  • 1 Post By zenit
  • 1 Post By Turbojocky13
 Old 05-03-2017, 08:34 PM   #1
Turbojocky13's Avatar
Posts: 96   (View Stats)
Turbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant future
Groaned at 32 Times in 13 Posts
Default High FLOW/Low Boost
Hey everybody! had a quick question. just finished my build (for info on it check it out here)
The build so far 700+
But I was wondering who else is getting 400+ Grams per sec on their Big turbo cars?
started tuning today for the millionth time PurpleDrank (the best) and saw I was making over 400 grams a sec on 21.9 psi (base Map) anyone else making this much and how much power are you making? I understand it's not a direct correlation, but curious. plugged the data into virtual dyno
which says I'm making...
With VVT 482hp
without VVT 447hp
Not sure if I can believe that in full until I put it on a real dyno. all the data I entered is indeed correct.
-22.97 circumference wheels
-90 degree outside air temp
-2800 lbs (100% gutted, i mean literally everything down to the steering lock) probably weighs more
-4th gear pull
- Forged eagle rods - Wiseco pistons - AutoTech CDFP - 4in TIH - 4in Mrp Maf housing - Custom Fiberglass RamAir - Accessport purpledrank tune - Stiffy Torque Damper - S366 Borgwarner Turbo -SureMotorsports Balance shaft delete - Air to Water intercooler - Arp headstuds - Spark plugs itv22 -RaceRoots T4 turbo manifold - 3in downpipe dump - Egr delete - 3 bar map sensor (Bosch) - Focus ST Direct Port Meth Intake Manifold- No BOV - Tial 38mm wastegate -GrimSpeed 3 port boost controller - Torque solutions rear engine mount - Torque solutions short shift plate - Torque solutions shifter counter weight - DEI heat shielding - 100% Gutted - 245/40/18 street radials- Streetunit Solid Motor Mounts- 3in Intercooler piping- etc etc...
Turbojocky13 is offline   Reply With Quote
The Following 2 Users Say Thank You to Turbojocky13 For This Useful Post:
Code Monkey (05-03-2017), KiwiFlavor (05-04-2017)
 Old 05-04-2017, 05:27 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
I hit 475+g/s at 25psi, but it's been a long while since my car has been on the road. IIRC VD also had me around 480hp. Never made it to a real dyno.
Turbojocky13 (05-05-2017)
 Old 05-04-2017, 07:09 PM   #3
torquemaniac's Avatar
Posts: 733   (View Stats)
I got 395g/s at 21.6psi on my 91 octane tune (0-60 test log)
Maxed my MAF at 29psi when the weather was cool last week while troubleshooting a faulty boost controller...(I didnt log g/s since my MAF curve is scaled to compensate for the meth injection, but my pre-scaled MAF curve shows 507g/s at 5V)
2011 CX-7 AWD 2.3 turbo
The Following User Says Thank You to torquemaniac For This Useful Post:
 Old 05-04-2017, 09:29 PM   #4
zenit's Avatar
Posts: 1,364   (View Stats)
Groans: 57
...over 400 grams a sec on 21.9 psi
Sound familiar @xfeejayx;?
xfeejayx likes this.
-feejay
-wetzel
xfeejayx (05-05-2017)
 Old 05-05-2017, 07:22 AM   #5
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
I don't have the logs readily available right now, but it was something like 45 lbs/min (340 g/s) at 18 psi? That mani really does flow well, and engine speed going up will move you almost straight down on a compressor map (can't see your rpm on dyno).
But with that big custom intake on a base map, and added meth... who knows what everything is actually scaled to. You may never know what your real flow is with meth nozzles in the picture.
-Wetz
QFT
 Old 05-05-2017, 09:05 AM   #6
Thanks for the input guys! Was doing some research and like I thought there is no direct correlation between the two only guesstimates, there are a couple of formulas you can use but it's mostly for deciding on what size turbo you should be looking for depending on HP wanted.
One formula is ( G/s / .82) = desired hp. So (400 G/s / .82) = 487 hp and that's ball park but some say that's BHP and Not WHP
The other formula is (Lb/mn x 10) and that's way high at like 520hp
There's arguments on that one as well with some saying the following
-supercharger (Lb/mn * 1.1)(- % of driveline loss) = HP
-Turbo (Lb/mn * 1.25)(-% of driveline loss) = HP
The last one making the most since
52 Lb/mn * 1.25 -8% = 460
10% = 450 ( said 8% because Solid motor mounts and Raxles)
All very interesting stuff! Had no idea about any of this before looking into it. Can't wait to finish the tuning, put it on a dyno and see how close any of these formulas might be.
Thoughts??
 Old 05-05-2017, 09:09 AM   #7
Yes I totally agree, not to mention that Giant Ram Air Headlight, the Maf is calibrated but who knows how accurate those numbers really are.
zenit likes this.
BNR S3, high boost/high WGDC and low air flow mituc MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 04-26-2017 05:14 PM
K&N high flow air filter Jordanms3 2010 MS3 - Turbo Induction 10 04-22-2010 08:33 AM
Need High Flow Cat? rtaylor60
Cobb Access Port/Maps
6 07-22-2009 10:23 PM
Buying a high flow cat ?? SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 15 02-18-2009 02:46 PM
Page generated in 0.29358 seconds with 25 queries
