Like Tree5Likes
 Old 08-29-2011, 07:31 PM   #1
bmylez's Avatar
Posts: 3,197   (View Stats)
Default Brian's ballin' azz Precision turbo build
Alright, hoes, time for me to finally make this thread. I have a 4 day weekend comin up (thanks, Air Force) and I just so happen to be getting my downpipe from Jeff "The Man" Mason (s/n mason) on Thursday. I have basically everything else I need except the Tial outlet flange for a dump tube. I ordered it on the weekend, so maybe it will be here in time...I'll work that out later.
Ok, build specs:
Steedspeed T3 manifold with 38mm wg port
PTE 5857 with billet compressor wheel
Tial MV-S EWG with 16psi spring combo
TurboXS MBC
3" downpipe made by mason
Eventually going to make a custom 3" intake, but that's not a priority
Ok, n00dz:
As you can see, I don't need Dustin's crutch, his modified oil lines. The stock banjo bolt is M12x1.5. This banjo has a .060" restrictor, the correct size for journal bearing. This setup should work perfectly.
Turbo blanket (it's beat up because I used it on my Focus turbo build)
2007 CTS-V - Trying to sell
The Following 15 Users Say Thank You to bmylez For This Useful Post:
aaronc7 (08-31-2011), AJ713 (09-03-2011), BlueStreak (09-01-2011), Broxer (11-08-2011), djuosnteisn (09-09-2011), doubleflusher (09-20-2011), emag remrofni (09-02-2011), essejkcamraw (08-30-2011), I Love Brownies (09-02-2011), JasonMzdSpd3 (05-08-2012), LiEast (09-04-2011), mason (08-30-2011), PapaSmurf (08-31-2011), PunjabiPlaya (08-29-2011), TexasSpeed3 (11-12-2011)
MX-5 EFR Turbo Build Andy@Killshot Miata - Forced Induction 40 12-28-2011 04:01 PM
Turbo Build UKMPS3MK2 2010 MS3 - Turbo Induction 12 05-10-2011 09:53 AM
My big turbo build Speedie6 MazdaSpeed 3/6 - Big Turbo Builds 4 12-09-2010 01:54 AM
Anyone running a precision turbo on MS3 origjdm3 MazdaSpeed 3/6 - Big Turbo Builds 37 07-08-2010 04:04 PM
Page generated in 0.66162 seconds with 32 queries
