Like Tree47Likes
 Old 09-06-2013, 09:07 AM   #161
1sicms3's Avatar
Posts: 18   (View Stats)
1sicms3 is a jewel in the rough1sicms3 is a jewel in the rough1sicms3 is a jewel in the rough
Default BNR S3 Swap How To
First post updated with link to tuning thread.
As for my first impressions, this swap seems to have resulted in similar spool to stock, I cant really tell the difference except by examining logs and even then I am not sure they are comparable since my last log with the K04 took ~500R rpm from 3000 to spool to 20psi @ 70deg and the BNR took about the same to spool to 18.5psi @ 105deg
So as a whole spool is similar, but the top end is where the difference is. The BNR is holding 18.5psi to redline without breaking a sweat in 105deg ambients, where the K04 was falling off to 16.5psi @ 70deg.
1sicms3 is offline   Reply With Quote
 Old 09-06-2013, 09:40 AM   #162
1sicms3's Avatar
im going with bnr stage 1, would i have to do a retune?
 Old 09-06-2013, 09:57 AM   #163
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Why?
No.
Pickles Tune in progress
 Old 09-10-2013, 01:21 PM   #164
He Hate Me's Avatar
Posts: 460   (View Stats)
He Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the world
Just incase anyone needed some new nuts for the Turbo to Mani or Turbo to Downpipe, here is the part #: JE1040355, $6.12 EACH at my dealer!
Some spaces are definitely a PITA with the stock downpipe, but doable. Wasn't able to get my turbo bracket off from the 2 bolts on the block, those suckers were on their GOOD! Even heated, PB'd, LW, them and nothing.
Thank you for this write up as well Ziggo, helped a lot.
Might possible add a 22mm (7/8) Oxygen Sensor Socket to required tools to remove the top o2 sensor on the downpipe to get the stock heatshield off to reach the downpipe nuts.
All nuts for the mani, and downpipe are definitely all reachable from the top, if anyone is wandering.
1/2" breaker bar made life easy for all the nuts.
He Hate Me is offline   Reply With Quote
The Following User Says Thank You to He Hate Me For This Useful Post:
BoostedRide (02-20-2015)
 Old 09-10-2013, 05:40 PM   #165
himurax13's Avatar
Groans: 255
The 15mm copper colored exhaust nuts from edgeauto are like a dollar each and are much beefier ...
 Old 09-10-2013, 05:42 PM   #166
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
And because they're copper they don't seize up like the OE ones do.
The Following 3 Users Say Thank You to silvapain For This Useful Post:
Funkster777 (09-10-2013), ItsNox (09-15-2013), LatinKraze (09-10-2013)
 Old 09-10-2013, 05:48 PM   #167
himurax13's Avatar
Groans: 255
True but they require a bit more effort to install due to the beefier oval design.
On certain downpipes, only the OEM nuts will work where the downpipe is really close to the stud.
silvapain (09-10-2013)
 Old 09-10-2013, 05:59 PM   #168
He Hate Me's Avatar
The Following 4 Users Say Thank You to He Hate Me For This Useful Post:
atvfreek (09-10-2013), Code Monkey (10-28-2013), Micha (11-11-2015), silvapain (09-10-2013)
 Old 09-10-2013, 06:10 PM   #169
How many of you have installed the latest BNR with the 2 port WG actuator? Have you had issues increasing boost and when you do, it spikes in the upper RPMs?
 Old 09-10-2013, 06:15 PM   #170
beachshoer's Avatar
Posts: 2,039   (View Stats)
THAT doesn't sound good.....
2010 BM MS3
BNR S3
STRATIFIED TUNED
Other Mazdas in my stable
2010 VR MS3 Wifes Ride
1999 Miata
2001 Miata LS
 Old 09-10-2013, 06:26 PM   #171
I've tuned a few of the new ones now and I am seeing a trend in how boost control works. Just want to get more data.
Nliiitend1 (09-10-2013)
 Old 10-27-2013, 08:28 PM   #172
tokoam's Avatar
Posts: 199   (View Stats)
tokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant future
Groaned at 17 Times in 4 Posts
I think you and I were having this issue at the beginning it has since gotten better.. but it still happens with upper gears like 5th or 6th gear it spike's.Boost guage showing 23-24 psi ap showing 22.7 but its only for a split sec and then drops back to 18-19.
tokoam is offline   Reply With Quote
 Old 10-28-2013, 03:44 PM   #173
atvfreek's Avatar
Posts: 7,787   (View Stats)
Do you have a 3 bar map sensor? Of not then that is the stock map sensor being maxed out at 22.7psi.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 10-28-2013, 03:53 PM   #174
aviator79's Avatar
Posts: 3,934   (View Stats)
Im confused. So it used to only have one port? Mine has 2, so for now hooked it up like stock as using stock EBCS. When I install my 3 port I was going to use the bottom for the EBCS and the top for my boost only line to Synapse rather than Ting into EBCS line as it is now. Will that work?
 Old 10-28-2013, 04:09 PM   #175
himurax13's Avatar
Groans: 255
Are you talking about the Wastegate solenoid? The recent versions of the BNR Stage 3 come with 2 ports now. I forgot how @Lex; said to route the vacuum lines for it.
 Old 10-28-2013, 05:18 PM   #176
aviator79's Avatar
No the wastegate actuator. Mine has the two port just like stock turbo. Dont have time to install my 3 port yet so ran comp port to WG port like OEM and will run top port to stock solenoid like OEM. So did you have to T off between comp port and WG port before if not using a 3 port? IDK, im just curious.
 Old 10-28-2013, 05:41 PM   #177
You can run it exactly like OEM but the restriction in the top port is not big enough to give you enough boost from what I've seen.
IMO the new WG actuator is a big step backwards for these turbos. All the new ones have been a much bigger pain to the tune than the old single port WG actuators.
LatinKraze (01-04-2014)
 Old 10-28-2013, 06:05 PM   #178
aviator79's Avatar
Not doubting you, but doesnt really make sense if the smaller port is plugged...I just want to be able to drive my car to work in the morning...slowly.
 Old 10-28-2013, 06:10 PM   #179
tokoam's Avatar
Nope still on stock map sensor I will eventually upgrade to full 3 but for the time being it is what it is.
 Old 01-03-2014, 11:52 PM   #180
RogerH's Avatar
Posts: 68   (View Stats)
RogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond repute
Groaned at 3 Times in 1 Post
I just got one of the bnr turbos with the dual port wastegate. is there anything I can do before I install it to make it easier to tune? I have a cobb ebcs I was going to install with it.
RogerH is offline   Reply With Quote
 Old 01-04-2014, 09:31 AM   #181
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
would an OEM K04 Wastegate be a better canidate then the new ones on the BNR's?
redboat is offline   Reply With Quote
 Old 01-04-2014, 03:00 PM   #182
manselainen's Avatar
Posts: 38   (View Stats)
manselainen is a splendid one to beholdmanselainen is a splendid one to beholdmanselainen is a splendid one to beholdmanselainen is a splendid one to beholdmanselainen is a splendid one to beholdmanselainen is a splendid one to beholdmanselainen is a splendid one to behold
I installed a 1 mm welding tip as restrictor in pressure line to WG as there does not seem to be a restrictor there unlike in K04 (I'm reusing stock EBCS). One thing to check: in my kit the copper crush washers for oil feed banjo bolt were too small.
3 MPS '07, BNR S3, HTP 3", ETS TMIC, Cobb catted DP, PTP HPFP internals, Bosch 3 bar MAP w/ PNP Harness, RMM, KW Variant 3, DO water/meth, Michelin Pilot Sport Cup 2 235/40-18, OZ Alleggerita, self tuned with VersaTuner E30, awaiting inspiration to build bottom end due to major blow-by @ 100 kmiles / 165 kkm
manselainen is offline   Reply With Quote
 Old 01-04-2014, 03:06 PM   #183
LatinKraze's Avatar
Posts: 804   (View Stats)
With my install the banjo supplied for the coolant line was damaged. Caused a leak whenever I fed coolant through the system. Don't know if I damaged it or it was damaged but check both faces of the banjo for imperfections. I reused the coolant hard line, custom bent lol, until I found a replacement banjo.
2016 CX-5 GT AWD
 Old 01-04-2014, 03:52 PM   #184
The banjo outlet supplied with the kit was of smaller diameter than EGR inlet where this coolant return goes. So my 6AN line was loose on banjo, causing a coolant leak. Double hose clamp hopefully did the trick in my case. It seems surprisingly difficult to get these small part kits right
 Old 01-04-2014, 06:37 PM   #185
LatinKraze's Avatar
Only when quality control starts taking a back seat
2016 CX-5 GT AWD
 Old 01-05-2014, 01:15 PM   #186
This Ziggo's how-to helped me a lot!
I wish I can put here some my experiences without having to write my own. As I continued to run stock parts (downpipe, exhaust manifold, EBCS, TIP) my case was somewhat different. Hope this info may be of some use to others.
- I removed wipers and cowl to get some more room
- I did not remove oxygen sensor but cut the DP heat shield off -> major PITA, I don't recommend it
- exhaust manifold was not removed
- all EM to turbo nuts and studs can be removed from top, same applies for all turbo to DP nuts, studs can be removed later when turbo is on the work bench
- I did not remove turbo brace, just took one bolt off to free turbo
- I removed EGR, one EM manifold stud closest to EGR and heat shield of brake fluid -> turbo was removed from side
- I reused oil feed banjo bolt crush washers as new did not fit
- I reused both oil return gaskets (BNR kit had gasket for oil line to block)
- some glue to hold bolts is your friend when installing oil return to turbo
- I reused all studs and bolts
- stock TIP was not possible to get back on without cutting rubber gasket a bit
The Following 4 Users Say Thank You to manselainen For This Useful Post:
G1sdaname (05-22-2015), ItsNox (01-05-2014), redboat (01-05-2014), Ziggo (01-07-2014)
 Old 02-20-2015, 09:20 AM   #187
BoostedRide's Avatar
Posts: 171   (View Stats)
BoostedRide is a jewel in the roughBoostedRide is a jewel in the roughBoostedRide is a jewel in the rough
Does anyone have the Mazda part#s for the EM to turbo & turbo to DP gaskets?
How many of these nuts should I order?
Last edited by BoostedRide; 02-20-2015 at 09:20 AM. Reason: MSF Database - Automerged Doublepost
BoostedRide is offline   Reply With Quote
 Old 02-20-2015, 09:25 AM   #188
Lex2007's Avatar
Posts: 574   (View Stats)
This stuff works great.
Amazon.com: Permatex 81878 Ultra Copper Maximum Temperature RTV Silicone Gasket Maker, 3 oz. Tube: AutomotiveAmazon.com: Permatex 81878 Ultra Copper Maximum Temperature RTV Silicone Gasket Maker, 3 oz. Tube: Automotive
The Following User Says Thank You to Lex2007 For This Useful Post:
 Old 02-20-2015, 09:35 AM   #189
I want to do it right as I am not doing the labor myself.
 Old 02-20-2015, 09:38 AM   #190
Lex2007's Avatar
Hey I've used that stuff when hard gaskets weren't readily available and it worked just as good. But I see your point.
 Old 02-20-2015, 10:15 AM   #191
some call me...Tim's Avatar
Posts: 15   (View Stats)
some call me...Tim has a spectacular aura aboutsome call me...Tim has a spectacular aura about
From what I've seen, there seems to be a little confusion so someone correct me if I'm wrong but I believe you want L3K9-13-710 and L3F2-13-490. Onlinemazdaparts has good (relatively) prices.
-Tim
2007 Cosmic Blue MS3
Bilstein B8 Sports... That's it
some call me...Tim is offline   Reply With Quote
The Following User Says Thank You to some call me...Tim For This Useful Post:
 Old 02-20-2015, 05:53 PM   #192
Feline Führer
neganox's Avatar
Posts: 1,790   (View Stats)
DP gasket - Mazda OEM Downpipe Gasket (Upper) MS3 MS6
Turbo to EM gasket - Mazda OEM Manifold Turbo Gasket MS3 MS6
Studs incase some snap - 10mm (1.5 pitch) Stud
Locking nuts - 10mm (1.5 pitch) Nut Locking Head
Darthspeed3 (03-02-2015), G1sdaname (05-22-2015), ItsNox (02-20-2015), Micha (11-11-2015), some call me...Tim (02-20-2015)
 Old 03-02-2015, 10:51 AM   #193
Darthspeed3's Avatar
Posts: 292   (View Stats)
Darthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the world
Great write-up to the op!! I'll definitely use it this spring
Gen1 - Built and sleeved block, some headwork, Gen2 6266, FJ turbo kit, JMF with PI.
Darthspeed3 is offline   Reply With Quote
 Old 08-08-2015, 06:29 PM   #194
Project_dog's Avatar
Posts: 333   (View Stats)
Project_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond repute
Groaned at 7 Times in 5 Posts
Do you need to run a oil restriction bolt on a bnr s3 ?
2007 Mazda CX-7: Custom FMIC, Forge V1 BPV, Grimmspeed 3 port EBC, BNR S3 turbo, 3 inch Catless DP, Muffler Delete, JBR 3.5 intake, Autotech HPFP Internals, JBR OCC, Vogland Springs. Stereo: Two Memphis 10" Subs, 2 Memphis 1.500 Amps. Memphis 4.50 Amp, Image Dynamics Components and Coaxials.
Project_dog is offline   Reply With Quote
 Old 08-08-2015, 08:56 PM   #195
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
No.
Project_dog likes this.
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 08-08-2015, 08:57 PM   #196
Feline Führer
neganox's Avatar
Oil restriction bolts are a band-aid for a smokey turbo. No.
 Old 08-08-2015, 09:02 PM   #197
Okay. Thank you. Just got one for my cx 7. Can't wait to get it
 Old 08-11-2015, 01:43 PM   #198
Lex2007's Avatar
Ziggo, so its been a few years since you installed the BNR S3.
How has it treated you?
 Old 08-12-2015, 09:45 AM   #199
Ziggo's Avatar
Posts: 3,843   (View Stats)
Still running strong. I had the issue with the housing bolts backing out that the early units did, but other than that I have had no issues. Drive it every day almost on my 5/7 E85 mix map.
Ask Me About My:
 Old 08-12-2015, 09:54 AM   #200
Lex2007's Avatar
Awesome! How many miles if you don't mind me asking?
Few more questions:
-Not sure if you have emissions testing in Tx, but we do here in Maryland and my concern is whether I would pass emissions. There is no visual, they just plug into OBDII port.
-Did the OEM clutch withstand the added torque?
-Whats your MPG, out of curiosity? (I have a long commute.)
- Any PCV issues with the additional boost?
Thanks for your post and for sharing your experience with us.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/bnr-s3-swap-how-88946/
Turbolader ausbauen / tauschen This thread Refback 06-09-2015 12:25 PM
Eine Frage an die Turbo Spezialisten - leichtes Pfeifen unter Last This thread Refback 12-31-2014 04:56 AM
TURBO Ein-Ausbau, Tips bzw. Anleitung This thread Refback 10-21-2014 02:11 PM
Turbolader defekt - Seite 2 This thread Refback 07-23-2014 03:20 AM
How do I remove the oil drain from a KO4 turbo ? - Page 6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 06-02-2014 04:35 PM
Turboaufladung - [ALLE] BNR Turbo Upgrades This thread Refback 07-08-2013 11:01 AM
Bnr s3 upgrade help This thread Pingback 06-25-2013 12:36 AM
Whats New/General Speed 6 Discussion - Page 236 This thread Refback 06-08-2013 05:23 PM
Beaner time! - Page 15 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-10-2013 04:37 PM
BNR Stage 3 Turbo Upgrade - Page 5 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 02-24-2013 05:04 PM
Turboaufladung - [ALLE] BNR Turbo Upgrades - Seite 5 This thread Refback 02-20-2013 03:00 AM
Beaner time! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 01-26-2013 08:23 PM
mikey32235 everything is broken - Page 11 This thread Refback 12-01-2012 07:42 AM
• View topic - KO4E Turbo Upgrade This thread Refback 11-28-2012 11:27 PM
[ALLE] BNR Turbo Upgrades - Seite 5 - Turboaufladung - mazda-mps.de This thread Refback 11-13-2012 10:41 PM
[ALLE] BNR Turbo Upgrades - Turboaufladung - mazda-mps.de This thread Refback 11-03-2012 11:53 AM
BNR Stage 3 Turbo Upgrade - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 10-12-2012 10:04 AM
INTERCEPTOR EVOLUTION!!! This thread Refback 11-24-2011 02:15 PM
Fs-ZE Swap Focus MSP - ECU Computer Tuning 4 09-11-2014 08:43 AM
HID swap TXspeed3 MazdaSpeed 3/6 - Appearance 19 06-28-2009 05:04 PM
Page generated in 0.62811 seconds with 41 queries
