 Old 03-14-2011, 04:36 PM   #1
versyejr's Avatar
Posts: 31   (View Stats)
versyejr has a spectacular aura aboutversyejr has a spectacular aura about
Default BNR Stage I
As far as the stage 1 BNR turbos, would I need to install a fuel pump, or have a standback, or get a new tune? Or can I just install it and go. I'm looking for a reliable, non smoking car and I cannot get that with a KO4, so BNR it may be. But I'm also not looking to get too away from stock either.
HELP!!!
Thanx
versyejr is offline   Reply With Quote
 Old 03-14-2011, 04:38 PM   #2
ScarMS3's Avatar
Posts: 2,088   (View Stats)
Groans: 97
Donate and search, but I would imagine you would need a fuel pump with a bump in boost, as well as a tune since it differs from stock k04, but that is just an assumption.
 Old 03-14-2011, 05:31 PM   #3
rtabagaboy's Avatar
Posts: 363   (View Stats)
Groaned at 7 Times in 3 Posts
Just put it on. Floor it at 1000RPM in 6th gear and see what happens. I bet that sucka spools hella quick you'll be doing burnouts in no time son!
2008.5 BlackMica Mods:
AZ Status!
The Following User Says Thank You to rtabagaboy For This Useful Post:
turd burglar (03-14-2011)
The Following User Says NO Thank You to rtabagaboy For This Un-useful Post:
Regulator (03-14-2011)
 Old 03-14-2011, 05:33 PM   #4
i8urgti's Avatar
Posts: 1,660   (View Stats)
i8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the world
Groans: 267
buy bnr stage3 fuel pump, ap, dp, fmic, intake, tune.
2006 LPM MS6 GT (totaled)
0-60 mph : 4.2 second (as per DH)
12.83 @ ???MPH 1.67 60ft
2002 Miata Se (convertible whore)
i8urgti is offline   Reply With Quote
 Old 03-14-2011, 06:01 PM   #5
turd burglar's Avatar
Posts: 1,895   (View Stats)
Groans: 39
bt thread, not more realiable but still basically a k04 thread
 Old 03-14-2011, 07:14 PM   #6
bmylez's Avatar
Posts: 3,197   (View Stats)
Yeah, reworked K04s can barely be considered BT. If you want more reliability and way more power, get a bolt-on ATP turbo. Yeah, you're restricted by the Mazda exhaust housing, but a 3071 will make plenty of power.
2007 CTS-V - Trying to sell
Interesting look at Stage 1 + SF vs. Stage 1 + MSCAI2 maps, similarities and differences bast525
Cobb ATR Support
4 05-24-2009 07:52 PM
Page generated in 0.26799 seconds with 25 queries
