Like Tree11Likes
 Old 07-01-2015, 09:35 PM   #1
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
Steve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the world
Default GTX3076R T4 Divided 1.06 Topmount
Like the title says. GTX3076R T4 divided 1.06AR topmount.
It's going into my MS6.
AFI T4 divided topmount manifold - ceramic coated and wrapped
Dual Tial 38mm MV-S wastegates
ATP T4 divided 1.06 AR housing ceramic coated and blanket
Garrett GTX3076R w/ Snail Turbo billet compressor wheel (original ingested debris)
Carrillo rods/bolts
CP 9:1 Pistons
ARP main and head studs
Ported head
Port matched stock intake w/ VTCS intact
The goal is to see how much area under the curve can be obtained without supplemental fuel.
Then the baby turbo goes buh-bye and we get serious w/ some new fueling solutions.
As you can see from the pic, it's almost ready to go in.
Code Monkey and Biglegg like this.
Steve
Lead Tuner
Steve@VersaTune is offline   Reply With Quote
The Following 13 Users Say Thank You to Steve@VersaTune For This Useful Post:
BrianB6 (07-05-2015), Code Monkey (07-01-2015), Dralphy (07-23-2015), fivefingerdeathpunch (07-02-2015), Mauro_Penguin (07-05-2015), mazdaspeeding (07-01-2015), MD1032 (03-04-2016), mituc (01-10-2016), phate (07-01-2015), SpeedRebirth (07-05-2015), theschrum (07-05-2015), Tokay444 (07-05-2015), WetzMS3 (07-02-2015)
 Old 07-02-2015, 05:29 AM   #2
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
Port matched with VTCS still in it? Seems kinda odd. Is there just a lot of space around the flappers now?
 Old 07-02-2015, 06:37 AM   #3
I didn't go deep into the runners. I just flared the opening from the flaps out to the flange to smooth the transition.
Steve
Lead Tuner
The Following User Says Thank You to Steve@VersaTune For This Useful Post:
Easter Bunny (01-06-2016)
 Old 07-02-2015, 08:27 AM   #4
maisonvi's Avatar
Groans: 75
Any reason why? Just to keep cold start not terrible? Seems like it would be quite a restriction on the rest of the system. Especially with a ported head you should have awesome flow.
 Old 07-02-2015, 08:39 AM   #5
Trying to keep low end torque for early spool. I'm going for max area under the curve for this phase. I will put a new intake on when I swap the turbo.
Steve
Lead Tuner
 Old 07-05-2015, 01:48 AM   #6
MSP611's Avatar
Posts: 2,291   (View Stats)
Thts quite a big hotside if Ur looking for spool
In progress:
 Old 07-05-2015, 07:02 AM   #7
I'm trying to see if all of the insulation on the exhaust manifold and housing can make up for it. I may swap out the housing.
Steve
Lead Tuner
 Old 07-05-2015, 07:19 AM   #8
cam1391's Avatar
Posts: 326   (View Stats)
Im so confused. It seems like trying to make a spoon a fork it your goal.
The Following 2 Users Say Thank You to cam1391 For This Useful Post:
Easter Bunny (01-06-2016), impossible (05-29-2017)
 Old 07-05-2015, 07:40 AM   #9
MSP611's Avatar
Ummm I'm pretty sure insulation on Ur exhaust mani. Isn't going to make up for Ur spool
In progress:
 Old 07-05-2015, 07:49 AM   #10
I plan on testing different parts. That's what this car is for. T4 hotside selection is limited. I plan to make some big numbers later on. I didn't want to have to swap the manifold. I wish there was a true twin scroll t4 like the EFRs have. I may switch to an EFR when I'm ready to go big.
Steve
Lead Tuner
 Old 07-05-2015, 07:59 AM   #11
Mauro_Penguin's Avatar
Posts: 1,997   (View Stats)
Groans: 171
Tell me more about this twin scroll manifold your using.
 Old 07-05-2015, 08:13 AM   #12
theschrum's Avatar
Posts: 1,031   (View Stats)
theschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the worldtheschrum is the leader of the world
When going twin scroll, you can't really compare the a/r of the turbine housing to what you would go with single scroll. Spool should come on very quickly with this size turbo and 1.06 hotside.
With my PTE 6262 and a T4 1.06 twin scroll hotside, I hit 23psi on my very first pull at 3240 rpm.
06 Speed 6 GT: True twin scroll T4 PTE Billet 6262, dual MVS, SP 10.6:1 pistons, K1 rods, sleeved block...
08 Speed 3|SOLD
theschrum is offline   Reply With Quote
The Following 6 Users Say Thank You to theschrum For This Useful Post:
802MS3 (07-05-2015), Code Monkey (07-05-2015), Easter Bunny (01-06-2016), fivefingerdeathpunch (01-06-2016), Mauro_Penguin (07-05-2015), WetzMS3 (01-06-2016)
 Old 07-05-2015, 08:16 AM   #13
AFI Turbo Manifold - Mazda Speed 3/6 Topmount - Race only- TREADSTONE PERFORMANCE
Pics of mine with twin EWG:
After ceramic coating:
Mauro_Penguin likes this.
Steve
Lead Tuner
The Following 3 Users Say Thank You to Steve@VersaTune For This Useful Post:
impossible (05-29-2017), Mauro_Penguin (07-05-2015), theschrum (07-05-2015)
 Old 07-05-2015, 08:17 AM   #14
MSP611's Avatar
where did u get a twinscroll housing for a PTE??
NM found AGP turbo carries them... fuck if I would of known I would of got a t3 twinscroll housing and mani... fuck!!
In progress:
The Following User Says Thank You to MSP611 For This Useful Post:
 Old 07-05-2015, 08:21 AM   #15
Yeah. 1.06 isn't as huge as it sounds. I do wish there was a .92 T4 twinscroll option like the EFRs have.
where did u get a twinscroll housing for a PTE?? ive never seen one on any site for sale
ATP. It's listed as GT35, but they have a GT30 option.
Turbine Housing, T4 Divided inlet 3" V-Band outlet, 1.06 A/R for GT3582R/GTX35 : atpturbo.com
Steve
Lead Tuner
Last edited by Steve@VersaTune; 07-05-2015 at 08:21 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-05-2015, 08:31 AM   #16
theschrum's Avatar
Also, not sure if AFI fixed the design, but there will likely be clearance issues for the wg if you are keeping your A/C. And super tight dp fitment.
08 Speed 3|SOLD
The Following 2 Users Say Thank You to theschrum For This Useful Post:
802MS3 (07-05-2015), Mauro_Penguin (07-05-2015)
 Old 07-05-2015, 08:34 AM   #17
MSP611's Avatar
this is on the top mount mani's??
In progress:
 Old 07-05-2015, 08:42 AM   #18
I'm having the DP and WG piping custom fabbed. They can cut and redirect that WG pipe if needed.
After looking at the pics side by side, my WG pipe has a different angle. I'll find out about clearance in a day or two. It's going in this week.
theschrum likes this.
Steve
Lead Tuner
The Following 2 Users Say Thank You to Steve@VersaTune For This Useful Post:
Code Monkey (07-05-2015), Mauro_Penguin (07-05-2015)
 Old 07-05-2015, 09:11 AM   #19
JMEngineer's Avatar
Posts: 2,122   (View Stats)
JMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the world
Groans: 32
Groaned at 19 Times in 15 Posts
I have a topmount 3076 with the .78A/R T3 twin scroll housing; I should have gone with the 1.06.
I had to put a custom spring in my dual port BOV to allow some recirc while cruising to keep it from surging. It's nearly impossible to stay out of boost during normal driving and it hits 32 psi at just over 3000rpm.
2006 MS6 GT - Built engine, twin scroll GT3076R, dual MV-S wastegates dumped to atmosphere, TR1035 FMIC, too many parts to list...
2009 MS3 GT - Built engine, JBR intake/TIP and short shifter, all engine mounts, Autotech HPFP internals, ETS TMIC, Custom AP tune, Pauter rods, CP pistons, and 6-puck ACT clutch
-GTX2867R Coming Soon
JMEngineer is offline   Reply With Quote
The Following 8 Users Say Thank You to JMEngineer For This Useful Post:
802MS3 (07-05-2015), Code Monkey (07-05-2015), Easter Bunny (01-06-2016), fivefingerdeathpunch (01-06-2016), Mauro_Penguin (07-05-2015), theschrum (07-05-2015), torquemaniac (01-28-2016), WetzMS3 (01-06-2016)
 Old 07-05-2015, 09:41 AM   #20
cam1391's Avatar
Wow that is an incredible difference from single scroll.
 Old 07-05-2015, 12:55 PM   #21
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
I thought wrapping a manifold that has ceramic coat is a no-no?
 Old 07-05-2015, 03:53 PM   #22
The twin scroll already improves spool characteristics by reducing cylinder interference so you can run a larger A/R from that perspective and achieve similar spool.
However a twin scroll housing with the same A/R as a single scroll will be more restrictive. The increased surface area of having a divided housing means more friction for the exhaust gases. This is another reason to run a bigger A/R on a twin scroll versus a single.
802MS3 (07-05-2015), Code Monkey (07-05-2015), Mauro_Penguin (07-24-2015), RE-ACTIONENGSPEED3 (07-23-2015), theschrum (07-05-2015), WetzMS3 (01-06-2016)
 Old 07-23-2015, 10:52 AM   #23
RE-ACTIONENGSPEED3's Avatar
Posts: 401   (View Stats)
so any updates?
2008 speed3
True red.
Pte 6466 & AWD Mode on !!!!
 Old 07-23-2015, 11:57 AM   #24
I've been crazy busy lately. I got it in the car on Monday night. There is a clearance issue with one wastegate. I will need to make a short angled extension to locate it where there is clearance. I'm travelling right now so I can't post pics.
Steve
Lead Tuner
802MS3 (07-23-2015), Mauro_Penguin (07-24-2015), RE-ACTIONENGSPEED3 (07-24-2015)
 Old 07-24-2015, 05:21 AM   #25
When you have time share some photos , because i`m really interested in the top mount setup with t4 divided option .........
2008 speed3
True red.
The Following User Says Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
 Old 07-24-2015, 05:39 AM   #26
Jtaylor's Avatar
Posts: 656   (View Stats)
Shouldn't you be running a 10 second 1/4 mile right now?
08 MazdaSpeed3
The Following User Says Thank You to Jtaylor For This Useful Post:
ItsNox (07-24-2015)
 Old 07-24-2015, 05:45 AM   #27
I should, but the next race in my country is very unknown (due to my country`s economical situation)about when it will take place...I estimate late September....
2008 speed3
True red.
The Following 6 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
Easter Bunny (01-06-2016), ItsNox (07-24-2015), Jtaylor (07-24-2015), Mauro_Penguin (07-24-2015), Micha (08-03-2015), WetzMS3 (01-27-2016)
 Old 07-24-2015, 07:49 PM   #28
theschrum's Avatar
I'm guessing you ran into this issue.
08 Speed 3|SOLD
The Following User Says Thank You to theschrum For This Useful Post:
 Old 07-24-2015, 08:34 PM   #29
No. It's on a different angle than that. The tial mvs I have hits the protruding firewall on my MS6. It clears the ac line.
Steve
Lead Tuner
 Old 07-27-2015, 09:10 PM   #30
Here is my setup. Close, but not quite clear.
Steve
Lead Tuner
The Following 4 Users Say Thank You to Steve@VersaTune For This Useful Post:
Code Monkey (07-27-2015), Easter Bunny (01-06-2016), Mauro_Penguin (07-29-2015), Micha (08-03-2015)
 Old 01-06-2016, 12:20 PM   #31
At the fab shop now. Should be on the road next week.
Steve
Lead Tuner
Mauro_Penguin (01-07-2016), Vansquish (01-06-2016), WetzMS3 (01-06-2016)
 Old 01-06-2016, 12:35 PM   #32
MSP611's Avatar
Im excited to see wat this does... I may have to put a twin scroll housing on my AFI Mani and see how this turbo handles it
Sent from my Nexus 7 using Tapatalk
In progress:
 Old 01-06-2016, 12:46 PM   #33
I ran the engine for 10 min with just a short elbow on the turbo to check for oil/water leaks. With the ceramic coating + turbo blanket, I was able to put my hand on the blanket. It was only a little warm. It's safe to say that the exhaust energy is being retained in the exhaust stream. I'm very anxious to see what the spool profile looks like.
Steve
Lead Tuner
ALPINEST4RS (02-05-2016), Easter Bunny (01-06-2016), Mauro_Penguin (01-07-2016), RE-ACTIONENGSPEED3 (01-06-2016)
 Old 01-06-2016, 12:49 PM   #34
twin scroll rocks.......
I`m really curious to se how this turbo setup will spools and handles power at high revs.
2008 speed3
True red.
 Old 01-06-2016, 12:54 PM   #35
MSP611's Avatar
Hmm guess we'll see if this double heat protection is a go or not.. Will tell me i need to buy a blanket or not cuz I was slightly wondering the same thing lol.
In progress:
 Old 01-10-2016, 09:28 AM   #36
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
I'm really curious to see how the spool is on this. One of the last things I'm still deciding for my turbo is what A/R I want. I'll be on an S256 (similar size to the gt3076) but on a T3 housing and I can't decide between a .75 and 1.0.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 01-14-2016, 03:24 PM   #37
Posts: 2,237   (View Stats)
if the spool isn't good but you already have the twinscroll can you try soemething similar to this?
Maybe juste a trap made in between with a kind of wastegate pressurised actuator to activate the second part when the initial boost is reached ?
Is Variable Twin Scroll Turbocharging the Answer to Future Turbos?
 Old 01-14-2016, 03:33 PM   #38
PurplFox's Avatar
Posts: 352   (View Stats)
PurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the world
Thats a cool idea. would you control the scrolls with a manual set up
Cobb AP
JBR Tru-3.0
CNT Catted DP "Gutted"
CNT Catback
JBR 88 RMM DM PMM and TMM
3 port, Turbosmart dual port
FReaktune E33
PurplFox is offline   Reply With Quote
 Old 01-14-2016, 05:02 PM   #39
just a pressure actuator could probably works fine? a used 8psi WG for exemple.
the second chamber would open when the intake reach 8 psi. the only problem could be to direct the flow of the blocked side to the other scroll
 Old 01-26-2016, 11:03 PM   #40
JMEngineer's Avatar
Groans: 32
Photo evidence... 30psi at about 3100rpm in 4th
The Following User Says Thank You to JMEngineer For This Useful Post:
Mazdazilla6 (01-26-2016)
Oil prices headed up or down? Experts divided Haltech Automotive News 0 05-11-2015 08:50 AM
Stage 2 Topmount logs Speeed3 MazdaSpeed 3/6 - ECU Computer Tuning 59 11-10-2011 12:05 PM
Page generated in 0.60997 seconds with 34 queries
