Like Tree41Likes
 Old 07-25-2011, 12:01 PM   #1
708
Erich's Avatar
Posts: 4,274   (View Stats)
Default Bullseye Billet S259 build (soon to be double Batmowheel S366)
Finally up and running. Things went much smoother at first startup then expected with the large throttle body. Still have some tuning work to do, break in (500 miles of babying it, then another 500 miles of a conservative tune.) After that it will make the trip to Portland for Tim to work his magic on it for a race gas tune. Once we know everything works well and nothing else needs to be tweaked, we pull everything off for cleanup and powder coating. Some pictures of the swap and semi-finished product:
Intercooler:
Water Over Air set up with 800HP core, custom 3” intercooler piping, 12 x 12 x 2 heat exchanger, tank has been welded into the front crash beam of the car. It supports 1.2gallons of fluid, custom brackets for heat exchanger and intercooler core. Bosch “Cobra” pump all pushing through ¾ inch silicone hose.
Initial mock up:
Crash bar reservoir:
Heat exchanger:
IC and piping:
Turbo kit:
Custom tubular manifold with T3 flange, running BW S259 billet wheel on a .70 exhaust housing. 45mm TurboSmart WG running 16 psi spring, 2” dump tube dumped under car at back side of downpipe. Custom downpipe and oil lines. You can hear the turbo spool starting at around 2500 RPM (currently at16 psi).
Mocked up:
From underneath:
Wastegate:
Intake Manifold:
Custom tube intake manifold, flow tested at 290 + CFM per runner at 28 inches. 72mm t-body that is plug and play (just needs to be wired in), custom t-body spacer, direct port injection meth with four M4 nozzles. We installed the MAP/BAT sensor in the end of the manifold where the PCV is located, this way we can get the highest and safest temperatures for tuning purposes. Custom PCV evac system, PCV goes into intake manifold and the front block plate now has a bung installed to run a hose to the exhaust system that has a low crack pressure evac valve on it. This way we have vacuum under boost and idle/low throttle applications, vacuum all the time in the motor for proper oil control.
Port Meth Injection:
Cylinder Head:
CNC’ed combustion chambers and exhaust ports. Gasket matched intake runners with a thermal gasket runner matched also. Flow testedat 255CFM at 28 inches intake side, exhaust side TBA. Custom camshafts, upgraded VVT actuator, all the valves have been “mirror” polished and radius cut. Current combination of piston and combustion chamber volume give us a 8.95 to 1 compression ratio.
Engine:
Forged pistons, forged rods, coated OEM bearings, block filled with “block crete”, balanced and blue printed, crank has been “strapped”, ARP custom main studs and head studs (extra large nuts and washers), 5 layer head gasket, balance shaft delete, windage tray, custom oiling modifications to chain tensioner to support high RPM use.
Large nuts:
On the stand:
Clutch/Drivetrain:
Custom Feramic disk with billet flywheel, high sprung pressure plate, supports 600 + WTQ and 750 + WHP. Stock trans and axles for now.
Fuel system:
Stage 2 fuel pump, PRV (performance rail valve), upgraded injector seals, upgraded injector studs, nuts and washers. We have yet to see under 1900 psi under WOT conditions.
Tuning:
Cobb AP, 3 bar map sensor, Tuning (race gas) Tim at SurgeLine (to come after break in)
Other items to mention:
Custom P/S line (to clear the intake plenum)
3” custom intake with heat shield
Custom battery box with slim battery.
The Following 136 Users Say Thank You to Erich For This Useful Post:
06Speed6 (07-26-2011), 802MS3 (07-25-2011), A1ex (05-07-2012), abovie3 (07-31-2011), AJ713 (07-25-2011), ak_spray (02-07-2012), All2envyMS3 (02-07-2012), Alpha (09-18-2011), atvfreek (03-07-2013), backward_0 (07-27-2011), bcmurphy87 (09-22-2011), bertrand_CX_7 (07-26-2011), BigjohnB20 (07-25-2011), Blackspeed (07-25-2011), BlueStreak (07-25-2011), bmylez (01-08-2012), Boosted Beluga (02-07-2012), breakfasteatre (02-06-2012), Broxer (11-17-2011), btstarcher (05-06-2013), CCC (08-09-2011), charlesfist (07-25-2011), Chimmike (07-31-2011), Ckmazdaspeed3 (07-31-2011), cld12pk2go (07-30-2011), Coaststarlight (02-07-2012), Code Monkey (07-19-2013), cpolly69 (08-16-2011), daafisch (02-06-2012), dan7225 (07-25-2011), Dano (08-01-2011), Darksun280 (09-18-2011), Dash08 (05-07-2013), DingoDave (02-10-2012), djuosnteisn (07-25-2011), Docnox (09-21-2011), Don06speed6 (09-21-2011), doubleflusher (07-25-2011), dougefresh_ (07-25-2011), Easter Bunny (02-06-2012), essejkcamraw (07-25-2011), Fail_6 (02-29-2012), Fatguy729 (07-26-2011), fishin53 (07-25-2011), Fobio (07-25-2011), ganque (09-13-2011), Hammology (08-18-2015), helmetface (09-13-2011), I Love Brownies (07-25-2011), i8urgti (07-25-2011), Ingle (02-07-2012), J-Liss (09-22-2011), JacksonMS30 (02-07-2012), jack_hammer (07-26-2011), JMEngineer (07-25-2011), JmkC (09-13-2011), JP@edgeautosport.com (08-15-2011), jracer (07-25-2011), Jsn_Rob (02-28-2012), jwilkins88 (07-25-2011), karl-hungus (07-25-2011), kmac (07-25-2011), kyzomo (09-14-2011), laxplayermjd (07-28-2011), LiEast (07-25-2011), lito37 (08-13-2011), m4tic (07-26-2011), mason (07-28-2011), MATT DAMOND (07-28-2011), mayer (11-17-2011), mazda.speed3 (09-22-2011), MazdaASM (07-28-2011), mazdafreak (02-07-2012), MGM_GT3 (02-07-2012), Micha (02-08-2012), Mistersix (03-10-2013), Mizzle (07-31-2011), Monotonous ONE (07-25-2011), MS3-a(sore)ASS-rex (07-25-2011), ms3blackmica (04-24-2013), Ms3_Miami (03-02-2012), MS6FL (03-31-2012), mtnrunner (07-25-2011), myt_tuf1 (07-25-2011), MZR165 (07-25-2011), nighthawk358 (03-02-2012), NJSPEED3 (07-26-2011), NoRegrets (02-07-2012), NoTraction (05-11-2012), Novej (02-06-2012), obijack (02-08-2012), Oliverms3 (02-08-2012), psychophyr (02-06-2012), QwkEVO (02-16-2012), Raider (02-28-2012), Realgib3 (07-26-2011), redneck4Christ (08-18-2015), redneckrecon (07-25-2011), rfinkle2 (07-25-2011), Rich990 (06-29-2013), RichieRichness (07-25-2011), rigor (07-25-2011), robertof (07-29-2011), robry (08-13-2011), Scribbles (02-06-2012), sidekick (03-11-2013), SIXual Panda (07-25-2011), Snotrocket (02-28-2012), Snyeed (09-18-2011), Speed3eak (03-03-2012), SpeedNess (09-13-2011), SpeedSixxx (02-29-2012), spnkr21 (09-22-2011), superskaterxes (07-25-2011), super_pablo_ (09-21-2011), Sweetsandman (03-12-2013), Tabasco69 (03-11-2013), taf0422 (08-13-2011), thanox2 (07-31-2011), theschrum (07-29-2011), TiGraySpeed6 (02-08-2012), Tokay444 (08-18-2015), Tomas (03-29-2012), Tommy (04-14-2012), triplejumper18 (07-25-2011), uncorked11 (02-06-2012), ViRtUaLheretic (07-29-2011), wankular (07-25-2011), wolly6973 (02-07-2012), writhen (07-31-2011), xb2ms3 (02-06-2012), xdm88 (02-07-2012), ZetaDrift (05-16-2014), Ziggo (09-13-2011), zpele (07-25-2011)
 Old 07-25-2011, 12:07 PM   #2
BlueStreak's Avatar
Posts: 1,467   (View Stats)
That intercooler setup is beyond sexy.
'07 CWP MS3
Forged.
The Following User Says Thank You to BlueStreak For This Useful Post:
Erich (07-25-2011)
 Old 07-25-2011, 12:07 PM   #3
I Love Brownies's Avatar
Posts: 3,791   (View Stats)
Groans: 371
looks like its going to be full of win and a mad sleeper
The Following 3 Users Say Thank You to I Love Brownies For This Useful Post:
Erich (07-25-2011), ganque (09-13-2011), MS3-a(sore)ASS-rex (07-25-2011)
 Old 07-25-2011, 12:14 PM   #4
708
Erich's Avatar
First drive, you can hear the turbo spooling from down the street at the very end:
AJ713, WAHBAM, ak_spray and 3 others like this.
The Following 20 Users Say Thank You to Erich For This Useful Post:
802MS3 (07-25-2011), AJ713 (07-25-2011), ak_spray (02-07-2012), charlesfist (07-25-2011), Chimmike (07-31-2011), dsmluck (07-29-2011), essejkcamraw (07-25-2011), Fail_6 (02-29-2012), ganque (09-13-2011), Ingle (02-07-2012), jracer (07-25-2011), jwilkins88 (07-25-2011), kmac (07-25-2011), MS3-a(sore)ASS-rex (07-25-2011), Ms3_Miami (11-27-2011), NoRegrets (02-07-2012), rfinkle2 (07-25-2011), robry (08-13-2011), SLOWHATCH (01-08-2012), WAHBAM (09-21-2011)
 Old 07-25-2011, 12:15 PM   #5
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Fucking sick build man. So glad someone chose on of the BW S series turbos! I'm looking to run that "Lil" guys big brother if clearance won't be an issue.
NATOR PA
Erich (07-25-2011)
 Old 07-25-2011, 12:18 PM   #6
708
Erich's Avatar
I was concerned with spool time. As early as the S259 is spooling I kind of wish now I had gone with one of the bigger S's with the new batmowheel inducers and compressor housings.
The Following 3 Users Say Thank You to Erich For This Useful Post:
AJ713 (07-25-2011), MS3-a(sore)ASS-rex (07-25-2011), rfinkle2 (07-25-2011)
 Old 07-25-2011, 12:20 PM   #7
Groans: 224
What RPM are you seeing full boost at? I know it's only 16psi but that should give you a decent idea of how it will look.
If what you're saying is true then the S362ETT is definitely what I want then.
NATOR PA
Erich (07-25-2011)
 Old 07-25-2011, 12:35 PM   #8
708
Erich's Avatar
Haven't been in boost much at all yet. The lowest logged instance I have is about 3900 RPM, but I have seen as much as 400 RPM lower then that so around 3500 RPM. I will definitely get some logs up once it hits 500 miles and we start playing with a conservative boost tune.
The Following 2 Users Say Thank You to Erich For This Useful Post:
 Old 07-25-2011, 12:37 PM   #9
Groans: 224
Awesome. Best of luck man. I'll be following your build especially close
NATOR PA
Erich (07-25-2011)
 Old 07-25-2011, 12:21 PM   #10
lol thanks for waiting till this was all done rather then posting a unicorn thread with 2+ year build
The Following 27 Users Say Thank You to superskaterxes For This Useful Post:
06Speed6 (07-26-2011), 802MS3 (07-25-2011), AJ713 (07-25-2011), Alpha (07-26-2011), BigjohnB20 (07-25-2011), Ckmazdaspeed3 (07-31-2011), Dano (08-01-2011), Decepticon (09-22-2011), dougefresh_ (07-25-2011), Erich (07-25-2011), Fail_6 (02-29-2012), i8urgti (07-25-2011), Ingle (02-07-2012), jack_hammer (07-26-2011), kyzomo (09-14-2011), MATT DAMOND (07-28-2011), mazda.speed3 (09-22-2011), Micha (02-08-2012), Mizzle (07-31-2011), MS3-a(sore)ASS-rex (07-25-2011), ms3blackmica (04-24-2013), NJSPEED3 (07-25-2011), Realgib3 (07-26-2011), SLOWHATCH (01-08-2012), SpeedNess (09-13-2011), uncorked11 (02-06-2012), xhymer (09-17-2011)
 Old 07-25-2011, 12:44 PM   #11
zpele's Avatar
Posts: 1,654   (View Stats)
zpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the world
Groans: 354
Groaned at 213 Times in 109 Posts
This looks fucking sick. That intercooler setup is sexy as hell too. Can't wait to see the dyno numbers for it.
2012 Shelby GT500 - Roush Axleback ~ JLT Oil Separator ~ JLT 123mm intake ~ Ngauge ~ Lund Tuned ~ smaller pulley ~ xpipe (loud as fuck now)
2007 Mazdaspeed6 (SOLD) - COBB SRI ~ Gutted Stock Midpipe ~ HKS BPV ~ JBR RMM ~ AWR PMM ~ AWR TMM ~ Juggernaught Rear Diff Mount ~ Dreadnaught Rear Diff Mount ~ ACT Stage 2 Clutch ~ ITV22s ~ AP(self fucking tuned in a week fuckers) ~ Autotech Internals ~ eBay Downpipe ~ Poke Sub thingy
zpele is offline   Reply With Quote
The Following User Says Thank You to zpele For This Useful Post:
Erich (07-25-2011)
 Old 07-25-2011, 12:48 PM   #12
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
^+1
amazing.
how long has this taken and how much has it cost? or maybe you don't want to think about that...
The Following User Says Thank You to tddvrrn For This Useful Post:
Erich (07-25-2011)
 Old 07-25-2011, 12:50 PM   #13
mtnrunner's Avatar
Posts: 864   (View Stats)
mtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the world
Looks great man, just a couple questions. Where is your intake and MAF? And you said your going to make the trip to surgeline for tim to tune your car, where are you located. There are a few of us near portland that meet up quite a bit.
Murdered out 2007 speed3 GT with navi.
mtnrunner is offline   Reply With Quote
The Following User Says Thank You to mtnrunner For This Useful Post:
Erich (07-25-2011)
 Old 07-25-2011, 12:54 PM   #14
708
Erich's Avatar
Intake piping runs along the top of the transmission and then takes a 90 degree bend into the CPe XcelXL and filter. Turns out this location is too hot for the intake air (we suspected it would be, common sense because it is right behind the radiator) so to avoid additional bends we are building a box to isolate the filter from the engine bay and a fan to move the air from the fender in front of the wheel to the filter.
ozzzzz likes this.
AJ713 (07-25-2011), kmac (07-25-2011), MS3-a(sore)ASS-rex (07-25-2011)
 Old 07-25-2011, 11:40 PM   #15
708
Erich's Avatar
Forgot to answer the last question. I am in the Seattle area. I am going to try to make it down to the August surgeline meet (just to show up, not to tune), but no guarantees of that yet. Would be a great way to get some of the break in miles on the car.
 Old 07-25-2011, 12:53 PM   #16
Karmat's Avatar
Posts: 1,179   (View Stats)
OH MY LAWD.
That is sick.
2002 Corvette Z06 (Black)
The Following User Says Thank You to Karmat For This Useful Post:
Erich (07-25-2011)
 Old 07-25-2011, 01:46 PM   #17
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
GL man!
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
Erich (07-25-2011)
 Old 07-25-2011, 01:54 PM   #18
kmac's Avatar
Posts: 1,792   (View Stats)
Look great, that's some nice work. I would think about giving your car anal.
The Following User Says Thank You to kmac For This Useful Post:
Erich (07-25-2011)
 Old 07-25-2011, 01:59 PM   #19
708
Erich's Avatar
Sex with the ported head was a point of discussion.
The Following User Says Thank You to Erich For This Useful Post:
kmac (07-26-2011)
 Old 07-25-2011, 02:01 PM   #20
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Congrats and GL with the build
The Following 2 Users Say Thank You to NJSPEED3 For This Useful Post:
Erich (07-25-2011), kmac (07-25-2011)
 Old 07-25-2011, 02:04 PM   #21
That is definitely the sickest intercooler setup on the forum.
Best of luck with the car Erich.
Erich (07-25-2011), Fail_6 (02-29-2012), kmac (07-25-2011)
 Old 07-25-2011, 02:08 PM   #22
708
Erich's Avatar
I really like the look of my setup, but for efficiency of routing kmac's is the way to go. I don't think I am losing a whole lot to what @kmac did though.
kmac (07-25-2011), rfinkle2 (07-25-2011)
 Old 07-25-2011, 02:07 PM   #23
i8urgti's Avatar
Posts: 1,660   (View Stats)
i8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the world
Groans: 267
between you and @SPEED6 KILLAH i cant wait to see the numbers you both put down on the dyno and track
2006 LPM MS6 GT (totaled)
0-60 mph : 4.2 second (as per DH)
12.83 @ ???MPH 1.67 60ft
2002 Miata Se (convertible whore)
i8urgti is offline   Reply With Quote
The Following 2 Users Say Thank You to i8urgti For This Useful Post:
Erich (07-25-2011), MS3-a(sore)ASS-rex (07-25-2011)
 Old 07-25-2011, 02:12 PM   #24
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
level 3 anomaly detected.
Notifying Mitsu command of Possible threat.
Will not engage until more info is gathered.
Returning to base.
Carry on citizens....
10.7 @ 133 auto 1G DSM
The Following 30 Users Say Thank You to Darksun280 For This Useful Post:
06Speed6 (07-26-2011), 802MS3 (07-25-2011), AJ713 (07-25-2011), bcmurphy87 (02-07-2012), BrianB6 (07-28-2011), CCC (08-09-2011), Chimmike (07-31-2011), Chriscote (08-19-2011), doubleflusher (07-25-2011), emag remrofni (07-26-2011), Erich (07-25-2011), Fail_6 (02-29-2012), Fobio (07-25-2011), IshiKage (07-25-2011), jack_hammer (07-26-2011), jwilkins88 (07-25-2011), kmac (07-25-2011), kunfu (08-01-2011), letzleta (02-02-2012), manelscout4life (07-25-2011), MarkyMark (07-27-2011), mason (07-31-2011), mazdafreak (02-07-2012), MS3-a(sore)ASS-rex (07-25-2011), NJSPEED3 (07-25-2011), Realgib3 (07-26-2011), RichieRichness (07-25-2011), taf0422 (08-13-2011), triplejumper18 (07-26-2011), wette460 (09-15-2011)
The Following User Says NO Thank You to Darksun280 For This Un-useful Post:
11cruzito11 (07-29-2011)
 Old 07-25-2011, 02:43 PM   #25
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Very nice...waiting for more vids.
RichieRichness is offline   Reply With Quote
The Following 2 Users Say Thank You to RichieRichness For This Useful Post:
Erich (07-25-2011), kmac (07-26-2011)
 Old 07-25-2011, 03:33 PM   #26
Tripple OG
NJSPEED3's Avatar
Groans: 113
More info on the head work please?
The Following 3 Users Say Thank You to NJSPEED3 For This Useful Post:
Alpha (09-18-2011), Erich (07-25-2011), kmac (07-26-2011)
 Old 07-25-2011, 07:07 PM   #27
708
Erich's Avatar
Cylinder chambers are dished. A donor head was cut to figure out the water cavities and then both the intake and exhaust runners were ported and polished to safest thickness to those water chamber. I know additional work was done as well, but can't remember off the top of my head.
The Following 4 Users Say Thank You to Erich For This Useful Post:
Fobio (08-22-2011), kmac (07-25-2011), Mchart (09-19-2011), NJSPEED3 (07-26-2011)
 Old 07-25-2011, 10:58 PM   #28
essejkcamraw's Avatar
Posts: 922   (View Stats)
essejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the world
Groans: 47
Groaned at 25 Times in 19 Posts
fuuuuuck yeahhh this is good. GL with this man!
From built & Big turbo to Miata Gheys
essejkcamraw is offline   Reply With Quote
The Following User Says Thank You to essejkcamraw For This Useful Post:
Erich (07-25-2011)
 Old 07-25-2011, 03:42 PM   #29
Groans: 371
this thing will be a beast. slicks are a must and hopefully 11's?
The Following User Says Thank You to I Love Brownies For This Useful Post:
Erich (07-25-2011)
 Old 07-25-2011, 05:17 PM   #30
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Nice! Looking forward to results/more vids
Erich (07-25-2011)
 Old 07-25-2011, 05:34 PM   #31
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
SPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the world
looks very good... carzy intake manifold.. Is that one of pt-performane intake manifold ? more info on the cylinder head?
SPEED6 KILLAH is offline   Reply With Quote
The Following 2 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
 Old 07-25-2011, 06:14 PM   #32
708
Erich's Avatar
It is all John's work.
btstarcher (05-06-2013), SLOWHATCH (01-08-2012)
 Old 07-25-2011, 06:24 PM   #33
m4tic's Avatar
Posts: 4,928   (View Stats)
what the fuck is that thing
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
The Following 2 Users Say Thank You to m4tic For This Useful Post:
Chriscote (08-19-2011), Erich (07-25-2011)
 Old 07-26-2011, 12:31 AM   #34
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
and then i jizzed in my pants
The Following 3 Users Say Thank You to dooderek For This Useful Post:
bmoneyms3 (02-07-2012), Erich (07-26-2011), kmac (07-26-2011)
 Old 07-26-2011, 07:56 AM   #35
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Nice build ! looks awesome !!
Looks like it will put up some big numbers !
So i assume PTP ( john ) did all the work ? With all the shit he got from MSF.. he will have the last laugh..if it puts up huge HP numbers....
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
The Following 5 Users Say Thank You to jracer For This Useful Post:
Alpha (07-26-2011), CCC (08-09-2011), Erich (07-26-2011), kmac (07-26-2011), SLOWHATCH (01-08-2012)
 Old 07-26-2011, 10:07 AM   #36
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
this is a thread worth watching
it's fun to do bad things
The Following User Says Thank You to jack_hammer For This Useful Post:
Erich (07-26-2011)
 Old 07-26-2011, 10:25 AM   #37
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Nice work and nice head. I like the L/A system too.
2006 Mazdaspeed 6
Erich (07-26-2011)
 Old 07-27-2011, 12:19 AM   #38
708
Erich's Avatar
A couple more pictures. Clutch out of the car, oil pan with windage tray and flow sheet for the IM.
File Type: jpg MS DISI intake manifold flow charts (2).JPG (189.0 KB, 3217 views)
btstarcher (05-06-2013), charlesfist (07-27-2011), kmac (07-27-2011), Tomas (07-31-2011)
 Old 07-27-2011, 12:40 AM   #39
backward_0's Avatar
Posts: 773   (View Stats)
backward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the world
holy fuck!
2013 WRX Stock as Fuck.
1997 Eclipse GSX
The Red Rocket, 2011 MS3 Some other bastards problem now.
backward_0 is offline   Reply With Quote
The Following User Says Thank You to backward_0 For This Useful Post:
Erich (07-27-2011)
 Old 07-28-2011, 06:42 AM   #40
jracer's Avatar
Groans: 89
is the clutch a one off custom ? whats the flywheel weight ?
cost for that set up ?
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
The Following User Says Thank You to jracer For This Useful Post:
Erich (07-31-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/bullseye-billet-s259-build-soon-double-batmowheel-86881/
COBB Tuning - The First AccessPORT Tuned 600+ WHP MAZDASPEED3 This thread Refback 06-18-2015 03:14 AM
Engine rebuild mk1 ? Mazda MPS Owners Club This thread Refback 12-28-2014 12:55 PM
Engine rebuild mk1 This thread Refback 06-07-2014 07:39 AM
Search Results mazda This thread Refback 03-29-2014 08:59 PM
Engine rebuild mk1 This thread Refback 02-17-2014 08:47 PM
Engine rebuild mk1 ? Mazda MPS Owners Club This thread Refback 09-12-2013 04:54 PM
Untitled document This thread Refback 12-23-2012 10:24 AM
| Page 6 This thread Refback 11-11-2012 02:08 PM
?????? This thread Refback 09-25-2012 01:22 PM
| Page 5 This thread Refback 09-16-2012 10:31 AM
------The Mazdaspeed Thread----- This thread Refback 07-04-2012 08:17 AM
My Mazdaspeed 3 - Page 3 - Club3G Forum : Mitsubishi Eclipse 3G Forums This thread Pingback 06-09-2012 01:48 PM
| Page 3 This thread Refback 05-19-2012 09:11 AM
COBB Tuning Blog » Search Results » mazdaspeed This thread Refback 04-24-2012 12:44 AM
COBB Tuning Blog » Mazdaspeed This thread Refback 04-19-2012 01:54 PM
COBB Tuning Blog » AccessPORT This thread Refback 04-18-2012 01:50 PM
COBB Tuning Blog This thread Refback 04-13-2012 09:05 PM
COBB Tuning Blog » AccessPORT Manager This thread Refback 04-08-2012 07:21 AM
COBB Tuning Blog » Video This thread Refback 04-02-2012 02:25 PM
COBB Tuning Blog » Motorsports This thread Refback 04-01-2012 04:26 PM
708 whp Mazdaspeed3 This thread Refback 03-04-2012 08:36 PM
COBB Tuning Blog » MAZDASPEED3 This thread Refback 02-23-2012 11:03 PM
COBB Tuning Blog » COBB Tuning This thread Refback 02-22-2012 08:37 PM
The First AccessPORT Tuned 600+ WHP MAZDASPEED3 | SpeedForums.org This thread Refback 02-16-2012 10:20 PM
The First AccessPORT Tuned 600+ WHP MAZDASPEED3 This thread Refback 02-16-2012 03:46 PM
The First AccessPORT Tuned 600+ WHP MAZDASPEED3 — blogs.cobbtuning.com — Readability This thread Refback 02-16-2012 02:37 PM
COBB Tuning Blog » The First AccessPORT Tuned 600+ WHP MAZDASPEED3 This thread Refback 02-16-2012 07:56 AM
Gros setup pour mazdaspeed 3 - 640WHP - Page 2 - Mazda 3 Quebec This thread Refback 02-13-2012 11:27 AM
640whp mazdaspeed3 This thread Refback 02-07-2012 09:33 AM
640whp ms3??? This thread Refback 02-07-2012 08:26 AM
Report: Audi would rather build its own plant in Mexico than double-up with VW Haltech Automotive News 0 07-22-2011 09:30 AM
Need a JB Billet RMM installation pdf (Help!) MoparGo Mazdaspeed3/6 General Discussion 17 06-08-2011 06:58 AM
jbr 80 duro billet rmm tddvrrn JAMES BARONE RACING 8 05-08-2011 10:12 PM
SEMA 2009: Toyota Tundra Hot Rod kinda cool, but misses the bullseye Haltech Automotive News 0 11-04-2009 04:00 PM
Bullseye / Borg Warner .55 A/R T3 S256 Turbo, Need input! JumpingJackson MazdaSpeed 3/6 - Turbo Induction 5 09-03-2009 07:45 AM
Page generated in 0.89408 seconds with 45 queries
