![]() | | #81 | ![]() |
![]() ![]() Join Date: Dec 2011 Location: San Marcos, TX
Rep Power: 692 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,138
Groans: 38
__________________ 06 MS6 & 06 MS6 [SIGPIC][/SIGPIC] The beauty is the beast Daily driven | |
![]() | | #82 | ![]() |
Groans: 38
(Thread Starter) | Not Ranked : 0 score Vdyno of a 4th gear wot log tonight on the base breakin tune. Ready to turn it up. @ms3blackmica; I'm ready for some tunez. Logs sent. Lets see what this girl can do!
__________________ 06 MS6 & 06 MS6 [SIGPIC][/SIGPIC] The beauty is the beast Daily driven Last edited by derek13p; 10-08-2014 at 10:56 AM. |
| The Following User Says NO Thank You to derek13p For This Un-useful Post: | Rich990 (11-06-2014) |
![]() | | #83 | ![]() |
Groans: 38
(Thread Starter) | Not Ranked : 0 score Some shots of the new valve cover and SpeedPerf6rmanc3 breather cap. Should have another map tonight to go do some runs in!
| The Following 8 Users Say Thank You to derek13p For This Useful Post: | Code Monkey (10-13-2014), ItsNox (10-19-2014), Kellerspeed3 (10-13-2014), ms3blackmica (10-13-2014), Poohster (10-13-2014), pzr2874 (10-13-2014), Realgib3 (10-13-2014), rymanmazda (10-13-2014) |
![]() | | #84 | ![]() |
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
| Not Ranked : 0 score Rode in this bitch yesterday, can't wait to see it fully tuned
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER |
| The Following User Says Thank You to SofaKingAwesome For This Useful Post: | derek13p (10-13-2014) |
![]() | | #85 | ![]() |
Groans: 38
(Thread Starter) | Not Ranked : 0 score Cleaned up the wiring thanks to @KotzurRacing; and getting ready for some port injection in the tune! Looks a lot nicer now. Can anyone confirm the wiring of the split injection controller for the MS6 for me? I tapped the middle wire of the MAF sensor for the green(MAF) wire on the controller, the red power wire from the controller I did an add a fuse to the Eng Bar in the fuse box, and the ground I put to the top of the HPFP. As for the yellow ones, we found the coil wires that did not have a common wire with the other coils, which may be where the problem is as I have no instruction on which wires to tap. @SPEEDPERF6RMANC3; would you be able to give some input? I know yall have done a few 6s with this kit.
![]() | | #86 | ![]() |
![]() Join Date: Apr 2012 Location: Las Vegas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 965
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score Looks good man. Hope you get the wiring issue figured out.
__________________ Gen2 Bolted E85 BNRS3--SOLD '14 Sterling Gray 5.0 w/ TrackPack -- AED Tuned on E85 - Ford Racing 47# Injectors - Lethal Performance Catless H Pipe - GT500 Axelbacks - MGW Full Shifter - BMR Springs - BMR Panhard Bar - BMR LCAs - BMR LCA Relocation Brackets - Maximum Motorsports CC Plates - SS Clutch Line - JLT PS Oil Separator - BOSS LS Wheels 19x9/10 |
![]() | | #87 | ![]() |
Groans: 890
| Not Ranked : 0 score What should the condition for the power be? And there's got to be a better ground than that.
![]() | | #88 | ![]() |
![]() Join Date: Jun 2011 Location: Parma, OH
Rep Power: 1009 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score Tap the very far left wire on each coil pack plug.
__________________ Parting out car, 800whp motor with 4k miles on it, 6466 turbo kit... ect I also do diesel gear swaps hit me up for more info. |
![]() | | #89 | ![]() |
| Not Ranked : 0 score update?
| The Following 2 Users Say Thank You to stevenlapensee For This Useful Post: | ItsNox (12-02-2014), SofaKingAwesome (12-01-2014) |
![]() | | #90 | ![]() |
Groans: 38
(Thread Starter) | Not Ranked : 0 score Nothing major yet. Was getting it tuned but the 3.5in intake wasn't big enough cause the engine was flowing a lot more than expected, so had to order pipe to make a 4 incher, and with getting a new job and working till 930 every damn night its harder to get shit done. @KotzurRacing; fab'd up a 4in for me on sunday though, and changed a bad wheel bearing. I'm now getting a almost whining sound coming from the front suspension when turning left(driver side), only while moving, not while stopped. Gotta figure out what that is next. Got a set of brembos on the way for the front and will be ordering coilovers next paycheck, then get some new bushings and what not and do some maintenance for her. But yeah, should be getting a new map for the 4in soon and do some maf cals and then get back to port injection and then e85. I learned that on the first map of port injection I can get some good wheel spin in the rain and get pretty damn sideways in the corners haha..
| The Following 7 Users Say Thank You to derek13p For This Useful Post: | Code Monkey (12-03-2014), ItsNox (12-06-2014), Kellerspeed3 (12-05-2014), Macncheese (02-22-2015), Micha (12-14-2014), rymanmazda (12-03-2014), stevenlapensee (12-03-2014) |
![]() | | #91 | ![]() |
Groans: 38
(Thread Starter) | Not Ranked : 0 score Ordered some ISC coilovers today. Hope they are good!
![]() | | #92 | ![]() |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
You'll quickly find out that an MS6 becomes a F-Body Camaro LOL
__________________ www.tunedbynishan.com | |
![]() | | #93 | ![]() |
| Not Ranked : 0 score I can haz custom intake too?
![]() | | #94 | ![]() |
![]() Join Date: Apr 2013 Location: San Antonio TX
Rep Power: 221 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 362
| Not Ranked : 0 score Hit me up when you want me to build you one. Just finished a 3.5 intake for a k04 car
__________________ COBB BROKE JMS FIXED MazdaSpeed. Errrone can afford |
| The Following 4 Users Say Thank You to KotzurRacing For This Useful Post: |
![]() | | #95 | ![]() |
![]() Join Date: Dec 2008 Location: Harrisburg, pa
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score just out of curiosity, since you seem to be a machinist. Is there a specific spot where you pin the cams? do you have to time them first so you know the links and teeth line up and them drill them? or just say screw it and drill a hole? |
![]() | | #96 | ![]() |
| Not Ranked : 0 score Every set is different. Must set timing first. We used a set of allen headed bolts, torqued them and then drilled through the sprocket and cam. Intake cam is a different story. It has four holes for the vvt and the last thing you want to do is drill one of them.
![]() | | #97 | ![]() |
Groans: 38
(Thread Starter) | Not Ranked : 0 score a little flyby a while back.
| The Following 8 Users Say Thank You to derek13p For This Useful Post: | BLKSTIG (12-07-2014), Boostin'likeAboss (12-09-2014), Code Monkey (12-07-2014), Hammology (06-11-2015), hatchedspeed3 (12-08-2014), Macncheese (02-22-2015), Pu Manchu (12-08-2014), pzr2874 (12-09-2014) |
![]() | | #98 | ![]() |
| Not Ranked : 0 score so you basically time the engine complete with the allen headed bolts tighten everything down and then just unbolt the cams and take them to your drill. that way you know your chain and all the teeth will line up properly? seems easy when i write it down like that lol... i know its probably not. thanks for the clarification! |
![]() | | #99 | ![]() |
__________________ COBB BROKE JMS FIXED MazdaSpeed. Errrone can afford | |
| The Following 2 Users Say Thank You to KotzurRacing For This Useful Post: | derek13p (12-08-2014), sleeperstang1994 (12-08-2014) |
![]() | | #100 | ![]() |
![]() Join Date: Nov 2013 Location: Killeen, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 724
| Not Ranked : 0 score car looks great derek. props to you and @KotzurRacing; on an awesome build. im going to try and finish up my shitbox this weekend so I can actually come see you guys again.
__________________ 08 TR MS3 - totaled and stocked out 1-5-2014 Daily Driver - 2016 WRX w/STI lip kit 2009 CWP MS3 1-23-2014 CXRacing FMIC with TR8 Core /// HKS Turbo Timer /// 6000k HIDs /// Yellow Fog Covers /// Cobb SRI /// Ultimate Racing TBE /// White Avid 21 18x8.5 Wrapped In Kuhmo 225-40-18s /// Short Throw Shifter /// Kozmic Motorsports EGR Delete /// Corksport HPFP internals /// CS Front Sway Bar /// /// JBR RMM, TMM, and PMM (all 80a) /// Slotted Rotors /// CS Foglight Kit /// CS License Plate Bracket /// CS Bypass Hose /// Rolled Fenders /// JBR Weighted Red Shift Knob /// Cobb AP //////![]() |
| The Following User Says Thank You to hatchedspeed3 For This Useful Post: | derek13p (12-15-2014) |
![]() | | #101 | ![]() |
![]() Join Date: Dec 2014 Location: Saint Johns, FL
Rep Power: 213 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 143
| Not Ranked : 0 score I wonder if my wife will let me do this to her MS6 one day. Can I claim better gas mileage? On a serious note: this is a damn awesome build. Good luck, @derek13p;. Please tell me you are going to air brush either a Unicorn or Chuck Norris on the hood.
__________________ 2007 MS3 GT Autotech CDFP Internals || Cobb AP, SRI, TIH, DP, CB, BPV, EBCS, FSB & RSB || cp-e Injector Seals, EGR Delete|| JBR OCC, Shifter Plate, PMM & TMM, TB & Intake TIG, Coolant Bypass|| Mazdaspeed Coilovers || TRZ RMM|| TWM Bushings || MOOG Front & Rear Endlinks 2006 MS6 GT (ZZB Rebirth) Autotech CDFP Internals || BNR Stage 3 || Bosch 3 Bar || Cobb AP || cp-e Injector Seals, CBE, DP || ETS TMIC || Full Race EM || H&R Coilovers || JBR Mounts, 3.5" WP Aluminum Intake || Matt Damond OCC, Shifter Plate, EGR Delete || Racing Beat Rear Endlinks || Relentless PnP IM || SPC Balljoints || Whiteline RSB || The Company of Which I Will Not Name Front & Rear Diff Mounts 1990 Miata I like it raw |
| The Following User Says Thank You to sporkbomb For This Useful Post: | derek13p (02-11-2015) |
![]() | | #102 | ![]() |
![]() Join Date: Jun 2012 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 201
| Not Ranked : 0 score Nice meeting you out at TX2k man, build is looking good!
__________________ 2012 MazdaSPEED 3 - Crystal White Pearl Performance - Precision 5858 - Built motor (K1 Rods / Wiseco Pistons / ARP main studs / Stock head bolts) - Cobb V3 AccessPORT - PERM 5th port kit, PERM Plate - HTP 3.5" Intake (Powder Coated Pure Orange) - Autotech HPFP Internals – CPE Vband Exhaust Manifold - Kozmic Vband Downpipe, Dumptube, Oil feed / Return lines, Vented OCC, Primary EGR delete – Ultimate Racing Catback, FMIC modified for 5th port by Kozmic Motorsports - Turbosmart dual port , 45mm EWG - JBR Coolant Bypass, EGR Delete, Throttle body TIG, Dogbone RMM, Transmission Mount, Sealed OCC - Grimmspeed EBCS - NGK plugs - Bosch 3.5 Bar MAP w/MattJackson86 PnP Harness – Ported Intake manifold with VCTS delete, 1/8" Intake manifold TIG by Zack - Spec Stage 3+ Clutch and flywheel Tuned by Voltwings (OLD k04 SET UP ) 374.5 WHP 447.2 WTQ with stock K04 - 1-17-14 Dynocom dyno (New BT numbers soon) ~487WHP 455wtq Virtual Dyno and out of fuel... moar injectors! Looks - Pure Orange Powder Coated Gen Pu Stockers - Muteki SR48 Lugs - 5k HIDs / 3K HID Fogs |
| The Following User Says Thank You to kashbringer For This Useful Post: | derek13p (06-11-2015) |
![]() | | #103 | ![]() |
![]() Join Date: Feb 2013 Location: Anchorage AK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 131
Groaned at 9 Times in 4 Posts
| Not Ranked : 0 score updates?
__________________ YEEMARKS SP63 Built Engine. 5858. Meth. Old Time in S3: 12.4 @ 111 Parts needed to install: JMF, HTP 4.0", HKS BOV |
![]() | | #104 | ![]() |
| Not Ranked : 0 score Yes derek has been super busy with work. Trying to get him to post the results. Car is RIDICULOUSLY STUPID NASTY made really great power for the low amount of boost hes running.
| The Following User Says Thank You to KotzurRacing For This Useful Post: | BLKSTIG (06-11-2015) |
![]() | | #105 | ![]() |
Groans: 38
(Thread Starter) | Not Ranked : 0 score Made 613awhp and 519awtq at JMS in San Antonio. Did some powdercoating, got a turbo blanket. Next will be a bigger IC and a 6466 a different tuning solution and some axels.
| The Following 13 Users Say Thank You to derek13p For This Useful Post: | BLKSTIG (06-12-2015), Code Monkey (06-11-2015), Hammology (06-11-2015), ItsNox (06-18-2015), Kellerspeed3 (06-14-2015), KotzurRacing (06-12-2015), levon.mark (06-15-2015), Mazdazilla6 (10-31-2015), Micha (10-31-2015), pixelNate (01-27-2016), Pu Manchu (06-12-2015), SarcasticOne (06-11-2015), SpeedRebirth (06-11-2015) |
![]() | | #106 | ![]() |
![]() Join Date: Dec 2009 Location: layton, UT
| Not Ranked : 0 score Some monster numbers!!! This is on a 6266 or 6262?? Are u running e85mix??
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
| The Following User Says Thank You to MSP611 For This Useful Post: | derek13p (06-12-2015) |
![]() | | #107 | ![]() |
![]() Join Date: Jul 2013 Location: Ventura County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,661
Groans: 36
EDIT: Im dumb, he said next up is 6466.... fuck my mouth. EDIT #2 : GT3582
__________________ 2007 MAZDASPEED6 VELOCITY RED MICA Built motor GTX3071 Meth 6th Port Last edited by Hammology; 06-12-2015 at 12:03 AM. | |
![]() | | #108 | ![]() |
Groans: 36
| Not Ranked : 0 score Looks fast as fuck. What psi? And what rpm are you hitting max boost?
__________________ 2007 MAZDASPEED6 VELOCITY RED MICA Built motor GTX3071 Meth 6th Port |
![]() | | #109 | ![]() |
Groans: 38
Its pretty fun for sure lol.
![]() | | #110 | ![]() |
| Not Ranked : 0 score zayumm nice work ! I remember seeing this car on JMS's Instagram, but wasn't sure if it was yours?
| The Following User Says Thank You to levon.mark For This Useful Post: | derek13p (10-31-2015) |
![]() | | #111 | ![]() |
![]() Join Date: Mar 2010 Location: Charlotte NC
Rep Power: 169 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26
| Not Ranked : 0 score holy shit. this build thread has me totally erect!!! so much inspiration. mid motor build myself on my vrm ms6
__________________ 2006 vrm mazdaspeed 6 304awhp/327awtq on k04 tuned by socks build coming soon....f cylinder #3 2003.5 mazdaspeed protege. turbo daily/montain monster......ounce the motor is in |
| The Following User Says Thank You to BlackEscortGT For This Useful Post: | derek13p (10-31-2015) |
![]() | | #112 | ![]() |
Groans: 38
(Thread Starter) | Not Ranked : 0 score It put a 5 car whoopin on an evo 9 the other day going to cars and coffee. That was just 2nd and 3rd gear too
| The Following 6 Users Say Thank You to derek13p For This Useful Post: | BLKSTIG (11-01-2015), Code Monkey (10-31-2015), DingoDave (10-31-2015), KotzurRacing (10-31-2015), pzr2874 (11-05-2015), SpeedRebirth (01-26-2016) |
![]() | | #113 | ![]() |
| Not Ranked : 0 score mmm this is nice (borat accent)!!! thts crazy u are spooling tht fast with this monster!! highly impressed
| The Following User Says Thank You to MSP611 For This Useful Post: | derek13p (10-31-2015) |
![]() | | #114 | ![]() |
| Not Ranked : 0 score @derek13p; Where'd you buy the kit to pin your cams? Also, anything new? Sticking with the t3 flange when you change turbos?
![]() | | #115 | ![]() |
| Not Ranked : 0 score No kit used. I bought some dowel pins and set the timing on the motor, then installed some Allen head bolt in the cams. Then removed the cams from the motor, built a jig for my drill press and went to town. Was way easier then I thought it would be. Took about 5 mins to drill both cams, just marked the vvt holes in the cam first so that we didn't drill into them.
| The Following 2 Users Say Thank You to KotzurRacing For This Useful Post: | Mazdazilla6 (01-26-2016), SpeedRebirth (01-26-2016) |
![]() | | #116 | ![]() |
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings | |
![]() | | #117 | ![]() |
| Not Ranked : 0 score A place in town called quality fasteners very similar to fastenall
| The Following User Says Thank You to KotzurRacing For This Useful Post: | Mazdazilla6 (01-27-2016) |
![]() | | #118 | ![]() |
Groans: 38
(Thread Starter) | Not Ranked : 0 score http://www.mazdaspeedforum.org/forum/foru...-gt500-203391/ Little race a buddy caught on film for me.
| The Following 4 Users Say Thank You to derek13p For This Useful Post: |
![]() | | #119 | ![]() |
| Not Ranked : 0 score hey question @derek13p; how did u setup ur ITFP? u have an upgraded ITFP?
![]() | | #120 | ![]() |
Groans: 38
Edit: Post 66 on 2nd page is where it shows it. Btw, you have the longest signature I've ever seen lol
| Build me a BIG Turbo Build for MS3 | NCspecV81 | 2010 MS3 - Big Turbo Builds | 14 | 04-15-2013 02:16 PM |
| Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy | Haltech | Automotive News | 0 | 09-02-2011 07:20 AM |
| Chrysler to build plug-in Ram test fleet, won't build Two Mode hybrid pickup | Haltech | Automotive News | 0 | 03-22-2010 10:10 PM |
| Theory: Build before Build | demonspeed | MazdaSpeed 6 - Engine, Transmission & Driveline | 5 | 02-10-2009 06:52 PM |
| Build-a-Bull: Automobile mag helps build the first production Lambo LP560-4 | Haltech | Automotive News | 0 | 04-01-2008 05:20 PM |
