the low 3000rpm range which is still beneficial because it will not have the rod snapping response there and will be able to push more air above 6000rpm without adding flames so it. The response around 2500-3000rpm area with these slightly larger turbos it's definitely something you'll have to get in use to or learn, because they will have at least one more second of delay compared to the S3 and more compared to the factory turbo.
tmillner likes this.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
Whitebullet (12-26-2018)
 Old 10-14-2016, 12:06 PM   #132
ryguy 3's Avatar
Posts: 353   (View Stats)
Hahaha no
 Old 10-14-2016, 12:16 PM   #133
tmillner's Avatar
Never driven s3. But even with the k04 and my mods the car was pretty useless in 1st and 2nd.
 Old 10-14-2016, 12:35 PM   #134
MSP6's Avatar
Posts: 1,246   (View Stats)
1st and 2nd will be less useful in a K04 car than in a BT car, your logic is backwards..
 Old 10-14-2016, 12:42 PM   #135
tmillner's Avatar
No my logic is right.
 Old 10-14-2016, 01:23 PM   #136
MSP6's Avatar
That was more directed at @Lex2007;
A K04 car tuned with bolt ons etc is more likely to spin 1st-2nd than an S3, S4, etc. The faster the spool, the faster the tires will break loose.
 Old 10-14-2016, 01:47 PM   #137
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
So you're saying that a k04 car will spin more tire than an s3 because it's a "quicker spooling" turbo? Well, shit, why not just go straight to a 6266? Then you're sure to hook since they spool so slow, right??
It's about torque, not spool. If there is sufficient wheel torque to overcome available grip, she'll spin. You spin more in 1st and 2nd because gearing gives you more torque at the wheels.
For example, a turbo like an S4 may spin you all the way through 2nd where a k04 will spin you up to 4krpm because the S4 can maintain torque up the revs.
-Wetz
QFT
MD1032 (10-14-2016)
 Old 10-14-2016, 02:00 PM   #138
MSP6's Avatar
Sigh, so being at work and not wanting to go into a lengthy post, yes I said spool. You are correct it is "torque" not "spool". The quicker spool of the K04 brings on more low end torque, at a faster rate than say an S4 will. This is more likely to break the tires loose in 1st and 2nd in terms of regular driving, part throttle, half throttle situations that would likely not happen wither a larger turbo. I'm not talking who will spin them in 3rd and 4th on the highway.
My case is that his argument of "..its just gonna spin tires in 1st and 2nd" as an argument against going BT makes no sense. A slower spooling turbo will help you modulate wheelspin better than one that is at 20psi at 3k before you blink.
 Old 10-14-2016, 02:04 PM   #139
MD1032's Avatar
Groans: 143
...or you can just not drive like a gorilla and modulate the throttle instead of just flooring it and spinning your tires.
Cheapspeed likes this.
2007 Mazdaspeed3 GT
Cheapspeed (10-14-2016)
 Old 10-14-2016, 02:16 PM   #140
xfeejayx's Avatar
Groans: 78
Your argument is jumping around here, but I think I see what you're getting at.
Your argument is modulation, not turbo related. "The torque comes faster." However, you could always turn a k04 down if you really wanted to. I don't have FWD problems, but my load is mapped linearly to APP to allow me better modulation. This is tuneable via throttle, wastegate, whatever. Having a bigger turbo would mean you would have to WG even more, or trim even more of it's capability.
To say a bigger turbo capable of more torque will be better for wheelspin is nonsensical. More torque is more likely to spin. Period.
Now to unsub before I get driven nuts again.
-Wetz
QFT
allo80 (10-16-2016)
 Old 10-14-2016, 03:37 PM   #141
mituc's Avatar
Groans: 111
The smaller the turbo the greater the torque at low RPM and the quicker the spool. That exactly is the recipe for wheel spin. With a GTX3071 (which spools like a CS or S4, but is slightly more potent up top) on pump gas I was able to floor it in 2nd and not need a new pair of tires in the front next morning. WOT in 2nd in a slightly tuned K04 equals wheel spin.
With the K04 I only added a TMIC and an intake without even a tune (yeah, I was stupid back then) and every WOT event in 1st and 2nd was a smoke show.
 Old 10-14-2016, 06:54 PM   #142
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
I've learned to feather the pedal in 1st and 2nd for part boost that helps me keep traction and push me into my seat. Spinning tires is boring unless I'm under an overpass and want to be obnoxious.
MD1032 (10-14-2016)
 Old 10-15-2016, 11:30 AM   #143
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
No problem. I say wait for the S4 v2 .. nothing has been wrong with mine other than it needed a lot added preload with the meth tune just to hit 24 psi.. maybe this will be addressed with v2. It's really a good performing turbo and with a good tuner, it can be tuned to respond to pretty much any preference..
Edit.. sorry if the last line sounds like I'm selling on an infomercial lol..
In all honesty I have experienced tunes by two well known tuners(for the S4). Tuner A is like a magician and every revision has been great with throttle/turbo response I prefer.
Tuner B, well, let's just say I've had good revisions to something that was super hyper ninja shit.. which I hated and made drivability garbage. At the end he just wasn't as polished of a tuner as people think he is.
The reason for 2 tuners is cause tuner A is very busy and slow with kicking out revisions...got impatient and went to tuner B.. Now I'm back with tuner A, he is worth the wait.
Moral of the story. Choose a good tuner!
 Old 10-15-2016, 02:35 PM   #144
blackms3_71's Avatar
Posts: 2,250   (View Stats)
Tuner b sounds like justin lol.
memin likes this.
 Old 10-15-2016, 03:22 PM   #145
Thanks for not asking ... but no, it aint Justin.
I have used justin with the K04 so has my brother with his ST.. no complaints here
 Old 10-15-2016, 04:08 PM   #146
Tiner's Avatar
Posts: 116   (View Stats)
Tiner will become famous soon enoughTiner will become famous soon enough
Tiner is offline   Reply With Quote
 Old 10-16-2016, 07:28 AM   #147
MSP6's Avatar
It's not jumping around. It's specific to a K04 vs a larger turbo in 1st-2nd gear only. Your argument was that its gearing that causes the wheelspin in 1st and 2nd. By that logic removing any/all turbo from our car and driving it NA, or having the K04, or having a GT70 frame turbo would all be the same?
You can't typically achieve full boost even on a K04 in 1st and 2nd gear let alone an S3, S4 or larger.
 Old 10-16-2016, 08:57 PM   #148
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
When does the S4 v2 come out? And what concerns does it address?
The Following 2 Users Say Thank You to BuddySpeed3 For This Useful Post:
blackms3_71 (10-20-2016), We're All Thieves (11-22-2016)
 Old 10-17-2016, 12:26 AM   #149
Not sure... I would call them.. I don't think there is a "concern" .. well at least for me; even needing more preload isn't a concern since it can be specific to setup and really the opposite of harmful.
BuddySpeed3 (10-18-2016)
 Old 12-22-2018, 07:06 PM   #150
Whitebullet's Avatar
Posts: 24   (View Stats)
Whitebullet has a little shameless behaviour in the past
Read all 4 dang pages of this thread and still undecided about bnr s3 or s4. I like the earlier spool with more punch like the k04. But am i missing out on the s4 power band
When does s4 spool, i’ve seen 3100 and 3500 in this same thread. Compared to what rpm for K04 and S3?
Thanks
06 ms6, sp63 stage 1, bnr, atp downpipe, cpe tmic, 91 octane
Read some good intel on bnr’s site. S3 for my build
Quote from their site:
If your car is fully bolted with high performance fuel pump internals we suggest an S3 with a tune. Fully bolted with added methanol injection go with the S4 and a tune. Stock engine internals, don’t even think about doing an S5 or S6!
Whitebullet is offline   Reply With Quote
 Old 12-23-2018, 11:41 AM   #151
Coffeespeed's Avatar
Posts: 17   (View Stats)
Coffeespeed has a spectacular aura aboutCoffeespeed has a spectacular aura about
Researched b/w CS, S3 and S4 for a year. Went with an S4 and so glad that I did. I got data logs from the pulls that I am doing right now for the E-tune on this thread, so use that to see if spool characteristics is what you are looking for. I got cats and a TMIC.
Coffees genpu going BNRS4 and stuffs.
Coffeespeed is offline   Reply With Quote
The Following User Says Thank You to Coffeespeed For This Useful Post:
Whitebullet (12-23-2018)
Page generated in 0.51989 seconds with 37 queries
