Dereks MS6 Build 28 Attachment(s) Dereks MS6 Build So I've finally decided to make a build thread being that my car is so close to being done. I picked this MS6 up in december of last year. Had got rid of my 2012 MS3 2 months prior, went to a 350z because it was half the payments, hated it and then found this. Came with a Turbosmart 50/50 BPV, OCC, Sure Full 3in intake, Sure boost tubes, Sure short shifter, plastidiped wheels. http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 Immediately I purchased a spare block to start to build. Got some eagle rods to use in the block and CP pistons. http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 I couldnt wait to build the block before modding it so I got JBRs stiffest trilogy set, 3 port ebcs, and a full engine rebuild kit from Edge. http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 @KotzurRacing; made me a 2 port pcv plate http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 Purchased @PapaSmurf; old gt3582r http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 Got a top mount exhaust mani from a guy in Houston. Was too close to the reservoir and the fact that he asked me if he could see my engine bay made me realise he made it for a MS3. Test fit it on a 3, good to go, sold it. http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 Cobb AP v3 http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 Battery relocated to the trunk http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 Got a set of Evo X wheels. http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 CX Racing IC piping and a TR8L core installed http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 Then This. http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 I had oil coming out of my 50/50 bpv, and it was dripping out of my SRI filter... The oil was coming out of my VC breather that was attached to the SURE sri Got so bad that from San Marcos to San Antonio it lost 2 quarts through the VC into a makeshift Oil Catch Bucket. Took it to my buddies shop and its sat there since feburary. Got a beater to ride in for the mean time 1988 300ZX 5spd N/A http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 Since then I have ordered and recieved a big ol intake, blasted it down and deciding which color to powder coat it now. http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 ACT 6 puck clutch http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 Rear diff brace, rsb and lowering springs from Corksport http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 Crower springs, supertech +1mm intake and exhaust valves http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 Keyed crank and L19 head studs http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 A new top mount exhaust mani for the twin scroll setup http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 New DP and dump tube http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 JMF intake mani w/the port injection system from SP63 http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 Short block is together http://www.mazdaspeedforum.org/forum/foru...1&d=1405974051 Now just have to get the intake and exhaust cams pinned and it will be time to put everything together and start getting it tuned and broken in. |
Nice build. Cars going to be a monster. |
Quote:
My nigga! Glad we're getting shit done around here. Let me know if you need hands or any odds/ends. |
Man you weren't joking when you were telling about this beast of a build when we met a couple of weeks ago. Good Job, can't wait to see this in person! |
Quote:
Quote:
Quote:
All kinds if win going on here! Good luck with the build! |
bout fuckin time we see a thread, you've had this car hidden away for months. best wishes for the rest of the build! |
Cant wait to see it running. Keep us updated |
Got any pics of the +1 valves installed? I'm looking to do it but there isn't too much info on them. |
Quote:
Very nice, I like. |
Sub'd... every time I see a thread like this it makes me want to build an engine. Then I realize how much it actually costs. Kudos to you for spending the time and money to do this. Hopefully I can someday. |
Congrats D, I'm sure your very excited to get her on the road. |
Quote:
you cut off the gonzo dick!!! wtf!! ahaha looks good man. |
Quote:
Could you post up more pictures of how you relocated your battery and what hardware you used? There is very little info/pics on this and the ones i've seen are not all that detailed. Maby you could even make a thread on it? :yumyum: |
Quote:
3 Attachment(s) Quote:
http://www.mazdaspeedforum.org/forum/foru...1&d=1406065589 The red wire you see going into the fuse box runs into the same hole as the wire harness, sliced a small hole and lubed up the wire a bit and ran it through from under the steering column, pulled it through into the bay with some needle nose pliers, ran it under the box and attached it to the left side(looking from the front of the vehicle) wire post in the fuse box. We got a bit like this http://www.mazdaspeedforum.org/forum/foru...1&d=1406065589 (but big enough for the wire we used) and bent it at a 90 and bolted it down with the rest of the lines. then pulled up the plastic molding along the driver side to the trunk, ran the wire under it till the battery, attached it to positive and grounded the negative |
4 Attachment(s) Quote:
Nice and big for the details haha http://www.mazdaspeedforum.org/forum/foru...1&d=1406068548 http://www.mazdaspeedforum.org/forum/foru...1&d=1406068548 http://www.mazdaspeedforum.org/forum/foru...1&d=1406068548 About to torque down the head studs Then tomorrow pin the cams. Will take pics of that process too. http://www.mazdaspeedforum.org/forum/foru...1&d=1406068548 |
12 Attachment(s) Okay! So, got the cams pinned and the engine timed yesterday. First step, get the cams in the head, cam bearing caps tightened down, and cam timing tool in. Should look like this. http://www.mazdaspeedforum.org/forum/foru...1&d=1406214653 http://www.mazdaspeedforum.org/forum/foru...1&d=1406214653 Notice how on the intake cam you have the 4 holes on the end. Put the cam gears and timing chain on, release the tensioner pin and let the gears go into place where it would be perfectly timed(I have a keyed crank so the gear on the crank cannot move). We put an allen head bolt in so there would be enough clearance to drill the cam and gear while they were tightened down. Once the bolt was tightened we marked the vvt at 12 o-clock, anywhere between 12 and 1 would work. Really so would 3, 6, 7, 9, and 10 but we chose TDC to use. The exhaust cam you can drill anywhere. http://www.mazdaspeedforum.org/forum/foru...1&d=1406214653 http://www.mazdaspeedforum.org/forum/foru...1&d=1406214653 From the front of the gear on the exhaust cam to the back part on the cam measured .43 in, so we marked a 3/16 drill bit .4 in from the tip took to the top secret jig and started drilling. The pins we bought were too long so we had to cut them down to .4 in. http://www.mazdaspeedforum.org/forum/foru...1&d=1406214653 http://www.mazdaspeedforum.org/forum/foru...1&d=1406214653 http://www.mazdaspeedforum.org/forum/foru...1&d=1406214653 http://www.mazdaspeedforum.org/forum/foru...1&d=1406214653 http://www.mazdaspeedforum.org/forum/foru...1&d=1406214653 http://www.mazdaspeedforum.org/forum/foru...1&d=1406214653 Using the vice you see the cam in 2 images up, we put the exhaust gear and vvt on the cams, torqued them down to 55 ft/lbs, put them back on the head, tightened everything down and released the tensioner again. Bam, shit was perfect. http://www.mazdaspeedforum.org/forum/foru...1&d=1406214653 http://www.mazdaspeedforum.org/forum/foru...1&d=1406214653 Big thanks to @KotzurRacing; for all the help! |
Blah, blah, when it runs come get me, lol, fuckin "A" Derek, can't wait to see her on the road. |
Quote:
Quote:
Quote:
Quote:
Can't wait to see the final product. If you need any help, let me know bud |
Quote:
Solid build man! Props for spending the money. It will all be worth it in the end. Definitely keep us up to date! |
3 Attachment(s) Well, @KotzurRacing; made a oil pump gear holder device today and torqued the bolt on that down http://www.mazdaspeedforum.org/forum/foru...1&d=1406349487 http://www.mazdaspeedforum.org/forum/foru...1&d=1406349487 And then Got the timing cover on and everything on that torqued down and sealed. http://www.mazdaspeedforum.org/forum/foru...1&d=1406349487 Little by little. |
awesome build. i follow on IG and have kept track on there for your build! youll have to post a video walkaround or look at this setup! |
http://i.imgur.com/7q6NbJb.png let the record show that this guy raced about even with a first gen cts-v now he thinks he's a unicorn hunter... smh |
Quote:
Who is going to be tuning this beast? |
Quote:
Fathead could tune it, and you wouldn't have a chance phteven. :theyareontome: |
2 Attachment(s) Not much progress this week, been busy and there's a car on the lift I'm waiting on to be gone so i can use it. But we got the valve cover powder coated and the oil feed line done, almost done with the drain line. http://www.mazdaspeedforum.org/forum/foru...1&d=1407253764 http://www.mazdaspeedforum.org/forum/foru...1&d=1407253764 |
Nice, did Matt do the pping? |
| All times are GMT -7. The time now is 07:31 PM. |
