  • 1 Post By RichieRichness
  • 1 Post By MS3 Ventura
 Old 03-26-2013, 10:43 PM   #1
MS3 Ventura's Avatar
Posts: 172   (View Stats)
MS3 Ventura has a brilliant futureMS3 Ventura has a brilliant futureMS3 Ventura has a brilliant futureMS3 Ventura has a brilliant futureMS3 Ventura has a brilliant futureMS3 Ventura has a brilliant futureMS3 Ventura has a brilliant futureMS3 Ventura has a brilliant futureMS3 Ventura has a brilliant futureMS3 Ventura has a brilliant futureMS3 Ventura has a brilliant future
Default GTX3071R boost creep/boost spike! Need help!
Installed a GTX3071R w/internal WG and 14psi spring. First got boost creep, because I didn't port it I assume. So, I ported it. I followed the various posts for porting and thought that I had it pretty close. Then...
Using a COBB EBCS, I now have a huge boost spike of 25-26psi by 4.5K rpm (target is ~21psi).
Unplugged the EBCS and connected the WG to the boost pressure on the charged side, about 6" after the turbo outlet. Under WOT got boost climbing to 22psi around 6K rpm. Seems like I didn't port enough and/or have some mechanical problem.
Then I took the WG actuator arm off of the WG flapper. Under WOT the boost eventually climbs to 18-19psi by 6K rpm. Not sure what to expect when the flapper is wide open after porting.
I'd appreciate any ideas / help. Thanks
MS3 Ventura is offline   Reply With Quote
 Old 03-27-2013, 05:12 PM   #2
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
get a catted dp for creep.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following 2 Users Say Thank You to 86AmishMs3 For This Useful Post:
atvfreek (03-28-2013), MS3 Ventura (03-27-2013)
 Old 03-27-2013, 05:37 PM   #3
Vader's Avatar
Posts: 1,651   (View Stats)
Vader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the worldVader is the leader of the world
Groans: 45
Sounds like what mine was doing. Sounds like the way it is reacting on spring pressure is normal, from what I've read/seen.
Do you have an MBC? If so, try it instead of the ECBS to start.
Link - http://www.mazdaspeedforum.org/forum/foru...ml#post1216204
Originally Posted by mikelevi View Post
...When you have 600 lbs of faggot in your car, you are much slower than someone with 10 lbs of dick.
Vader is offline   Reply With Quote
The Following User Says Thank You to Vader For This Useful Post:
 Old 03-27-2013, 08:13 PM   #4
Thanks 86. I have a CPE DP with a hi-flow cat. I guess it's not enough to control it.
Thanks Vader. Any recommendations for a good MBC? I'm now using the COBB EBCS so I'll switch over to the MBC and see how it goes.
Last edited by MS3 Ventura; 03-27-2013 at 08:13 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-27-2013, 08:16 PM   #5
Voltwings's Avatar
Posts: 3,713   (View Stats)
large intakes will also cause "creep." When i had my 3071 IWG with an 8 psi spring and installed my 4" intake i would see a steady 10 psi from it.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
MS3 Ventura (03-27-2013), RichieRichness (04-01-2013)
 Old 03-27-2013, 08:32 PM   #6
I'm using an Aeros 3.25" MAF (full 3") intake, so I must be experiencing some creep from that too.
The Following User Says Thank You to MS3 Ventura For This Useful Post:
WhiteWidow (03-29-2013)
 Old 03-27-2013, 08:39 PM   #7
Voltwings's Avatar
mmm i wouldnt expect that frm a 3" as thats pretty standard size for BT, its typically 3.5" +
Past:
-Sold-
-Sold-
Current:
 Old 03-27-2013, 10:13 PM   #8
86AmishMs3's Avatar
Groans: 338
post logs
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 03-27-2013, 10:22 PM   #9
post logs
Here's one I just did running off of spring pressure only (no MBCS).
 Old 03-27-2013, 10:25 PM   #10
Here's another log using my EBCS (4th gear). My previous logs were in 3rd.
I also attached porting photos.
File Type: xlsx 4th gear WOT after port turbo 3-24-13 run1.xlsx (14.9 KB, 9 views)
 Old 03-28-2013, 08:54 AM   #11
86AmishMs3's Avatar
Groans: 338
Ok so have you just tried spring pressure and see what happens...ie no boost control. boost source directly to wastegate.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 03-28-2013, 11:04 AM   #12
@RichieRichness;
 Old 03-28-2013, 10:27 PM   #13
WhiteWidow's Avatar
Posts: 44   (View Stats)
WhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud ofWhiteWidow has much to be proud of
Groaned at 5 Times in 2 Posts
I know this doesn't prolly help but my boost spikes are from my clutch being too weak to handle the power! I have a new one to install now. It's only if I go over 17 PSI on my gtx3071.
WhiteWidow is offline   Reply With Quote
 Old 03-28-2013, 11:10 PM   #14
Yup did that yesterday (post and log are above).
I already have an upgraded clutch/pressure plate. It's definitely not the clutch slipping.
Last edited by MS3 Ventura; 03-28-2013 at 11:10 PM. Reason: MSF Database - Automerged Doublepost
speed312 (04-17-2014)
 Old 03-28-2013, 11:24 PM   #15
86AmishMs3's Avatar
Groans: 338
damn nucka....loosen the preload a lot and start there.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
The Following 3 Users Say Thank You to 86AmishMs3 For This Useful Post:
RichieRichness (04-01-2013), WhiteWidow (03-29-2013), xhymer (04-07-2013)
 Old 03-29-2013, 04:39 PM   #16
Navy_Mech2's Avatar
Posts: 484   (View Stats)
Navy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the world
Could be that you have too small of a waste gate to run that low boost. My s259 will creep from 14 to 18 on spring pressure but with the wastegate at 1% I hit 23 which was what fuel cut was at and I bent a rod. I have a 40mm WG by the way
Sent by my thumbs
06 MS6 |SP Built motor - Weisco Pistons .020" over, Manley H-Beam Rods, Ported Head, Ported Intake, VTCS Delete, BS Delete, VVT Actuator, Keyed Crank, 6th Port Fuel Injection | ACT 6 Puck w/ Streetlite Flywheel | Bullseye S259 .70 A/R Single Scroll | 3.5" Intake/MAF Housing | Steedspeed Twin Scroll T3 Top Mount Manifold | Tubosmart 40mm EWG | Custom DP | Custom TBE | Custom LTA Intercooler | HKS Type IV TT | Dashhawk | COBB AP | AWR RMM | PTP HPFP Guts |
KILLAH BUILT
Navy_Mech2 is offline   Reply With Quote
The Following User Says Thank You to Navy_Mech2 For This Useful Post:
MS3 Ventura (04-07-2013)
 Old 03-29-2013, 05:38 PM   #17
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Yeah that throat is not ported nearly enough,
You also get less boost spikes if you port the throat of the turbo, not just the hole for the wastegate. You need to port the throat deeper at the point where the lower lip on the inner scroll ends and around it. I.e increase the ID of the smallest ID part of the housing. That's the only way you re going to get the ATP housing not to spike. Not only that but you won't be able to run more than 25 psi at 6K with the throat as is due to turbo/ exhaust choke. Even with a 21 psi spring.
MS3 Ventura (04-07-2013), RichieRichness (04-01-2013)
 Old 04-01-2013, 10:50 AM   #18
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
I didn't really see a spike in your logs....but more of creep. If you have too much pre-load you will see a quick spike then boost will settle back down.
however,
I would reduce pre-load first like what @86azms3; suggested.
If that doesn't help then you prob need to do more porting.
deadlandxtreme likes this.
RichieRichness is offline   Reply With Quote
The Following User Says Thank You to RichieRichness For This Useful Post:
deadlandxtreme (04-01-2013)
 Old 04-07-2013, 10:03 PM   #19
Yeah tried it and got same over boost. Will definitely be porting again.
Thanks I'm going to port it again this coming weekend and I'll do my best to open it up as much as possible.
Last edited by MS3 Ventura; 04-07-2013 at 10:03 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-11-2013, 11:18 AM   #20
Problem solved! Opened up wastegate hole such that it had 0.050" - 0.070" overlap with the flapper. Now holding boost steady at 20 psi or higher boost targets.
WhiteWidow likes this.
The Following 3 Users Say Thank You to MS3 Ventura For This Useful Post:
RichieRichness (05-14-2013), Speed_j23 (05-11-2013), Vader (05-11-2013)
 Old 05-11-2013, 11:44 AM   #21
Close the throttle plate on it.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/gtx3071r-boost-creep-boost-spike-need-help-141367/
VersaTune - View topic - ATP GTX3071r Turbos This thread Refback 10-09-2015 05:06 AM
VersaTune ? View topic - ATP GTX3071r Turbos This thread Refback 05-12-2013 04:57 AM
Boost Creep? Silver Ecstasy MazdaSpeed 3 - Engine, Transmission & Driveline 17 02-14-2012 04:28 PM
Boost creep 86AmishMs3 MazdaSpeed 3/6 - ECU Computer Tuning 11 12-21-2011 05:30 PM
Boost creep? psmith22 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 07-24-2011 11:47 PM
Boost creep? DubVms3 MazdaSpeed 3/6 - Turbo Induction 4 03-11-2011 04:12 AM
Boost Creep RocketScientist MazdaSpeed 3/6 - Turbo Induction 3 08-02-2010 11:13 AM
Page generated in 0.41014 seconds with 30 queries
