Like Tree11Likes
 Old 01-29-2016, 08:26 AM   #41
Posts: 2,235   (View Stats)
are your planning to replace the 0-20psi for a 0-30 ?
JMEngineer (02-04-2016)
 Old 02-03-2016, 01:02 PM   #42
JMEngineer's Avatar
Posts: 2,122   (View Stats)
JMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the world
Groans: 32
Groaned at 19 Times in 15 Posts
maybe... I still have a few things to sort out before the real tuning starts. Right now it makes decent power with a lot of boost but the AFR's and timing are very conservative.
With a few degrees of timing I'll probably have to turn down the boost to avoid knock. It's my DD so I'm not planning to run any meth or E. If it still hits 30psi with no knock then I'll probably upgrade the gauge.
2006 MS6 GT - Built engine, twin scroll GT3076R, dual MV-S wastegates dumped to atmosphere, TR1035 FMIC, too many parts to list...
2009 MS3 GT - Built engine, JBR intake/TIP and short shifter, all engine mounts, Autotech HPFP internals, ETS TMIC, Custom AP tune, Pauter rods, CP pistons, and 6-puck ACT clutch
-GTX2867R Coming Soon
JMEngineer is offline   Reply With Quote
 Old 02-03-2016, 03:39 PM   #43
At first i was like: how can he know it is at 30 when the gauge stop at 20...but then...saw the needle at the beginning but on the wrong side of the stop pin héhé
do you have internal mods to spool that early or it is just because of the twin scroll ? (higher CR, porting etc)
 Old 02-03-2016, 03:46 PM   #44
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
30PSI on pump gas on a 2.3 litre engine may not work. 25-26 though will.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 02-03-2016, 08:48 PM   #45
JMEngineer's Avatar
Groans: 32
JMF intake manifold but no porting and CR was actually lowered to 9.0:1
I estimated it would end up somewhere around 27-28psi at 9.0:1 which is about the same effective CR as 25-26psi and 9.5:1
 Old 02-04-2016, 06:07 PM   #46
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
Steve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the world
I ran 30+ PSI on 93 octane R+M/2 no meth or eth with 9:1 CP pistons. I plan to run more soon.
Steve
Lead Tuner
Steve@VersaTune is offline   Reply With Quote
The Following 2 Users Say Thank You to Steve@VersaTune For This Useful Post:
JMEngineer (02-04-2016), Mauro_Penguin (02-05-2016)
 Old 02-05-2016, 04:22 AM   #47
mituc's Avatar
Groans: 111
I'm just curious, how much timing were you running at, say, 5500, 6000, 6250, 6500 and 6700rpm, assuming that there was no major KR?
 Old 03-03-2016, 10:30 PM   #48
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
@Steve@VersaTune; How's this going? I'm really excited to see how it works for you. I'm curious to see how well such a large AR will spool with twinscroll.
Also, I never realized VT was based out of MI. I'm on the other side of the state from you guys just North of Grand Rapids!
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
MD1032 (03-04-2016)
 Old 03-03-2016, 10:35 PM   #49
Cool, glad to know that the West side is represented here
I've been so damn busy with VT, I have not had any time to work on the car. I need to fix some leaks and move the O2 sensors. It's 99% done.
Mazdazilla6 likes this.
Steve
Lead Tuner
The Following 6 Users Say Thank You to Steve@VersaTune For This Useful Post:
cshunter (03-05-2016), Mauro_Penguin (03-04-2016), Mazdazilla6 (03-03-2016), MD1032 (03-04-2016), SpeedRebirth (03-04-2016), WetzMS3 (03-04-2016)
 Old 03-03-2016, 11:54 PM   #50
Awesome! Hope you get her up to 100% soon.
You should try to make it out the MWM this year! Last year was in IL, but the year before was MI. It's a whole group of a bunch of awesome dudes (and lady dudes) who love hanging out talking about car stuff. They also do some car and non car related stuff too.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 03-28-2017, 02:06 PM   #51
Anything new?
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 03-28-2017, 02:07 PM   #52
Looking for a fab shop in Detroit that actually wants work. None have returned my calls.
Can't get anyone to redo the DP and WG pipes.
Steve
Lead Tuner
 Old 03-29-2017, 07:43 AM   #53
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
Not sure how I missed that you're doing this. Definitely going to bug you about this at some point.
It seems top mount might not be worth it? That hotside looks real close to the shroud in your pictures, so may not have much room to grow bigger.
-Wetz
QFT
 Old 03-29-2017, 01:42 PM   #54
If you'd like I can ask the welders at my work if they'd be interested. Are you looking to get them completely remade or modified to fit?
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 03-29-2017, 01:45 PM   #55
The WG pipes need flex bellows added, and one of the WG pipes hits the firewall when the engine rocks under torque. I'm looking for a full service shop to just make it work. I don't have time to deal with it. The car has been sitting for over 2 years.
Steve
Lead Tuner
The Following User Says Thank You to Steve@VersaTune For This Useful Post:
impossible (05-29-2017)
 Old 01-23-2018, 08:27 AM   #56
It's ALIVE!!!!!
The intake piping needs to be redone with prettier custom bent pipe, but it runs now.
Useful boost starts around 3200-3300. Pulling hard by 3500. I'm still on WG spring pressure of 20 PSI. BCS will be attached soon for 35 PSI.
Code Monkey likes this.
Steve
Lead Tuner
The Following 4 Users Say Thank You to Steve@VersaTune For This Useful Post:
Code Monkey (01-23-2018), mituc (01-23-2018), Pu Manchu (01-24-2018), Yatta (01-23-2018)
 Old 01-23-2018, 08:47 AM   #57
mituc's Avatar
Groans: 111
It's ALIVE!!!!!
Factory Intake manifold? Is VCTS still on?
 Old 01-23-2018, 08:48 AM   #58
Yes, and yes.
Steve
Lead Tuner
mituc (01-23-2018)
 Old 01-23-2018, 11:15 AM   #59
mituc's Avatar
Groans: 111
Well, at 30-31PSI I'm flowing about 435/440 pump gas g/s through the OEM mani with the VCTS on, so if you plan to leave that on and boost up to 35PSI with that huge turbo and flanges this setup should be good for quite a lot of power.
 Old 01-23-2018, 12:05 PM   #60
So far, transient response is really good. It doesn't drive like a big turbo.
Sent from my SM-G935V using Tapatalk
mituc and Db09ms3 like this.
Steve
Lead Tuner
Oil prices headed up or down? Experts divided Haltech Automotive News 0 05-11-2015 08:50 AM
Stage 2 Topmount logs Speeed3 MazdaSpeed 3/6 - ECU Computer Tuning 59 11-10-2011 12:05 PM
Page generated in 0.41978 seconds with 26 queries
