Like Tree6Likes
 Old 01-18-2011, 07:27 AM   #41
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
i don't know if the long ass timing chain and vvt can hang @ that rpm either ? their has been a few with timing chain failures with different cams / springs / broke the vvt and stretched the chain
and i don't think he even wound it up to 7000
did you do a vvt delete?
good luck man
at 104000 2 bent rods
tuned by nishan
 Old 01-18-2011, 10:55 AM   #42
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
I think the chain failures have more to do with the fuel pump being on the other side of the block and driven by the cam. That is a lot of torque to put on something so small.
 Old 01-19-2011, 10:05 AM   #43
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
In for results. I want to play with higher rpms too.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
Docnox (05-27-2011), RedBliss (04-22-2011), xcoldricex (01-24-2011)
 Old 01-19-2011, 10:50 AM   #44
Brian MP5T's Avatar
Posts: 1,101   (View Stats)
Brian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the worldBrian MP5T is the leader of the world
Subs
(This thread will either be Epic Win or Epic Fail)
Either way, I like the project and really like how high you have set the bar.
Brian MP5T is offline   Reply With Quote
 Old 01-19-2011, 11:12 AM   #45
Captain
I guess the real risk comes in on whether or not you'll have interference the instant a valve floats....
When a valve floats... the power will fall off pretty damn fast, and it'll be easily noticeable on the dyno.
So if / when i plan on playing with higher revs... i'm going to do it in like 100 rpm increments on a dyno.... and hope i simply just float a valve without doing any damage.
Personally, i think 7500 is doable without any modification... but i have absolutely no factual info to back that claim up. It's 99% hopeful thinking.
www.permtuning.com
 Old 01-22-2011, 05:08 AM   #46
Wilksy's Avatar
Posts: 237   (View Stats)
Wilksy is the leader of the worldWilksy is the leader of the worldWilksy is the leader of the worldWilksy is the leader of the worldWilksy is the leader of the worldWilksy is the leader of the worldWilksy is the leader of the worldWilksy is the leader of the worldWilksy is the leader of the worldWilksy is the leader of the worldWilksy is the leader of the world
the tuner is going to go as high in the rpm as it will allow without breaking something. 8000rpm is too much for the work we are doing. we will take it to the limit before boom, will post up results, see what we get too .. this is a standard rebuild with bottom end balancing, valve springs.
Fuck the cunts, I make dreams come true...
Wilksy is offline   Reply With Quote
The Following 2 Users Say Thank You to Wilksy For This Useful Post:
FreeFlyFreak (01-22-2011), xcoldricex (01-24-2011)
 Old 01-22-2011, 06:14 PM   #47
Wilksy's Avatar
My normal standard mazda 3 neo 2ltr cuts off at 7200rpm , so with valve springs and balancing this will be safe maybe 7200-7500rpm?
 Old 01-22-2011, 08:52 PM   #48
rigor's Avatar
Groans: 40
i dont think valve float will be a problem will the injectors be able to keep up? open and close 8.333 times per sec is that right?
tuned by nishan
The Following User Says Thank You to rigor For This Useful Post:
FreeFlyFreak (01-23-2011)
 Old 01-23-2011, 05:41 PM   #49
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
curiosity sub
The Following User Says NO Thank You to Speed3eak For This Un-useful Post:
mituc (03-17-2011)
 Old 01-23-2011, 10:46 PM   #50
Miembro
nighthawk358's Avatar
Posts: 725   (View Stats)
nighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the world
Groans: 27
when are you planning on testing these unknown waters?
2008.5 MS3 Metro Gray...slow
nighthawk358 is offline   Reply With Quote
 Old 01-24-2011, 02:35 AM   #51
speedtoz's Avatar
Posts: 453   (View Stats)
speedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the world
in for win or fail!
^^^My fail boats^^^
2006 mazdaspeed 6: fujita CAI, PG TIP, Turbosmart dual BOV, ITV22, Corksprt TBE, Cobb AP, SURE front/rear diff mounts(FTW), whiteline RSB
1978 280z(s30): currently needs some love....and going turbo o.0
1990 300zx: 850cc injectors, 300degree fuel rail, aeromotive FPR, garrett gt 28's twin turbo upgrade(@19psi), stillen IC's, CZP's 3in dp and mid pipe, Selin dual intakes, GTR R32 brakes, Nismo clutch, HKS hi-power exhaust, megan coil-overs, SPL full titanium suspension parts, z1 boost tubes, 2 AEM AFR's, AEM boost guage
RWHP:???? RWTRQ: 475@4500 rpm. needs new clutch(blown).
2008 350z HR: Greddy dual Ti-C, Carbonetics LSD, Nismo diff, GTM TP's, Stillen CAI's
(waiting on full metal CSC and carbonetic clutch and light wieght flywheel, then it's TT time!) currently on hold due to needing new clutch and flywheel/metal csc and master. wanting skyline manifold.
speedtoz is offline   Reply With Quote
 Old 01-24-2011, 05:00 AM   #52
Wilksy's Avatar
cars at tuners now. hope to have it back 30th jan
The Following 4 Users Say Thank You to Wilksy For This Useful Post:
djuosnteisn (01-24-2011), Docnox (05-27-2011), wette460 (03-29-2011), xcoldricex (01-24-2011)
 Old 01-24-2011, 07:05 AM   #53
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
so the build is done ?? any pictures ?
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 01-24-2011, 10:13 AM   #54
Captain
Originally Posted by jracer View Post
so the build is done ?? ant pictures ?
Here's a few:
www.permtuning.com
The Following 21 Users Say Thank You to djuosnteisn For This Useful Post:
AndyMS3 (06-10-2011), bombdotcom (02-01-2011), Chriscote (05-24-2011), DaleNixon (03-18-2011), Docnox (01-24-2011), doubleflusher (03-17-2011), Enki (01-24-2011), FreeFlyFreak (01-24-2011), I Love Brownies (01-24-2011), jracer (01-24-2011), jwilkins88 (03-18-2011), madvillain (01-24-2011), mdl3v8 (05-03-2011), MS3-a(sore)ASS-rex (03-18-2011), psychophyr (01-24-2011), rigor (02-01-2011), Scynfewl (03-27-2011), Snotrocket (05-15-2011), Speed3eak (01-24-2011), turd burglar (01-24-2011), WRX_Fan_0717 (04-22-2011)
 Old 01-24-2011, 06:32 PM   #55
jracer's Avatar
Groans: 89
Hahahahaha.. Thanks DJ ..
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
The Following User Says Thank You to jracer For This Useful Post:
djuosnteisn (01-25-2011)
 Old 02-01-2011, 02:41 AM   #56
Wilksy's Avatar
Car not ready yet, had trouble getting turbo delivered but will be taking it there tomorrow myself, parts from the machinists are coming soon has been a delay there as well. Like all mods not everything goes 100% to plan
djuosnteisn (02-01-2011), rigor (02-01-2011)
 Old 02-05-2011, 05:49 PM   #57
Wilksy's Avatar
Turbo is at the workshop, parts form the machinist still delayed .
The Following 3 Users Say Thank You to Wilksy For This Useful Post:
djuosnteisn (02-06-2011), Docnox (05-27-2011), rigor (02-05-2011)
 Old 02-06-2011, 12:24 AM   #58
Captain
... parts form the machinist still delayed .
I've been saying that for a year now lol.
www.permtuning.com
 Old 02-06-2011, 12:35 AM   #59
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
VVT delete + forged internals and you can probably do 8000-8200rpm. If you have a turbo that spools around 4000rpm and is breathless up until, say, at least 7500 - WIN.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 03-08-2011, 01:12 AM   #60
Wilksy's Avatar
Had a set back with the bore being to worn for the stardard pistons. Oversize pistons will be here this week
djuosnteisn (03-08-2011), Docnox (05-27-2011), rigor (03-08-2011)
 Old 03-15-2011, 07:03 AM   #61
Wilksy's Avatar
Update, engine will be back tomorrow, in the hands of the perfectionist Aaron at MPSG. Aaron will start putting it together.
djuosnteisn (03-15-2011), jracer (03-15-2011), wette460 (03-29-2011)
 Old 03-15-2011, 09:52 AM   #62
Captain
I just helped a local (jmhinkle) with his bt build, and we set his rev limit to 6900 rpm. He's been routinely bouncing off it several times since then. We'll probably keep walking it up to at least 7200 when we dyno tune. Stock block / stock valve train.
Can't wait for some updates, Wilksy.
www.permtuning.com
Docnox (05-27-2011), IshiKage (03-18-2011), Speed3eak (03-28-2011), turd burglar (03-15-2011)
 Old 03-15-2011, 10:05 AM   #63
jax ms3gt's Avatar
Posts: 1,151   (View Stats)
K sub'd now awaiting more info
PERM TUNED
The Following User Says NO Thank You to jax ms3gt For This Un-useful Post:
mituc (03-17-2011)
 Old 03-17-2011, 02:17 AM   #64
Wilksy's Avatar
Engine rebuilding will start tomorrow, should be all done by next weekend. The 1000k run in period will start after that ...
djuosnteisn (03-17-2011), Docnox (05-27-2011), MS3-a(sore)ASS-rex (03-18-2011)
 Old 03-17-2011, 04:15 AM   #65
KRNAGE's Avatar
Posts: 120   (View Stats)
KRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond repute
subn for interest here too
edit: plus you should drive down to VIC for the bedding in process
06 Black MPS3 Sport Pack - Australia edition
Cobb AP (RichTune e85 / 98 maps) - Autotech HPFP Internals, JBR WP, CorkSport DP, Catback, Forge v1 BPV, Denso ITV22, PG FMIC Pipes JDM Core - TWM SS, PG Shift Weight, JBR Heavy Knob - JBR 88 Trilogy - JBR Rear Sway bar, Yellowspeed Coilovers, Centric Slotted/Drilled Rotors, Hawk HP+ pads, RX8 gen1 wheels - HTP Battery Tray - JBR EGR delete, JBR TB TIG - Spin-on oil convert - Polarised HU Screen
EXE-Crew
KRNAGE is offline   Reply With Quote
The Following User Says NO Thank You to KRNAGE For This Un-useful Post:
mituc (03-17-2011)
 Old 03-17-2011, 06:18 AM   #66
mituc's Avatar
Groans: 111
For all those nutheads that are replying to a thread "subbing for .ick", please subscribe to the damn thread from the Thread Tools section that you can find at the top of EACH thread.
I think that's mentioned in the forum rules too!
The Following 3 Users Say Thank You to mituc For This Useful Post:
DaleNixon (03-18-2011), Docnox (05-27-2011), thehead (03-17-2011)
 Old 03-18-2011, 03:52 AM   #67
Wilksy's Avatar
LOL@KRNAGE, will be down that way May 21st for the cruz south
 Old 03-18-2011, 05:25 AM   #68
KRNAGE's Avatar
i best sign up to that then so i can see this beast............it will be finished by then right
EXE-Crew
 Old 03-18-2011, 05:43 AM   #69
kmac's Avatar
Posts: 1,792   (View Stats)
I'm also going to be high reving as well with my big turbo. Good to se u are doing it , It's the only way to run a real time in the car once u go big turbo, because even if u make the power on a dyno u move the power band up so high in the rpm that your power band isn't long enough to run a real time in the 1320. 4200 to 6700 isn't much of a power band considering if power starts to come in at 42 your not make good power till almost 5k . I think once people start reving these things they will be a force not to be messed with.
The Following 2 Users Say Thank You to kmac For This Useful Post:
jracer (03-18-2011), kyzomo (03-18-2011)
 Old 03-18-2011, 01:32 PM   #70
Captain
Baby steps too... big turbos like fuel.... and DI does not lend itself lightly to high rpm's.
Increased fuel pressure will be key... and hopefully one day we'll have larger injectors... but til then... baby steps
www.permtuning.com
Docnox (05-27-2011), i8urgti (04-15-2011), kmac (03-18-2011), madvillain (03-19-2011), MS3-a(sore)ASS-rex (03-18-2011)
 Old 03-18-2011, 07:34 PM   #71
kmac's Avatar
I'm looking into the injectors with someone as we speak. The fuel pressure increase should be fine for now with meth or pick up injectors our biggest limitations as of now is not fuel.
The Following User Says Thank You to kmac For This Useful Post:
djuosnteisn (03-19-2011)
 Old 03-18-2011, 07:46 PM   #72
bmylez's Avatar
Posts: 3,197   (View Stats)
Man, you guys are crazy, wanting stuff that flows this much. Cageyvet is already at about 500whp with stock in-tank pump and all that. So greedy, heh. Gimme 380 and I will be happy for a long time.
2007 CTS-V - Trying to sell
The Following 2 Users Say Thank You to bmylez For This Useful Post:
 Old 03-18-2011, 07:51 PM   #73
kmac's Avatar
Lol , I agree I luv how u are content with 380 considering in a speed3 what can u do with all that on the street anyhow .
 Old 03-18-2011, 08:11 PM   #74
bmylez's Avatar
Well I think I'm barely at 300 at the moment. I'm already becoming discontented because 2nd gear doesn't always break loose that much. 380 would hit the spot. 3rd would spin most of the time. Over 500 is cool, but I'm realizing more and more how little you can use that power, haha.
 Old 03-18-2011, 09:01 PM   #75
jwilkins88's Avatar
Posts: 3,675   (View Stats)
Groans: 126
I'm also interested in this because I think that I'm going to be upping my rev limit.
After I put my 35r on, I'll start raising it, me thinks. No point in doing it now since my turbo is maxed out
The Following User Says Thank You to jwilkins88 For This Useful Post:
 Old 03-28-2011, 07:31 PM   #76
Wilksy's Avatar
Waiting on a call this week to let me know its running .. than its a 1000k run in and on the dyno ... not sure what rpm the first run will be? i feel they may keep it at 7000rpm. than get me to take it back after a few more k's are racked up for a lift in the rpm ( will know more later )
4G63 (03-28-2011), djuosnteisn (03-29-2011), Speed3eak (03-28-2011)
 Old 03-28-2011, 07:43 PM   #77
Speed3eak's Avatar
Groans: 82
Don't you have the .55 a/r atp hotside? I dunno why, but I thought I read that somewhere.
So... Wouldn't a t3 hotside help raise the limits? Or you just wanna go 35R because you're a G unit warrior and you want 550 on the stock internals?
The Following User Says Thank You to Speed3eak For This Useful Post:
jwilkins88 (03-28-2011)
 Old 03-28-2011, 07:45 PM   #78
4G63's Avatar
Posts: 1,479   (View Stats)
Groans: 123
Awesome man very good stuff. Nice to someone doing this!
2003 Evo VIII
 Old 03-28-2011, 08:37 PM   #79
jwilkins88's Avatar
Groans: 126
Yes. I want to see where the stock block will pop, but I don't think I'll be able to do it on my turbo
 Old 03-28-2011, 08:44 PM   #80
bmylez's Avatar
Well, I'm sure you could pop the block if you really wanted to...but I get what you're saying. I actually forgot that you were on ATP housing. That's very impressive. After weighing my options, I'm very tempted to get an ATP 3076, slap it on the stock manifold and see where 25psi gets me. I'm not that power hungry, but the k04 is just, bleh, up top.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/high-rpm-big-turbo-69185/
Race Cams!!! This thread Pingback 06-30-2012 07:34 PM
High RPM, Big Turbos - Page 2 This thread Refback 02-20-2012 05:43 PM
High RPM, Big Turbos Post #1 Pingback 01-10-2011 04:15 AM
Geneva 2010: Citroen DS High Rider rides in on its high horse Haltech Automotive News 0 03-03-2010 07:30 AM
High Speed, High Fashion: Izod secures deal as IndyCar title sponsor Haltech Automotive News 0 11-08-2009 03:40 PM
High strength studs for turbo (manifold to head and manifold to turbo) bnoon MazdaSpeed 3/6 - Turbo Induction 4 03-11-2009 10:26 PM
Rumormill: Turbo & High-Tech Performance Magazine gets the axe Haltech Automotive News 0 10-31-2008 06:30 AM
Page generated in 0.56793 seconds with 36 queries
