Like Tree47Likes
 Old 09-07-2016, 05:11 PM   #241
PRIME-B's Avatar
Posts: 27   (View Stats)
PRIME-B has a spectacular aura aboutPRIME-B has a spectacular aura aboutPRIME-B has a spectacular aura about
Yessir. Single port WGA.
hey man how did you end up mounting the wg bracket? I have a v1 also and have run into the same problem when rotating. I currently only have 1 bolt on the WG bracket and it looks like if I drill out the bracket that there wouldnt even be enough left over on the bracket to bolt up anyway. the WG is hitting the compressor housing.
"If you're not 1st, You're last"
PRIME-B is offline   Reply With Quote
 Old 09-07-2016, 09:17 PM   #242
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
I also get new exhaust nuts too. They are cheap.
Sent from my VS986 using Tapatalk
Pickles Tune in progress
PRIME-B (09-07-2016)
 Old 09-08-2016, 07:29 PM   #243
Micha's Avatar
Posts: 3,436   (View Stats)
I rotated it back to normal.
I had all the parts to run it in the normal position.
I am slow again.
I modded it a little.
 Old 09-08-2016, 07:34 PM   #244
PRIME-B's Avatar
Damn, I have under routed pipes so I've got to figure it out. I might have to fab up a bracket.
 Old 12-13-2016, 09:07 PM   #245
HaXiR's Avatar
Posts: 315   (View Stats)
HaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud of
Trying to find somewhere but for the S4 clocking, I cant get the plate to fit once rotated, it just doesn't fit. I feel like since the S4 is a different housing maybe it's just not possible because it's too big?
2008 Ms3 Black Mica R.I.P. March 2008 - March 2016. MODS: HTP 3" intake, CX Racing FMIC with TR8 core, BNR S3, AP V3, Kozmic EGR delete, Matt Damond OCC, JBR short shift plate with bushings, HIDS, CP-E injector seals, TIG, 1 step colder plugs, Grimspeed EBCS, CS RMM, JBR passenger MM, motor craft tranny fluid, Autotech Internals
Current:
08.5 Ms3 cwp GT: Built block (sp63 4032 pistons, eagle h beams, CA625+ rod bolts/head studs, arp main studs, key'd crank, supertech 55lb valve springs, bsd delete, Block/pistons/rings/bearings WPC treated), HTP 4" intake, bnr S5 turbo (when it comes out), HTP hotside under route pipes, TR8 core, custom made cold pipes, ST intake mani, TIG, CP-E downpipe, CNT CBE, autotech hpfp, AP V3, grimmspeed ebcs, GA v3, TWM short shift assembly, JBR short shift plate, HFS-4 Meth kit, HTP front mount custom meth tank, damond motor mount trilogy, damond 3 port pcv plate, dual damond catch cans (one vented), step colder plugs, corksport injector seals, GFB bov, 51r battery, Bilstein B8 shocks, OZ ultralegga rims, custom oem clutch with Kevlar, Gen 2 trans.
2003 Mazdaspeed protégé (spicy orange); pope E manifold and DP, injen cai, PoS fmic kit, Twisted motion gt2871 turbo, aem fic-6.
HaXiR is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/bnr-s3-swap-how-88946/
Turbolader ausbauen / tauschen This thread Refback 06-09-2015 12:25 PM
Eine Frage an die Turbo Spezialisten - leichtes Pfeifen unter Last This thread Refback 12-31-2014 04:56 AM
TURBO Ein-Ausbau, Tips bzw. Anleitung This thread Refback 10-21-2014 02:11 PM
Turbolader defekt - Seite 2 This thread Refback 07-23-2014 03:20 AM
How do I remove the oil drain from a KO4 turbo ? - Page 6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 06-02-2014 04:35 PM
Turboaufladung - [ALLE] BNR Turbo Upgrades This thread Refback 07-08-2013 11:01 AM
Bnr s3 upgrade help This thread Pingback 06-25-2013 12:36 AM
Whats New/General Speed 6 Discussion - Page 236 This thread Refback 06-08-2013 05:23 PM
Beaner time! - Page 15 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-10-2013 04:37 PM
BNR Stage 3 Turbo Upgrade - Page 5 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 02-24-2013 05:04 PM
Turboaufladung - [ALLE] BNR Turbo Upgrades - Seite 5 This thread Refback 02-20-2013 03:00 AM
Beaner time! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 01-26-2013 08:23 PM
mikey32235 everything is broken - Page 11 This thread Refback 12-01-2012 07:42 AM
• View topic - KO4E Turbo Upgrade This thread Refback 11-28-2012 11:27 PM
[ALLE] BNR Turbo Upgrades - Seite 5 - Turboaufladung - mazda-mps.de This thread Refback 11-13-2012 10:41 PM
[ALLE] BNR Turbo Upgrades - Turboaufladung - mazda-mps.de This thread Refback 11-03-2012 11:53 AM
BNR Stage 3 Turbo Upgrade - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 10-12-2012 10:04 AM
INTERCEPTOR EVOLUTION!!! This thread Refback 11-24-2011 02:15 PM
Fs-ZE Swap Focus MSP - ECU Computer Tuning 4 09-11-2014 08:43 AM
HID swap TXspeed3 MazdaSpeed 3/6 - Appearance 19 06-28-2009 05:04 PM
Page generated in 0.26923 seconds with 24 queries
