 Old 03-06-2012, 12:11 AM   #1
mtnrunner's Avatar
Posts: 864   (View Stats)
mtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the world
ATP states to run the line from as close to the turbo as possible so do do that you have to buy a boost a tap and drill a hole in a coupler then put the boost source there. i personally would just run off a boost source like your bpv line and run the vacuum line from there, it will work fine.
Murdered out 2007 speed3 GT with navi.
mtnrunner is offline   Reply With Quote
done! gt3076 samsel450r MazdaSpeed 6 - Engine, Transmission & Driveline 122 11-09-2009 04:35 PM
GT3076 owners please help 18psiWhiteMS3 MazdaSpeed 3/6 - Turbo Induction 5 10-22-2009 09:37 AM
Page generated in 0.23097 seconds with 21 queries
