Like Tree22Likes
 Old 06-16-2015, 01:25 AM   #1
Hammology's Avatar
Posts: 540   (View Stats)
Groans: 36
Neutral  :  -1 score
Default BUILT MOTOR+GTX3071 SPEED6
MOD LIST:
Manley H-beam rods
Carrillo Pistons
Crower valve springs
Pinned cams
Keyed crank
L19 head studs
ARP main studs
Minor head porting intake side
Ported intake mani
Custom Blow thru intercooler setup
Custom 4inch intake
PTP injector seals
CPE exhaust mani
GTX3071
Emusa 44mm wastegate(ebay) w/ custom dumptube
Tial Q 50mm BOV
M2 Downpipe
Devils own meth
SP63 6th port
Here is a V-Dyno from my latest logs. I believe this is the 3rd revision since the break-in map. Had the motor built by Jordan Keefover. Nishan is the tuner, and the car feels great so far.
datalog30.csv
datalog31.csv
memin, Mattyhawk1 and ItsNox like this.
Built motor
GTX3071
Meth
6th Port
The Following 10 Users Say Thank You to Hammology For This Useful Post:
Code Monkey (06-16-2015), fivefingerdeathpunch (06-18-2015), hermz (07-31-2015), ItsNox (06-17-2015), Mattyhawk1 (06-18-2015), Micha (06-21-2015), NCspecV81 (06-17-2015), Scare Dem (07-11-2015), SpeedRebirth (06-18-2015), WetzMS3 (06-18-2015)
 Old 06-16-2015, 06:29 PM   #2
Hammology's Avatar
Groans: 36
Built motor
GTX3071
Meth
6th Port
 Old 06-16-2015, 06:34 PM   #3
Hammology's Avatar
Groans: 36
Built motor
GTX3071
Meth
6th Port
 Old 06-17-2015, 04:19 PM   #4
ItsNox's Avatar
Posts: 3,076   (View Stats)
Excited to see the results! What numbers are you shooting for? How long did it take him to build your motor?
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
Hammology (06-17-2015)
 Old 06-17-2015, 05:11 PM   #5
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Nice build.
Are you going to have enough MAFv headroom to use fully use 6th port? You're already @ 4.5v.
2013 CWP and Stock
 Old 06-17-2015, 05:29 PM   #6
Hammology's Avatar
Groans: 36
Nice build.
Idk lol I'll leave that up to the mad scientist.
It took Jordan about a week to get everything balanced, machined, assembled, and to swap the motor. I can't say enough good things about the man. And as far as power goals are concerned, anywhere north of 400awhp 400awtq.
Built motor
GTX3071
Meth
6th Port
Last edited by Hammology; 06-17-2015 at 05:47 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to Hammology For This Useful Post:
ItsNox (06-18-2015), WetzMS3 (06-18-2015)
 Old 06-18-2015, 09:12 AM   #7
Mattyhawk1's Avatar
Posts: 739   (View Stats)
Sweet. Looking forward to seeing this in person.
The Following User Says Thank You to Mattyhawk1 For This Useful Post:
Hammology (06-18-2015)
 Old 06-18-2015, 09:30 AM   #8
my2k13speed3's Avatar
Posts: 2,325   (View Stats)
Is Jordan Keefover is Overspeed Motorsports right? Just saw his facebook page yesterday, subd' to see the results...Did he do the build and install?
The Following User Says Thank You to my2k13speed3 For This Useful Post:
 Old 06-18-2015, 12:32 PM   #9
Hammology's Avatar
Groans: 36
Yup, he did both.
Built motor
GTX3071
Meth
6th Port
 Old 06-18-2015, 12:57 PM   #10
Where is he located exactly? Mind me asking what you roughly paid for the build/install? May have to take a trip down to So-cal one of these days.
 Old 06-18-2015, 01:47 PM   #11
Hammology's Avatar
Groans: 36
He is located in Long Beach. A basic build and install is $4600 with parts included. Your engine must be a good core of course.
bigspender and BLKSTIG like this.
Built motor
GTX3071
Meth
6th Port
The Following User Says Thank You to Hammology For This Useful Post:
my2k13speed3 (06-18-2015)
 Old 06-20-2015, 12:11 AM   #12
Hammology's Avatar
Groans: 36
Here is a log from a new revision. Solid gains from 1lb of boost, and a few degrees of timing. Unfortunately 91oct has its limits, so im sure there isn't a ton of power left in this pump gas tune. Not to worry though. I have a DO14 nozzle on the way
datalog32.csv
Built motor
GTX3071
Meth
6th Port
BLKSTIG (06-21-2015), Code Monkey (06-20-2015)
 Old 06-20-2015, 06:57 PM   #13
sheston's Avatar
Posts: 1,847   (View Stats)
I'm sure the D014 will really wake that up. You might try some Meth (I use 2 gallons per tank) in the tank as well.
Good luck
Hammology (06-20-2015)
 Old 06-20-2015, 09:10 PM   #14
Hammology's Avatar
Groans: 36
I thought about that, but if I put anything in the tank it will be E85 since a gallon of that is like a third the price of meth.
Built motor
GTX3071
Meth
6th Port
 Old 06-20-2015, 10:44 PM   #15
NCspecV81's Avatar
How big is the housing on the blow-thru maf?
2013 CWP and Stock
Hammology (06-21-2015)
 Old 06-21-2015, 01:11 AM   #16
Hammology's Avatar
Groans: 36
3.5'
Built motor
GTX3071
Meth
6th Port
 Old 06-21-2015, 06:22 PM   #17
sheston's Avatar
You only need less than half as much Meth to get the same knock protection as E85. I like only having to get on extra fuel. Maybe I'm just lazy
 Old 06-21-2015, 08:12 PM   #18
NCspecV81's Avatar
I use 1 gallon of meth intank for solely knock protection. I don't even tune for it.
2013 CWP and Stock
Hammology (06-21-2015), ItsNox (06-22-2015)
 Old 06-21-2015, 10:27 PM   #19
Hammology's Avatar
Groans: 36
I'll consider it. I don't think its a bad idea. I doubt i'll have a gallon of meth to put in my tank every time i fill up.
Built motor
GTX3071
Meth
6th Port
 Old 07-10-2015, 02:06 AM   #20
Hammology's Avatar
Groans: 36
Took a trip to @keefover; today at Overspeed Motorsports to get some work done. He fabbed/welded my hotpipe to eliminate a coupler, did a valve cover modification, and swapped my meth nozzle thats a pain in the ass to get to. I took a 4th gear log just to make sure the meth was working as advertised, and it is. @ms3blackmica; just sent me a map that will supposedly get the bitches I iz excite.
datalog35.csv
Built motor
GTX3071
Meth
6th Port
Koke382 (07-10-2015)
 Old 07-10-2015, 05:15 PM   #21
sheston's Avatar
That is a flat power curve. Load is flat and cfms are linear. I'm jealous
 Old 07-10-2015, 05:17 PM   #22
Hammology's Avatar
Groans: 36
Just flashed the first meth revision today.... HORY SHEET BATMAN!
Built motor
GTX3071
Meth
6th Port
 Old 07-10-2015, 11:14 PM   #23
BLKSTIG's Avatar
Posts: 507   (View Stats)
no VD
 Old 07-10-2015, 11:22 PM   #24
Hammology's Avatar
Groans: 36
Originally Posted by BLKSTIG View Post
no VD
Calm your tits I'll get to it. I'm on a road trip right now.
BLKSTIG likes this.
Built motor
GTX3071
Meth
6th Port
BLKSTIG (07-11-2015), thepatient77 (07-15-2015)
 Old 07-10-2015, 11:33 PM   #25
Hammology's Avatar
Groans: 36
datalog37.csv
Im pretty sure the spike in power up top was a dip in the road, but you get the idea.
Code Monkey, BLKSTIG and sh4d0w like this.
Built motor
GTX3071
Meth
6th Port
The Following 3 Users Say Thank You to Hammology For This Useful Post:
BLKSTIG (07-11-2015), Code Monkey (07-12-2015), Micha (07-20-2015)
 Old 07-11-2015, 12:30 AM   #26
BLKSTIG's Avatar
Took you long enough. I can now finish massaging my penis using visual simulation
 Old 07-11-2015, 12:34 AM   #27
Hammology's Avatar
Groans: 36
Lolz I need moar bewst!
Built motor
GTX3071
Meth
6th Port
 Old 07-12-2015, 09:32 PM   #28
Hammology's Avatar
Groans: 36
Just received a new map from Nishan targeting 26psi
BLKSTIG likes this.
Built motor
GTX3071
Meth
6th Port
BLKSTIG (07-12-2015)
 Old 07-12-2015, 09:44 PM   #29
Can you get the full spool earlier or is it as good as it gets?
 Old 07-12-2015, 09:51 PM   #30
Hammology's Avatar
Groans: 36
I'm not sure. @ms3blackmica; would know more about that. If I had to guess I would say a little.
Built motor
GTX3071
Meth
6th Port
 Old 07-12-2015, 11:01 PM   #31
BLKSTIG's Avatar
How long is the vd gonna take on this one @Hammology;
 Old 07-12-2015, 11:03 PM   #32
Hammology's Avatar
Groans: 36
I haven't even flashed the map yet lol
Built motor
GTX3071
Meth
6th Port
 Old 07-12-2015, 11:03 PM   #33
BLKSTIG's Avatar
Lol slackin
 Old 07-13-2015, 01:28 AM   #34
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
This is only a second revision.
www.tunedbynishan.com
The Following 2 Users Say Thank You to ms3blackmica For This Useful Post:
Hammology (07-13-2015), Micha (07-20-2015)
 Old 07-13-2015, 04:19 PM   #35
Hammology's Avatar
Groans: 36
Just went for a ride with the new 26psi map flashed....I spun tires in second. Haven't found a suitable road to take logs on yet. Humboldt has a lot of fun twisty mountain roads though.
Built motor
GTX3071
Meth
6th Port
BLKSTIG (07-14-2015), ItsNox (07-13-2015), SpeedRebirth (07-14-2015)
 Old 07-15-2015, 02:30 PM   #36
BLKSTIG's Avatar
updates?
 Old 07-15-2015, 03:05 PM   #37
Hammology's Avatar
Groans: 36
updates?
Car is fast as fuck. There are no roads near by to take logs on. I'll get a video of a pull next time I'm in the car.
BLKSTIG likes this.
Built motor
GTX3071
Meth
6th Port
 Old 07-15-2015, 03:06 PM   #38
Nitro's Avatar
Posts: 229   (View Stats)
Nitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond repute
How do you keep any traction on the street?
COBB AP : JBR 3 Inch Full Intake : CORKSPORT TMIC : AUTOTECH INTERNALS : JBR SSP
CPE Full RMM : Cobb Catted DOWNPIPE : BNR S3 : KW V1 Coilovers : Klutch SL18 Rims
Guardian Angel : Stratified 3 Port : Michelin PSS 235/40/18 : SNOW PERFORMANCE : E85
Stratified Tune
Nitro is offline   Reply With Quote
 Old 07-15-2015, 03:09 PM   #39
Hammology's Avatar
Groans: 36
AWD lol
Built motor
GTX3071
Meth
6th Port
 Old 07-15-2015, 03:10 PM   #40
Nitro's Avatar
Fair enough.....but at that power level it must be a the breaking point of shredding those tires....lol
Stratified Tune
Built Motor MS6 I_AINT_RICE MazdaSpeed 3/6 - Big Turbo Builds 87 05-15-2016 11:26 PM
built motor blackms3_71 Mazdaspeed3/6 General Discussion 11 01-31-2013 08:19 AM
Page generated in 0.56596 seconds with 30 queries
