 Old 02-09-2020, 12:07 PM   #1
armyman's Avatar
Posts: 30   (View Stats)
armyman has a spectacular aura aboutarmyman has a spectacular aura about
Default crankshaft pulley
Are there any alternatives for the crankshaft pulley? CS doesn't make them anymore.
Looking for a set including waterpump, alternator, etc but would like same size only lighter. Maybe one of you has experience with pullies from other cars fitted on a Mazdaspeed? Maybe sizes of the different pullies?
Building up a forged engine
CPe HPFP, Corksport Mazdaspeed 6 power series catted downpipe, Corksport TMIC, Corksport MZR Bypass valve, Cooling Mist W/M injection with cmgs, JBR Tru-3.5 Wide Path Full aluminum Intake System, Denso ITV-22, intank 265 L fuel pump, rear engine mount, EGR block off plate, XS stainless steel exhaust manifold ceramic coating, BNR stage 3 turbo, Stratified Mazda 3 Port Electronic Boost Control Valve, Stratified tune, HKS Twin Power
armyman is offline   Reply With Quote
« Dereks MS6 Build | - »
Mazda crank pulley tool vs Ford crank pulley tool SPEED6 KILLAH MazdaSpeed 6 - Engine, Transmission & Driveline 52 03-11-2017 09:46 AM
Lightweight Crankshaft Pulley? Matrix311 MazdaSpeed 3 - Engine, Transmission & Driveline 0 10-07-2011 11:45 PM
CorkSport DISI Crankshaft Pulley CorkSport CorkSport 1 08-03-2011 01:51 PM
Look At My Crankshaft holeinmypocket MazdaSpeed 3 - Engine, Transmission & Driveline 20 06-27-2011 05:39 PM
Page generated in 0.25642 seconds with 21 queries
