 Old 02-09-2020, 12:07 PM   #1
armyman's Avatar
Posts: 30   (View Stats)
armyman has a spectacular aura aboutarmyman has a spectacular aura about
Default crankshaft pulley
Are there any alternatives for the crankshaft pulley? CS doesn't make them anymore.
Looking for a set including waterpump, alternator, etc but would like same size only lighter. Maybe one of you has experience with pullies from other cars fitted on a Mazdaspeed? Maybe sizes of the different pullies?
Building up a forged engine
CPe HPFP, Corksport Mazdaspeed 6 power series catted downpipe, Corksport TMIC, Corksport MZR Bypass valve, Cooling Mist W/M injection with cmgs, JBR Tru-3.5 Wide Path Full aluminum Intake System, Denso ITV-22, intank 265 L fuel pump, rear engine mount, EGR block off plate, XS stainless steel exhaust manifold ceramic coating, BNR stage 3 turbo, Stratified Mazda 3 Port Electronic Boost Control Valve, Stratified tune, HKS Twin Power
armyman is offline   Reply With Quote
 Old 02-10-2020, 10:48 AM   #2
Posts: 2,233   (View Stats)
what are you looking to achieve by this ? Do you already have a lightweight flywheel ? it is probably where you can gain the most and the more easily....
You may check if ford pulley are similar since the engine bloc is from the same family but imo it doesn't worth it. it isn't a high revving and peaky engine but a torque monster. I would save that money to use it somewhere else....
 Old 02-10-2020, 02:32 PM   #3
armyman's Avatar
The pulley on the build engine has some bites out of it. Most of the time such a set is cheaper. I have to replace it anyway, so why not do it lightweight. Oem is more expensive i believe. It's not for the gain of 6 HP. Just need good replacement or other alternative that is cheaper than oem.
 Old 02-10-2020, 03:22 PM   #4
you can probably import a used oem one from middle of USA, there is many blown engine with no use of this part...
Or you may ask speedshop about focus parts. If you look at thins one it is very similar but the tooth wheel doesn't seem attached....is it just not pictured or the focus has it bolted and you re-use it???
https://www.agencypower.com/agency-p...150841504.html
« Dereks MS6 Build | - »
Mazda crank pulley tool vs Ford crank pulley tool SPEED6 KILLAH MazdaSpeed 6 - Engine, Transmission & Driveline 52 03-11-2017 09:46 AM
Lightweight Crankshaft Pulley? Matrix311 MazdaSpeed 3 - Engine, Transmission & Driveline 0 10-07-2011 11:45 PM
CorkSport DISI Crankshaft Pulley CorkSport CorkSport 1 08-03-2011 01:51 PM
Look At My Crankshaft holeinmypocket MazdaSpeed 3 - Engine, Transmission & Driveline 20 06-27-2011 05:39 PM
Page generated in 0.24991 seconds with 21 queries
