 Old 07-03-2013, 05:37 AM   #1
Rich990's Avatar
Posts: 274   (View Stats)
Rich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the world
Default BNR turbos at altitude
Hello.
I wanted to find out if anyone is running a BNR at altitude and if so how it holds boost, particularly after 5000 rpm, and also what maf flow you guys see.
I have a bnr stage 2 and it just drops boost after 5000, I have an option to retrofit a 2871 or 2876 wheel at a low cost, I just wonder if it will make a difference at my altitude.
Ill start:
5500 feet above sea level, baro pressure is about 12.2 psi
BNR stage 2
Full bolt ons except manifolds
3port running 100% wgdc from 5000-redline
Fmic
Hits 20/21 psi at 3000 and holds 20 to about 4500 and trails to max 16 psi at redline
Max flow I have seen is 318 gs and hits 2.5 load and tapers off to 1.8 load at redline.
Thanks.
Rich.
2007 Velocity Red MS6
Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads
Parts stockpile... Wiseco 88mm's / Manley H beams
Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04
Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth)
Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust
5500 ft altitude FTL
MSF in South Africa
Rich990 is offline   Reply With Quote
 Old 07-03-2013, 07:22 AM   #2
S3 has a much larger compressor wheel and you will be able to hold above 20psi. As for flow you will be around 20-25 g/s below what people see at sea level.
Rich990 (07-03-2013)
 Old 07-03-2013, 02:46 PM   #3
Rich990's Avatar
excellent, thank you Lex, thats what I wanted to hear!!
MSF in South Africa
 Old 07-11-2013, 12:35 AM   #4
Rich990's Avatar
Sorry to revive this, do you guys think a 2876 wheel will be too big for the housing and / or the turbine wheel?
5500 ft means I lose about 3/4 psi capability on the top end and I would like to be able to hold 22 psi at redline, without the turbo spitting fire.
Thanks
MSF in South Africa
 Old 07-11-2013, 01:06 AM   #5
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
2876 in a small turbine housing will be a bit of an odd turbo- I would opt for the 71mm compressor option, basically making it like a BNR S3
Altitude Strikes again... snailD 2010 MS3 - Dyno Sheets/Discussions 13 09-10-2012 11:45 AM
bolt ons at altitude.. hcbr929rr2 Gen2 MS3 General Discussion 3 11-02-2011 04:38 AM
Altitude? what? where? BUNGEEZZ MazdaSpeed 3/6 - ECU Computer Tuning 18 07-24-2010 03:50 PM
High Altitude 1/4mi Times Emoranges Drag Racing 6 04-14-2010 07:04 AM
altitude and my 3071 djuosnteisn MazdaSpeed 3/6 - Turbo Induction 0 08-13-2009 01:22 PM
Page generated in 0.25360 seconds with 22 queries
