Like Tree10Likes
 Old 07-13-2011, 05:43 PM   #361
driver311's Avatar
Posts: 1,769   (View Stats)
Everything is skewed with E85. I see over 400g/s with a K04, haha. :/
Driver, sounds like a fun car!
To an extent. It changes based off how much you have scaled it. Ive scaled mine 12%. I was seeing about 290-300gs on pump. Then it went up to about about 30-40gs after than and Ive turned up the wick on my tune since. Ill post logs and such soon. Either way car is ripping and numbers are numbers. I wanna see what that damn dyno and track says. With about 330gs the car trapped 115 so you do all the math and figure it out for me lol.
Mazdaspeed
 Old 07-13-2011, 11:31 PM   #362
driver311's Avatar
Played with my tune a touch more. Richened up a touch and added a lil bit of timing. 390-400gs from 5k up. Car is handling business.
Mazdaspeed
 Old 07-14-2011, 05:35 AM   #363
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
400/1.12 = 357 g/s.
That is around 47 lbs/min of flow, which is about all one can expect from your 3071 (unless ATP doesn't use the 56 trim).
 Old 07-14-2011, 08:48 AM   #364
driver311's Avatar
I have a 3076r
Mazdaspeed
 Old 07-14-2011, 08:50 AM   #365
801MS3's Avatar
Posts: 453   (View Stats)
801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world
Groans: 30
Edit: Posted response same time.
08.5 MS3- : ATP GT3071r: cp-e XL intake: cp-e big inlet: cp-e rmm 75 Duro: cp-e e-flex motor mounts : cp-e catted down pipe: cp-e cbe,: cp-e FMIC, cp-e HPFP: cp-e safe seals : DNP Manifold: COBB AP: COBB RSB: DO stg 2 meth kit ,: SURE TIG's, : KW V2 coilovers: Konig Milligram 18x8.5 +35, Hankook ventus evo's 235/40/18, Saitek adj endlinks :HKS BPV: TWM STS:
465whp 468 wtq Best e.t 11.9 Best trap 123mph
801MS3 is offline   Reply With Quote
 Old 07-14-2011, 11:32 AM   #366
driver311's Avatar
Here is a few log from today. 22psi feels good
Mazdaspeed
The Following User Says Thank You to driver311 For This Useful Post:
Dano (07-14-2011)
 Old 07-14-2011, 11:47 AM   #367
bewsted's Avatar
Posts: 2,456   (View Stats)
bewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the world
Your AFR's are all over the place.
Wonder why?
EWG K04...GETSUM!
A journey to make people cry like babies when loosing to a wagon.
bewsted is offline   Reply With Quote
 Old 07-14-2011, 12:27 PM   #368
driver311's Avatar
Well they range from 11.7-12.0 really. YOur just over analyzing it. When I first shift it goes a lil leaner but no big deal. Im cool with anything under 12.5 and over 11.5. In fact this map my afr is set at 11.9 and I have been running 12.3. Ill probably lean it back out some. What matter is im in a safe range, fuel trims are good, power is great, and no knock. Remember we are dealing with a different fuel here that doesnt burn like pump gas. ON pump or race gas my afrs are a straight line across. This is still a work in progress. Im happy and car feels insane. Im loving it.
I am maxing my fuel system out over 22psi though. At 21psi I see about 90% duty cycle. So I might take my % back a touch. Maybe run 40% e85 and see if I can stick with 22psi. We will see.
Mazdaspeed
 Old 07-14-2011, 12:40 PM   #369
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Anthony, you should pull the solenoid apart some time if your bored, and give it a once through like Phate has several times. I'm sure he could walk you through it.
I'd be curious to see if it's dirty, and if so, if cleaning would help stabilize the afr's.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 07-14-2011, 12:50 PM   #370
driver311's Avatar
Ill check that out. Thanks
Just loaded a new map with 12.2 afr raised fp a touch. Im gonna take some more logs and see what happens. Ill post that up.
Mazdaspeed
djuosnteisn (07-14-2011)
 Old 07-14-2011, 01:19 PM   #371
driver311's Avatar
Here is another with a lil less boost.
Mazdaspeed
 Old 07-14-2011, 01:43 PM   #372
pearl_ms3's Avatar
Posts: 545   (View Stats)
pearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the world
Groans: 32
Groaned at 27 Times in 12 Posts
sure wish my car was that fast.....
CP-E INTAKE W/ AMSOIL FILTER, CP-E INLET, TURBOSMART BOV, DENSO ITV22, AWR RMM, STREET-UNIT TMM & PMM, STEEDSPEED MANI CERAMIC COATED, T3 GT3076, TIAL EWG, CUSTOM V-BAND DOWNPIPE, UR CATTED TESTPIPE, TURBO XS CATBACK EXHAUST, COBB FMIC, CP-E FUEL PUMP, DASHHAWK+CP-E MOUNT, JBARONE SSP, COBB ACCESSPORT STAGE 2 SF 91 FMIC. SELF TUNED WITH 400HP/375TQ @ 21 PSI ON 100 OCTANE.
pearl_ms3 is offline   Reply With Quote
 Old 07-14-2011, 01:49 PM   #373
bewsted's Avatar
I checked my pump after like 5 fill ups. I had such a small amount of residue it was hard to even notice.
I guess I need to pull that solenoid apart too huh?
So when you going back to the track man....Interested in seeing what you get on vs the last time.
EWG K04...GETSUM!
The Following User Says Thank You to bewsted For This Useful Post:
 Old 07-14-2011, 01:50 PM   #374
driver311's Avatar
It feels pretty good for sure. I just need to figure out how to get my timing to hold where I have it set. Im requesting 14.5 degrees and only seeing 11.5?
Mazdaspeed
 Old 07-14-2011, 01:55 PM   #375
Babyface's Avatar
Posts: 320   (View Stats)
Babyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the worldBabyface is the leader of the world
Wow, now I just wish they had E85 around here............
Babyface is offline   Reply With Quote
 Old 07-14-2011, 01:58 PM   #376
bewsted's Avatar
I was going to ask why you lowered timing but I figured you had a reason.....
The only issue I have is maxing out WGDC. Can't get anything about 93 or 94 above 5500 rpms.
So have some issues holding above 5500 rpms....Guess i should check for vacuum leaks too.
EWG K04...GETSUM!
 Old 07-14-2011, 02:02 PM   #377
driver311's Avatar
Do a e85 search in your area. Its there somewhere, it has to be. CArs run off the shit you know. LOL
Mazdaspeed
 Old 07-14-2011, 02:05 PM   #378
bewsted's Avatar
Have you ever fucked with your max tables? Maybe Your hitting over the set max timing?
EWG K04...GETSUM!
Dano (07-14-2011)
 Old 07-14-2011, 02:10 PM   #379
driver311's Avatar
Ive been running that much timing for along time with no issues. Its just since I went past 2.2ish load. Its like its still trending down as load climbs. I have it set high. IM not sure. Dustin is gonna look at my map. I thought I had it propa but Im not always right. LOL
Mazdaspeed
 Old 07-14-2011, 02:12 PM   #380
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Man, I'm seeing >3.6 load @ ~3k rpm and >2.5 load @ 6k. I would check the max tables and whatnot.
 Old 07-14-2011, 02:24 PM   #381
driver311's Avatar
what table exactly. cause my commanded wot ol table is asking for 15 max?
So you must be on straight e85 to be seeing those kind of loads. Im running a 3076r at 22psi and on 50% e85 and see nothing near that. LOL
Mazdaspeed
Last edited by driver311; 07-14-2011 at 02:24 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-14-2011, 02:24 PM   #382
Eth Fiend
phate's Avatar
It's like a "max ignition" something or other table. It's at the bottom of the ignition tables, if I remember correctly. It's an absolute limit that limits both CL and OL timing, no matter what they are commanding.
 Old 07-14-2011, 02:31 PM   #383
dsmluck's Avatar
Posts: 1,193   (View Stats)
dsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the world
Groans: 60
I made a post a while back about a leaner spike right when I go full throttle. AFRs also seem to wander .3 to .4 or so from targets in the lower RPMS at WOT. Past 5k they stick right at 12.2 or so (targeted). I am currently running 45% E-85. Could the E85 be causing slight fluctuations in the AFR? I remember logs from before I ran E85 and that shit was like a laser it was soo straight. Also how lean do your AFRs go? I hit 13.0 when I was targeting 12.3 once and backed the AFRs way off in the RPM range to lessen the initial spike from 3-4k at WOT. Car didn't knock once even when it hit 13.0.
2003 Lancer Evolution VIII - FIC 1120cc/Walbro 255/E85/Pure Drive Performance Tune
1990 Talon TSI AWD: Evo III 16g/E85/Exhaust/PTE 1000cc's/2g Maf/ECMLink *Wrecked*
2012 WRX: TD05 20g/E85/FIC 900cc's/Walbro 255 *SOLD* 12.8@110mph
2009 MS3: GT3076r/(75/25) E85/Bolt-ons *SOLD* 13.6@112mph
dsmluck is offline   Reply With Quote
 Old 07-14-2011, 02:35 PM   #384
bewsted's Avatar
The way I cure that is lower my target at the point in which it spikes too match what I am running past that particular cell.
If your targetting 12.0 @ 3500 RPM BUT hitting 12.4......Try lowering your target down to say 11.8 or so and see what happens.
On the subject of load I seen 2.68 today which made me go HOLY SHIT lol....
EWG K04...GETSUM!
 Old 07-14-2011, 02:38 PM   #385
driver311's Avatar
Probably is the gas but Im not worried about it. Just wanna get my timing set and just stick with 20psi on street and when I go to track Ill run 22-23psi. Should be more than enough to hit 440whp on track and dyno and rock some 11s with ease. Thats all I want at this point. Im playing with fire trying to go farther. We have already come so far in last 6months with these cars and tuning. Cobb has been awesome and opened lots of doors for us. Im just happy that we are finally getting the results we always knew these cars had in them.
Dyno soon boys and 11s soon to follow. YOu can mark my words. I was already so close to 11s with wayyyyyy less power. LOL
Mazdaspeed
The Following 4 Users Say Thank You to driver311 For This Useful Post:
4G63 (07-14-2011), Dano (07-14-2011), dsmluck (07-14-2011), rfinkle2 (07-14-2011)
 Old 07-14-2011, 02:45 PM   #386
bewsted's Avatar
I am really hoping to make some good power saturday....
Would be nice to see those 11s on our boards couldn't agree more.
EWG K04...GETSUM!
 Old 07-14-2011, 02:45 PM   #387
dsmluck's Avatar
Groans: 60
Yea thats what I am doing. Mine is weird though. I target 11.8 at 3000-4000 and then 12.2 from there up. In reality I will still see spikes up to 12.4 sometimes in that range and sometimes I see as low as 11.8. After that in the RPM range the AFRs smooth out. It doesn't really bother me as long as I don't see knock.
Fuck I need a bigger turbo.
The Following User Says Thank You to dsmluck For This Useful Post:
 Old 07-14-2011, 02:48 PM   #388
Captain
I still see the lean spike on a few cars.... no clue how to fix it at this point. It's a transition thing IMO.... dunno. Never see knock there though.
Wonder if it's something hardware related, like slow 02 sensor or something.
www.permtuning.com
 Old 07-14-2011, 02:50 PM   #389
driver311's Avatar
Im sure thats exactly it dustin.
Mazdaspeed
 Old 07-14-2011, 04:20 PM   #390
Eth/Meth Junkie
cld12pk2go's Avatar
I have a 3076r
Yep, my reading fail for just seeing the "12.0 @113 on atp3071r 18psi" in your sig...
If both of you OL ignition tables are the same, then it is most likely the max ignition tables.
I just copy my entire OL ignition table starting at 0.31 load into my max tables.
 Old 07-14-2011, 04:24 PM   #391
bewsted's Avatar
Shouldn't the only thing that matters be anything above your lowest load at WOT?
Just saying.
Maybe pu's have something different I only have 1 OL table
EWG K04...GETSUM!
 Old 07-14-2011, 04:35 PM   #392
11cruzito11's Avatar
Posts: 824   (View Stats)
Groaned at 5 Times in 2 Posts
[QUOTE=driver311;929317]Ok some updates. Car has a new turbo. Im currently running atps new ewg back half 3076r.
When you say your running ATPs new EWG back half 3076r, are you talking about this below:
Externally Wastgated Turbine Housing for Mazdspeed 3 - GT3071R/GT3076R : atpturbo.com
The Following 2 Users Say Thank You to 11cruzito11 For This Useful Post:
Dano (07-14-2011), rfinkle2 (07-14-2011)
 Old 07-14-2011, 04:43 PM   #393
bewsted's Avatar
That is the balls....eliminates the need for a different exhaust mani... im assuming there is no wastegate clearance issues?
EWG K04...GETSUM!
 Old 07-14-2011, 04:54 PM   #394
Captain
Doesn't seem to be, that's what driver's running. Looks trick.
www.permtuning.com
 Old 07-14-2011, 05:07 PM   #395
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Anthony....post up a pic of that EWG housing setup.
nevermind...too much trouble to see down there anyway.
 Old 07-14-2011, 05:08 PM   #396
Captain
Hahaha, i have one he sent me a while back, lemme see if i can upload it, hang on.
www.permtuning.com
 Old 07-14-2011, 05:16 PM   #397
Captain
*edit*, i've emptied my in box since then.
www.permtuning.com
Dano (07-14-2011)
 Old 07-14-2011, 05:41 PM   #398
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
I'll refill your box.
 Old 07-14-2011, 05:42 PM   #399
So can you confirm he is running that housing?
I want to use that housing and wasn't sure if anyone was running it.
 Old 07-14-2011, 07:51 PM   #400
driver311's Avatar
Yes im running it and it works pretty efffing slick. Clears perfect. All you need is a small dump tube made and your set. I was thinking about talking my good buddy austin to get it for his 3071 setup so he can get rid of his boost spikes and get that sick ass sound you get from this tial wg. Im loving it.
Mazdaspeed
The Following 3 Users Say Thank You to driver311 For This Useful Post:
11cruzito11 (07-14-2011), 802MS3 (07-14-2011), rfinkle2 (07-16-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/drivers-attempt-e85-68330/
GPL - Pagina 9 - Cafenea - Club Mazda This thread Refback 11-11-2014 10:08 AM
turbo charging e85 pu - Web Search Results This thread Refback 04-18-2014 05:27 PM
GPL - Club Mazda - Page 9 This thread Refback 12-17-2011 08:53 AM
partial e 85 on disi - Colorado Mazda Club This thread Refback 04-03-2011 05:15 PM
E15 Ethanol gas Controversy - Page 7 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Refback 01-28-2011 09:16 AM
GPL - Club Mazda This thread Refback 01-15-2011 01:20 PM
My Photography Attempt... CWP MS3 typeshluder Members Rides Gallery 5 07-18-2010 09:58 PM
first attempt at datalogging and graphing super_pablo_ MazdaSpeed 3/6 - ECU Computer Tuning 9 02-15-2010 08:02 PM
Heres my first attempt at some pictures! ZMB MazdaSpeed 3/6 - Appearance 14 02-16-2009 12:49 PM
British study suggests that older drivers are safer drivers Haltech Automotive News 0 05-01-2008 05:50 AM
Page generated in 0.57026 seconds with 32 queries
