Like Tree10Likes
 Old 11-11-2015, 04:59 PM   #81
richt2831's Avatar
Posts: 87   (View Stats)
richt2831 has a brilliant futurericht2831 has a brilliant futurericht2831 has a brilliant futurericht2831 has a brilliant futurericht2831 has a brilliant futurericht2831 has a brilliant futurericht2831 has a brilliant futurericht2831 has a brilliant futurericht2831 has a brilliant futurericht2831 has a brilliant futurericht2831 has a brilliant future
1 bad MS3
richt2831 is offline   Reply With Quote
 Old 11-11-2015, 05:00 PM   #82
WAMBUSHHHH!'s Avatar
Posts: 1,599   (View Stats)
Ah so what we learned today is that car starters and computer equipment are troubleshooted in the same manner...hit it until it works or you've destroyed it so you know for sure you need a new one
sent from...I'm pooping
richt2831 likes this.
The Following 3 Users Say Thank You to WAMBUSHHHH! For This Useful Post:
DingoDave (11-16-2015), MD1032 (12-13-2015), Thepedigree13 (11-11-2015)
 Old 11-15-2015, 08:27 AM   #83
pastry00's Avatar
Posts: 154   (View Stats)
pastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud of
Groaned at 5 Times in 1 Post
Hey just wanted to update your guys on the turbo install.
Biggest difficulties with install. The most difficult part with the install was pulling the turbo out of the small hole as well as putting the corksport turbo into the small hole. Other then that I did not run into any really difficult issues to overcome, other then the issues with the car starting haha. Also if anyone installs the new 3.5 Bar map sensor by corksport u have to use a lot of force to plug it in it has to click, that gave me a lot of issues.
The turbo sounds great it has a deeper intake sound and sounds awsome! I can't get enough of the sound haha. I am currently running 17 pounds of boost as purple drank works on my tune once I send over more logs. The car moves though with 17 pounds of boost! Currently I was informed that I have a vaccumm leak from my tuner so I have to fix that before I move on. Thanks again for all the help guys.
pastry00 is offline   Reply With Quote
The Following 2 Users Say Thank You to pastry00 For This Useful Post:
richt2831 (11-20-2015), WAMBUSHHHH! (11-16-2015)
 Old 11-15-2015, 11:13 AM   #84
blackms3_71's Avatar
Posts: 2,250   (View Stats)
I can tell you it is the starter signal wire. I will put money on it
 Old 11-20-2015, 05:37 AM   #85
richt2831's Avatar
Let me know what kind of Hp you put down
1 bad MS3
 Old 11-20-2015, 05:45 PM   #86
pastry00's Avatar
Will do just waiting on a gasket for my BOV. Keep u updated.
 Old 11-20-2015, 06:10 PM   #87
my2k13speed3's Avatar
Posts: 2,325   (View Stats)
what fuel you plan on running?
 Old 11-20-2015, 06:31 PM   #88
richt2831's Avatar
Ok cool
1 bad MS3
 Old 12-13-2015, 01:23 PM   #89
pastry00's Avatar
So I got my final tune the other day from purple drank tuning. He kept it some what conservative since my car is a daily at 21 psi. I have yet to get it on a dyno to see how much horsepower I'm getting. I have to say though it is a great tune and the corksport turbo sounds incredible. It has a deep loud turbo sound to it and the car moves! It is a great improvement from the stock k04 I love driving my car again and it is quick! I was also told if a get a bigger intake right now I only have a 2.5 inch I can gain another 20 to 30 horsepower so I will get to that eventually. But for anyone thinking about getting a new turbo I would highly recommend getting corksport's turbo. It wasn't even that difficult to install myself.
my2k13speed3 likes this.
robbspeed (12-13-2015), We Are Ninja (06-08-2017)
 Old 12-13-2015, 01:56 PM   #90
What type of numbers are you seeing on vdyno?
 Old 03-15-2016, 07:59 PM   #91
Sleepin6's Avatar
Posts: 99   (View Stats)
Sleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to behold
Default Dyno #'s yet?
Dyno #'s yet?
MS6 GT...REBUILD IN PROGRESS
BOLTED AND BOOST PROVIDED BY...
SPEED1/CORKSPORT...
Sleepin6 is offline   Reply With Quote
 Old 03-20-2016, 07:53 PM   #92
MRR
MRR's Avatar
Posts: 95   (View Stats)
MRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to behold
Did mine too, No issues. l Tuned it myself no issues. Nice turbo. Its smooth through all the way to 7000 RPM. Keep an eye on your knock retard gauge (accessport) for safety. It needs to read bellow 1 at boosted RPMs. Sometimes dyno's tunes will differ from when you start driving hard on the road.
MRR is offline   Reply With Quote
 Old 03-20-2016, 10:18 PM   #93
gdawg25's Avatar
Posts: 248   (View Stats)
gdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the world
Let's see some logs and a vdyno.
'08 MS3 // Corksport Turbo // JBR 3.5" WP // CNT Racing Turbo-Back // CX Racing FMIC // COBB AP // SURE Ventus // SURE Return // Damond Motorsports PMM & TMM // SURE Torq R3 // Stratified Guardian Angel // Autotech HPFP Internals // JBR EBCS // Corksport 3.5bar MAP // JBR S2 OCC // JBR EGR Delete // JBR TIG's // CP-e Safe Seals // SURE Shortcut // Corksport Swaybars // Bilstein Sports // H&R Springs // Tenzo R Type M 18"x8" // Michelin PSS
gdawg25 is offline   Reply With Quote
 Old 03-21-2016, 01:52 AM   #94
MRR
MRR's Avatar
Attached is latest data log done 3 days ago. Ill try to get it dyno'ed soon if I can. And more than happy to post results.
 Old 03-21-2016, 11:14 AM   #95
gdawg25's Avatar
Download Virtual Dyno. Take a 4th gear WOT log on a flat, straight road, and upload the log to virtual dyno. Should be a good representation of what kind of power you are making.
 Old 03-21-2016, 12:53 PM   #96
Mazdaspeed3GT's Avatar
Posts: 79   (View Stats)
Mazdaspeed3GT is a jewel in the roughMazdaspeed3GT is a jewel in the roughMazdaspeed3GT is a jewel in the roughMazdaspeed3GT is a jewel in the rough
That log is from the CS turbo?
Not bashing, but it looks severely lacking in power.
You say you tune yourself, what are you using to tune?
CS 3" SRI | CX Racing + TR6 FMIC | CS HPFP | M2 Test Pipe | ClutchMasters FX100
COBB AP | CP-e RMM | Forge V2 | CS Shift Plate + Bushings | E30 Mix
CP-e Triple Gauge Pod | ProSport Evo Boost Gauge & Oil Temp Gauge
Mazdaspeed3GT is offline   Reply With Quote
 Old 03-21-2016, 02:28 PM   #97
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
You tuned it yourself, but you don't even know how to take a proper log?
MD1032 (03-22-2016)
 Old 03-21-2016, 08:00 PM   #98
pastry00's Avatar
I will try and upload a vdyno for you guys tomorow with my turbo. Sorry I have been really busy lately.
Sleepin6 likes this.
The Following User Says Thank You to pastry00 For This Useful Post:
Sleepin6 (03-21-2016)
 Old 03-22-2016, 12:59 AM   #99
MRR
MRR's Avatar
Did a couple of short runs. I cannot find somewhere close where its open to really rev it out, and can only go to 3rd gear. According to Vdyno, Im getting 250 whp before it reaches 5000 rpm 18PSI of boost and "0" knock retard. I'm very happy with that. I could tune it more aggressive like some but I do care for my engine. Besides, I don't have the running gear to support hi power out put (stock running gear). I use to own a Ford XR6 turbo with bolts ons tuned to 580 rear wheel KW with 820 nm. Use to smoke my tyres in 5th gear doing 73 mph, but when con rod 6 came out of the block, it was all over and embarrassing. Did I mention I'm running stock exhaust and intake. Car is very quiet.
 Old 03-22-2016, 01:14 PM   #100
pastry00's Avatar
Data log done in 3rd gear an vr dyno done in 4th gear. This is with my corksport turbo along with cobb ss downpipe, k&n typhoon intake 2.5 inch, cobb turbo inlet,3.5 BAR map sensor, Corksport electronic boost control solenoid and autotech fuel pump internals. Also have rear motor mount and passenger motor mount. The tune was done by purple drank tuning i asked for a conservative tune to keep the car safe and it is my daily driver. I love the tune and they said i could get another 30 to 40 horsepower if i get a larger intake cause the intake i currently have is restricting. Sorry to take so long to post results.
File Type: csv dyno_run2.csv (745 Bytes, 50 views)
 Old 03-23-2016, 04:58 AM   #101
g00s3y's Avatar
Groans: 438
Are you stupid or just a troll? I'm hoping for troll, but sadly, I don't think that's the case.
2.5" intake, why such a shitty intake?
3.5bar MAP, why 3.5 when 3bar would have been cheaper and there is no need for a 3.5 on a CS Turbo?
Definitely a lot left on the table in that tune though. You can easily make some power there once you get a bigger intake.
Last edited by g00s3y; 03-23-2016 at 04:58 AM. Reason: MSF Database - Automerged Doublepost
MD1032 (03-23-2016)
 Old 03-23-2016, 07:39 AM   #102
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
I don't know what you mean by not having the running gear to support high output. MS3's can easily handle 375 whp/wtq out of the box. Your tune is extremely conservative - you are barely making more power than a bone stock car. Additionally between your two runs, your boost response is extremely inconsistent and this could indicate some kind of hardware problem. Your tune is pretty poor by almost any measure - use the information on the forums here to optimize it more, then look into replacing some of the stock intake/exhaust hardware. Otherwise your CS turbo will have been a complete waste of money/time.
2007 Mazdaspeed3 GT
Djohns (03-23-2016)
 Old 03-23-2016, 08:26 AM   #103
ryguy 3's Avatar
Posts: 353   (View Stats)
Agreed, a couple bolt on's and a tune would get you 250 whp, that turbo seems a bit overkill.
 Old 03-31-2016, 03:55 PM   #104
MRR
MRR's Avatar
Million thanks for the advise. I've taken it well. got help from with CS and Cobb. Installed a new intake, a better cat and down pipe, also a new CS map sensor. Car is running heaps good. Boost is very consistent at 18 PSI.....
Thanks again.
File Type: csv Run 1.csv (879 Bytes, 21 views)
 Old 10-24-2016, 12:59 PM   #105
Lex2007's Avatar
Posts: 574   (View Stats)
Hey when you bolted the new turbo on did you tighten the 4 top bolts to spec (45-50 ft lbs) or did you tighten the 5 on the outlet side first?
The corskport directions just say tighten the 4 top bolts but neglect to mention the other 5. Is there any sequence in the torquing process?
Maybe it doesn't matter....top versus side studs.
 Old 10-24-2016, 01:49 PM   #106
richt2831's Avatar
Anyway you like Just make sure they are tight
1 bad MS3
The Following 2 Users Say Thank You to richt2831 For This Useful Post:
MD1032 (10-24-2016), WAMBUSHHHH! (10-24-2016)
 Old 10-24-2016, 01:54 PM   #107
Lex2007's Avatar
Thanks Mr. BTW that 45-50 ft lbs indicated by corksport is higher than OEM. OEM is 32-47 ft lbs.
CorkSport Coilover Install yasun 2010 MS3 - Suspension & Brakes 65 02-09-2016 09:12 PM
Corksport coilovers install help 07TRMS3 MazdaSpeed 3/6 - Suspension & Brakes 15 03-07-2013 12:48 PM
corksport sri install.....wow!!! killerb87 2010 MS3 - Engine, Transmission & Driveline 18 08-03-2011 03:15 PM
CorkSport FSB Install ADlBOO CorkSport 0 06-27-2011 06:36 PM
Corksport DownPipe Install Akira 2010 MS3 - How-To's 62 04-02-2011 11:12 PM
Page generated in 0.49729 seconds with 33 queries
