 Old 03-12-2011, 04:18 PM   #1
SkwidKid007's Avatar
Posts: 248   (View Stats)
SkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond reputeSkwidKid007 has a reputation beyond repute
Groaned at 3 Times in 1 Post
Default Drag Radials
Ok, im guessing this is the appropriate area for this thread... But heres the question, what are you big turbo/ 1/4 guys running for slicks?
Since i have 18's, its hard to find a descent tire that will fit... I really would love to run like a 16" rim and order some mickeys... Please tell me what you guys are doing to get your 60 fts... i need ideas... Big Import Face Off race is in two weeks and i need to have some tires/wheels ordered before then...
Thanks
2008.5 MS3 White
BNR StageIII, RPMC TIP, NGK ITV7IX-11, GS EBCS, Cobb SRI, HKS SSQV3 VTA, Exhaust Depot Black IC Piping, Godspeed FMIC, PTP HPFP, CP-e 75 duro RMM, Turbo XS long 3" DP, Magnaflow 3" CBE, Raceland CO, TWM STS & Bushings, Hawk Pads, Stop-tech Slotted Rotors, Pioneer Avic-Z130BT, Motegi MR-116's wrapped with 235/40/18 Eagle GTs
320WHP/364WTQ 20lbs 93- Calvin @ Cobb (13.3@109 Skreet Tires)
3/8 mix E85 21lbs- Ziggo (12.9@113 Skreet Tires)
SkwidKid007 is offline   Reply With Quote
 Old 03-12-2011, 05:13 PM   #2
kmac's Avatar
Posts: 1,792   (View Stats)
Get a set of mickey drag radials . That's all u need.
 Old 03-12-2011, 05:29 PM   #3
THey dont make anything in a size on an 18" rim that i can fit... unless im missing something here?
2008.5 MS3 White
 Old 03-12-2011, 05:55 PM   #4
kmac's Avatar
They make a et street radial 2 in size 245/40/18 if u have wide enough after market rims they fit I have them on a set.
 Old 03-12-2011, 05:59 PM   #5
ok... thanks for that... im looking at getting some 16" rims and buying tires to go on that.. i have an 8" rim with lowering springs... the stock 215/45's are rubbing, but at the track i wont be doing a LOT of turning... do you have rubbing issues? are you lowered?
2008.5 MS3 White
 Old 03-12-2011, 06:02 PM   #6
kmac's Avatar
I'm on coilovers and I don't have a problem thus far , but I'm also not that low.
 Old 03-12-2011, 06:04 PM   #7
mason's Avatar
Posts: 946   (View Stats)
i got nitto N1 dot drag radials, i like them alot.
 Old 03-12-2011, 07:11 PM   #8
Ok. I may just go with the nt05.
2008.5 MS3 White
drag radials??? arielmalespin MazdaSpeed 3/6 - Wheels & Tires 17 03-18-2011 01:03 PM
what size slicks/drag radials for 16x8 BeeZaa 2010 MS3 - Wheels & Tires 4 12-06-2010 08:05 AM
Slicks / Drag Radials 9900rpm 2010 MS3 - Wheels & Tires 0 03-23-2010 02:55 PM
Slicks / Drag Radials 9900rpm 2010 MS3 - Wheels & Tires 8 11-27-2009 03:42 PM
Drag Radials MidwestSpeed3 MazdaSpeed 3/6 - Wheels & Tires 3 06-24-2008 01:57 PM
Page generated in 0.27593 seconds with 22 queries
