 Old 08-27-2014, 01:32 PM   #1
slvrbullet's Avatar
Posts: 7   (View Stats)
slvrbullet will become famous soon enough
Default GT3071r complete build
I'm in the process of a complete rebuild with a turbo upgrade and I just want to make sure I don't miss anything along the way or that you may have some further recommendations to what I've done so far.
This is what I have so far:
Stock bore with CP-E stage2 pistons
Manley H-beam rods
Balance Shaft Delete and Oil pan baffle
Cometic head gasket
Autotech Fuel pump internals upgrade
Cobb AccessPort v3
Garrett GT3071R turbo
TurboSmart bypass vavle
Fujita Cold air intake
My questions:
I kind of came across this turbo for dirt cheap and figured why not go big. I'm assuming I will be doing the whole exhaust from the downpipe back by adding the bigger turbo? Any other things I should know about with this turbo addition? I've read up on the lines and some fitment issues. Whats the difference with the internal wastegate and external? Is one better than the other?
Would you recommend the PCV plate and EGR delete kit?
Breaking in the new engine once it is all back together and ready to move any recommendations? What oil to use in it during this process and after?
Tuning the engine and Cobb. It seems I have seen freektune on a lot of the threads and am leaning in that direction. Any advice how I should have the engine tuned since this will be a complete new set up? Or is that a question I would ask them directly when I'm at that point?
Hopefully I can get this thing back together and on the streets soon! If you guys want to see any build pictures please let me know I'm just waiting on getting the long-block back so I can install everything else.
slvrbullet is offline   Reply With Quote
 Old 08-27-2014, 01:52 PM   #2
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
You'll want to swap out that Fujita with a bigger intake. Go with the something bigger like HTP or JBR
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
 Old 08-27-2014, 01:55 PM   #3
Voltwings's Avatar
Posts: 3,713   (View Stats)
Yikes... you have got a LOT of reading to do. There are a lot of build threads in the big turbo sections already. I suggest you start there and see what problems / solutions people have run into already and all of your questions will be answered.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
jdmage_mx5 (08-27-2014)
 Old 08-27-2014, 09:35 PM   #4
Bulgsta's Avatar
Posts: 120   (View Stats)
Bulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond repute
I would recommend doing:
- ebay downpipe ($140)
- a catback
- 3 port ebcs
- bosch 3 bar map sensor
- an upgraded intercooler. Front mount preferred
and definitly no fujita. HTP is the way to go
as for the wastegate, EWG is always preferred.
And read up on the stickies and people's builds. Definitely gives you an idea of what you are about to tackle.
2007 Mazdaspeed 6
GTX3076 - CPE- EX-mani w/ 44mm EWG - CPE Safe Seals - COBB APv3 - COBB Shifter Weight - DO Stage 2 Meth - PnP Intake Mani - Catless TBE - Corksport FMIC - Corksport Rear Diff Mount - Corksport OCC - AWR RRM, TMM, PMM - TT Front Engine Mount - TT Front Diff Mount - HTP 3.5 " - GFB 50/50 - AT internals - GrimSpeed ECBS - 3 Bar Map - Perm PCV plate - JBR BSD w/ baffle - JBR TIGS - Sure Shortcut - Tower Strut Bar - EGR Delete - EGR Valve Deleted - Shifter Bushings - H&R Springs - Koni Yellow Shocks - Stoptech D&S rotors - EBC Pads - Stainless Steel Brake Lines - Denso ITV 22 - Whiteline RSB - Guardian Angel
Bulgsta is offline   Reply With Quote
 Old 08-27-2014, 09:45 PM   #5
jvms3's Avatar
Posts: 61   (View Stats)
jvms3 is a glorious beacon of lightjvms3 is a glorious beacon of lightjvms3 is a glorious beacon of lightjvms3 is a glorious beacon of lightjvms3 is a glorious beacon of lightjvms3 is a glorious beacon of light
Yea Def bigger intake ,3bar etc and lines such as oil return line and stuff. Stock k04 one won't fit lol I jumped into my bt build quick with just a turbo and some stuff and I got beat and realized I missed alot cause I didn't read lol
building motor, 3071gtx,cp-3 tbe,cpe 3.5 full intake , 3bar map , cp-e front mount, cp-3 hpfp
Pnp im, Tial 38mmewg, JBR rear sway bar, BC Racing extreme drop coils, Spc camber arms, Ugly garage door lip for now lol, xxr 527s,FreekTune!
jvms3 is offline   Reply With Quote
 Old 08-27-2014, 10:02 PM   #6
jvms3's Avatar
I'm outta the country for work and got the slightest bit of wife when I come back I can PM you a little list I made after I learned what I forgot when I did my big turbo
My sig isn't realy up to date so not all of it is in there lol
Last edited by jvms3; 08-27-2014 at 10:02 PM. Reason: MSF Database - Automerged Doublepost
GT3071R EWG build Goodrich27 2010 MS3 - Big Turbo Builds 26 07-20-2014 03:15 PM
GT3071R MS6 Daily Driver Build JDMCRX MazdaSpeed 3/6 - Big Turbo Builds 5 06-18-2014 07:29 AM
GT3071r Build Problems 48-f1 MazdaSpeed 3/6 - Big Turbo Builds 49 05-21-2012 04:22 PM
Genpu GT3071R Build w/ videos and dyno sheet JP@edgeautosport.com 2010 MS3 - Big Turbo Builds 212 03-21-2012 02:03 AM
Page generated in 0.26553 seconds with 24 queries
