Like Tree13Likes
 Old 04-07-2012, 02:17 PM   #81
XLT_66's Avatar
Posts: 850   (View Stats)
Why do you use your two different user names? Just use Evan@COBB, haha.
It happens because I forget to check which name I'm logged in as.
XLT_66 - Regular dude asking for advice, may regularly insult people, post racist remarks, and browse the NSFW and VIP threads.
Evan@COBB - Supposed to just be logged on to offer support and answer questions to all the noobz and anyone else that needs help with anything COBB related or otherwise.
I do need to do better about following those rules though.
On the plus side, My motor is almost ready to go back in.
However, does anyone know where this goes?
It was in my baggie for the timing cover but all the screw holes are buttoned up.
2009 CWP MS3 Sport
SOLD!
XLT_66 is offline   Reply With Quote
The Following User Says Thank You to XLT_66 For This Useful Post:
meicalnissyen (03-23-2015)
 Old 04-07-2012, 02:46 PM   #82
bmylez's Avatar
Posts: 3,197   (View Stats)
Hmmm, so it's a stud/nut....it's not long enough to be an alternator stud/nut, but maybe it's for one of your other accessories.
2007 CTS-V - Trying to sell
 Old 04-07-2012, 09:34 PM   #83
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
the bottom bolt for the timing cover is a stud much like that one you are holding.
 Old 04-09-2012, 07:35 AM   #84
XLT_66's Avatar
Which bottom bolt? There are several.
Also...little sneak peak at the collector coming along.
2009 CWP MS3 Sport
SOLD!
The Following 7 Users Say Thank You to XLT_66 For This Useful Post:
djuosnteisn (04-17-2012), IshiKage (04-17-2012), jracer (04-09-2012), Monotonous ONE (04-09-2012), ms3blackmica (04-25-2013), nighthawk358 (04-11-2012), NJSPEED3 (04-23-2012)
 Old 04-09-2012, 07:44 AM   #85
its one of the middle 2, i dont think it matters which one, just make sure the long end goes into the block so u can use the nut to screw it in
 Old 04-09-2012, 07:46 AM   #86
XLT_66's Avatar
In this picture, it looks to be right about the crank sensor.....
2009 CWP MS3 Sport
SOLD!
 Old 04-09-2012, 08:01 AM   #87
AFAIK nothing connects to the other side of it so i guess it doesent matter haha
 Old 04-09-2012, 12:13 PM   #88
Tripple OG
NJSPEED3's Avatar
Groans: 113
yeah its the one directly below the crank bolt, but like Ant said it makes no difference.
The Following 3 Users Say Thank You to NJSPEED3 For This Useful Post:
BlueStreak (04-23-2012), rfinkle2 (04-17-2012), XLT_66 (04-10-2012)
 Old 04-12-2012, 06:22 AM   #89
Adam is so pro's Avatar
Posts: 410   (View Stats)
Adam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the world
[ URL=http://minus.com/mLNVUZ9j8/3f][ IMG]http://i.minus.com/jeudY0g9Pz21c.JPG[/IMG][/URL]
[ URL=http://minus.com/mLNVUZ9j8/2f][ IMG]http://i.minus.com/joSwBkyfs725H.JPG[/IMG][/URL]
[ URL=http://minus.com/mLNVUZ9j8/1f][ IMG]http://i.minus.com/jKYCWCIxZPebs.JPG[/IMG][/URL]
Very nice!
Adam is so pro is offline   Reply With Quote
 Old 04-17-2012, 09:09 AM   #90
Master of Hard Parts
Evan@COBB's Avatar
Posts: 240   (View Stats)
Groaned at 8 Times in 2 Posts
Motor is in.
Still need to:
- Finish installing IM and PS
- Finish tucking OCC lines
- Fabricate 3" intake
- Fabricate 3" V-Band DP
- Finish 1 runner on the EM and tie in the WG runners
- Get hotside, DP, and EM coated
- Install FMIC pipes
- Plumb 3-Port EBCS
- Install Axles
- Plumb Turbo
- Adjust clutch
- Fluids
I'm sure they're more but the list is getting shorter.
The Following 15 Users Say Thank You to Evan@COBB For This Useful Post:
Adam is so pro (04-17-2012), amoosenamedhank (04-17-2012), ArcticSpeed3 (04-17-2012), BlueStreak (04-23-2012), Boosted Beluga (04-17-2012), djuosnteisn (04-17-2012), doubleflusher (04-30-2012), IshiKage (04-17-2012), jracer (04-17-2012), ms3blackmica (04-25-2013), NJSPEED3 (04-23-2012), NoTraction (04-24-2012), rfinkle2 (04-17-2012), taf0422 (04-17-2012), xxdjfate76xx (04-17-2012)
 Old 04-17-2012, 02:57 PM   #91
Tabasco69's Avatar
Posts: 554   (View Stats)
Tabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the world
It has rtv sealant on it, going to say a stud bolt for mounting the ac condensor to the oil pan?????
Adjust the clutch? huh?....do you mean bleed the slave, as far as I' am aware there is no clutch "adjustment", hydraulic slave is supposed to adjust automatically
425whp/395ftlbs - GTX3071R .82a/r- 20psi- 92 octane pump fuel
Tabasco69 is offline   Reply With Quote
 Old 04-17-2012, 03:01 PM   #92
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Similar bolt is used for the starter too IIRC, cause a wire harness or something bolts to it.
It'll be obvious once you get to that point, lol.
Looking great Evan!
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 04-23-2012, 01:25 PM   #93
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Just out of curiosity how much is it gona cost to build the TS manifold. it seems TS is alot more efficient than a normal turbo setup, can you gain more power out of a smaller turbo with this kind of setup. for example instead of 400 kinda being the limit on a GT2871 the limit would be somewhat higher?
Damond Built Speed 6
 Old 04-23-2012, 02:32 PM   #94
Tabasco69's Avatar
a gt28 has absolutely no problems with spool up and lag, ts does not change the flow of the tc in terms of lbs of air per minute....other avenues to bump up the flow are for example doing things like changing the turbine housing a/r size or even doing pre turbine injection (not something I am a big fan of doing but it effects the air density) can and will change the ve of a tc......in terms of lbs of air per minute
Twinscroll helps to reduce spool up/lag with larger frame tc, imo= I would not use it on anything smaller then a gt35....anything smaller it is a waste of time and money imo
the answer is no, if you want to squeeze more top end out of a gt28 you can go to a larger a/r turbine housing at the cost of shifting the powerband towards the topend and lossing a bit of spool on the bottom, a 71r using a .64 ar is good to about 42lbs/min and larger housing (.82 ar) can push about 45-46lbs/min . 1lb air/min = 10hp
The Following User Says Thank You to Tabasco69 For This Useful Post:
Deldran (04-23-2012)
 Old 04-23-2012, 02:38 PM   #95
Tripple OG
NJSPEED3's Avatar
Groans: 113
there goes the thread....
 Old 04-23-2012, 09:12 PM   #96
Deldran's Avatar
Groans: 118
Thanks Tabasco. Sorry for the nub question this is my first Turbo car. I knew that twin scroll was more efficient I just didn't know exactly what its impact was. Any update on the build its very interesting
 Old 04-24-2012, 02:37 AM   #97
Tabasco69's Avatar
What did I say? ^
 Old 04-25-2012, 08:19 AM   #98
Evan@COBB's Avatar
Manifold is almost done. Should be broken down and welded up tonight as well as the DP fabb'ed up and have them ready for ceramic coating, along with the hotside and wastegate housing.
Was hoping things would be good to start up this week, but it's looking more like next week now due to me being out of town again.
forever_skyline likes this.
The Following 13 Users Say Thank You to Evan@COBB For This Useful Post:
Adam is so pro (04-25-2012), amoosenamedhank (04-25-2012), BigjohnB20 (04-25-2012), BlueStreak (04-25-2012), Boosted Beluga (04-25-2012), djuosnteisn (04-25-2012), doubleflusher (04-30-2012), forever_skyline (05-09-2012), JacksonMS30 (04-25-2012), jracer (04-25-2012), ms3blackmica (04-25-2013), rghispanic88 (04-25-2012), ruthless013 (04-25-2012)
 Old 04-25-2012, 08:50 AM   #99
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Looks sexy. How much?
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 04-25-2012, 09:05 AM   #100
Evan@COBB's Avatar
Full turbo kit is setting me back the cost of materials and a future favor when he needs something drawn up, etc.
Not too shabby...
The Following 2 Users Say Thank You to Evan@COBB For This Useful Post:
djuosnteisn (04-25-2012), rfinkle2 (04-25-2012)
 Old 04-25-2012, 09:06 AM   #101
Badass.
 Old 04-25-2012, 09:44 AM   #102
Groans: 50
Sorry I ment how much to make another manifold
08 Mazdaspeed 3
 Old 04-25-2012, 10:46 AM   #103
Evan@COBB's Avatar
As of now, it is a one-off. Sorry...
It will be jigged though.
 Old 04-25-2012, 11:06 AM   #104
rghispanic88's Avatar
Posts: 3,131   (View Stats)
Groans: 263
in before its 1300 bucks just for the mani
2010 Black Mica
rghispanic88 is offline   Reply With Quote
 Old 04-25-2012, 11:19 AM   #105
Groans: 50
08 Mazdaspeed 3
 Old 04-25-2012, 12:16 PM   #106
Captain
Will the compressor clear the brake fluid reservoir?
Look gnarly, i like it! Should have fantastic spool with that thing.
www.permtuning.com
 Old 04-25-2012, 01:02 PM   #107
Evan@COBB's Avatar
Looks like it'll be tight where the heat shield for the brake reservoir is but we should be okay. I'm pretty sure we'll need to put a different outlet on the compressor to get the angle we're looking for.
I basically bolted the head flange to the motor when it was out of the car, held the turbo in where I thought a good position might be, and we tacked it all into place and built the runners from point A to point B.
Needless to say...hope it fits!
 Old 04-25-2012, 01:18 PM   #108
Captain
You could always clock that bish down, and route the hot pipe under the car. And if the intake is tricky..... go blow through and put a shroom filter on the compressor
www.permtuning.com
Tokay444 (04-25-2012)
 Old 04-25-2012, 01:46 PM   #109
The Panda's Avatar
Posts: 1,229   (View Stats)
The Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the world
Groaned at 8 Times in 7 Posts
mmmmm....shroomss.. It looks sexy..
2011 BLACK MS3
ZZB on GT3076 Rebuild in progress
The Panda is offline   Reply With Quote
 Old 04-25-2012, 05:09 PM   #110
mason's Avatar
Posts: 946   (View Stats)
can i see a pic of the tig torch he is using?
 Old 04-25-2012, 05:33 PM   #111
is this thing running yet?
maby you should start working on the car more and going to meets across the country less =D
lets go cobb!!!!
djuosnteisn (04-26-2012), doubleflusher (04-30-2012)
 Old 04-30-2012, 12:34 PM   #112
XLT_66's Avatar
Been out of town since Thursday night for my brother's bachelor party. Made it back smelling of stripper tits and with a pretty decent concussion.
Anyway... came back to a finished manifold. I just finished porting the head flange and decking it at lunch.
DP and recirc'd dump tube getting fabbed tonight and off to get coated, hopefully back on Wednesday.
From there...
Plumb the turbo
Install DP and dump
Make my 3" Intake
Rework the hotpipe
Install the axles
Fill it with fluids
Stap it to the dyno and break this thing in.
Once again, I could finish it this weekend if I were going to be around. Headed to Vegas for another bachelor party on Thursday morning.
You'd think I had another car to drive or something by how long this is getting dragged out...
2009 CWP MS3 Sport
SOLD!
The Following 5 Users Say Thank You to XLT_66 For This Useful Post:
Adam is so pro (04-30-2012), djuosnteisn (05-07-2012), doubleflusher (04-30-2012), mason (04-30-2012), ms3blackmica (04-25-2013)
 Old 04-30-2012, 12:47 PM   #113
Groans: 50
So by the next weekend?
08 Mazdaspeed 3
 Old 04-30-2012, 02:16 PM   #114
XLT_66's Avatar
If this thing isn't complete by Sunday, May 13th, I'm going to shoot myself.
2009 CWP MS3 Sport
SOLD!
Boosted Beluga (04-30-2012)
 Old 04-30-2012, 03:18 PM   #115
Groans: 50
If you shoot yourself can I have your setup?
08 Mazdaspeed 3
The Following User Says Thank You to Boosted Beluga For This Useful Post:
superskaterxes (05-07-2012)
 Old 04-30-2012, 04:41 PM   #116
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
That's what she said.
 Old 04-30-2012, 05:08 PM   #117
mason's Avatar
im in vegas!
 Old 05-07-2012, 01:11 PM   #118
Evan@COBB's Avatar
Anyone know where this damper goes? I think it goes somewhere on one of the front fenders but I can't find any mounting holes.
Lemme know...
 Old 05-07-2012, 01:15 PM   #119
Groans: 50
I want to say it goes on the TMM but I think I threw mine away.
weight reduction yo.
08 Mazdaspeed 3
 Old 05-07-2012, 01:16 PM   #120
dampers = unnecessary
because racecar........
Boosted Beluga (05-07-2012)
Built Motor is Done..... yoichi MazdaSpeed 6 - Engine, Transmission & Driveline 107 12-14-2009 10:52 AM
built motor ms3boost MazdaSpeed 3 - Engine, Transmission & Driveline 17 05-20-2009 10:22 AM
Who Has A Built Motor? Need Impressions Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 99 12-22-2008 08:51 AM
Page generated in 0.59157 seconds with 34 queries
