Like Tree34Likes
 Old 08-03-2015, 04:19 PM   #1
brandonf's Avatar
Posts: 511   (View Stats)
brandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the world
Default brandonf (FLO)'s BT speed6 build
Car: 2006 Mazdaspeed 6 (Liquid Platinum Metallic)
Expected: ~550awhp 93 and >700awhp on 50/50 e85
Motor: From @Downmented; <3 (RUNNING)
- Speed Perf6rmanc3 built long block
- Bored .20 over
- Custom Wiseco 10.6:1 Compression pistons
- Manley I-Beam rods
- 11mm H11 head studs/ stock head gasket
- Keyed Crank/ pinned cams
- Stock camshafts with 65lb Crower valve springs
- Single runner intake CnC port work of the head
- Ported exhaust side
Turbo: From @Downmented;
- PTE 6265 (installed)
Transmission:
- Pu gears + ms6 final drive (installed)
- Imoto 1/2 and 3/4 brass shift forks (installed)
- Clutchmasters 850 Race twin disk clutch (installed)
- SP63 transfer case bearing caps (installed)
- DSS Axles (acquired)
Fuel system:
- (4) Bosch 2000CC PI injectors (acquired)
- JMF v2 PI Intake Manifold (installed)
- Squash Performance Dual ITFP Tophat w/ dual DW 300 LPH itfp's (ordered)
- AEM adjustable FPR (acquired)
- Split Second controller for 4 injectors
- Fuelab fuel filter (acquired)
Exhaust:
- CPE Single exit cbe (installed)
- Steedspeed top mount t4 twin-scroll Exhaust manifold (installed)
- ? V-band Downpipe (installed)
- Exhaust cutout
Suspension:
- H&R coilovers (fronts installed)
- CS Upper control arms (installed)
- AWR Front endlinks ((installed))
- Steeda rear endlinks (acquired)
- SPC Front ball joints (not needed, CS upper control arms came with adjustable ball joints)
- CS Adjustable rear camber arms (acquired)
- Whiteline rear sway bar (acquired)
Wheels/tires/Brakes:
- Enkei pf01ss 17x9 +48 (installed)
- Dunlop Z2 Star specs 255/40/17 (installed)
- fd wheels w/ Hoosier QTP's for the drag strip (selling, won't fit with evo8 brakes)
- Evo 8 brakes w/ unknown pads (installed)
- Muteki SR48 lugs (acquired)
- ARP extended studs (not needed)
- Techna-Fit Stainless Steel Brake Lines (installed)
- Eiback 15mm hubcentric spacers (installed)
Mounts:
- JBR Trilogy PMM/TMM/RMM (installed)
- TT Front engine mount (installed)
- Whitewidow front differential mount (acquired)
- CS Rear differential mount (acquired)
Other:
- MDM Power steering cooler (installed)
- CS Front Strut bar (acquired)
- CS Rear Brace Bar (acquired)
- Tial QR BPV (installed)
- 4" intake (installed)
- ? FMIC (installed)
- TR1035? intercooler (installed)
- 4 bar MAP sensor
- WOT box (acquired)
- SP63 Breather cap (installed)
- Sparco Evo II US racing seat driver side (acquired)
- Wedge Engineering bracket w/ dual locking sliders (ordered)
- APR Front Splitter (acquired)
- MD Dual catch cans (installed)
- Cpe 3 gauge mount (installed)
- VEI Systems Boost gauge -up to 90 psi (installed)
- AEM Failsafe Wideband AFR gauge (installed)
- ProSport Oil Filter Adapter Plate(installed)
- HTP OEM Battery Trunk Relocation Kit (installed)
- Redline Tuning QuickLIFT ELITE Hood Struts (installed)
- Techna-Fit Stainless Steel Clutch Line(installed)
- Denso Iridium Power Spark Plug ITV24 (installed)
- CS Injector Seals (installed)
- Tanabe oil pressure gauge (installed)
- Apexi Turbo Timer (ordered)
Audio:
- Sundown Audio SAZ-1500D sub amp (installed)
- SSA 12" Xcon (installed)
- Khaotik Enclosure ported enclosure (installed)
- Clarion dxz775usb head unit (installed)
- JBL ms-62c component speakers (acquired)
- Sundown sax-100.4d speaker amp (acquired)
Downmented, tastysi2004 and ItsNox like this.
2011 Silver MS3: Totaled
2006 Silver Speed 6: Modification in process
Speed3: 1/4: 12.8@115.71
Build log for the 6: http://www.mazdaspeedforum.org/forum/forum/f498/brandonf-flo-s-bt-speed6-build-191584
Last edited by brandonf; 05-15-2016 at 07:53 PM. Reason: MSF Database - Automerged Doublepost
brandonf is offline   Reply With Quote
The Following 25 Users Say Thank You to brandonf For This Useful Post:
802MS3 (08-03-2015), blackmicamps6 (08-04-2015), Bleupit80 (08-03-2015), Code Monkey (08-03-2015), CWP_MS3 (08-03-2015), Downmented (08-08-2015), ESA (08-04-2015), Hammology (08-11-2015), impossible (05-07-2016), ItsNox (08-03-2015), jax ms3gt (08-09-2015), JgamB (12-29-2015), Manny (08-09-2015), Mauro_Penguin (08-06-2015), Mazdazilla6 (05-15-2016), Micha (08-03-2015), mxlplx71 (08-04-2015), phate (08-03-2015), Poohster (08-05-2015), simply_pandora (08-11-2015), SpeedRebirth (08-04-2015), tastysi2004 (08-03-2015), theschrum (08-08-2015), WetzMS3 (08-04-2015), xxdjfate76xx (08-04-2015)
 Old 08-03-2015, 04:31 PM   #2
tastysi2004's Avatar
Posts: 1,063   (View Stats)
first!!! great job flo! ill be after you!!!
2008 MS3 gt mica black
EL NATOR DE Virginia/Florida
Update: getting that
Purple drank in my tank.
554whp/546wtq @ 30psi.
another build? maybe soon..
#CATBACKEXHAUST
The Following User Says Thank You to tastysi2004 For This Useful Post:
brandonf (08-03-2015)
 Old 08-03-2015, 05:11 PM   #3
Bleupit80's Avatar
Posts: 62   (View Stats)
Bleupit80 has much to be proud ofBleupit80 has much to be proud ofBleupit80 has much to be proud ofBleupit80 has much to be proud ofBleupit80 has much to be proud ofBleupit80 has much to be proud ofBleupit80 has much to be proud ofBleupit80 has much to be proud ofBleupit80 has much to be proud of
Nice Flo!!!
2006 Whitewater Pearl Mazdaspeed 6 GT #355
FJ BUILT LONG BLOCK
BNR S4
JBR TRU 3"
SURE BOOST TUBES
JBR SSP
JBR CHROME MOLLY RMM
COBB AP
AUTOTECH HPFP INTERNALS
EBAY DP
3.5 BAR
PURPLE DRANK TUNED
WAITING TO BE INSTALLED
PROSPORT EVO BOOST GAUGE
TR1035 w/ CXRACING PIPING
JMF INTAKE
AWR PASSENGER MOTOR MOUNT
AWR TRANSMISSION MOUNT
Bleupit80 is offline   Reply With Quote
The Following User Says Thank You to Bleupit80 For This Useful Post:
 Old 08-03-2015, 05:15 PM   #4
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Oh snap.
www.tunedbynishan.com
 Old 08-03-2015, 05:17 PM   #5
ItsNox's Avatar
Posts: 3,076   (View Stats)
Very nice!!! Curious to see what springs you go with and HELL YEA on those gears!!!
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
 Old 08-03-2015, 07:15 PM   #6
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
You sneaky little slut, you...
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
The Following 2 Users Say Thank You to CWP_MS3 For This Useful Post:
brandonf (08-03-2015), simply_pandora (08-11-2015)
 Old 08-03-2015, 08:10 PM   #7
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
This is serious. Hope it all comes together so I can come see it during one of my trips down to the Equinix campus.
'08 CWP MS3 w/ T3 3071r
brandonf (08-04-2015)
 Old 08-04-2015, 10:56 AM   #8
brandonf's Avatar
Any suggestions on pieces I might be missing or feedback on pieces I don't have yet? Oil cooler/exhaust cut out/etc?
@802MS3; I'm down in Virginia Beach, but I might be able to sneak away on a data center trip if you give me a heads up..
 Old 08-04-2015, 11:30 AM   #9
ItsNox's Avatar
Be weary of electric cutouts. @avesfan101; is pushing 500+ HP and the heat from it has cooked like 4 electric cutouts. All replaced under warranty, but still.
Matt Damon Oil Cooler is always a nice addition. Especially on this kind of build.
'06 Mazdaspeed 6 GT
- Miltuned
 Old 08-04-2015, 06:12 PM   #10
kidlifecrisis's Avatar
Posts: 672   (View Stats)
kidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the world
Subbed, this looks promising Brandon!
kidlifecrisis is offline   Reply With Quote
The Following User Says Thank You to kidlifecrisis For This Useful Post:
 Old 08-05-2015, 06:44 PM   #11
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Curious on the ms6 final drive. How that work with the pu gears?
2013 CWP and Stock
ItsNox (08-06-2015)
 Old 08-06-2015, 11:36 AM   #12
brandonf's Avatar
I talked to dave woods and he mentioned he's pretty sure that's what he is using in his 6.. i do need to do some more research though, cuz it sounds like I should be using the first final gear from the pu as well, but not sure..
I was originally going to just swap the guts from everything in the pu tranny to the 6 though
The Following User Says Thank You to brandonf For This Useful Post:
WetzMS3 (08-06-2015)
 Old 08-07-2015, 11:35 AM   #13
NCspecV81's Avatar
Well if you get that final to work post up the details I'll follow suit.
2013 CWP and Stock
 Old 08-07-2015, 05:36 PM   #14
brandonf's Avatar
Due to my laziness, I just went with the h&r coilovers from edge.. also bought the cpe 3 gauge mount and sr48 muteki lugs (cuz @Rokusek; stole mine)
2.0t03speed likes this.
The Following 2 Users Say Thank You to brandonf For This Useful Post:
2.0t03speed (08-07-2015), ItsNox (08-07-2015)
 Old 08-07-2015, 06:16 PM   #15
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Due to my laziness, I just went with the h&r coilovers from edge.. also bought the cpe 3 gauge mount and sr48 muteki lugs (cuz Rokusek stole mine)
I am disappoint.
ItsNox likes this.
-06 MS6
-Corn fed 07 MS3 - Sold
brandonf (08-07-2015)
 Old 08-07-2015, 07:27 PM   #16
maddocx240's Avatar
Posts: 823   (View Stats)
@brandonf; where are you getting a koyo radiator from?
 Old 08-07-2015, 07:35 PM   #17
brandonf's Avatar
I am disappoint.
I know.. i know.. I just figured since it's not going to be much of a competitive autox'er, I don't need the premium setup you went with. :/
After talking with @2.0t03speed;, he mentioned I probably won't need an upgraded radiator if I get a aux fan controller, so I'm going to try that route first. I can always add one later on if I need though.
Last edited by brandonf; 08-07-2015 at 07:35 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-07-2015, 08:58 PM   #18
maddocx240's Avatar
i dont know of koyo making a radiator for the ms6, thats why i asked. i know they make one for the gen1 ms3.
 Old 08-07-2015, 05:37 PM   #19
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
baller alert
theschrum likes this.
The Following 2 Users Say Thank You to 2.0t03speed For This Useful Post:
brandonf (08-07-2015), ItsNox (08-07-2015)
 Old 08-07-2015, 05:58 PM   #20
brandonf's Avatar
Added car audio setup, but likely no one here cares.
 Old 08-07-2015, 07:38 PM   #21
speedfreak2013's Avatar
Posts: 89   (View Stats)
speedfreak2013 has much to be proud ofspeedfreak2013 has much to be proud ofspeedfreak2013 has much to be proud ofspeedfreak2013 has much to be proud ofspeedfreak2013 has much to be proud ofspeedfreak2013 has much to be proud ofspeedfreak2013 has much to be proud ofspeedfreak2013 has much to be proud ofspeedfreak2013 has much to be proud ofspeedfreak2013 has much to be proud of
very nice list also curious about the final drive and gear swap
2013 MS3 BLACK MICA "SCARLET" the black widow
CURRENT MODS: COBB V3 AP//INJEN CAI//CS TIP//OBX CATLESS DP//OBX CBE//SURE SSP//SURE SHIFT COLUMN BUSHINGS//SPARCO SHIFT KNOB//JBR COUNTER WEIGHT//TREADSTONE GEN 2 FMIC KIT//CS 80 DURO RMM//DEVILS OWN METH KIT//DAMOND OCC//DAMOND PMM//PNP INTAKE MANI AND POST DELETE BY ME//VTCS DELETE BY ME AGAIN//DAMOND EGR DELETE//JBR TIGS//AND ENOUGH STICKERS TO HAVE MORE HP THAN YOU//
FREEKTUNED FTMFW
speedfreak2013 is offline   Reply With Quote
 Old 08-07-2015, 09:47 PM   #22
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
so roughly 6 months.
so this is just a 6 month cock tease thread?
94 M
MS6
IS350
 Old 08-07-2015, 11:40 PM   #23
brandonf's Avatar
yes.. plenty of time to do research on what i'll need, collect parts, and to plan it properly. I do plan on installing stuff like suspension, but nothing major until the breathalyzer comes out
 Old 08-08-2015, 11:52 AM   #24
L0k1's Avatar
Posts: 171   (View Stats)
L0k1 is the leader of the worldL0k1 is the leader of the worldL0k1 is the leader of the worldL0k1 is the leader of the worldL0k1 is the leader of the worldL0k1 is the leader of the worldL0k1 is the leader of the worldL0k1 is the leader of the worldL0k1 is the leader of the worldL0k1 is the leader of the worldL0k1 is the leader of the world
Nice
2009 ZZB'd MS3 Black -FUCK CO-SIGNING(YES I AM AN IDIOT but its mine now going to have fun with it)
17x8 anti freeze green Rota boost rims
CP-E Stage 2 RMM//// Autotech Interals//
[Sold]2010 MS3 Black
CS TURBO and CS shift knob fully weighted
HTP 3.5" intake and Battery tray
UR catted DP/RP and custom CBE
CP-E Stage 2 RMM// ETS 3.25" TMIC// Autotech Interals forge BPV// Grimspeed ebcs// 3bar map"// JBR short shift plate
Not installed:Fortune 500 coil overs/ Boost gauge/ AFR gauge/ JBR eyelids/Camber arms/ JBR OCC/ Guardian angel/ Devils own meth stage 2
381 whp/ 396wtq
Purple Drank
L0k1 is offline   Reply With Quote
 Old 08-08-2015, 12:06 PM   #25
89T
89T's Avatar
Posts: 599   (View Stats)
89T is the leader of the world89T is the leader of the world89T is the leader of the world89T is the leader of the world89T is the leader of the world89T is the leader of the world89T is the leader of the world89T is the leader of the world89T is the leader of the world89T is the leader of the world89T is the leader of the world
Ooooooo I like it very much
2007 Mazdaspeed 6 Black
Total # laps on Nürburgring: 3 Total # Crashes on the ring : 1 Fastest Lap on the ring 11:16
Pulling motor and transmission to build!
2002 VW Golf GTI 337
Daily
CAI/Franken Turbo F21/2.0 Coil Pack conversation /550cc injectors/Black Forrest SMIC/High flow Downpipe with muffle/resonator delete
2002 VW Golf GTI blue
Wife's Car
Custom SRI/Rear Muffler Delete/Blisten Heavy duty shocks and springs/Motegi Racing Wheels
89T is offline   Reply With Quote
 Old 08-08-2015, 03:12 PM   #26
Putin 2.3T's Avatar
Posts: 1,040   (View Stats)
Lets have a race to see who installs their motor first..
brandonf likes this.
2011 Mazdaspeed 3 [Sold]
The Following 2 Users Say Thank You to Putin 2.3T For This Useful Post:
brandonf (08-08-2015), Micha (08-09-2015)
 Old 08-08-2015, 03:50 PM   #27
brandonf's Avatar
Well they way you're going, it'll be me
Putin 2.3T likes this.
Micha (08-09-2015), Putin 2.3T (08-08-2015)
 Old 08-09-2015, 08:33 AM   #28
Manny's Avatar
Posts: 1,185   (View Stats)
Groans: 320
@2.0t03speed; if you ought to go full retard, this the way to go about it. I approve of this.
when was the last time your speed reeled in this many bitches?
The Following 2 Users Say Thank You to Manny For This Useful Post:
Bleupit80 (08-11-2015), brandonf (08-09-2015)
 Old 08-11-2015, 01:27 PM   #29
brandonf's Avatar
Apparently I forgot to cash my profit sharing check from christmas, so work sent me a new one... so....
Front diff mount ordered from newage
Bleupit80 (08-11-2015), ItsNox (08-11-2015)
 Old 08-11-2015, 02:02 PM   #30
Bleupit80's Avatar
Nice FLO. Wish I had the patience and funds to do this!!
FJ BUILT LONG BLOCK
BNR S4
JBR TRU 3"
SURE BOOST TUBES
JBR SSP
COBB AP
EBAY DP
3.5 BAR
PURPLE DRANK TUNED
JMF INTAKE
brandonf (08-11-2015)
 Old 08-11-2015, 04:50 PM   #31
brandonf's Avatar
I also just purchased the MDM power steering cooler, cuz why not?
Next up is the fuel system parts
ItsNox (08-12-2015)
 Old 08-11-2015, 06:01 PM   #32
ItsNox's Avatar
Shit just keeps getting sweeter. I like how this is going. I should consider doing the same since I fried a ps pump at ENM @ the tail of the dragon.
'06 Mazdaspeed 6 GT
- Miltuned
 Old 08-11-2015, 07:15 PM   #33
brandonf's Avatar
Ricer lugs and H&R coilovers showed up today.. hopefully the cp-e triple gauge pod will show up tomorrow
ItsNox (08-12-2015)
 Old 08-11-2015, 11:00 PM   #34
brandonf's Avatar
I'm about to pick this up, but not sure which fittings to get:
Mazda Speed 3/6 Dual Pump System
I'm going with the dual dw300's, but not sure between these options:
-6 supply and return
-8 supply and -6 return
-8 supply and return
@psychophyr; or anyone else?
 Old 08-11-2015, 11:45 PM   #35
Putin 2.3T's Avatar
8AN all the way!
The Following User Says Thank You to Putin 2.3T For This Useful Post:
brandonf (08-12-2015)
 Old 08-12-2015, 12:45 AM   #36
brandonf's Avatar
Moar purchases! I picked up the AEM FPR/FueLab -8an In/Out Fuel Filter from @Putin 2.3T; and also purchased the Squash Performance dual itfp tophat w/ dual dw300's -8an supply/return.
Moar to come soon!
tastysi2004, ItsNox and Putin 2.3T like this.
Bleupit80 (08-15-2015)
 Old 08-12-2015, 05:07 AM   #37
Moar to come soon!
you do know the JMF v2 is a -6 rail right ? should of just got the -6 setup.
 Old 08-12-2015, 10:39 AM   #38
Putin 2.3T's Avatar
-6AN ORB to -8AN male fittings aren't hard to find. That's what I did for my setup.
 Old 08-12-2015, 10:49 AM   #39
-6AN ORB to -8an male fittings aren't hard to find. That's what I did for my setup.
but why not just do straight -6? save money on fittings/line. his fuel rail is -6 his fpr is -6. iono just makes more sense to me to use -6 instead of adapting up and down.
brandonf (08-12-2015), ItsNox (08-12-2015)
 Old 08-12-2015, 10:04 AM   #40
ItsNox's Avatar
Moar to come soon!
What the fuck man you're buying new sweetness every day of the week. By the time you're ready to put it all together you'll have more parts to put on the car than are already there.
Love it.
'06 Mazdaspeed 6 GT
- Miltuned
Psycho's Speed6 Build (PT6266) psychophyr Mazda MZR DISI Engine Builds (2006-2013) 710 09-18-2014 09:27 AM
07 Speed6 Build ABQ Speed6 MazdaSpeed 3/6 - Build Diaries 57 05-27-2014 01:22 AM
Page generated in 0.61088 seconds with 38 queries
