  • 1 Post By leon78
 Old 04-19-2012, 04:22 PM   #1
Bratschist's Avatar
Posts: 79   (View Stats)
Bratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud of
Default GT30 or GT35 and why?
Well, I searched in the forum but could not find anything that could directly answer this, only what people have done.
My main concern is: I want to upgrade my car. I definitely want my car to pack quite a bit of hp and be faster. So slowly I have been improving things whenever and wherever I can. Intake, FMIC, Exhaust, AP. Everything I can do I will (money allowing). But I finally started looking into a turbo upgrade and what I found out was that just like a restaurant you have never been to, there are too many options on the menu, if you know what I mean. gt28, gt3071, gt3076, gt35, aerocharger, and the list goes...
The much I have researched, I have narrowed down quite a bit my options:
I do not want a gt28 because I feel that the improvement can be better.
I do not want an "upgraded k04" as I have seen.
I would DIE to have an aerocharger, but the price is just too much.
so, it came down to basically three options: gt 3071, 76 and gt35
now here is where I believe I start to go wrong and need help
if the difference between gt3071 and gt3076 is so small that the change is only the last 2 digits, then its better to get the 71 just because I would be saving about 200 bucks. However, if I upgrade to the gt30 (either one) I will know that there is another one (gt35).
I also understand that the power curve is very different between those two (gt30 and gt35) so we can skip that topic so we can narrow our discussion.
I know my thoughts are kind of all over the place, but just bear with me a little and it might make sense at the end.
So, continuing, lets say (for the sake of the argument) that the upgrading scale is:
k04 = stock
gt28 = stage 1
gt3071 = stage 2
gt3076 = stage 2+
gt35 = stage 3
Which is my understanding, so if I buy stage 2, how far off stage 3 am I?
In other words, how different is gt30 to gt35?
I am asking all this because I don't to upgrade the turbo twice, from k04 to gt30 then gt35 if I can go straight to gt35.
any help is very welcome. if you also know about other places where I can read about the difference other than the seller, then post a link. I am not lazy to read, so I will also appreciate it.
thanks in advance
Upgrades so far:
  1. Window Tint 20%
  2. Ipod Integration
  3. CorkSport LED light kit
  4. TWM Performance Shifter
  5. SLS Test Pipe
  6. CorkSport FMIC and SR air intake
  7. SURE Motorsport Torq R6
  8. AccessPort Stage 2+ Map
  9. QTP Electronic Exhaust Cut-Out
  10. KMD HPFP Internals Upgrade
  11. CorkSport Downpipe
Bratschist is offline   Reply With Quote
The Following 6 Users Say NO Thank You to Bratschist For This Un-useful Post:
adlpb (04-20-2012), Bucker (04-19-2012), captain slow (04-20-2012), CCC (04-28-2012), Downmented (04-19-2012), Jonny Quest (04-27-2012)
 Old 04-19-2012, 04:41 PM   #2
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
FUCK YES IM THE FIRST
 Old 04-19-2012, 04:43 PM   #3
Police - Grammarhead
Vansquish's Avatar
I am the deuce.
@Bratschist, I believe this topic has been beaten to death in various parts of the forum. You can probably find the info you're looking for if you spend a bit of time/effort searching for it. You've also neglected the GTX series in your calculus.
JasonMzdSpd3 (04-20-2012)
 Old 04-19-2012, 04:43 PM   #4
Eric28243's Avatar
Posts: 554   (View Stats)
Eric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the world
SECKEND ON CAPS ROCK FRUSTDAY!
...NOOOOOOOOOO
'08 Polar White Saturn SKY Redline - "The RAWRmobile"
BorgWarner EFR 6758 + IWG Mani, forge v2 BPV, Energy Full Suspension Bushings, GMPP 3-Bars, Vibrant Racing Catted HiFlow Downpipe, WERKS Boost Tubes, Intake, Power-Steering Relocation Kit, Radiator Hoses, and Race FMIC, Koni Yellows + Eibach Pro-Kit's, RPi GT CBE, HP Tuner SquishyTooned on E40, RK Sport Rotors/Pads, DDMWorks 2-gauge Pillarpod and Armrest, Prosport HALO Electronic Wideband and Boost Gauges, Spec Stage 2+ Clutch + Fidanza Single-Mass FryWhee, XTUNERS Gauge Cluster, GM Roadster.com HID/LED Full Exterior and Interior Light Conversion
Dyno: Uhh... fast as hell?
'08.0 Cosmic Blue MS3 - "The Daily" STOCKED OUT (almost)
COBB SRI/TIP - COBB AP SquishyTooned on E40 - COBB XLE BPV - HKS Hi-Power CBE - ITV22s - Corksport RMM Inserts - JBR Shifter Bushings and SSP - PTP Fuel Pump - PG + Treadstone - 35% Tint - ebaY Double-Penetrator - MS3 Vent Kit Install
Dyno: 319 / 331
CWP_MS3 is my mackdaddy
Eric28243 is offline   Reply With Quote
 Old 04-19-2012, 04:44 PM   #5
2zz mr-s
dooderek's Avatar
Groans: 239
OK BRO, ILL ANSWER YOUR QUESTIONS TOMORROW. IM TOO RAGED TO GIVE A COHERENT RESPONSE
The Following User Says Thank You to dooderek For This Useful Post:
 Old 04-19-2012, 04:50 PM   #6
m4tic's Avatar
Posts: 4,928   (View Stats)
do you want to enjoy daily/street driving? Upgraded k04, BNR S3, GT/X28 or even gtx3071
Do you think you'll be stretching her legs a bit? GT/X307x
you want to be a highway warrior? GT35 GT40
There are several other turbocharger makes that you may be interested in. But if you want 0 fab work, drop in parts; you have Garrett turbos and upgraded K04.
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
Juyoung (02-16-2013)
 Old 04-19-2012, 04:55 PM   #7
Mchart's Avatar
Posts: 980   (View Stats)
Mchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the world
Groans: 54
Groaned at 42 Times in 32 Posts
Get one of those bigass ship turbo's and mount it in the rear hatch/trunk area.
Mods - Six (6) Kenny Loggins albums in each position in my 6 disc changer.
HOW-TO Tune a car - http://youtu.be/5ET9YXP1M04
Mchart is offline   Reply With Quote
The Following 2 Users Say Thank You to Mchart For This Useful Post:
duappleganger (04-20-2012), JasonMzdSpd3 (04-20-2012)
 Old 04-19-2012, 04:57 PM   #8
Black Metal's Avatar
Posts: 699   (View Stats)
Black Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the world
Groans: 78
GO BIGGER
- 2006 Black Mica MS6 -
- GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP -
- Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught -
- GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete -
12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30
12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20
- 2004 Silver Sunlight Metallic RX-8 -
- 6MT - Stock -
Black Metal is offline   Reply With Quote
 Old 04-19-2012, 05:00 PM   #9
Mchart's Avatar
Groans: 54
It should fit.
The Following 3 Users Say Thank You to Mchart For This Useful Post:
Black Metal (04-19-2012), Juyoung (02-16-2013), Raider (04-20-2012)
 Old 04-19-2012, 07:37 PM   #10
Bratschist's Avatar
I get it, not many people like talking about stuff that has been beaten to death, the thing is, I DID look/search and put an effort, but the information is always scattered all over and it would be nice if someone could compile them in a more concise tread where you don't have to read a bunch of unrelated posts. just like I'm trying to do. What I am also trying to do is to get the best posts I find elsewhere and bring to this tread, but my plan might be going down from the beginning with some unrelated posts. But thanks anyways for the help
Upgrades so far:
  1. Window Tint 20%
  2. Ipod Integration
  5. SLS Test Pipe
 Old 04-19-2012, 07:40 PM   #11
2zz mr-s
dooderek's Avatar
Groans: 239
BRO, PM ME TOMORROW WHEN IM NOT RAGING. ILL GIVE YOU A GOOD BREAK DOWN
 Old 04-19-2012, 07:44 PM   #12
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
In a nutshell your HP goal determines what turbo you want. 300~400+= gtx28, 400~475+ gtx3071, 400~550+ gtx3076, 400~600+ gtx35.
READ:
http://www.turbobygarrett.com/turbob...Tech%20101.pdf
http://www.turbobygarrett.com/turbob...Tech%20102.pdf
http://www.turbobygarrett.com/turbob...Tech%20103.pdf
They will help you understand the differences between the garrett turbo's you mention, and why you would choose on over the other...
The Following 4 Users Say Thank You to SSinstaller For This Useful Post:
802MS3 (04-20-2012), best_predator (12-22-2012), Bratschist (04-20-2012), SLOWHATCH (04-20-2012)
 Old 04-19-2012, 07:46 PM   #13
Bratschist's Avatar
thanks a lot, but i'm not allowed to PM yet. Don't have enough posts. Also, I want to help other people by doing this so they dont have to go through what i'm going and search and read a bunch of BS and get frustrated until they get some good enough info, if you know what I'm saying...
Upgrades so far:
  1. Window Tint 20%
  2. Ipod Integration
  5. SLS Test Pipe
 Old 04-20-2012, 01:54 AM   #14
leon78's Avatar
Posts: 2,595   (View Stats)
http://www.mazdaspeedforum.org/forum/foru...al-way-111319/
@eric@edgeautosport just made this....read...and read MOAR!
JasonMzdSpd3 likes this.
2013 Scion FR-S (Whiteout)
Less parking more racing
The Following 3 Users Say Thank You to leon78 For This Useful Post:
EdgeAutosport.com (04-20-2012), JasonMzdSpd3 (04-20-2012), SLOWHATCH (04-20-2012)
 Old 04-20-2012, 11:54 AM   #15
shadesofgray19's Avatar
Posts: 794   (View Stats)
He's never expressed what his goals are, how much horsepower and how he intends to drive the car. The GTX2867 looks to be a fun DD turbo that flows like a GT30 turbo and capable of almost 400 whp. The GTX3071 seems to be very popular for good reasons as he the OP can find in numerous threads. I think it is a sign that not many people that have a MS3 are doing GT35 turbos which I believe is spool and traction. I just don't think it is the right setup for fwd.
These suggestions would be completely different for the MS6 due to AWD to put power to the ground, weight, and drivetrain loss.
The Following User Says Thank You to shadesofgray19 For This Useful Post:
 Old 04-20-2012, 11:59 AM   #16
2zz mr-s
dooderek's Avatar
Groans: 239
get a gtx3076. i have a precision 6031 with 61 lbs flow per min. car is fun but i gotta drive smarter because i dont have full spol till 4300 rpms. i like the gtx's since they offer power with fast response for their size
i wouldnt even consider these stages because your giving up spool and response for top end power
 Old 04-20-2012, 12:08 PM   #17
ricknm's Avatar
Posts: 1,102   (View Stats)
ricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the world
I'll admit too. searching on this forum is not the easiest to find your info. You're better off googleing mazdaspeedforums followed by your question. thats worked for me several times.
BNR s3 w/ some other stuff. Hypnotic tuned.
ricknm is offline   Reply With Quote
The Following 2 Users Say Thank You to ricknm For This Useful Post:
 Old 04-20-2012, 12:49 PM   #18
Us the google tab on our search bar here it works like a champ
JasonMzdSpd3 (04-20-2012), Juyoung (02-16-2013), uncorked11 (04-20-2012)
 Old 04-20-2012, 12:51 PM   #19
ricknm's Avatar
either or im sure work just fine
The Following User Says Thank You to ricknm For This Useful Post:
 Old 04-20-2012, 02:00 PM   #20
Bratschist's Avatar
thanks all for participating. In another forum a user posted about a twin scroll GT3076. Any thoughts on that? Also, does anyone else know about the Aerochargers?
Upgrades so far:
  1. Window Tint 20%
  2. Ipod Integration
  5. SLS Test Pipe
 Old 04-20-2012, 02:06 PM   #21
2zz mr-s
dooderek's Avatar
Groans: 239
is that a mazdaspeed flange?
 Old 04-20-2012, 02:09 PM   #22
looks like a 4 bolt discharge so im guessing not
 Old 04-20-2012, 02:10 PM   #23
Bratschist's Avatar
no, they don't make the AC with specific setting, you would have to buy a new header. which is a down side
and most likely a custom DP too
Upgrades so far:
  1. Window Tint 20%
  2. Ipod Integration
  5. SLS Test Pipe
Last edited by Bratschist; 04-20-2012 at 02:10 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-20-2012, 02:11 PM   #24
same with a twin scroll gtx30r
 Old 04-20-2012, 02:21 PM   #25
2zz mr-s
dooderek's Avatar
Groans: 239
the inlet looks offset like a mspeed
 Old 04-20-2012, 02:55 PM   #26
Unless you add additional injectors, there's no point in getting anything bigger than a GT30 series.
anavrinIV (04-20-2012), EdgeAutosport.com (04-20-2012), Juyoung (02-16-2013), Scribbles (04-20-2012), SLOWHATCH (04-20-2012), uncorked11 (04-20-2012)
 Old 04-20-2012, 04:47 PM   #27
uncorked11's Avatar
Posts: 1,238   (View Stats)
Groans: 165
I can tell you I like my GTX3071R. The down side is the internal waste gate is shit. With that being said in my very limited opinion with 100 miles daily driven I believe it will be the perfect turbo for this car when external wastegate gets mounted. Keep in mind I do not carry the weight of knowledge that many others have on this site but I know what I read and I know what I have delt with with the ATP turbo. I can say I would not change my choice in turbo other then EWG from the start.
New....Camaro SS/RS
Stocked out selling parts.
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
The Following 2 Users Say Thank You to uncorked11 For This Useful Post:
EdgeAutosport.com (04-20-2012), SLOWHATCH (04-20-2012)
 Old 04-20-2012, 05:41 PM   #28
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
did you port the exh housing at all?
'08 CWP MS3 w/ T3 3071r
 Old 04-20-2012, 07:33 PM   #29
uncorked11's Avatar
Groans: 165
No I was under the understanding that the creap issue was fixed before I installed. at this point I am 1. to lazy to take the turbo out, port then re-install and then be pissed again if the issue remains. 2. I wanted EWG in the first place but failed on intelligent basic finance.
New....Camaro SS/RS
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
 Old 04-27-2012, 04:55 AM   #30
Jonny Quest's Avatar
Posts: 365   (View Stats)
Jonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the world
Groans: 43
Groaned at 111 Times in 19 Posts
This is what im going with. i have to mount it on my roof and use a really fine chicken wire covered with a sheet as an intake but it should work.
Jonny Quest is offline   Reply With Quote
 Old 04-27-2012, 05:04 AM   #31
Groans: 43
GTX3076R all the way
Thsi is what happens when you hit 25psi on a gt30 and get traction dturboman Mazdaspeed3/6 General Discussion 34 02-23-2012 07:43 PM
GT35 opinion essejkcamraw MazdaSpeed 3/6 - Turbo Induction 56 11-15-2010 06:15 PM
Page generated in 0.50920 seconds with 35 queries
