 Old 05-06-2013, 09:38 AM   #1
Rich990's Avatar
Posts: 274   (View Stats)
Rich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the world
Default BNR Stage 2 to Stage 3 conversion
Hey guys,
I recently picked up a BNR Stage 2, used from a friend.
I want to convert it to the Stage 3 by having a 2871 compressor wheel fitted.
From what I have seen on the web, the Compressor Housing on my S2 is the same as the Stage 3, it is the Mitsubishi compressor housing from the 88 RX7 Series 4 (it has HT18S-2S on the housing).
I’m in South Africa so for the cost of shipping in a new S3 I may as well spend a bit more and get GT30. So i want to try get this one upgraded locally if possible.
What I need to know is, what is different between the S2 and S3?
Is it just the compressor wheel? Can I keep the CHRA and the turbine wheel?
If its just a wheel swap with a bit of CNC work to machine the housing to accept the larger wheel then I think that will be a nice option.
Lastly, do you guys think it would be possible to fit a GTX 2867 wheel in there?
Thanks
Rich
2007 Velocity Red MS6
Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads
Parts stockpile... Wiseco 88mm's / Manley H beams
Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04
Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth)
Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust
5500 ft altitude FTL
MSF in South Africa
Rich990 is offline   Reply With Quote
 Old 05-06-2013, 10:52 AM   #2
The stage2 is a GT2860 so the compressor wheel will be smaller and the compressor housing will be smaller as well.
I believe the exhaust side is the same as a stage3. To upgrade you'd probably need the 2871 compressor wheel and the larger housing - not sure if the backing plates match.
Rich990 (05-06-2013)
 Old 05-06-2013, 11:44 PM   #3
Rich990's Avatar
Thanks Lex. If I can get it done locally for around $500, would you say the extra flow potential would be worth it? Bearing in mind I'm at 5500 ft in Johannesburg, South Africa.
Power goals are 330 whp on meth and e.
MSF in South Africa
 Old 05-06-2013, 11:45 PM   #4
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
You could just sell it and get a stage 3 turbo. You might be able to find a buyer.
I was interested in messing with a stage 2 turbo myself.
Sent via stockish Black Mica Pu
Pickles Tune in progress
 Old 05-07-2013, 01:47 AM   #5
Rich990's Avatar
^ Stage 3 turbo would mean sending a stock ko4 to the States, pay a whole lot more cash than I want to for a S3, then shipping the S3 back to South Africa and paying import duties and sales tax again. Would end up costing around $2000 with all the shipping and customs duties etc.
And as far as I know there are no BNR S3's for sale in South Africa, so i'm trying to get it reworked locally.
MSF in South Africa
Dyno Results Stage 1 - Stage 2 ChimmyChong 2010 MS3 - Dyno Sheets/Discussions 7 02-11-2012 06:55 PM
Interesting look at Stage 1 + SF vs. Stage 1 + MSCAI2 maps, similarities and differences bast525
Cobb ATR Support
4 05-24-2009 07:52 PM
Page generated in 0.25538 seconds with 22 queries
