Like Tree7Likes
 Old 11-26-2011, 02:09 AM   #1
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Neutral  :  -1 score
Default Cheap Jew Big turbo build
Jewing my way to 400+whp
Was going to originally go with a gtx with atp hotside. But work bonuses are no longer that big at work. So bought the turbo used (buyer said roughly 5k miles) and jewed out on other things to save money. All in all all parts were bought for under 1500 total. I figured if I went the route i was going (gtx with ATP hotside) would have been closer to 2300. 800 dollars that can be spent on hookers and blow. Would have been cheaper if I decided to stay stock intake. But decided to open that up.
Parts:
GT3076 ATP IWG hotside (came with: Coolant in line, low profile oil feed banjo, coolant return barbed banjo fitting)
Treadstone 3" maf
Treadstone 2" silicon hose and 2" coupler (will be coupled to ets tmic)
2x Treadstone garrett/efr 10an drain flanges (much cheaper then ATP with integrated
gasket and no need for step down studs)
10an drain line lubed with doubleflusher's man juice
Silicon intakes 3" 45 degree elbow
HTP 3" turbo inlet with 3" to 4" reducer (not picture being fabbed)
Various tbolt and worm clamps, new crush washers, studs
Hallman Pro RX boost controller in homo purple
3 bar map still needs to be ordered
Everything
GT3076
Decided to do a little porting to the flapper area with a dynafile and some rotary grinding stones.
Inside the turbine housing
Flapper side with half moon bit of metal taken out and smoothed the transition greatly
Once I get my TIP in I'll start getting ready for the build and snapping some pics along the way to hopefully help anybody else going the bolt on route. Not that it hasn't been done before.
Hamilton69 likes this.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
Last edited by 86AmishMs3; 02-03-2012 at 07:01 PM. Reason: MSF Database - Automerged Doublepost
The Following 15 Users Say Thank You to 86AmishMs3 For This Useful Post:
AZSPEED3 (11-26-2011), breakfstincluded (11-26-2011), Broxer (03-17-2012), Dahouse702 (12-16-2011), Darksun280 (11-26-2011), doubleflusher (11-26-2011), Frequentflyer (12-19-2011), Hamilton69 (11-26-2011), jracer (11-26-2011), kritz (11-26-2011), mzr0818 (11-26-2011), rtabagaboy (11-26-2011), Scribbles (11-26-2011), uncorked11 (11-26-2011), wankular (12-12-2011)
The Following User Says NO Thank You to 86AmishMs3 For This Un-useful Post:
Vansquish (11-26-2011)
 Old 11-26-2011, 05:03 AM   #2
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
In for build pics.
Nator is what it does.
86AmishMs3 (11-26-2011)
 Old 11-26-2011, 06:27 AM   #3
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
you say you're staying TMIC?
i'd use that $800 put aside for hookers and blow and get fmic.
07 MS3
The original Genpoo Hater
86AmishMs3 (11-26-2011), ZoomByU (12-22-2011)
 Old 11-26-2011, 06:27 AM   #4
mzr0818's Avatar
Groans: 221
Looks good.
EMWNM 2013
2008 mazdaspeed 3 true red
Tuned by Nishan
 Old 11-26-2011, 06:32 AM   #5
irishking03's Avatar
Posts: 2,136   (View Stats)
irishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the world
3076 should put you in the 450 range shouldnt it.
2009 Metro Grey Numbers Fully Bolted.
Nator Pa Dyno Day: 311HP 328TQ Pump 93
Nator Pa Dyno Day: 310HP 329TQ Pump 93
End of Drive 9/24/2013
2012 Liquid Silver
Cobb AP
irishking03 is offline   Reply With Quote
The Following User Says Thank You to irishking03 For This Useful Post:
 Old 11-26-2011, 09:33 AM   #6
ColonR's Avatar
Posts: 1,453   (View Stats)
ColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the world
Your gunna need a 21/2 to 2in reducer piece of silicone for the inter cooler hot pipe from your Turbo
1992 miata, track beast here I come with 2 bride seats!! (current)
3076r speed6 owner (traded)
2000 camaro 415rwhp thru midwest chassis fab (sold)
ColonR is offline   Reply With Quote
The Following User Says Thank You to ColonR For This Useful Post:
 Old 11-26-2011, 10:08 AM   #7
86AmishMs3's Avatar
Groans: 338
All in time. With around 550in3 of area the ets falls somewhere in between a tr6 and tr8 core size. The ets is no slouch when it comes to size. Not like i'm running a cx racing fmic with a puny core.
Negative, tmic is a 2" coupler.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
Last edited by 86AmishMs3; 11-26-2011 at 10:09 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to 86AmishMs3 For This Useful Post:
m249saw (12-21-2011)
 Old 11-26-2011, 10:16 AM   #8
Scribbles's Avatar
Posts: 861   (View Stats)
Scribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the world
Shit, finally. You've been talking about this forever. We also have the exact same carpet O.o
Congrats on finally getting everything together, 76 wont disappoint you. Let us know if you need help installing this
07 MS3
Built motor with K1 rods/wesico pistons, ATP 3076r, SS Mani, ATP DP, Cobb FMIC V2, CPE FP, TurboSmart MBC, TurboSmart Dual Port BOV, Hotchkis RSB FSB, BC Coilovers, AP, Dashhawk, Trilogy JBR 88 duro's, JBR catch can, Guardian Angel
Perm
Scribbles is offline   Reply With Quote
The Following User Says Thank You to Scribbles For This Useful Post:
 Old 11-26-2011, 10:24 AM   #9
spoof3r's Avatar
Posts: 260   (View Stats)
spoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the world
Has anyone really successfully run a TMIC on a BT build? I know I was having major heat soak issues on mine before I even went BT. My tuner told me to not even bother.
Oh well, FMIC look sick anyways! Good luck with the build, man!
2010 Mazdaspeed3 - Garrett GT3076R Turbo, SteedSpeed Manifold, Tial 38mm External Wastegate w/ Dump Tube, ATP Big MAF Housing, ATP 3" TIP/Intake, HKS SSQV BOV, Ultimate Racing FMIC, Ultimate Racing Catless DP, CS Test pipe, CS Catback Exhaust, Autotech HPFP Internals, Hallman Pro Boost Controller, Cobb AccessPORT, BC Coilovers, DDM 8000k HID's, Red Brake Calipers w/ Decals, Custom Smoked Headlights, Smoked Taillights, 18% Window Tint.
2011 Mazda2 Sport - OEM Fog Lights, OEM Touring Rear Spoiler, Sport Edition F2 Silver Wheels, Green Brake Calipers, 18% Window Tint,
Social Engineering - Because there is no patch for human stupidity.
spoof3r is offline   Reply With Quote
The Following User Says Thank You to spoof3r For This Useful Post:
 Old 11-26-2011, 03:48 PM   #10
6oost3d's Avatar
Posts: 151   (View Stats)
6oost3d is the leader of the world6oost3d is the leader of the world6oost3d is the leader of the world6oost3d is the leader of the world6oost3d is the leader of the world6oost3d is the leader of the world6oost3d is the leader of the world6oost3d is the leader of the world6oost3d is the leader of the world6oost3d is the leader of the world6oost3d is the leader of the world
Looks like my turbo went into the right hands. good luck with the build!
Did you get a tap for the boost source?
2006 Mazdaspeed6 GT
GTX3582 T3 .82 A/R // Wiseco Pistons // K1 Rods // H11 Head Studs// Steedspeed Top Mount Manifold // TiAL MVR // TiAL MVS // PERM Top Mount Kit // NGK plugs // Custom FMIC // Cobb AP // Bosch 3 Bar MAP// Magnaflow Exhaust // MSD Dashhawk // RPM Springs //JBR STG 2 OCC // JBR EGR Delete //Autotech Fuel Pump Internals // SU Motor Mount // Prosport Boost Guage // ACT 6 Puck //Fiber Images Carbon Fiber Hood // Snow Performance Stage 2 WMI, d10 & d12 nozzles // Corn Fed
516whp/476tq - Mega Meat 2013
6oost3d is offline   Reply With Quote
The Following User Says Thank You to 6oost3d For This Useful Post:
 Old 11-26-2011, 03:52 PM   #11
Will fuck up ur day
Chimmike's Avatar
Groans: 433
I'm not concerned about the core size on the ETS, the heatsoak is the problem. FMIC will never heatsoak as much as a TMIC will and will constantly see better flow.
anywho, good luck
07 MS3
 Old 11-26-2011, 03:53 PM   #12
Police - Grammarhead
Vansquish's Avatar
You'll have to excuse me for this. I may be putting myself directly in the line of fire for a bunch of flaming, but just how offensive are you trying to be?
Your build looks like it could be a lot of fun, and I'm glad for the info and pictures, but the way you titled this thread, and the way you're talking about this is incredibly racist, anti-semitic and offensive.
I normally don't take offense to this sort of thing, but I can't understand why you'd even say that you're "Jewing" your way to something (and yes, I do understand what the phrase means).
I hope you can change the title and your post, but if you can't, I hope you at least change the language you use in the future.
free_refil (01-09-2012)
The Following 12 Users Say NO Thank You to Vansquish For This Un-useful Post:
86AmishMs3 (11-26-2011), Danish (12-20-2011), Easter Bunny (12-18-2011), jracer (12-10-2011), jroc (11-26-2011), Mac21 (12-21-2011), psychophyr (12-09-2011), Realgib3 (11-27-2011), Roddiy (12-18-2011), rtabagaboy (11-26-2011), sheldonross (12-21-2011), ZoomByU (12-22-2011)
 Old 11-26-2011, 04:04 PM   #13
COOL STORY BRO
Hamilton69's Avatar
Posts: 2,418   (View Stats)
Groans: 179
Neutral  :  0 score
slang term....i found it humorous
ZOOM ZOOM BOOM
The Following 5 Users Say Thank You to Hamilton69 For This Useful Post:
86AmishMs3 (11-26-2011), Danish (12-20-2011), jracer (11-26-2011), jroc (11-26-2011), TriO (04-11-2012)
 Old 11-26-2011, 04:44 PM   #14
bmylez's Avatar
Posts: 3,197   (View Stats)
Neutral  :  -1 score
Surprised you've made it for over 2 years on this site. I don't get offended by all the other racial slurs thrown around 'cause it's all in fun and the majority of people on here don't know the race of the other, so it's just blind joking.
Good luck to ya, OP. Car will be beast mode.
2007 CTS-V - Trying to sell
The Following 3 Users Say Thank You to bmylez For This Useful Post:
86AmishMs3 (11-26-2011), jracer (11-26-2011), ZoomByU (12-22-2011)
 Old 11-26-2011, 04:51 PM   #15
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
looks like fun....if you are going MBC why get an upgraded MAP?
 Old 11-26-2011, 04:53 PM   #16
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Neutral  :  0 score
Good build !
No offended taken . Other dude needs to chill.
We all are Jews when buying parts when money is tight ! Lol
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
The Following 7 Users Say Thank You to jracer For This Useful Post:
86AmishMs3 (11-26-2011), dougefresh_ (12-09-2011), jayspeed3 (11-27-2011), jroc (11-26-2011), memin (12-18-2011), speedyspaghetti (12-07-2011), TriO (04-11-2012)
 Old 11-26-2011, 04:53 PM   #17
bmylez's Avatar
So he can log boost?
 Old 11-26-2011, 05:00 PM   #18
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
agreed, I felt like I was adjusting MBC blind once I went over 23 psi. I dont trust my boost guage really lol
The Following User Says Thank You to crazyp For This Useful Post:
 Old 11-26-2011, 05:14 PM   #19
86AmishMs3's Avatar
Groans: 338
Neutral  :  0 score
ahahaha this is msf dude. I don't know where you've been. I don't care who gets offended here. You have to take everything with a grain of salt.
Yeah it got it, just in one of the boxes. Thanks!
MAP sensor is cheaper then boost gauge haha. Plus one day i might try ebcs. But for ease of tuning mbc.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
Last edited by 86AmishMs3; 11-26-2011 at 05:14 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-26-2011, 05:15 PM   #20
Vansquish's Avatar
I do tend to take things with a grain of salt, for some reason, this thread's title just hit me differently. I don't want to derail your thread either.
Back to it, your build looks like it's going to be pretty baller. I hope it turns out well, I'll be watching so I can figure out how I can do my own "cheap" build. Cheers man.
The Following 4 Users Say Thank You to Vansquish For This Useful Post:
86AmishMs3 (11-26-2011), AZSPEED3 (11-26-2011), Easter Bunny (12-18-2011), free_refil (01-09-2012)
 Old 12-09-2011, 09:08 PM   #21
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Could be good for boost limits fuel cut too.... not that I'd know, lol
Mazel Tov
The Following 3 Users Say Thank You to dougefresh_ For This Useful Post:
86AmishMs3 (12-10-2011), psychophyr (12-09-2011), rigor (12-10-2011)
 Old 12-16-2011, 06:18 PM   #22
86AmishMs3's Avatar
Groans: 338
Got dissasembled today. Obigatory pics of turbo comparo and then pics of ma intake for the turbo.
Acually turbo install is going smooth. Have the 3076 already on the car to the manifold.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
The Following 5 Users Say Thank You to 86AmishMs3 For This Useful Post:
Broxer (03-17-2012), dougefresh_ (12-16-2011), jracer (12-16-2011), Ms3_Miami (12-24-2011), rfinkle2 (07-06-2012)
 Old 12-16-2011, 06:28 PM   #23
MoparGo
Lurkers
MoparGo's Avatar
Posts: n/a
Arrow Wow...
...that Garrett dwarfs the k04... In fact, it looks like it consumed a couple of k04s.
Are you certain this is a "cheap jew" build? It looks more like a "rich protestant" build ().
Potentially derogatory remarks aside, subbed to see the finished installation. Ditto on the Mazel Tov sir.
The Following 3 Users Say Thank You to For This Useful Post:
86AmishMs3 (12-16-2011), dougefresh_ (12-16-2011), SLOWHATCH (12-23-2011)
 Old 12-16-2011, 06:30 PM   #24
86AmishMs3's Avatar
Groans: 338
Are you certain this is a "cheap jew" build? It looks more like a "rich protestant" build().
Hahah yeah. But i would call it a fairly cheap build. I mean everything else I saved a lot of money on, and I wanted a quality turbo, not so much on an ebay turbo.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 12-16-2011, 06:49 PM   #25
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
lol cheap
The Following User Says Thank You to dooderek For This Useful Post:
86AmishMs3 (12-17-2011)
 Old 12-16-2011, 06:56 PM   #26
dsmluck's Avatar
Posts: 1,193   (View Stats)
dsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the world
Groans: 60
You don't need a FMIC. If I was building a speed again I would go TMIC and Meth. You can still heat soak the pipes on a FMIC so its not immune to engine heat. TMIC is easier to keep from getting boost leaks and its a much shorter path. I ran a CX core with a 50\50 meth setup and the FMIC would heat soak in the summer but as soon as I was in boost the BATs would drop to below ambient. This was on the 3076. I fucking hated the FMIC and would have gladly traded it for a good aftermarket TMIC.
2003 Lancer Evolution VIII - FIC 1120cc/Walbro 255/E85/Pure Drive Performance Tune
1990 Talon TSI AWD: Evo III 16g/E85/Exhaust/PTE 1000cc's/2g Maf/ECMLink *Wrecked*
2012 WRX: TD05 20g/E85/FIC 900cc's/Walbro 255 *SOLD* 12.8@110mph
2009 MS3: GT3076r/(75/25) E85/Bolt-ons *SOLD* 13.6@112mph
dsmluck is offline   Reply With Quote
 Old 12-17-2011, 09:44 PM   #27
86AmishMs3's Avatar
Groans: 338
Ok so turbo installed. A little bit of a bitch, new tune loaded. Running completely off of manual boost control. Having issues building boost, it's tough just to get to 5psi under 5500rpm's, but it starts creeping exponentially at redline, any thoughts. I need to get a log going probably for more assistance, but wonering if any thoughts.
Wastegate is preloaded, and hooked up properly. Acts as if it's open always....
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 12-17-2011, 10:29 PM   #28
86AmishMs3's Avatar
Groans: 338
Just me or does that actuater arm look all the way open
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 12-18-2011, 06:38 AM   #29
bmylez's Avatar
Unless you have a massive boost leak that somehow fixes itself near redline, I agree with WGA is stuck. I sure hope you don't have to pull the whole turbo to fix that...
 Old 12-18-2011, 03:20 PM   #30
Scribbles's Avatar
nator az fail. lol jking. but yea, the arm does look open.
Why stock mani? ffffuuuuuu
07 MS3
Perm
 Old 12-18-2011, 03:37 PM   #31
bmylez's Avatar
Stock manifold is fine, man. When I finally go gt3076, I'm keeping stock manifold. Make sure you have some sort of turbo bracket or it will stress the manifold too much.
 Old 12-18-2011, 05:44 PM   #32
86AmishMs3's Avatar
Groans: 338
The big heavy cast son of a bitch, i think it should be able to handle the weight of the guy. Well time will tell at least.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 12-18-2011, 05:53 PM   #33
bmylez's Avatar
Yes, but what about the flexible portion in the middle? I wouldn't want to put much weight on that. I'm not afraid with stock turbo 'cause it's such a little guy, but a gt3076 weighs a lot more.
 Old 12-18-2011, 07:13 PM   #34
86AmishMs3's Avatar
Groans: 338
meh it breaks it breaks, i can have another stocker for cheap. But when you get yours i'll let you know how mine has been holding up .
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 12-18-2011, 07:26 PM   #35
86AmishMs3's Avatar
Groans: 338
Once i get this actuator issue figured out i will start posting logs. But mandatory engine bay shot (no cover on at the moment, and mbc is sitting on the engine) Oh and not pictured chisel in the recirc tube until i get a longer line.
Only big issues I had were removing the manifold, again to get the oil feed on. Too difficult to put the oil feed on the turbo when bolted to the mani. Didn't want to take a chance of crossthreading.
Also the atp supplied oil drain, is far too long. Cut about an inch and a half off. No big deal. Used a banjo nipple bold on coolant out instead of bending the stock line. And also extended the heater hose to get the turbo inlet pipe in.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 12-20-2011, 07:56 AM   #36
86AmishMs3's Avatar
Groans: 338
Flipped the wastegate actuator around. Now i reach spring pressure. Time to start tuning now. thanks @JacksonMS30 and @eric@edgeautosport for your help on this one.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
The Following 2 Users Say Thank You to 86AmishMs3 For This Useful Post:
JacksonMS30 (12-20-2011), rfinkle2 (12-20-2011)
 Old 12-20-2011, 06:10 PM   #37
Scribbles's Avatar
Curious how your logs will look. You going part e85?
07 MS3
Perm
 Old 12-20-2011, 11:16 PM   #38
86AmishMs3's Avatar
Groans: 338
Yep, we'll see how she does on 2.5g and then maybe i'll bump up to 5g. This should help me get a little more agressive. So far this turbo is awesome.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 12-21-2011, 07:14 AM   #39
bmylez's Avatar
So if you read Anthony's (driver311) thread, he is a firm believer that using the smallest amount of e85 necessary to get all the KR-prevention benefits is optimal. I know, just someone's opinion, but his car is going nuts with just 4 gal and he never ever has knock. I think his 1/4 mile times speak for themselves
86AmishMs3 (12-21-2011)
 Old 12-21-2011, 07:24 AM   #40
86AmishMs3's Avatar
Groans: 338
definately. I don't want to deal with the same things the 100% e85 guys are dealing with. Just enough to give me knock protection.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
Page generated in 0.59815 seconds with 38 queries
