 Old 12-14-2011, 11:00 PM   #1
black-speed3-gt's Avatar
Posts: 46   (View Stats)
black-speed3-gt will become famous soon enough
Default CUTTING PLZ HELP!
ok starting a data log at 3k rpms, mash it right at 4k rpms cuts then goes then at 6k rpms cuts again
on the dash hawk it looks like the ingector shut down like i let off...
ANY IDEAS???
mods-fully bolted brn-stge 3 turbo
18psi
no meth
black-speed3-gt is offline   Reply With Quote
 Old 12-14-2011, 11:05 PM   #2
xtasy's Avatar
Posts: 685   (View Stats)
xtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the world
Groaned at 6 Times in 4 Posts
Fuel pump?
Mazdaspeed3 E85 ~ Sold 333/383
Mazdaspeed6 #10018 TiGrey
Forged Internals, PTE5858.
2015' Freektuned on 93Octane 322/337 (stock top mount and BPV)
2016' Freektuned on e85/93 480/444 (maxed out 3bar map sensor)
2017' Freektuned on e85/93 525/497 (maxed out pte5858 @ 35/36psi & fueling)
Mazda CX-5 AWD Daily
xtasy is offline   Reply With Quote
 Old 12-14-2011, 11:06 PM   #3
Police - Grammarhead
Vansquish's Avatar
Where's the log? Show us, then we can help.
 Old 12-14-2011, 11:09 PM   #4
yes fuel pump
logs will be posted soon
 Old 12-14-2011, 11:13 PM   #5
bykeryder4life's Avatar
Posts: 1,032   (View Stats)
bykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the world
Groans: 38
edit: not sure if I posted them right but theres 3 logs of his car cutting. last log shows 4.2 kr, normally see no more than 2 degrees of kr so im not sure what thats about. the cut feels like a fuel cut but fuel pressure stays high the whole time. maybe a load cut or ignition problem (coilpack blowing out under load)? had water in spark plug tubes in the past causing a misfire...
bykeryder4life is offline   Reply With Quote
 Old 12-14-2011, 11:14 PM   #6
logs posted right above
 Old 12-15-2011, 05:24 AM   #7
bmylez's Avatar
Posts: 3,197   (View Stats)
Uhh...what are you tuning with? If you're taking DH logs and not AP, please don't tell me you have a Standback.
Also, when I try to open those logs, it says I need the associated .LRP file.
2007 CTS-V - Trying to sell
 Old 12-15-2011, 06:21 PM   #8
Groans: 38
Uhh...what are you tuning with? If you're taking DH logs and not AP, please don't tell me you have a Standback..
yeah he is running a SB, using the DH to datalog since a working laptop is not available to log with the SB while driving.... From what I gather his car is hitting a load cut. On runs where it doesnt cut the afr is steady 11's to low 12's, the KR never goes over 2* usually like .7* or so, and fuel pressure is <1700. When it cuts, its like the injectors shut off, feels like a fuel cut but the logs never show FP dropping. It gets worse with increased boost or cold weather... Time for the load cut flashes or switch to AP..?
 Old 12-15-2011, 05:43 AM   #9
Boost Addict's Avatar
Posts: 1,327   (View Stats)
Boost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the world
Yeah those logs are posted completely wrong, post a .csv file.
2008.5 BM MS3 // Cobb AP V3// JBR 3.5" WP Full Intake // CXRacing Piping/Godspeed Core // CNT 3" Catted Downpipe // Custom 3" CBE // KMD v2.1 Fuel Pump Internals // Turbosmart Dual Port BOV // Airlift Suspension // Corksport Skid Plate // JBR 88Duro Dogbone RMM // JBR SSP // SURE AGS Knob // Denso ITV22 // STACK Boost Gauge // DDM 6k Low HID's // CP-e Towplate // 15% Tint // 18x10 Blitz Type 03
FREEKTUNE
Boost Addict is offline   Reply With Quote
The Following User Says Thank You to Boost Addict For This Useful Post:
bykeryder4life (12-15-2011)
 Old 12-15-2011, 06:26 PM   #10
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
i hope you mean >1700
The Following User Says Thank You to TWOptSL0W For This Useful Post:
 Old 12-15-2011, 06:31 PM   #11
Groans: 38
hah yes sorry its above 1700psi
 Old 12-15-2011, 06:35 PM   #12
bmylez's Avatar
Go AP....NOW!!!
SB sucks so much cock.
 Old 12-15-2011, 06:52 PM   #13
Groans: 38
lol SB is a good tuning device man, It just depends on your setup and hp goals. I parted out long ago and sold my ms3 but back when I had it, I ran SB with no problems and the car ran really well, made good #'s.
Anyhow, the OP is now looking into getting an AP since the SB aint working for his setup and goals so updates will be posted when they come...
 Old 12-15-2011, 06:56 PM   #14
ScarMS3's Avatar
Posts: 2,088   (View Stats)
Groans: 97
Sorry I'm late.
Cutting
There should be an 800 number too somewhere.
The Following User Says NO Thank You to ScarMS3 For This Un-useful Post:
 Old 12-15-2011, 07:15 PM   #15
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
alot has changed since then man
 Old 12-15-2011, 08:03 PM   #16
ya AP is the way i gotta go from what i hear...
MS6 - Cutting OEM Springs FADE2GRY MazdaSpeed 3/6 - Suspension & Brakes 54 10-14-2013 06:59 PM
Cutting at WOT skiptowncat MazdaSpeed 3/6 - Troubleshoot/Diagnostics 50 09-26-2011 01:23 PM
Still cutting ms310 2010 MS3 - ECU Computer Tuning 47 04-21-2011 10:54 AM
Car Bucking and Cutting Phantom MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 08-11-2009 10:38 PM
Cutting ECU Wires kingpin748 MazdaSpeed 3/6 - ECU Computer Tuning 22 08-10-2008 10:59 AM
Page generated in 0.34276 seconds with 29 queries
