 Old 02-19-2016, 12:40 AM   #1
Kevopg's Avatar
Posts: 120   (View Stats)
Kevopg is a name known to allKevopg is a name known to allKevopg is a name known to allKevopg is a name known to allKevopg is a name known to allKevopg is a name known to all
Default Bnr s4 build
S4 is coming in soon and I want to know if I will be needing to fab a coolant line like for the s3? If anyone has and tips on installing the s4 I'm all for it. This is the first time I will be doing a project like this.
Jnun91 likes this.
Kevopg is offline   Reply With Quote
 Old 02-19-2016, 09:39 AM   #2
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
MS6 or MS3? Too many details left out. Are you referring to coolant feed or return?
 Old 02-19-2016, 09:56 AM   #3
Police - Grammarhead
Vansquish's Avatar
I've got an S3, and there was no "fabbing" required at all.
 Old 02-19-2016, 11:03 AM   #4
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
@SpecialK;
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 02-19-2016, 11:21 AM   #5
GEE1989's Avatar
Posts: 182   (View Stats)
GEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant future
According to edgeauto it's a direct bolt on
Sent from my SM-G920P using Tapatalk
08 MS3
Corksport turbo, built motor, meth injection, and FREEKTUNED
GEE1989 is offline   Reply With Quote
 Old 02-19-2016, 07:11 PM   #6
Kevopg's Avatar
Thanks, it's a ms6. Pretty much stock I have the ap and a mscai. Autotech internals, circuit werks dp, jdm mani, cxracing fmic, jbr 3" wp , and rear diff mounts all arrived so far just waiting on the turbo package.
 Old 02-19-2016, 10:02 PM   #7
fivefingerdeathpunch's Avatar
Posts: 437   (View Stats)
I can't remember why because it's been a while, but when we installed my S3 it was widely suggested to use a 6AN braided hose for the coolant return back to the EGR so that's what we did. It required cutting it to size etc.
 Old 02-20-2016, 08:23 AM   #8
dale_gribble's Avatar
Posts: 4,720   (View Stats)
@fivefingerdeathpunch; the v2's came with a hard coolant inlet line so I didn't have to do that. The s4 probably comes with the hard line too.
MINI H1 6.0 - CAR LED TAILS
fivefingerdeathpunch (02-20-2016), Kevopg (02-20-2016)
 Old 02-26-2016, 11:26 AM   #9
tmzx10r's Avatar
Posts: 10   (View Stats)
tmzx10r will become famous soon enoughtmzx10r will become famous soon enough
just got done installing my s4 in my 6. no fab required direct bolt on.
tmzx10r is offline   Reply With Quote
The Following User Says Thank You to tmzx10r For This Useful Post:
mxlplx71 (02-26-2016)
 Old 02-28-2016, 08:02 AM   #10
Tomarchio's Avatar
Posts: 1   (View Stats)
Tomarchio is an unknown quantity at this point
just finished my s4 on 2012 speed3. No fab at all.
Tomarchio is offline   Reply With Quote
 Old 03-04-2016, 09:44 PM   #11
Kevopg's Avatar
How did the install go for you guys? I just started tearing everything out. I've been recording every step as I'm going along. I'll post a link as soon as the first part uploads.
The Following User Says Thank You to Kevopg For This Useful Post:
impossible (03-05-2016)
 Old 03-05-2016, 09:54 PM   #12
Kevopg's Avatar
 Old 03-05-2016, 11:43 PM   #13
Kevopg's Avatar
 Old 03-11-2016, 11:50 AM   #14
Kevopg's Avatar
 Old 03-12-2016, 05:22 PM   #15
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
Mine went in without a hitch... attached are the only pics I took.
The Following 3 Users Say Thank You to specvspeedfreak For This Useful Post:
impossible (05-31-2016), Jsn_Rob (03-12-2016), Matt H. (04-15-2016)
 Old 03-12-2016, 06:01 PM   #16
Kevopg's Avatar
I don't have a pic right now but anyone know what the nipple on top of the exhaust manifold is for? There isn't one on the stock one. Do I just screw out the nipple and put a cap?
 Old 03-16-2016, 11:35 AM   #17
Got my base map and everything looks solid. No boost creep like I had w/ the S3v2. It's slow as shit (spring pressure only) but I know once the tune progresses it'll be a blast.
 Old 03-21-2016, 07:41 AM   #18
3deepsadzam's Avatar
Posts: 19   (View Stats)
3deepsadzam will become famous soon enough
Bnrs4 ????Does anybody know the hot side housing spec and the turbine wheel diameter I'm trying to see if the atp ewg housing is even possible, I spoke with Bryan not to long ago about what size the bnrs4 is was told it is a smaller gt3076 and has a 4mm smaller diameter compressor wheel than the atp gt3076 if I could get some input if not I'll call him just 3rd shift schedule sucks
BNR s4. 24psi Manley Built.
Bsd Hbeam rods 2618 Pistons. Full race manifold SBend stage3 daily koni struts h&r Spring
HTP 3.5. Tq solution mnts Eibach sway Bar
TRW shifter. Cpe 3 gauge dash. Cobb catted dp
CS IJ seals. Auto tech internals. 3"Stainless slp ex
P&P - Vtcs delete.
Sp63 dual vent breath.
PURPLE DRANK TUNED
3deepsadzam is offline   Reply With Quote
 Old 05-01-2016, 03:26 PM   #19
Kevopg's Avatar
 Old 05-01-2016, 03:38 PM   #20
Don
Don's Avatar
Posts: 181   (View Stats)
Don has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond reputeDon has a reputation beyond repute
Ugh. K04 started to show it's smoke recently. I'm liking all the good things I hear about the s3 and s4. All these recent threads are making it hard for me not to buy now
2010 speed3
Corksport catted turbo back
Corksport SRI W/TIP
Autotech internals
AP3 Running PD tune
Stock turbo. Waiting for it to go
Konig deception wheels
BC br coilovers
Oh yea..... I won the lottery!!!!!
Don is offline   Reply With Quote
 Old 05-14-2016, 06:05 PM   #21
Kevopg's Avatar
I got my first revision back from Justin and after cruzing on it for a few miles I felt a jerk and then her a ticking noise .I'm pretty sure I bent a rod. I hear it with slight throttle pulses and fell vibs in the clutch. Going to do a compression test soon.
 Old 05-14-2016, 09:14 PM   #22
tmillner's Avatar
Posts: 621   (View Stats)
That sucks....Post results of the compression test
Sent from my SM-N920P using Tapatalk
 Old 05-16-2016, 12:43 AM   #23
Kevopg's Avatar
Any advice on a replacement?
 Old 05-16-2016, 01:31 AM   #24
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
Pop n drop from sp63? FJ Performance?
When I contemplated building my own engine it came to about 2500-3000 for parts and that does not include special tools needed for measuring and installing everything. So getting it built might be worth it if you have a good shop near you
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 05-16-2016, 08:28 AM   #25
Kevopg's Avatar
Got a quote from an auto parts store for a reman w/3 year warranty for 3400 otd and 460 will be returned with core. 2940 after tax and core! The part # is Dffr. I think it is the same one edge sells. Anyone else have one of these? Haven't seen much reviews on these
 Old 05-16-2016, 08:30 AM   #26
tmillner's Avatar
Would you be putting in yourself?
 Old 05-16-2016, 08:40 AM   #27
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Rebuild.
Check the discussion about the pistons and head studs, everything else is pretty much a subjective choice.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 05-16-2016, 08:41 AM   #28
Kevopg's Avatar
Yea
 Old 05-16-2016, 10:55 AM   #29
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Thumbs up
How did this happen on a first revision of the tune?
 Old 05-16-2016, 02:32 PM   #30
mituc's Avatar
Groans: 111
There can be no connection between the tune and the timing of this problem, because:
1. the larger the turbo the harder is to get it to make significant boost down low where rod cracking and bending events can occur.
2. the first revisions of the tunes are usually conservative in therms of both boost and timing just to get a baseline and a feeling of where the engine and turbo are, what is the preload of the wastegate arm, wastegate spring, gas quality, piston crown contamination, intake valve contamination, leaks of all kinds, rattles and false knock, and so on.
So even if you jump on the throttle with both feet it's hard to do such damage, not to say only while cruising around.
So my guess is that the engine was wounded previously and it was just a matter of bad luck and bad timing that the wounded/previously cracked rod bent only now. Stock tune MS6s and CX7s are more prone to this than the FWDs.
It always hurts to hear that someone's engine is in a bad shape. I remember how I felt myself when I figured that I may have some cracked ringlands when the engine started consuming oil over night (like one quart every 300-400 miles).
However the situation is not that bad. Get yourself some good pistons, some rods, an engine rebuild kit + gaskets, a good meth kit and reward yourself with supercar acceleration in a totally uninteresting family saloon and make those rich kids with porsches jump out of a moving car thinking they are actually standing still.
tmillner likes this.
impossible (05-31-2016), tmillner (05-16-2016)
 Old 05-16-2016, 02:50 PM   #31
tmillner's Avatar
That last sentence was awesome. You have won the forum today....
The Following User Says Thank You to tmillner For This Useful Post:
mituc (05-16-2016)
 Old 05-16-2016, 03:26 PM   #32
Kevopg's Avatar
Thanks guys, still don't know what route I'm going but I'm selling my wife's car and whatever I get from that will determine which way I'm going.
I don't think it was anything he did. Old engine kinda knew it would soon but didn't think this soon. Gives me an excuse know.
Last edited by Kevopg; 05-16-2016 at 03:26 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-16-2016, 03:33 PM   #33
tmillner's Avatar
How many miles did you have? Really sucks to hear....
Guess I'll start planning for the same thing
 Old 05-16-2016, 06:12 PM   #34
Kevopg's Avatar
170xxx
 Old 05-17-2016, 03:54 AM   #35
nigvlb_'s Avatar
nigvlb_ is an unknown quantity at this point
Need longer coolant hose. I needed it while installing mine lol.
nigvlb_ is offline   Reply With Quote
 Old 05-17-2016, 01:14 PM   #36
g00s3y's Avatar
Groans: 438
My bad, reading fail, I thought this was on a brand new built engine. Ignore my stupidity.
 Old 05-20-2016, 03:49 PM   #37
Kevopg's Avatar
Started the car today and let it warm up before I did the compression test and the knock sound was gone. Felt no vibes in the clutch and did a few high revs and it sounded nice. Then I did the compression test from driver side to passenger side.
160 160 155 115
Not good, was hoping for the best.
Sale pending on wife's car so hopefully soon
 Old 05-24-2016, 09:23 PM   #38
Kevopg's Avatar
I look at sp63 stage 1 long block and it looks like that will more then likely be my route. Anyone know the process on sending there own block in to get worked on? Shipping, how long it usually takes , does it come fully assembled and timed?
 Old 05-24-2016, 09:53 PM   #39
wolfpack92054's Avatar
Posts: 65   (View Stats)
wolfpack92054 has much to be proud ofwolfpack92054 has much to be proud ofwolfpack92054 has much to be proud ofwolfpack92054 has much to be proud ofwolfpack92054 has much to be proud ofwolfpack92054 has much to be proud ofwolfpack92054 has much to be proud ofwolfpack92054 has much to be proud of
there is a guy out here in socal who sells built speed motors. his name is jordan keefover and his company is called overspeed motorsports. hit him up. hes been dropping built blocks in our socal cars like mad lately. seems like atleast 1 or 2 a month lol
wolfpack92054 is offline   Reply With Quote
 Old 05-29-2016, 11:58 PM   #40
Kevopg's Avatar
Sold the wife's car! Going with sp63 stage 1 and getting sum meth
The Following 2 Users Say Thank You to Kevopg For This Useful Post:
joeyspeed3 (05-30-2016), SpeedRebirth (05-30-2016)
Build me a BIG Turbo Build for MS3 NCspecV81 2010 MS3 - Big Turbo Builds 14 04-15-2013 02:16 PM
Page generated in 0.55435 seconds with 38 queries
