 Old 05-21-2011, 08:42 PM   #1
zx2man's Avatar
Posts: 1,356   (View Stats)
Default BT stock motor ms3/6 mileage
Dear stock motor big turbo ms3/6's guys, post up your overall miles on car, and then miles on after big turbo swap. Just for a reference, and hopefully people can update thier miles every few months or so.
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
JBARONE SHIFTERPLATE
COBB RSB
KONIG WHEELS/HANKOOK TIRES
zx2man is offline   Reply With Quote
The Following 4 Users Say Thank You to zx2man For This Useful Post:
kmac (05-21-2011), Post pwned (05-29-2011), Speed3eak (05-31-2011), TenaciousBoost (05-23-2011)
 Old 05-21-2011, 08:54 PM   #2
kmac's Avatar
Posts: 1,792   (View Stats)
2008 ms3 20k on the motor.
Been on the car since 8k, so I'm running it for 12k and no problems.
Compression is 180psi across the board.
The Following 2 Users Say Thank You to kmac For This Useful Post:
dougefresh_ (05-21-2011), zx2man (05-21-2011)
 Old 05-21-2011, 09:11 PM   #3
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
sup niggah im high
u no has 3071 in hata mothafukka? yet?
zx2man (05-21-2011)
 Old 05-21-2011, 09:25 PM   #4
zx2man's Avatar
in about 3 weeks you weed smoking crazy sexy motherfucker.
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
COBB RSB
 Old 05-21-2011, 09:32 PM   #5
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
hahahahahahahha u still want me after the accent??
hahahahahahahahah
weed a talk
zx2man (05-21-2011)
 Old 05-22-2011, 10:14 PM   #6
jwilkins88's Avatar
Posts: 3,675   (View Stats)
Groans: 126
2009 Mazdaspeed Unicorn
30k Miles total
ATP 3076 has been on for 9k miles
Car has been driven to hell and back several times.
I've been running 22+ psi the whole time with very few issues.
The Following 2 Users Say Thank You to jwilkins88 For This Useful Post:
mghtymouse380 (05-22-2011), zx2man (05-22-2011)
 Old 05-23-2011, 12:55 AM   #7
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
2007 MS6 big cock edition
49k+ miles at the moment
TS T3 3076 with Steed TS mani on for about 4k miles
pushing 25+ psi the whole time with a few minor issues based on being a developmental kit.
The Following User Says Thank You to jmhinkle For This Useful Post:
zx2man (05-23-2011)
 Old 05-23-2011, 01:33 AM   #8
wette460's Avatar
Posts: 385   (View Stats)
wette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the world
2007 MS3
38K miles
3071 on at 12K miles
Been running 19 psi for last 15K, low 12 AFR, no KR
Just finishing up T3 build with .82 a/r and steedspeed mani, ported IM and meth...dyno sheet soon to come
new setup will be 21 psi
T3 GTX 3076R .82 a/r, ATP wide-mouth turbo inlet, CPE FMIC, 3.25" MAF custom intake, HKS BPV, Steedspeed T3 Exh. mani, CPE High Output Fuel Pump, Streetunit MM, CP-E side mounts, Mazdaspeed CBE, v-band custom DP, TiAL 38mm EWG, DO stg 2 meth 75/25 w/ do7, 3.5 bar MAP, Cobb AP, TWM solid shifter base bushings, BC racing 32 way adj. coilovers, Mazdaspeed camber links, 18" Bronze Enkei wheels
wette460 is offline   Reply With Quote
The Following 2 Users Say Thank You to wette460 For This Useful Post:
Speed3eak (05-23-2011), zx2man (05-23-2011)
 Old 05-29-2011, 04:28 AM   #9
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
07 ms3 88k miles
3071r about 10k miles on it running 21-22 psi.....
been running 24psi last 2 weeks no issues
/in b4 i try 25-26psi and make a boom thread
rigor (06-30-2011), zx2man (05-30-2011)
 Old 05-29-2011, 05:16 AM   #10
Post pwned's Avatar
Posts: 799   (View Stats)
Post pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the world
^^ you make me want to go BT on my DD!!
I need a beater/learning car.
In for info.
2010 Mica Black
RMM/RSB/SRI+TIP
Post pwned is offline   Reply With Quote
 Old 05-29-2011, 05:25 AM   #11
Axle Breaker
jmhinkle's Avatar
Groans: 162
BT is far better for DD than K04. Doesn't make 20 psi at 1500 RPM like K04 and doesn't make 1000* of 16psi at redline.
The Following 3 Users Say Thank You to jmhinkle For This Useful Post:
jwilkins88 (05-29-2011), Post pwned (05-29-2011), wette460 (05-30-2011)
 Old 05-29-2011, 05:53 AM   #12
Post pwned's Avatar
Stop tempting Me!!!!
I read lennys BT thread and I might be able to go the bolting but the tuning is where I'll blow her up.
2010 Mica Black
RMM/RSB/SRI+TIP
 Old 05-29-2011, 11:27 PM   #13
driver311's Avatar
Posts: 1,769   (View Stats)
08 speed3 52k on car. new motor at 47k. Replaced with 09 brand new motor
Still stock tranny and clutch and no issues. Been used to for autocross, drag racing, track events and many thousands of logs and races. LOL Im impressed with the clutch.
5000 miles between 350-400whp on my atp3071r bolt on turbo. NO need for custom setups when this one is proven to make the power and not break the bank if you gonna keep it under 400whp. And even the 3071r will get you there(on low boost). Shoot Id venture to say the 2871r would get you there also at 22psi. Ive never had mine over 18psi on the street cause the car just gets worthless. Been a rocky road but these cars are finally getting figured out due to all the hard work of the badasses on this forum, and the few jackasses to. LOL
Hopefully Ill put 50k more on it with my 30r. Car seems to love it. The ko4 gave the speeds a bad name. A 16g sized turbo would have put the speeds in a whole new leaque.
Mazdaspeed
The Following 3 Users Say Thank You to driver311 For This Useful Post:
Post pwned (05-30-2011), wette460 (07-03-2011), zx2man (05-30-2011)
 Old 06-30-2011, 09:59 PM   #14
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
stock block
.5557
been on 7000 miles
@23 psi and a little 26 psi and 19psi
no issues no flying dipstick
at 104000 2 bent rods
tuned by nishan
The Following 2 Users Say Thank You to rigor For This Useful Post:
wette460 (07-03-2011), zx2man (07-01-2011)
 Old 05-31-2011, 09:54 AM   #15
Scribbles's Avatar
Posts: 861   (View Stats)
Scribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the world
45k on the motor
07 speed
Atp 3076, 200mi on turbo, stock clutch
07 MS3
Built motor with K1 rods/wesico pistons, ATP 3076r, SS Mani, ATP DP, Cobb FMIC V2, CPE FP, TurboSmart MBC, TurboSmart Dual Port BOV, Hotchkis RSB FSB, BC Coilovers, AP, Dashhawk, Trilogy JBR 88 duro's, JBR catch can, Guardian Angel
Perm
Scribbles is offline   Reply With Quote
The Following 3 Users Say Thank You to Scribbles For This Useful Post:
jwilkins88 (06-07-2011), wette460 (07-03-2011), zx2man (07-01-2011)
 Old 06-07-2011, 02:44 PM   #16
avtoprofi's Avatar
Posts: 5   (View Stats)
avtoprofi has a spectacular aura aboutavtoprofi has a spectacular aura about
MS`6 Stock engine, Garrett GT3076R Tial A/R 1.06
new motor, 12k miles on 16psi (1.1bar)
Mazda 6 MPS for comfortable and fast ride
Mazda 3 MPS for a mad ride and adrenalin
I Love MPS!
avtoprofi is offline   Reply With Quote
The Following 3 Users Say Thank You to avtoprofi For This Useful Post:
Fkin motor blew! (stock '07) Mazdaspeedgirl MazdaSpeed 3 - Engine, Transmission & Driveline 180 05-26-2010 01:03 PM
Highest RPM stock motor can be rev'd to... ?? all4bspinnin MazdaSpeed 6 - Engine, Transmission & Driveline 17 08-31-2009 02:49 PM
CP-E Motor Mounts for the Mazdaspeed 3 in stock ! kevin@gripgarage.com Mazdaspeed3/6 General Discussion 0 04-24-2009 02:25 PM
Motor Mounts in stock? TheDoc Mazdaspeed3/6 General Discussion 1 07-09-2008 12:50 PM
Page generated in 0.37030 seconds with 30 queries
