Like Tree53Likes
 Old 03-29-2016, 07:31 PM   #81
tmillner's Avatar
Posts: 621   (View Stats)
The s4 cab take you beyond the stock motor if you ever decide to go that route
Sent from my SM-N920P using Tapatalk
 Old 03-29-2016, 07:40 PM   #82
broda's Avatar
Posts: 375   (View Stats)
To be fair if you're planning on getting a built engine you may as well go a step further than an S4 anyway.
Nitro likes this.
The Following User Says Thank You to broda For This Useful Post:
Code Monkey (04-01-2016)
 Old 03-29-2016, 09:03 PM   #83
Dennisms3's Avatar
Posts: 198   (View Stats)
Dennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant future
Originally Posted by Chef_boi_r_u_dum View Post
Still torn between the two. Is it worth the extra few hundred bucks if you aren't going to be running meth or e85?
correction: $150. Ignore me. I'll retreat back to the corner.
If you want to make more power on pump gas then yeah, its worth the extra 150$. Plus so much more room for power later down the line.
memin likes this.
Dennisms3 is offline   Reply With Quote
 Old 03-29-2016, 09:56 PM   #84
Dennisms3's Avatar
Default BNR S3 or BNR S4
Here is a comparison of my e30 mix k04 tune vs my bnr on 91 octane tune. I did pull timing in the mid range after this k04 log and on a dynojet I put down 319whp 335wtrq with the K04 on e30 mix. I haven't dynoed the bnr yet.
The Following User Says Thank You to Dennisms3 For This Useful Post:
Whitebullet (12-26-2018)
 Old 04-01-2016, 08:39 PM   #85
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
The thing I like about the BNR turbo kits is that they are fairly priced and are very close to a direct bolt on, and offer the kind of performance I'm looking for. I'm currently on the stock block, so I'm mainly looking for more power up at higher rpm's which the k04 just can't provide, but I also don't want to sacrifice responsiveness too much either
It's clear to see that the BNR flows a lot more air at higher rpm and makes more power even on 91 octane, exactly what a stock blocker needs lol
Originally Posted by Rambo View Post
Been lurking for awhile, I have no plan on building the block so I think the s3 will fit my needs. Don't need anymore than 350 whp as I find hooking even with PSS is difficult and no plan on meth either. Also in Canada e85 is almost impossible to find.
That's why I run a gallon of methanol in the gas tank. Works wonders with 94 octane. I'm able to get away with 17 degrees of timing, and 18.5 psi at 6k rpm on the K04 with no knock. On top of that I run WMI with a small nozzle to keep BAT's cool and power consistent. Just need an S4 to take full advantage of my setup. I also don't plan on building the block any time soon, but if I do the S4 should be plenty.
Rambo likes this.
Last edited by BuddySpeed3; 04-01-2016 at 08:41 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-01-2016, 08:41 PM   #86
tmillner's Avatar
Where do you get your methanol? Consumer places or online?
Rambo likes this.
 Old 04-01-2016, 08:52 PM   #87
Based on the dynos and logs I've seen, on shipped WG preload, the S4 is spooled by ~3500-3600. Spools like a mid turbo, flows like a bigger one.
So to get more boost with less wgdc, would it be necessary to adjust the wastegate actuator to a higher threshold?
Would it be possible to over boost at lower rpm's if the wastegate actuator is adjusted too high on the s3 or s4? I know the K04 does this all the time. I had to zero out wgdc until 3000 rpm to keep boost in check at lower rpm's.
I read somewhere that this was happening with the BNR's and then they started shipping them with a lower wastegate setting to open around 12 psi.
 Old 04-04-2016, 09:36 AM   #88
iamareios's Avatar
Posts: 79   (View Stats)
iamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to behold
Just picked up an S4 for $900! Only had 1500miles clocked on her.
Sent from my SM-G935T using Tapatalk
(PD tuned) 397hp/358tq 91/100% meth
BNR S4, XS v3 manifold, CNT dp, OBX cbe, JBR ebcs, AUTOTECH hpfp, PnP/vtcs del. manifold, SU TMIC, HTP 3.5" intake, Synapse DV, D10 100% meth kit, Damond OCC VTA, AFR failsafe, Bilstein b8's/Cobb springs, stuff
iamareios is offline   Reply With Quote
 Old 04-04-2016, 09:40 AM   #89
Chef_boi_r_u_dum's Avatar
Posts: 380   (View Stats)
Chef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond reputeChef_boi_r_u_dum has a reputation beyond repute
S3 for me.
My decision was made based on not wanting to max the stock block/internals, not wanting to use aux fueling/meth and not wanting to buy a new intake.
2016 Mustang "Echo" Boost in sexy ass green.
2008 silver MS3 -Sold-
Chef_boi_r_u_dum is offline   Reply With Quote
 Old 04-04-2016, 10:13 AM   #90
Dennisms3's Avatar
S3 for me.
Same, but i got a bigger intake. Lol
 Old 04-05-2016, 09:27 AM   #91
Methyl Hydrate or Air Brake Anti freeze, I get it from Canadian Tire, they sell 1 gallon for 10 bucks. I also heard Home Depot may carry the same thing, but never checked.
The Following User Says Thank You to BuddySpeed3 For This Useful Post:
Liquidsilver (03-03-2017)
 Old 04-05-2016, 09:33 AM   #92
tmillner's Avatar
I'm a diesel mechanic i got that air brake stuff everywhere. Never really looked at it. Knew it was alcohol, didn't but 2 and 2 together.
Thanks for the info
The Following User Says Thank You to tmillner For This Useful Post:
 Old 04-06-2016, 12:17 AM   #93
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
Gotta admit.... even only being on my 2nd revision 91 tune...the S4 feels great... so far max boost is a hair under 19 psi and 11 degrees of timing (@ 6.4k).. Can't wait till 91 tune is complete so I can get started with the meth tune.
Jakeypoo and iamareios like this.
 Old 04-07-2016, 05:25 PM   #94
My gosh that thing is gonna rip! It's crazy how much power its making on 91 alone. It's just feeding the engine way more efficiently.
 Old 04-07-2016, 08:37 PM   #95
Well I didn't mention anything about the power it's making lol.. it should be around 320whp right now (based on butt dyno) ... but it's how it makes and feels with that power that is impressive.
 Old 04-07-2016, 10:47 PM   #96
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
Why is this thread even still going? All this theory talk, when you can just buy it and find out for yourself. Makes more power on pump gas, can be maxed out on a built motor and aggressive tune with sufficient fuel and has better boost control than even the v2 BNR S3. If you dislike the turbo for whatever reasons It won't be the end of your car, I ran the GTX28676R and will now be going BNR S4 this go around before trying out a Precision turbo on a vband setup. JUST DO IT.
BuddySpeed3 (04-09-2016)
 Old 04-08-2016, 12:39 AM   #97
sent from my Nexus 6P
impossible (05-01-2016)
 Old 04-14-2016, 10:22 PM   #98
ryguy 3's Avatar
Posts: 353   (View Stats)
Does anyone know the gains from a 3 inch intake over cs "stg2"?
My thought was I'd rather re-buy an intake then a turbo if I want bigger
I gained about 20 g/s when I went from the corksport stage 2 to the jbr Tru 3".
 Old 04-15-2016, 09:23 AM   #99
voodoo2crue's Avatar
Posts: 371   (View Stats)
voodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the world
Got the S4 in yesterday, here's some BNR porn
Liquidsilver likes this.
2012 MS3 VRM/w Tech
Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom
1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather
Plugs-NGK LTR7IX-11(6510)
Oil-RP 10/30
Tires-235 40 18 Federal 595 rsrr
Brakes-EBC Yellow pads with ATE 200 fluid
Check out my wheelwell page here. If your a member hit me up.
https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/
voodoo2crue is offline   Reply With Quote
The Following 2 Users Say Thank You to voodoo2crue For This Useful Post:
BuddySpeed3 (04-24-2016), djrich26 (04-17-2016)
 Old 04-26-2016, 03:03 PM   #100
iamareios's Avatar
This was from last weekend Currently tuning with Freektune
voodoo2crue and Liquidsilver like this.
The Following User Says Thank You to iamareios For This Useful Post:
 Old 04-26-2016, 03:05 PM   #101
Mine was a pain. Took me all of sunday to install. I'm also tuning with Freektune right now.
Yay for bigger turbos!
 Old 04-26-2016, 03:11 PM   #102
iamareios's Avatar
I picked mine up used so it didn't come with any exhaust studs or nuts. That was my only problem. Extracting the old rusted ones off my turbo and reusing them. PITA! Otherwise i did it without having to remove the exhaust manifold.
 Old 04-26-2016, 03:13 PM   #103
Maybe that's why. I did it with the manifold and stock dp in place.
 Old 04-30-2016, 05:09 PM   #104
Been driving on an almost complete 91 tune S4 for sometime now and can say hands down the S4 is superior to the S3... I remember when the S3 was claimed as the best turbo for daily driving and stock block <<< that can't be said anymore.. The off/on boost delivery is perfect with smoother and stronger power... The best part? the power band is widened up to perfection... It has a strong hit (maybe not as fast as the s3) but the continues chugging of the turbo all the way to redline just has a different, kick ass feel now... inherents a good side effect; the feel of taller gearing. WIN
Even though I really want to start my meth tune... it's at a real good place with just 91 so no big deal.
The Following 2 Users Say Thank You to specvspeedfreak For This Useful Post:
impossible (05-01-2016), Whitebullet (12-26-2018)
 Old 05-01-2016, 12:47 AM   #105
impossible's Avatar
Groans: 30
@OP: Don't let your dreams be dreams.
Atticaz likes this.
 Old 05-01-2016, 04:54 AM   #106
tmillner's Avatar
Side note, wtf is he doing? Transformers rattle his brain?
 Old 05-01-2016, 04:59 AM   #107
impossible's Avatar
Groans: 30
lmao idk hollywood brings out the weird in people but I still love Shia Labeouf on screen, dude has come a LONG WAY from Even Stevens lol
 Old 05-01-2016, 07:44 AM   #108
He's trying to motivate you. Don't let your memes be dreams.
 Old 05-01-2016, 07:47 AM   #109
tmillner's Avatar
Was the rhyme by design?
 Old 05-01-2016, 09:07 AM   #110
Yeah, he made it that way and even doing it with a green screen so people can do what they want with it.
 Old 05-02-2016, 11:50 AM   #111
Installed the S4 this weekend and tune is still in progress. Here's where I'm at versus the k04 in similar temps(82F). All mods are the same other than the turbo and intake. I always stopped my k04 pulls well short of redline as the power always would fall off to under 280ish with the DJ factor, now it's balls to the wall till redline.
2012 MS3 VRM/w Tech
Oil-RP 10/30
 Old 05-02-2016, 12:18 PM   #112
damn almost 24 psi? Who is tuning it?
Mine will be targeting 21 psi on the next (final) revision.
 Old 05-02-2016, 12:31 PM   #113
tmillner's Avatar
Running e33?
 Old 05-02-2016, 12:46 PM   #114
Self tuning targeting 23.5 at RL Voodoo's BNR S4 Tune in progress
Running e33?
On E25 atm
2012 MS3 VRM/w Tech
Oil-RP 10/30
 Old 05-02-2016, 12:47 PM   #115
tmillner's Avatar
I wish i was smart enough to self tune. S4 keeps pulling doesnt it
 Old 05-02-2016, 12:53 PM   #116
Pump gas?
Yes it does, it's like driving a different car.
2012 MS3 VRM/w Tech
Oil-RP 10/30
 Old 05-02-2016, 01:12 PM   #117
Pump gas?
For now, yes.. Will be moving to meth tune next.
Should've asked if you were running E... Makes sense; but still a bit high maybe
 Old 05-02-2016, 01:13 PM   #118
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
I've decided to go s4. My car has been down because of the 1 of the POS oem injector seals blowing, and CS was out of their beauties until the end of April. While all this has happened I decided i'll be taking off my s3, and will be getting the s4. And the seals should be here tomorrow.
So yeah, I'll be putting an s3 up for sale this week/weekend sometime. Just have to stop being lazy an actually remove it.
And go green again I see.
voodoo2crue likes this.
 Old 05-02-2016, 02:00 PM   #119
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Why would you upgrade from an S3 to a CS anyway man? That's a sidegrade, not an upgrade.
Hope the S4 works for you. I'm probably going the opposite direction (smaller) after having the S3 honestly but I can understand the appeal of big turbo power especially for how cheap the S4 is. It's an amazing value.
2007 Mazdaspeed3 GT
 Old 05-02-2016, 02:09 PM   #120
ryguy 3's Avatar
You didn't read did you? He's talking about CS injector seals and going from the S3 - S4.
Page generated in 0.56054 seconds with 32 queries
