Like Tree46Likes
 Old 12-23-2011, 01:21 PM   #921
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Got the egr re-tapped, and it's completely solid now. I also hooked up the HKS ignition (will relocate power box later), and finished rigging up the Perrin Pro in interrupt mode. So now I just need to order the 3 bar map sensor and plug. Tuning soon...
A couple of the rides at the shop that tapped the egr for me (one of these things is not like the others, lol):
The Following 3 Users Say Thank You to dougefresh_ For This Useful Post:
rigor (12-23-2011), SilverDemon (12-23-2011), spnkr21 (12-23-2011)
 Old 12-23-2011, 01:30 PM   #922
SilverDemon's Avatar
Posts: 3,034   (View Stats)
Lemme guess.....the black Jeep ?
dougefresh_ likes this.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 4 Users Say Thank You to SilverDemon For This Useful Post:
djuosnteisn (12-27-2011), dougefresh_ (12-23-2011), jmhinkle (12-23-2011), spnkr21 (12-24-2011)
 Old 12-23-2011, 04:37 PM   #923
I ordered the Bosche 3-bar map sensor, and plug earlier today from the links in Jumping Jackson's thread:
Bosch 0281002437 - Bosch T-MAP Sensors - Overview - SummitRacing.com
Home » Shop » Connectors / Harnesses » Bosch » 4-way sealed Plug Bosch BSK Connector Pigtail for Bosch MAP Sensor
I should have those sometime next week, and I'll install it as soon as I can, and then get to tuning. It'll be nice not having to worry about blowout. I have a map with the scalars for the 3-bar, so I may just stick to the boost based map I have now until I get the 3-bar here, and installed.
The Following 4 Users Say Thank You to dougefresh_ For This Useful Post:
Boosted Beluga (12-23-2011), crazyp (12-23-2011), rigor (12-23-2011), SilverDemon (12-23-2011)
 Old 12-26-2011, 08:00 AM   #924
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
Doug, I figured out the crank sensor errors. It's in your idle and start up part of your MAF cal. From roughly 1.5 V down you are either running way rich or lean. My car was acting like it wanted more fuel at idle. I was seeing +25 at idle in this cold weather since I put on the 35r. I gave it +25% and it started pulling it back that much then. I've been throwing the crank sensor code ever since installing the 35. I decided to cut it 15% and she is happy now. Very minimal + or - changes now across the board. Well below 5% total. No more code. Not sure what plugs you are running, but the 2 step colder do funky things below 40* with your AFR's and fuel trims.
The Following 6 Users Say Thank You to jmhinkle For This Useful Post:
crazyp (12-26-2011), djuosnteisn (12-27-2011), dougefresh_ (12-26-2011), Easter Bunny (12-31-2011), jracer (12-26-2011), TiGraySpeed6 (12-26-2011)
 Old 12-26-2011, 02:25 PM   #925
Cool, that's probably my problem. I had intentionally thrown 20% excess at idle before when I had the egr leak, and I thought I had pulled most of it later, but maybe not. Then I didn't want to mess with it at all until the ecu was 'ready' for emissions. That's simple enough though to fix though, and I'll take care of it after I get the new map sensor. It's it Boston, so it should be here tomorrow, but the plug is lagging. Thanks for the heads up!
 Old 12-31-2011, 09:02 AM   #926
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
where do you go for vacuum hose's
 Old 12-31-2011, 09:25 AM   #927
Axle Breaker
jmhinkle's Avatar
Groans: 162
Don't know about Doug, but I only get it from boostcontroller.com anymore. Their hose quality is the best I've experienced. I order in bulk and keep it around for when people need it.
The Following 3 Users Say Thank You to jmhinkle For This Useful Post:
breakfstincluded (01-01-2012), crazyp (12-31-2011), dougefresh_ (12-31-2011)
 Old 12-31-2011, 05:58 PM   #928
I hooked the mbc back up for the winter. I'm going use the Perrin with the 3-bar in the Spring, and I'm just going to keep things simple for now. I went down the Cape to see some friends for the night, and on the way down I broke down, lol. I swapped the Hallman back in, and was in a rush to leave Boston. So, about 80 miles later, and I'm boosting it up hard. I shift into 3rd, and no power. I just start slowing down, and had to pull over, and the car died. It won't turn over, and no cel. I pop the hood, and see this, LOL!!:
So, it took 2 seconds to fix, and everything was fine. I took a couple 4 gear pulls on the highway on the way home today. I need need to pull a few % fuel from like 3.6-4.3volts, but the rest is all within 1-2% of 12.0 afr target. 2 logs in attached spreadsheet. Car runs good. E85 soon.
 Old 12-31-2011, 06:04 PM   #929
Navy_Mech2's Avatar
Posts: 484   (View Stats)
Navy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the world
lol. i woulda been shitting bricks if that had happened to me
06 MS6 |SP Built motor - Weisco Pistons .020" over, Manley H-Beam Rods, Ported Head, Ported Intake, VTCS Delete, BS Delete, VVT Actuator, Keyed Crank, 6th Port Fuel Injection | ACT 6 Puck w/ Streetlite Flywheel | Bullseye S259 .70 A/R Single Scroll | 3.5" Intake/MAF Housing | Steedspeed Twin Scroll T3 Top Mount Manifold | Tubosmart 40mm EWG | Custom DP | Custom TBE | Custom LTA Intercooler | HKS Type IV TT | Dashhawk | COBB AP | AWR RMM | PTP HPFP Guts |
KILLAH BUILT
Navy_Mech2 is offline   Reply With Quote
The Following User Says Thank You to Navy_Mech2 For This Useful Post:
 Old 12-31-2011, 07:43 PM   #930
Axle Breaker
jmhinkle's Avatar
Groans: 162
Strange place to come apart. Was the coupler just loose?
I put the 3076 back on today. Fixed some piping that was pushing on my bumper. Put in a new EGT probe because the first one was jacked. Drained my OCC that had to be completely full. Took the car for a spin and realized I totally prefer the 3076 to the 35. Just way more streetable for normal use. 35 is too slow to spool in the 6 when we always have traction.
The Following 4 Users Say Thank You to jmhinkle For This Useful Post:
crazyp (12-31-2011), djuosnteisn (01-09-2012), dougefresh_ (12-31-2011), jracer (12-31-2011)
 Old 12-31-2011, 08:20 PM   #931
In my haste to beat traffic, I didn't tighten the t-bolt clamp holding the intake on, at ALL! lol I just hooked up tightened the recirc hose, plugged in the maf, and closed the hood. I'm surprised it ran as well as it did all the way down, and going wot a bunch of times, haha.
Thanks for the review of the 35. I wasn't planning on going 35r or anything, but it's nice to know you like the 76 for a DD.
 Old 01-01-2012, 04:04 PM   #932
I'm going E30 this Wednesday as I have to drop my gf off at the airport anyways, and that's where the E85 Gulf is located, and it's the closest to me (7 miles). I'm going to add 10% fuel to my maf, put some miles on it, take some logs, and adjust. That shouldn't take long, and then I'll move onto timing. I'd like to get her tuned soon as there's a dyno meet coming up in a few weeks.
cld12pk2go (01-02-2012), crazyp (01-01-2012), spnkr21 (01-01-2012)
 Old 01-01-2012, 10:12 PM   #933
2.3speed06's Avatar
Posts: 811   (View Stats)
2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world
Wish I had the knowledge n know how's too do a build like this. I read as much as I can but only hands on would really help. Good luck with the build!!
2.3speed06 is offline   Reply With Quote
The Following User Says NO Thank You to 2.3speed06 For This Un-useful Post:
turd burglar (01-01-2012)
 Old 01-02-2012, 06:00 AM   #934
bmylez's Avatar
Posts: 3,197   (View Stats)
Notice he has a 2.3 MS6....as opposed to the 2.0 MS6 offered in '04...
2007 CTS-V - Trying to sell
 Old 01-02-2012, 10:38 AM   #935
Thumbs up 1st E85 Logs Below...
I filled up with 4 gallons of E85, and then topped her off earlier. To adjust my map, I added 13% fuel up top, tapering to 5% more around 100g/s or so. I added 3* timing as well, so I'm starting out with 14* up top, which it hits np. Nothing crazy, but this is just a base map, and I could only run 11* before with no kr @25-26psi.
I've only driven about 12 miles on the map, so it still has to settle. I only did one pull by my house (2nd & 3rd) so far. My wot afrs are a bit rich, but not too far off actually. Once the map settles, I'd do a maf g/s log, and cal the maf up to 125 g/s or so, then do some 4th gear pulls, and dial in the top of the maf. After that, it's just a matter of adding some more timing in until she knocks, then back off a couple degrees. If I can run 17-18* with no kr, I'll just stop there.
Any suggestions for part throttle timing, and timing in lower load values? I've read that retarding timing earlier can help spool up, but I'm not sure how much and I haven't messed with that before. 4th gear logs coming soon.
EDIT: Did a full 3rd gear pull from 2,800rpms up. Looks good, just a bit rich. I'll lean her out soon, and then I'll start adding more timing. I'm a bit concerned about upping the boost, as I'm sure my IDC% will go up further past 100%. As long as it's under 120% I'll be happy, lol.
crazyp (01-02-2012)
 Old 01-02-2012, 04:38 PM   #936
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
yeah that 120% crap is freaking me out lol.
your running meth too right?
The Following User Says Thank You to crazyp For This Useful Post:
dougefresh_ (01-02-2012)
 Old 01-02-2012, 04:54 PM   #937
Yeah, I'm running Boost Juice (50/50 mix) with a D010 nozzle. So, I had already pulled over 10% fuel up top going up from the D07. So, that bought me some headroom moving to E25 (4 gallons per tank). I'm at just over 100% IDC now, but I was a bit rich, so I had to pull from 2-10% fuel from the maf, after adding 13% to start with. So, the new map has the fuel pulled from the maf, and I'm running 16* up top. I guess we'll see if she knocks, and what the afrs & IDC% look like.
 Old 01-02-2012, 05:21 PM   #938
bmylez's Avatar
In that case, you still have some injector to spare, haha. Looks like you're on your way to over 400whp, sweet.
Oh, and about Boost Juice. I was at Vatozone today and Heet was $2.30 a bottle, so I'm gonna start getting Boost Juice and cutting it with a little water. 25% meth is all I need. It will be much much cheaper than mixing Heet.
 Old 01-03-2012, 11:38 AM   #939
Thumbs up E30 4th Pulls, and VD 433/431 SAE @32F
Here's a few 4th gear pulls. She pulls hard at 26psi, especially with all that extra timing. Here's a couple of Virtual Dynos (1st at SAE for 32F, and the second one without):
SAE @ 32F
Not SAE:
Logs for the 4 runs attached.
 Old 01-03-2012, 04:33 PM   #940
bmylez's Avatar
Alright, so you're running 30% e85, and it takes ~26% more e85 to make the same energy as gas...so 30% of 26% is 7.8%. Max airflow is 435 g/s, so if you were straight gas, it should be 401 g/s.
Does that sound right or am I retarded? That's assuming your MAF is scaled correctly, but that's some good airflow
dougefresh_ (01-03-2012)
 Old 01-03-2012, 05:13 PM   #941
That sounds about right. I'm having other issues now though :/
Clutch Vibrating for a bit when engaged
I explained it to Skate's, and he said not to worry about it @superskaterxes
 Old 01-03-2012, 05:22 PM   #942
bmylez's Avatar
Ugh, I hope it's fine...
The Following 2 Users Say Thank You to bmylez For This Useful Post:
dougefresh_ (01-03-2012), rfinkle2 (01-03-2012)
 Old 01-03-2012, 05:25 PM   #943
Peculiar that the ecu is retarding the same amount of timing regardless of rpm...
crazyp (01-04-2012), dougefresh_ (01-03-2012)
 Old 01-05-2012, 03:29 PM   #944
The Following 2 Users Say Thank You to dougefresh_ For This Useful Post:
rigor (01-05-2012), wolly6973 (01-09-2012)
 Old 01-05-2012, 04:26 PM   #945
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
You're a strange one DF, you're a strange one.......
340hp / 371tq
dougefresh_ (01-05-2012), jmhinkle (01-05-2012), wolly6973 (01-09-2012)
 Old 01-05-2012, 05:58 PM   #946
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
what kind of porn are you running in the background lol
at 104000 2 bent rods
tuned by nishan
The Following 2 Users Say Thank You to rigor For This Useful Post:
djuosnteisn (01-09-2012), dougefresh_ (01-05-2012)
 Old 01-05-2012, 06:17 PM   #947
lol, it's Deuce Bigalow, Male Gigalo, hahaha. It's a comedy, not a porn Finklestein! lawl
rigor (01-05-2012)
 Old 01-09-2012, 10:35 AM   #948
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
...After that, it's just a matter of adding some more timing in until she knocks, then back off a couple degrees.
This isn't really the proper strategy when running an e85 mix. It's best to find mbt on the dyno. I'm gonna read your other thread on vibro-clutch mod nao.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
dougefresh_ (01-09-2012)
 Old 01-09-2012, 02:14 PM   #949
Yeah, I planned on renting dyno time later on, and was just going for something close on the street. And yup, I'm gonna have to start up a build fund. I'll see if I have any parts kicking around that I can sell. It's going to take awhile to get build funds together though
 Old 01-09-2012, 02:24 PM   #950
Captain
There are options for budget builds, but they seem to always turn into full builds. It's just hard to justify "cut corners" on something as critical and expensive as a forged motor. Your lucky you caught it early enough though, cause now all you have to fork out for is the price of the internals and some machine work. Had your rod come completely loose, you'd have to tack a short block (and possibly a head) onto that price tag.
It sucks. But if you get through this, and take your time and do things right, you'll end up with a bullet proof bottom end in a few months. Lemme know if you have any questions, and i'll try to help as best i can.
dougefresh_ and ItsNox like this.
www.permtuning.com
atvfreek (01-09-2012), dougefresh_ (01-09-2012), ItsNox (07-24-2015), rfinkle2 (01-09-2012)
 Old 01-09-2012, 03:52 PM   #951
Good point, and you're right. I'll do some researching around here for a bit, and see things look like. I was planning on building the motor at some point, so I guess now is a good a time as any. If I can get her on her feet by late Spring, that would be cool.
 Old 01-09-2012, 03:55 PM   #952
Axle Breaker
jmhinkle's Avatar
Groans: 162
Did you ever do the quick height test at least to check and see which one is down?
The Following 2 Users Say Thank You to jmhinkle For This Useful Post:
atvfreek (01-09-2012), TiGraySpeed6 (01-09-2012)
 Old 05-18-2012, 11:02 PM   #953
Here's a link to the thread of the stock rod/piston swap we did yesterday:
Towed In Today, Driving Home Tomorrow
TiGraySpeed6 likes this.
The Following 5 Users Say Thank You to dougefresh_ For This Useful Post:
atvfreek (05-19-2012), djuosnteisn (05-21-2012), jmhinkle (05-19-2012), SPEED6 KILLAH (05-25-2012), TiGraySpeed6 (05-19-2012)
 Old 07-24-2015, 10:40 AM   #954
xoiball's Avatar
Posts: 1   (View Stats)
xoiball is an unknown quantity at this point
Hey Dougefresh very interested I your speed please pm me with contact info. Never posted so i can't pm you. I seen the car on cars.com you probably have a message from me there. Hope to here from you asap. Thanks
xoiball is offline   Reply With Quote
 Old 07-24-2015, 10:42 AM   #955
The Following 7 Users Say Thank You to Code Monkey For This Useful Post:
blackmicamps6 (07-28-2015), dougefresh_ (07-28-2015), Easter Bunny (07-24-2015), Funkster777 (07-24-2015), ItsNox (07-24-2015), Mauro_Penguin (07-28-2015), SarcasticOne (07-24-2015)
 Old 07-28-2015, 03:00 PM   #956
Sale is pending, and she'll be gone by the end of the week.
 Old 07-28-2015, 04:04 PM   #957
Fag
dougefresh_ (07-28-2015), ItsNox (07-28-2015), Mauro_Penguin (07-28-2015)
 Old 07-28-2015, 04:29 PM   #958
Mauro_Penguin's Avatar
Posts: 1,997   (View Stats)
Groans: 171
Aaaand another ms6 leaves FL. It's sad, but hey now your part of that #teamluxury thing that everyone down here is doing. What's next on your list?
Hawaii? Some place exotic? Where you going Doug? Just tell me where are you going?
 Old 07-28-2015, 08:53 PM   #959
Correction... I brought a unicorn into FL and it's staying here
I'm not going anywhere hombre. Loving south FL... where do I need to vacation? Though I do have a close friend in Maui and a place to stay... hmmm, lol. Next on my list is the Certified Financial Planner (CFP) certification... I just need to take the exam in November, which will be a good chunk of work and time, but will pay off. Stay in skool!!
Mauro_Penguin likes this.
Mauro_Penguin (07-29-2015)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/dougefresh-s-top-mount-twin-scroll-3076-a-76618/
Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum - View Single Post - How to: Top mount turbo set up!! This thread Refback 06-09-2012 12:46 PM
How To TOP MOUNT TURBO SET UP! Easy, Breezy, Beautiful MS6 only because Race Car | SpeedForums.org This thread Refback 02-29-2012 05:19 PM
HOW TO: Top Mount Turbo Set Up This thread Refback 09-30-2011 02:21 PM
How to: Top mount turbo set up!! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 06-16-2011 12:21 AM
exhaust manifold $250 twin scroll Justin Lee MazdaSpeed 3/6 - Turbo Induction 20 10-14-2013 08:08 PM
My twin scroll BW s300sx 88-75 BT build djuosnteisn MazdaSpeed 3/6 - Big Turbo Builds 2409 08-31-2013 04:10 PM
Twin scroll stock mount manifold steedspeed MazdaSpeed 3/6 - Turbo Induction 287 07-28-2012 01:57 PM
removing twin scroll divider turd burglar MazdaSpeed 3/6 - Turbo Induction 11 05-12-2010 11:06 PM
Twin-Scroll K04?!?!? Mfinlay04 Mazdaspeed3/6 General Discussion 37 05-27-2009 06:28 PM
Page generated in 0.60865 seconds with 36 queries
