  • 1 Post By
 Old 10-29-2012, 02:55 PM   #1
G Sp33dy's Avatar
Posts: 337   (View Stats)
G Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the world
Groaned at 7 Times in 3 Posts
You should be able to be at full boost at 3k with that guy. Maybe 3200.
Yes, but you need to run a restrictor pill in the boost line that feeds the WGA and EBCS. I could mail you my leftover welding tips if you want to try it out. Or make life simple and buy Grimmspeed.
We tried this setup and my stock boost solenoid took a shit for whatever reason once the BNR was on. So in went the Grimmspeed. Hunt the forums you can find one used.
08 MGM::BNR S3:: PG-TR8 FMIC::Autotech HPFP:: Yota Injector Seals:: HTP 3.5":: Grimmspeed ECBS::gutted DP and TP:: FREEKTUNE:: 3bar:: Forge V1:: Koni yellows and corksport springs::: TB & IM thermal gaskets:: CNT cat back:DM 6k:: 30% tint:: shaved doors:: RPF1 17x8:: MD OCC::
'99 XJ, 3.5" lift, ARB front bumper, magnaflow exhaust on 31's
G Sp33dy is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/going-bnr-stage-3-a-126872/
porting du turbo oem - Mazda 3 Quebec This thread Refback 01-24-2013 03:28 PM
Interesting look at Stage 1 + SF vs. Stage 1 + MSCAI2 maps, similarities and differences bast525
Cobb ATR Support
4 05-24-2009 07:52 PM
Page generated in 0.24319 seconds with 22 queries
