 Old 02-10-2020, 03:22 PM   #4
Posts: 2,233   (View Stats)
you can probably import a used oem one from middle of USA, there is many blown engine with no use of this part...
Or you may ask speedshop about focus parts. If you look at thins one it is very similar but the tooth wheel doesn't seem attached....is it just not pictured or the focus has it bolted and you re-use it???
https://www.agencypower.com/agency-p...150841504.html
« Dereks MS6 Build | - »
Mazda crank pulley tool vs Ford crank pulley tool SPEED6 KILLAH MazdaSpeed 6 - Engine, Transmission & Driveline 52 03-11-2017 09:46 AM
Lightweight Crankshaft Pulley? Matrix311 MazdaSpeed 3 - Engine, Transmission & Driveline 0 10-07-2011 11:45 PM
CorkSport DISI Crankshaft Pulley CorkSport CorkSport 1 08-03-2011 01:51 PM
Look At My Crankshaft holeinmypocket MazdaSpeed 3 - Engine, Transmission & Driveline 20 06-27-2011 05:39 PM
Page generated in 0.25754 seconds with 22 queries
