| Banned ![]() Join Date: Jan 2013 Location: ohio, moving to nj
Rep Power: 0 ![]() Thanks: 7
Groaned at 21 Times in 6 Posts
(Thread Starter) | Not Ranked : 0 score hey msf, i am going with an engine build and big turbo and would like you help to make sure i make the right choices, i have done alot of research and just want to make sure i have it all downso here is what i have so far: Cobb bov: $265.00 CP Pistons: $550.00 Carrillo A beam rods: $790.00<-- going with these i think Carrillo H beam rods: $920.0 Cometic HG: $100.00 ARP Headstuds: $145.00 ARP Mainstuds: $98.00 Cobb 3 port: $105.00 Cobb FMIC: $985.00 GT2871: $1,680.00 <--changing this to gtx3071r Externally wastegated turbine housing: $380.00 Tial 44mm wastegate: $359.00 Turbo XS test pipe: $165.00 autotech internals: $339 and i also just picked up a brand new fuel pump also total part $5,600 roughly<--- all pricing was from my builder and this is where my research came in on the little stuff. 3x crank pully washers 2x cam washers thrust washer crank pully seal Crank flywheel seal 16x valve stem seal 32x valve locks (optional) 5x flywheel bolts Oil pickup o-ring (optional) Oil pickup (optional) Oil strainer (recommended) Oil pump (recommended) Oil chain oil chain guide(s?) Timing chain timing guides (2 different ones) Timing tensioner Dcr vvt (recommended) Cometec/oem head gasket Thermostat Injector seals (recommended) Injector stud kit (optional) Pcv OEM Crank Pulley Bolt i had my timing chain,vvt and all timing parts changed 10k ago by the dealer so not sure if i need to replace that since its only been 10k. well guys please let me know what you think i will be going green very soon so dont worry i got that covered since that the most important part to my build ![]() oh and i will also get the injector seals, and all jbr motor mounts as well Last edited by bigturbo3; 01-23-2013 at 07:35 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to bigturbo3 For This Useful Post: | SpeedRebirth (01-23-2013) |
| Not Ranked : 0 score You can reuse a lot of stuff from your old engine. There is a thread almost exactly like this posted by theurgy from a day or two ago.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. |
| The Following User Says Thank You to phate For This Useful Post: | helmetface (01-23-2013) |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
| Not Ranked : 0 score Go 38mm WG for a 3071r Also, save yourself the hassle and get a 90 -AN fitting to use in substitute of the 45 that is supplied with the oil return for the ATP hotside.
__________________ |
| The Following 2 Users Say Thank You to helmetface For This Useful Post: | SpeedRebirth (01-23-2013), Voltwings (01-24-2013) |
![]() Join Date: Feb 2011 Location: Oshkosh, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,456
Groans: 398
| Not Ranked : 0 score Edgeautosport can hook you up with an ewg gtx30 kit. Comes with wastegate, dump pipe, oil lines. You'll also need big turbo TIP.
__________________ 2007 MS3 Silver. Intake bits, exhaust bits, FMIC bits, freektuned, loved, cherrished, SOLD!!! 2014 5.0 Gotta Have It Green w/Track Pack |
| Not Ranked : 0 score Dang man, you could at least give @06Speed6 some credit for that list you "researched":
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | ||
| The Following 4 Users Say Thank You to phate For This Useful Post: |
I also have the part numbers in my part number thread that is stickied in the ms6 engine subforum.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG | |
| The Following 4 Users Say Thank You to 06Speed6 For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score yes sorry that list was from 06speed6 |
![]() Join Date: Apr 2012 Location: weslaco, texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score I have all my parts already. Here is my list: Overhaul gasket set Cometic head gasket (if over boring) Arp head studs Arp main studs Front oil seal (overhaul comes with one) Rear main seal Rod bearings Main bearings Crank pulley bolt Thrust washer Friction washers Cam friction washers Egr delete(if you dont have one) I got weisco pistons I got k1 rods Also going gtx3071r so i also got: Stratified 3 port ebcs Cpe big turbo inlet Cpe big maf housing Bosch 3 bar map 3 bar map pnp harness Cpe injector seals Going to buy a treadstone intercooler (you can get any upgraded one) And going to buy a stage 3 clutch The turbo im getting comes with the tial ewg and dump tube. Go with edgeauto. Speak with alan or jp. Tell em aj referred you. They will hook you up big time. And thats assuming you have a cobb ap, down pipe, hpfp internals, exhaust Last edited by Juliandlr1004; 01-23-2013 at 09:34 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to Juliandlr1004 For This Useful Post: | SpeedRebirth (01-23-2013) |
(Thread Starter) | Not Ranked : 0 score THANKS FOR THE INFO, IS ALL THAT STUFF NECESSARY OR DEPEND WHAT THE CONDITIONS ARE WHEN THE MOTOR GETS TAKING APART? I KNOW SOME THINGS ARE A MUST LIKE THE CRANK BOLT AND STUFF LIKE THAT, JUST TRYING TO SAVE A LITTLE ON THE BUILD IF I CAN BUT I DONT WANT TO CHEAP OUT EITHER |
![]() Join Date: Sep 2011 Location: Rockville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,554
Groans: 130
Groaned at 8 Times in 7 Posts
__________________ 06 Black Cherry Mica MS6 GT: Speed Perf6rmanc3 built motor, GT3076r EWG, ACT 6 puck Clutch kit, HTP 3.5" full intake, M2 downpipe, XS Power Exhaust Manifold, CP-E austenite 3" exhaust, Whiteline 24mm rear sway bar, Injector RX Cleaned injectors, JBR trilogy motor mounts, JBR EGR Block off plate, Ported and ceramic coated intake manifold, 3 bar MAP, 3 port EBCS, Cobb AP, CX racing piping with Treadstone TR8, CP-E SAFEseals, MD OCC, Step Colder spark plugs, Turbo XS RFL BOV, AT fp internals, CP-E rear diff mount, Turbine Tech Front rear diff mount, DSS 500hp rear drivers side axle, Wilwood 4 Pot Calipers, Team Dynamics 18"x8" Pro Race 1.2s +38, SPC front ball joints, H&R springs, Morimoto clear projector retrofits. | |
| Not Ranked : 0 score Go with my list bro...im not sure if im allowed to discuss what prices i got |
(Thread Starter) | Not Ranked : 0 score i just called jp so he will be helping me out, thanks for the info |
![]() Join Date: Nov 2010 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,489
| Not Ranked : 0 score The carillo rods are twice as expensive as the K1's and the K1's are every bit as good for making useable power... thats whats in my engine, just saying. The K1 / wiseco is a very proven set up on this platform, dont fix what aint broken (no pun intended in regards to blown motor...).
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
(Thread Starter) | Not Ranked : 0 score with the egr delete, i know you can check off that code but will it make any problem as far as inspection? |
| Not Ranked : 0 score Not sure. Barely gonna do mine |
| Not Ranked : 0 score well i have an EGR delete and a catted DP. Bought a catted DP so i would pass inspections, but after talking to a few people COBB turns off the "catless DP" code on all base maps anyways... so basically even with a catted DP the computer will read as catless. I'll be getting an inspection in the next few days and if i pass ill try to remember to post here haha.
| The Following User Says Thank You to Voltwings For This Useful Post: | bigturbo3 (01-24-2013) |
![]() Join Date: Jul 2011 Location: Fayetteville, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,655
| Not Ranked : 0 score it depends on the state. I no nc cars can have one not ready. So if i have a egr delete and a catless downpipe i will have 2 not readys. so what i do is put my egr back on before i get my inspection and i pass.
__________________ [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to StayBroke For This Useful Post: | Voltwings (01-24-2013) |
![]() Join Date: Mar 2012 Location: Cary NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
NC inspectors are required to lift the car and check for the presence of a cat also, among other things like wheel bearings. You can always weld a shell on the outside of the dp.
__________________ 2010 - BMW 335i M-Sport - Lemans Blue Metallic 2005 - Kawasaki ZX-6R 636 - Magma Red | |
__________________ [SIGPIC][/SIGPIC] | |
![]() Join Date: Dec 2008 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score I'm kind of looking at building my engine up as well. My car will be paid off in the next few months so i'll have some extra money to build up the engine. What would you say the average labor cost is to do the engine build? I'm talking just labor, not the cost of parts. I contacted 1 shop here in Phoenix and they quoted me $10,500 installed with parts. I thought that seemed a little high to me.
__________________ Eric Schlaht - Arizona Phoenix Photographer http://www.esimaging.net - http://www.facebook.com/esimaging [SIGPIC][/SIGPIC] 2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14** **9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp **11/19/13** Forged engine built and started up the car for the first time, success! **3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno **6/24/15** Sold the Mazdaspeed 3 **7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package |
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. | |
| Not Ranked : 0 score So $2500 seems about right to me, thats the price I had in mind. I will certainly shop around. This is just a shop another local mazda club uses for dyno days and such. We have LOTS of options here in Phoenix with lots of great shops, i'm not to worried about finding better pricing because i know it's out there. To save on the money I could pull the engine myself and bring it to a shop for them to do the work, that would probably save me even more money. I was just curious what everyone else has paid so i can get an idea of the standard costs and maybe use that as part of the price negotiation.
![]() | | #24 | ![]() |
| Not Ranked : 0 score You could build an engine right, for about $2500 if you pull it yourself. That includes machine work, forged rods and pistons, and the few small pieces that are necessary.
| The Following User Says Thank You to phate For This Useful Post: | magicka (01-24-2013) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score This guy is charging me $500 for labor excluding machone shop prices |
![]() | | #26 | ![]() |
Groans: 136
| Not Ranked : 0 score I have an excel file with a parts list including part numbers & cost in my build thread. The URL is in my sig. Tapadatass
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score all my parts come out to like $5500-6000 and i was told the total build would cost me like $7500 maybe 8 at the most... and thats with machine work and a few other things |
![]() | | #28 | ![]() |
| Not Ranked : 0 score |
| The Following User Says Thank You to Juliandlr1004 For This Useful Post: | phate (01-25-2013) |
![]() | | #29 | ![]() |
![]() | | #30 | ![]() |
Groans: 136
Tapadatass
__________________ | |
![]() | | #31 | ![]() |
1. Bore up to 0.20 over 2.Plate hone up toe 0.20 over 3.Vinny’s own plateau hone 4.Line hone main cap 5.Deck Block 6.Radius oil holes/Micro polish crank 7.Remove Galley balls, flush crank & install set screws 8.Balance entire rotating assembly 9.Resize rods for additional clearance 10.File fit rings to bore PARTS 1.Hand finished C.P. pistons, rings 8.5:1 compression with thermal barrier coating option, locks & 866 tool steel pins 2.Carrillo “SA” rods 3.ARP main stud kit 4.ARP Head Stud kit 5.A.C.L./Calico coated main bearings 6.A.C.L./Calico coated rod bearings 7.New thrust washers 8.GTR skyline factory head gaskets STAGE I CYLINDER HEAD 1. COMPLETE FULL RADIUS COMPETITION VALVE JOB 2.REFACE ALL STOCK VALVES 3.LAP ALL VALVES 4.MILL/DECK 2 CYLINDER HEADS 5.INSTALL VITON VALVE SEALS 6.INSTALL jim wolf SINGLE VALVE SPRINGS 7.REASSEMBLE BOTH CYLINDER HEADS 8.ADJUST VALVE CLEARANCE 9.MILD PORTING ON IN/EX TO BLEND SEAT TO PORT 10.HONE VALVE GUIDE TO SIZE this is what will be done and some step are for an nissan engine but you get the idea | |
![]() | | #32 | ![]() |
| Not Ranked : 0 score Thats why the price is so high |
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score why what would you say shouldnt be done, i feel like if i am going to do this might as well go all out and have it done the best way and make sure its done right plus it also include a tune and free oil changes on them and 1 year warranty. |
![]() | | #34 | ![]() |
![]() Join Date: Feb 2011 Location: Goldsboro, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34,434
Sent from my DROID RAZR using Forum Runner
__________________ 2009 CWP MS3 GT Rally Armor Flaps | Gen Pu Wheels | JBR 80d v1 RMM/RSB/TIGs/Boost & Bypass Tubes TWM Full Replacement Shifter | CS SRI/TIP/Skid Plate | Koni FSD 4045 | Matt Damon OCC | Cobb DP/AP | CP-e TMIC/HPFP PTP VVT Actuator/Injector Seals & Studs | Samco Rad Hoses | Redline Leather Shift & E-Brake Boot BNR S3 | Stratified Boost Dial | |
![]() | | #35 | ![]() |
| Not Ranked : 0 score Id buy supporting mods, rebuild pistons and.rods, slap on a gtx3071 and call it a day. Build the head when you plan on going 600+hp |
![]() | | #36 | ![]() |
(Thread Starter) | Not Ranked : 0 score i am having vinny ten racing shop in long island build it, i know some people dont like him but i have had him tune my car before and he know what he is doing and does very good work. and yes the parts are what is making the prices so high i think the labor and machine work and stuff will be around 1500 maybe less it depends you know
what should labor be around on a build like what i have posted just labor just checked he said it should be around 6k-7.5k for the total build Last edited by bigturbo3; 01-25-2013 at 09:36 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #37 | ![]() |
| Not Ranked : 0 score Check out my build threads, they outline the machine work performed for a brand new block build, and a used block rebuild. Silvapain used the same machine shop and all 3 came out to ~$1k for everything (including main/rod bearings). Most race shops don't do their own machine work, so there is a mark up on whatever they have done. I've worked with Vinny tens guys one time and had a good experience - I did a remote tuning session there for a NY guy. IDK anything about their engine building expertise, though. I would definitely make sure they have done these engines before, because they have some uncommon aspects. Unless you're going for >5-600hp, you probably don't need to do anything to the head except recondition it (valve job, seals, milled flat).
![]() | | #38 | ![]() |
| Not Ranked : 0 score Man shops up there are crazy expensive |
![]() | | #39 | ![]() |
Groans: 136
| Not Ranked : 0 score IMO, the head should be inspected for valve guides, seals, and bent valves when doing an engine build. Tapadatass
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score he told me he has not done an ms3 engine before, i was like hmm, but i do trust him and im sure it will be fine, is there anything i should make him aware of on the build? he has been building motors sine the 80's and hes an master technician,cobb certified. |
| Time for some EFR Forged Madness! Motor Build Advice Needed >>> | Alpha | MazdaSpeed 6 - Engine, Transmission & Driveline | 103 | 06-03-2014 03:34 PM |
| New engine break-in advice | corypechon | Mazdaspeed3/6 General Discussion | 7 | 02-11-2013 03:58 PM |
| engine overheat problem! please HELP!/ADVICE! | ziggi | MazdaSpeed 6 - Engine, Transmission & Driveline | 15 | 05-16-2011 10:06 AM |
| Engine build | josh0408 | MazdaSpeed 3/6 - Big Turbo Builds | 5 | 12-28-2010 07:15 PM |
