Like Tree46Likes
 Old 04-01-2011, 03:34 PM   #1
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Talking Dougefresh's Top Mount Twin Scroll 3076 Build
I was about to do a single scroll regular unleaded mount, when Joel swayed me otherwise. I'm basically copying his set up to a "T": TS 3076 T3 Divided w/ .78 A/R. I ordered my SteedSpeed Top Mount TS Mani w/ single ewg, and it should be shipping soon. I think DJ is spending my DP/SRI/TIP money on hookers, booze, & coke, lol. I hope so at least.
I still need to buy a 38mm Tial ewg, and some misc stuff from ATP. I'm in no rush, and the install isn't happening until the end of May at the earliest. I'm still in part collecting mode here. I ordered my injector seals & Skates and I will be putting those in in two weeks. I also ordered the BSD to do when I get back, as I haven't done that yet (33K miles).
I'm going to have to just run the CPE fmic for a few months w/ this until I have the time/money/space to do a proper custom fmic. I'm also considering just running a 1.3 or 1.4 bar spring and running spring pressure & 100% water w/ a D05 nozzle AT FIRST. That's just to get me up and running. After the huge fmic, I'll run the Perrin Ebcs, and get a proper tune w/ meth most likely a la DJ. I realize I'll be missing out on most (all?) the quicker spool of the TS by running spring, but it beats running the K04 for another 3 or 4 months. Time to get this show on the road!
El Pictarios:
.................................................. .......................................I made a little video of her too
I didn't realize the outlets were only 2".... I thought they were bigger for some reason (reason = n00b). I thought I received the wrong shit, lol. Big thanks to all the guys who have been helping me out a ton & helping bringing me up to speed. Special shout out to Joel for making me reconsider this, DJ for making this possible, Skates, Joe & the rest of you guys who help me out all the time. As always -MUCH APPRECIATED!!!
focusownerskid likes this.
The Following 49 Users Say Thank You to dougefresh_ For This Useful Post:
4G63 (06-13-2011), AJ713 (04-09-2011), AZSPEED3 (04-08-2011), BigJimMs3 (04-02-2011), BrianZX10R (05-13-2011), Broxer (08-26-2011), Chriscote (04-19-2011), Ckmazdaspeed3 (04-01-2011), ClutchEngaged (08-08-2011), cpolly69 (04-08-2011), Dano (05-26-2011), Dash08 (04-02-2011), DingoDave (04-20-2011), djuosnteisn (04-19-2011), Docnox (04-20-2011), doubleflusher (04-02-2011), EwMPS (10-05-2011), fishin53 (04-27-2011), FreeFlyFreak (08-22-2011), galens47 (07-31-2013), h.h.sk1nny (11-22-2011), Hamilton69 (05-18-2011), I Love Brownies (04-07-2011), i8urgti (04-02-2011), indianaryan (04-07-2011), jmhinkle (05-02-2011), josurr (10-29-2011), manelscout4life (05-25-2011), mazda.speed3 (04-20-2011), Mchart (07-18-2011), MGM_GT3 (12-02-2011), MPSdriver (04-10-2011), Ms3_Miami (10-30-2011), Nataphen (04-11-2011), Night Wolf (04-26-2011), qtrmile beast (04-01-2011), sellers (04-19-2011), SilverDemon (04-27-2011), SIXual Panda (04-07-2011), Special--k (04-01-2011), spiker98 (05-01-2011), spoolin00 (04-02-2011), superskaterxes (04-08-2011), triplejumper18 (04-02-2011), turd burglar (04-01-2011), uncorked11 (11-12-2011), vdgmcool (04-27-2011), wette460 (04-24-2011), zpele (07-07-2011)
 Old 04-01-2011, 04:04 PM   #2
LMB77's Avatar
Posts: 112   (View Stats)
LMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond reputeLMB77 has a reputation beyond repute
Good luck w/ the build and do an awesome write-up when you're done! Thanks!
06 Speed 6: Cobb SRI/ TIP, AP stage 2, CS TB, CP-E FMIC, Forge BPV, Cp-e rear mm. TT FMM, AT internals, Freek tuned on 50% e85.
LMB77 is offline   Reply With Quote
The Following User Says Thank You to LMB77 For This Useful Post:
dougefresh_ (04-01-2011)
 Old 04-01-2011, 04:12 PM   #3
Thanks man! DJ told me to just go ahead and set it up w/ the lower spring rate for the ewg + ebcs, and that the tweaks to boost later won't be a big deal. Right now I run my Perrin in interrupt mode, and I run the FS controller & BCS FS for meth. Here's a pic of the craziness... FS BCS is on the firewall, Perrin is in stock location, not pictured:
However, I have NO CLUE how to rig that shit up with the ewg. The unrestricted boost source (tapped hot pipe) is T'd off and runs to the BCS FS. It's still unrestricted to the Perrin though, because my particular BCS FS is N.C. (normally closed), unless there is a flow issue, then it opens and floods the wg to spring pressure (and then it doesn't matter that it's unrestricted). It's not a huge deal, and DJ said he's gonna sub soon & chime in. He's already helped me out a ton w/ some PMs.
EDIT: If anyone wants to run a Perrin/Grimmy in 'interrupt' mode with a stock turbo or BT w/ iwg, I did a detailed 'how to' on it last year: http://www.mazdaspeedforum.org/forum/foru...plicing-58098/
I couldn't live without this: http://www.mazdaspeedforum.org/forum/foru...-easier-54171/
And lots of folks need these: HOW TO: HPFP Uninstall with Pics!!
HOW TO CALIBRATE YOUR MAF! With An Example
How To CPE Injector Seals + Studs + EGR Delete
Warning: I go into heavy detail to help out my fellow n00000bs . I try to contribute when I can
The Following 6 Users Say Thank You to dougefresh_ For This Useful Post:
3mazdaspeed (04-27-2011), ChimmyChong (05-01-2011), djuosnteisn (04-19-2011), i8urgti (07-14-2011), Mchart (07-18-2011), wolly6973 (04-07-2011)
 Old 04-01-2011, 04:15 PM   #4
meelo88's Avatar
Posts: 557   (View Stats)
meelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the world
subbed to see the results of this!
"If I can't fix it, it was meant to be broken"
[SIGPIC][/SIGPIC] 2007 MazdaSPEED 6 Titanium Grey
TUNED BY NISHAN
POWER
SpeedPerformanc3 Wiseco Pistons (88mm)::Manley Forged H-Beams::BNR S3::Bosch 3Bar Map Sensor::CP-E Ex Mani::SBC Stg 2 Clutch::JBR RMM 80a::JBR STG II SRI::JBR Boost Tubes::JBR BPV Return::JBR SSP::CS TMIC::CS DP::Stratified 3 Port EBCS::Stratified Guardian Angel::TurboXS RP::Custom 3" Catback Exhaust::KMD 2.1::Flex Innovations Ground Kit::Turbosmart BPV::MD OCC::TWM Stage 1::BC Coilovers::Hawks HPS::EGR Delete::SURE Dreadnaught::SURE Juggernaut::SURE TIG
COSMETIC AND AUDIO
Mori H1 Proj Retrofit::DDM 3k HID Fogs::RPM Rear LED Reflectors::RPM Side LED Reflectors::Morel Elate 6 2W 6.5" Components::Morel Maximo 5C 5.25" Coaxial::Arc Audio KS300.4::Arc Audio KS1000.1::Audison BitOne.1::Zapco ST4
meelo88 is offline   Reply With Quote
The Following User Says Thank You to meelo88 For This Useful Post:
 Old 04-01-2011, 04:18 PM   #5
Special--k's Avatar
Posts: 611   (View Stats)
Special--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the world
hellz ya, nice
Special--k is offline   Reply With Quote
The Following User Says Thank You to Special--k For This Useful Post:
 Old 04-01-2011, 09:22 PM   #6
laxplayermjd's Avatar
Posts: 779   (View Stats)
thats a bigggg turbo. never realized the size difference
laxplayermjd is offline   Reply With Quote
The Following User Says Thank You to laxplayermjd For This Useful Post:
 Old 04-01-2011, 11:10 PM   #7
That's what she said.
laxplayermjd (04-02-2011)
 Old 04-02-2011, 07:32 PM   #8
greg08's Avatar
Posts: 480   (View Stats)
greg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond repute
Groaned at 22 Times in 15 Posts
Noob question, since you've been back there and seen how much space there is with the steedspeed mani, is there enoug room for a twin scroll hta3582r? Or is it a sqeeze for the gt3076? Also how much did you have to customize your cpe fmic to fit the new setup?
greg08 is offline   Reply With Quote
The Following User Says Thank You to greg08 For This Useful Post:
dougefresh_ (04-02-2011)
 Old 04-02-2011, 08:05 PM   #9
I haven't been back there with the mani yet. I'm still waiting on delivery of the SteedSpeed . I'm not familiar w/ the size of the 3582, but you can check out Joel's (jmhinkle's) turbo and see what you think. I'd ask Joel or DJ as they would know. (Joel I hope you don't mind I stole some of your pics):
Joel's Twin Scroll 3076:
As for the CPE fmic, I've just looked under my hood, and at Joel's pics above, and it looks like (by eyeball) the outlet of the TS76 is 6" (give or take a few) to the right of where the stock K04 currently sits. So, the hot pipe either needs to be modified quite a bit, or (more likely) I'm thinking it'll be easier to just have a custom hot pipe made to replace the CPE one, and go w/ the rest of the kit. That way when I do a proper custom, I can sell the cpe fmic "in tact" as opposed to chopping it, having a piece welding on, later removing it to have the original piece welded back, etc...
The Following 5 Users Say Thank You to dougefresh_ For This Useful Post:
djuosnteisn (04-19-2011), Docnox (04-20-2011), jmhinkle (10-31-2012), josurr (10-29-2011), Mchart (07-18-2011)
 Old 04-02-2011, 08:35 PM   #10
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Good shit bro!
With all the time we spend in the Black Ops thread, I forget we were here about cars first.
Good luck with the build man.
this forum serves 2 purposes
The Following 2 Users Say Thank You to Dash08 For This Useful Post:
Chriscote (04-19-2011), dougefresh_ (04-02-2011)
 Old 04-02-2011, 08:43 PM   #11
pearl_ms3's Avatar
Posts: 545   (View Stats)
pearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the world
Groans: 32
Groaned at 27 Times in 12 Posts
i have that exact turbo.
CP-E INTAKE W/ AMSOIL FILTER, CP-E INLET, TURBOSMART BOV, DENSO ITV22, AWR RMM, STREET-UNIT TMM & PMM, STEEDSPEED MANI CERAMIC COATED, T3 GT3076, TIAL EWG, CUSTOM V-BAND DOWNPIPE, UR CATTED TESTPIPE, TURBO XS CATBACK EXHAUST, COBB FMIC, CP-E FUEL PUMP, DASHHAWK+CP-E MOUNT, JBARONE SSP, COBB ACCESSPORT STAGE 2 SF 91 FMIC. SELF TUNED WITH 400HP/375TQ @ 21 PSI ON 100 OCTANE.
pearl_ms3 is offline   Reply With Quote
The Following 5 Users Say Thank You to pearl_ms3 For This Useful Post:
Chriscote (04-19-2011), djuosnteisn (04-19-2011), Docnox (04-20-2011), dougefresh_ (04-02-2011), jmhinkle (05-02-2011)
 Old 04-02-2011, 10:05 PM   #12
Originally Posted by Dash08 View Post
Good shit bro!
lol, right? Thanks bro. I prestiged all drunk like a nob, and now marathon pro is 15 captures instead of 10 :/. Got 5 in the last two games playing hardcore tho & unlocked my Python
Originally Posted by amoosenamedhank View Post
bastard.... this is the exact setup I've been hoping the magic turbo fairy is going to bring me. I thought I would be the first to come up with it.... then realized Joel was putting it together.
lol, you can beat me to it man. The install isn't happening until the end of May at best (after my first exam), and I have no clue how I'm gonna get it installed (no garage, etc). Before I decided to go top mount, I talked to a shop and they gave me a quote of $872 for 'regular' 3076 + DP (Still rocking stocker DP... had a CPE, but decided to go top mount before it was installed, and sold it to buy SP mani). If I can't get some local help for the install, I'm hoping I can shave a few bucks of the $872 for the top mount install. Still a great price imo. Gotta make some phone calls, etc.
The Following 2 Users Say Thank You to dougefresh_ For This Useful Post:
Dash08 (04-02-2011), djuosnteisn (04-19-2011)
 Old 04-02-2011, 10:10 PM   #13
I <3 your mom
Dash08's Avatar
Groans: 293
Speaking of which, I need to jump on COD tonight. I'm almost at level 50 on my second prestige. I've been owning with the Olympia shotgun.
 Old 04-02-2011, 09:14 PM   #14
amoosenamedhank's Avatar
Posts: 1,368   (View Stats)
Groans: 53
You know.... Moose stuff
The Following 4 Users Say Thank You to amoosenamedhank For This Useful Post:
 Old 04-04-2011, 11:33 AM   #15
Minor Update: Some parts arrived today.
CPE Seals & egr block off plate. Good to do at the same time as the mani is already off.
I'm still waiting on inj studs/nuts, BSD kit, & the steedspeed mani. Will update w/ pics when they arrive as well as the DJ DP/SRI/TIP. But like I mentioned in OP, insall won't be until end of May at best.
I still need to buy a Tail 38mm ewg, and some misc stuff from ATP, but I haz no money and no job . Donations are more than welcome
study time
EDIT: Studs & Nuts arrived today too.
Dash08 (04-04-2011), djuosnteisn (04-19-2011), Mchart (07-18-2011), rfinkle2 (04-08-2011), Special--k (04-04-2011)
 Old 04-04-2011, 11:58 AM   #16
Special--k's Avatar
sexy, Wonder who is going to be the first to do this on a genpu.
dougefresh_ (04-07-2011)
 Old 04-07-2011, 10:28 AM   #17
You?
Studs & nuts arrived for the seals along with the BSD kit. Got word from Leen that the mani shipped, but I tracked it, and it looks like it's jammed up at the border :/ . Anyone know who delivers stuff from steedspeed in the states? It's coming from candapost.ca. I've never seen a 'candapost' truck in my life, so I'm assuming it's taken over by another carrier state side.. but IDK. I just don't like missing goodies. Will post pics when mani shows up.
What's your guys' opinion on side mounts w/ this set up? All I have is the CPE rear diff mount & the SU RMM (sig is current). I'm not getting the TT front diff mount, but was wondering if side MMs were in order? They'll probably go in later, but figured I'd ask.
 Old 04-07-2011, 10:58 AM   #18
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
i have the awr trans mount and i like it !! what DSD kit did you buy ? did you get the baffle also ?
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
The Following User Says Thank You to jracer For This Useful Post:
 Old 04-07-2011, 11:04 AM   #19
Cool. I just went w/ the ebay BSD for $25. I got in touch w/ someone about the F2's but the price seemed way too high (they're not around anymore but the guy knows the dude who made them and there's a few kits laying around his house). I haven't heard back... I'll send him another pm. I think the only other options are PTP and Protege Garage? If that's the case I'd get the PG one, lol.
 Old 04-07-2011, 11:08 AM   #20
jracer's Avatar
Groans: 89
A email i got from GP works ( old F2 )
"Are asking about the BSD kit as well….
OK so the baffle kit for the Speed 3 is $65.00 and the BSD kit is $25.00…but if you get both at the same time we are doing them for $75.00 for both…and $5.00 shipping…."
Let me know…thanks
Tony
GPWerks Support Team
Tel: 562-789-4026
Email: gpwerks1@gmail.com
www.gp-werks.com
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 04-07-2011, 11:06 AM   #21
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
take some prozac doug
 Old 04-07-2011, 11:08 AM   #22
Take an EWG Lenny.
 Old 04-07-2011, 11:09 AM   #23
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
Take an EWG Lenny.
strong comeback man.
p.s. my comment was meant towards your monotone voice............. i thought u were trying to hypnotize me
djuosnteisn (04-19-2011), dougefresh_ (04-07-2011)
 Old 04-07-2011, 01:35 PM   #24
Tel: 562-789-4026
www.gp-werks.com
Cool thanks man!
lol, and I thought you were just randomly vicing my nuts. No, I'm totally psyched about this Lenny, but I have no means to install it as of yet, which is a huge bummer. I got a good quote for an install, but I can't even swing that (unemployed). I have some friends that want to help but everyone is like 1,000+ miles from me, lol. That and I have the first cpa exam May 26th, and the BT stuff is eating into my study time. The cpa exam makes learning ATR look like long division. So, I just got a lot on my mind, and no nicotine for over 24hrs now = I do need prozac! I would prefer chronic, but I need my ST memory for these exams.
PS. Thanks for the local NATOR thread for MA/NH btw... last time I was poking around in there they only had CT.
 Old 04-07-2011, 03:28 PM   #25
Bah, I missed the SteedSpeed mani delivery today on my way to drop off the car at the dealer & pick up a loaner car. It's a new camry... no clue what edition... I may put the ts76 on there instead and see what happens.
So, if you are buying a SteedSpeed Mani FWIW, it DOES change over from "Canada-post" to the USPS. I figured it switched at the border, but I didn't know who took over. You can track it via the Canada-post, and then the USPS site w/ the same tracking #. But don't expect updates this side of the border... as of last night it said "Inbound Out of Customs" and then I had a missed call on my cell on my way to the dealer from "Front Door," lol. So it was Mr. Postman trying to give me my mani... I'm picking her up tomorrow, and I'll take some pics.
The Following 3 Users Say Thank You to dougefresh_ For This Useful Post:
JMEngineer (07-23-2011), jracer (04-08-2011), rfinkle2 (04-08-2011)
 Old 04-08-2011, 11:20 AM   #26
Picked up the Steep Speed Top Mount Twin Scroll Today... She's a beaut!!! Weighs just under 19lbs in the box w/ peanuts, so prolly closer to 18lbs, IDK. It's nice & solid though that's for damn sure.
Some pics:
I still need to pick up a Tial 38mm, and some misc stuff from ATP. DJ's stuff is gonna take awhile, so this has to go on hold for a while. Works out well though, because I have more important shit to attend to.
The Following 8 Users Say Thank You to dougefresh_ For This Useful Post:
atvfreek (04-19-2011), BrianZX10R (05-13-2011), Dash08 (04-08-2011), djuosnteisn (04-19-2011), Docnox (04-20-2011), jmhinkle (10-31-2012), SIXual Panda (04-19-2011), triplejumper18 (04-11-2011)
 Old 04-08-2011, 11:29 AM   #27
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Looks great man can wait to see some videos and dyno sheet
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
The Following User Says Thank You to Boosted Beluga For This Useful Post:
dougefresh_ (04-08-2011)
 Old 04-08-2011, 11:33 AM   #28
Thanks man, but it's gonna be awhile . I still have the inj seals to do + BSD first. Keeping fingers crossed that I don't get blow out! lol. The numbers won't be anything crazy... if anything quite mild. I only plan on running 20-21 PSI until I get a good job and can afford a build.
 Old 04-08-2011, 12:32 PM   #29
Speeed3's Avatar
Posts: 484   (View Stats)
Speeed3 is the leader of the worldSpeeed3 is the leader of the worldSpeeed3 is the leader of the worldSpeeed3 is the leader of the worldSpeeed3 is the leader of the worldSpeeed3 is the leader of the worldSpeeed3 is the leader of the worldSpeeed3 is the leader of the worldSpeeed3 is the leader of the worldSpeeed3 is the leader of the worldSpeeed3 is the leader of the world
Nice
Speeed3 is offline   Reply With Quote
The Following User Says Thank You to Speeed3 For This Useful Post:
 Old 04-08-2011, 12:41 PM   #30
I <3 your mom
Dash08's Avatar
Groans: 293
People talk shit on the steed speed mani, but really, that thing is fucking nice.
Look how smooth the runners are. There are virtually no restrictions at all. I'm willing to bet they even matched the ports to the gasket.
Looks great man. Should be a fun set up.
The Following 3 Users Say Thank You to Dash08 For This Useful Post:
djuosnteisn (04-19-2011), dougefresh_ (04-08-2011), jmhinkle (05-02-2011)
 Old 04-08-2011, 12:54 PM   #31
People talk shit about everything, lol.
And thanks bro, but it's gonna be awhile. It's all good tho!
Dash08 (04-08-2011)
 Old 04-08-2011, 12:59 PM   #32
AZSPEED3's Avatar
Posts: 3,148   (View Stats)
AZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the worldAZSPEED3 is the leader of the world
Groans: 65
Good luck on the BT build. Looking forward to reading the write up.
Your write ups are usually the best informed and detailed
AZSPEED3 is offline   Reply With Quote
The Following User Says Thank You to AZSPEED3 For This Useful Post:
 Old 04-08-2011, 01:10 PM   #33
Originally Posted by AZSPEED3 View Post
Good luck on the BT build. Looking forward to reading the write up. Your write ups are usually the best informed and detailed
Dang, thanks man! People usually complain that I'm long winded, but not everyone has the same base level of knowledge, so I try to cover everything I think someone could get hung up on, and I assume they know little to nothing (like me, lol). I'm glad the writes up have helped. No promises on a write up though... unsure of how/when this will happen.
I'm waiting for jmhinkle's write up & how to myself as I'm copying his set up. If I have a shop do it, or I do it with some local help, I'll do my best to be detailed.
AZSPEED3 (04-09-2011), djuosnteisn (04-19-2011), jmhinkle (05-02-2011), Mchart (07-18-2011), rfinkle2 (04-08-2011)
 Old 04-11-2011, 08:27 AM   #34
Nataphen's Avatar
Posts: 2,704   (View Stats)
I'm very interested in seeing this come together. I won't be going BT until the warranty is up, but I'm wanting to go with a 3076 at least. With a TS, maybe even bigger than that will still spool plenty fast. Can't wait for the results!
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
The Following User Says Thank You to Nataphen For This Useful Post:
dougefresh_ (04-11-2011)
 Old 04-11-2011, 08:32 PM   #35
turd burglar's Avatar
Posts: 1,895   (View Stats)
Groans: 39
that pic makes me miss my top mount mani
The Following 3 Users Say Thank You to turd burglar For This Useful Post:
djuosnteisn (04-19-2011), dougefresh_ (04-11-2011), jmhinkle (05-02-2011)
 Old 04-18-2011, 10:31 PM   #36
Got the CPE injector seals in and replaced the torx bolts w/ studs & nuts thanks to superskate's help. We also deleted the egr, and flushed out my w/m system. Went to a huge meet in MD, met a bunch of the guys, and had a great time. 1,100 miles (side trips), working on the car, and finally back home. Tired as a mofo! Here's a write up on how to do the upgraded injector seals & egr delete (easy to do both at same time):
The only prep I have left before the BT is BSD. I have the bolt, but I need to pick up a baffled oil pan. I'm tired as hell....
The Following 4 Users Say Thank You to dougefresh_ For This Useful Post:
amoosenamedhank (04-19-2011), djuosnteisn (04-19-2011), jmhinkle (05-02-2011), jracer (04-19-2011)
 Old 04-19-2011, 11:13 AM   #37
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
If you wanna ghetto rig the baffle, you can probably get some avation snips and some sheet aluminum and make your own. After seeing PTPs baffle, I dont think it would take long to rivet something together.
2006 Mazdaspeed 6
dougefresh_ (04-19-2011)
 Old 04-19-2011, 11:22 AM   #38
speedms6's Avatar
Posts: 825   (View Stats)
speedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the world
here's a baffle(unless there is a reason not to get this, im losing track of which vendors people hate these days, there's so many)
Protege Garage - Oil Pan Baffle - Mazda 2.3 L3 Engine
2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge
speedms6 is offline   Reply With Quote
The Following User Says Thank You to speedms6 For This Useful Post:
 Old 04-19-2011, 11:36 AM   #39
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Great thread I'll finish up your intake and send it out shortly, so you have yet anther sexy pic to post.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
Docnox (04-20-2011), dougefresh_ (04-19-2011), jmhinkle (05-02-2011)
 Old 04-19-2011, 12:00 PM   #40
I'm not that handy w/ metal and I have very limited tools . I could make a nice one out of wood, but I may get splinters in the engine, haha. Skates is saying to skip it as I don't track it, but I'd rather get one for piece of mind. I'm actually more concerned about the bsd + a good baffle than I am about the BT install. I'd rather skip the pan if it's unnecessary, but I don't want to take any chances... after all that's invested, $80 won't kill me.
I was told to avoid that one & PTPs... not sure if anyone has had problems though? I vowed not to put anything from PTP on my car after my fuel pump fiasco last year. Joe linked me up to one I just gotta double check something.
There he is!! Thanks bro! The thread wouldn't be possible without your big juicy brain and mad welding skills! ...And tuning skills, and....and... lol. Thanks for checking out the thread, and thanks for sending the intake out soon . Will post many o' pics. Any word on the DP eta? I still need to send you $ for the dump tube... hopefully next week.
What's your $.02 on the baffled oil pan? I want to order that soon and get it done so I'll be all prepped. Getting reaalll close now .
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/dougefresh-s-top-mount-twin-scroll-3076-a-76618/
Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum - View Single Post - How to: Top mount turbo set up!! This thread Refback 06-09-2012 12:46 PM
How To TOP MOUNT TURBO SET UP! Easy, Breezy, Beautiful MS6 only because Race Car | SpeedForums.org This thread Refback 02-29-2012 05:19 PM
HOW TO: Top Mount Turbo Set Up This thread Refback 09-30-2011 02:21 PM
How to: Top mount turbo set up!! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 06-16-2011 12:21 AM
exhaust manifold $250 twin scroll Justin Lee MazdaSpeed 3/6 - Turbo Induction 20 10-14-2013 08:08 PM
My twin scroll BW s300sx 88-75 BT build djuosnteisn MazdaSpeed 3/6 - Big Turbo Builds 2409 08-31-2013 04:10 PM
Twin scroll stock mount manifold steedspeed MazdaSpeed 3/6 - Turbo Induction 287 07-28-2012 01:57 PM
removing twin scroll divider turd burglar MazdaSpeed 3/6 - Turbo Induction 11 05-12-2010 11:06 PM
Twin-Scroll K04?!?!? Mfinlay04 Mazdaspeed3/6 General Discussion 37 05-27-2009 06:28 PM
Page generated in 1.13994 seconds with 39 queries
